级别:信息 进程:dde-session-dae 时间:2021-01-30 05:20:11 信息:app_entry.go:239: attach window id: 62914570, wmClass: "dde-control-center" "dde-control-center", wmState: [], wmWindowType: [386], wmAllowedActions: [520 521 497 522 524 525 526 527 498], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:27200 级别:信息 进程:startdde 时间:2021-01-30 05:20:11 信息:startmanager.go:653: send openapp message, app info /usr/share/applications/dde-control-center.desktop/控制中心/dde-control-center 主机名:mub-PC 进程号:27092 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:20:09 信息:dock_manager_entries.go:149: removeAppEntry id: e7T60147bf5 主机名:mub-PC 进程号:27200 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:20:05 信息:[session uid=1000 pid=27104] Successfully activated service 'com.deepin.daemon.SoundEffect' 主机名:mub-PC 进程号:27104 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:20:05 信息:manager_connection.go:241: remove connection &network.connection{nmConn:(*networkmanager.ConnectionSettings)(0xc00092f6b0), connType:"wired", Path:"/org/freedesktop/NetworkManager/Settings/1", Uuid:"94da1a2b-8f54-35a2-a840-abf82eb7ed81", Id:"Wired connection 1", HwAddress:"92:BB:47:3B:1B:C5", ClonedAddress:"", Ssid:""} 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:20:05 信息:manager_connection.go:69: remove connection /org/freedesktop/NetworkManager/Settings/1 主机名:mub-PC 进程号:27200 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:20:05 信息:[session uid=1000 pid=27104] Activating service name='com.deepin.daemon.SoundEffect' requested by ':1.38' (uid=1000 pid=27497 comm="/usr/lib/deepin-daemon/dde-osd ") 主机名:mub-PC 进程号:27104 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:20:05 信息:state_handler.go:272: device disconnected, type wired, 110 => 30, reason[60] 激活连接操作正在等待执行 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:20:05 信息:manager_connection.go:62: add connection /org/freedesktop/NetworkManager/Settings/2 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:20:05 信息:manager_connection.go:62: add connection /org/freedesktop/NetworkManager/Settings/1 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:20:05 信息:nm_setting_wired.go:30: new wired connection, id=enp3s0f3u2, uuid=f7cb89f4-067f-2cab-4c9a-18a0b5786edc, devPath=/org/freedesktop/NetworkManager/Devices/3 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:20:05 信息:manager_device.go:200: wired plugin /org/freedesktop/NetworkManager/Devices/3 主机名:mub-PC 进程号:27200 级别:信息 进程:startdde 时间:2021-01-30 05:20:03 信息:checker.go:293: process memory: /home/mub/.config/autostart/dde-first-run.desktop 2@dde/uiapps/11 53592 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:20:03 信息:checker.go:293: process memory: /etc/xdg/autostart/at-spi-dbus-bus.desktop 2@dde/uiapps/8 0 open /sys/fs/cgroup/memory/2@dde/uiapps/8/cgroup.procs: no such file or directory 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:20:03 信息:checker.go:293: process memory: /etc/xdg/autostart/xdg-user-dirs.desktop 2@dde/uiapps/1 0 open /sys/fs/cgroup/memory/2@dde/uiapps/1/cgroup.procs: no such file or directory 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:20:03 信息:checker.go:293: process memory: /etc/xdg/autostart/geoclue-demo-agent.desktop 2@dde/uiapps/7 444 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:20:03 信息:checker.go:293: process memory: /etc/xdg/autostart/pulseaudio.desktop 2@dde/uiapps/9 0 open /sys/fs/cgroup/memory/2@dde/uiapps/9/cgroup.procs: no such file or directory 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:20:03 信息:checker.go:293: process memory: /etc/xdg/autostart/dde-preload.desktop 2@dde/uiapps/10 2308 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:20:03 信息:checker.go:293: process memory: /etc/xdg/autostart/com.deepin.deepinid.desktop 2@dde/uiapps/4 5260 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:20:03 信息:checker.go:293: process memory: /etc/xdg/autostart/dde-printer-watch.desktop 2@dde/uiapps/2 4856 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:20:03 信息:checker.go:293: process memory: /etc/xdg/autostart/deepin-ab-recovery.desktop 2@dde/uiapps/3 0 open /sys/fs/cgroup/memory/2@dde/uiapps/3/cgroup.procs: no such file or directory 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:20:03 信息:checker.go:293: process memory: /etc/xdg/autostart/dde-clipboard.desktop 2@dde/uiapps/5 7444 主机名:mub-PC 进程号:27092 级别:信息 进程:systemd 时间:2021-01-30 05:19:56 信息:var-lib-os\x2dprober-mount.mount: Succeeded. 主机名:mub-PC 进程号:27049 级别:信息 进程:systemd 时间:2021-01-30 05:19:56 信息:var-lib-os\x2dprober-mount.mount: Succeeded. 主机名:mub-PC 进程号:27049 级别:信息 进程:systemd 时间:2021-01-30 05:19:56 信息:var-lib-os\x2dprober-mount.mount: Succeeded. 主机名:mub-PC 进程号:27049 级别:信息 进程:systemd 时间:2021-01-30 05:19:55 信息:run-user-117.mount: Succeeded. 主机名:mub-PC 进程号:27049 级别:信息 进程:systemd 时间:2021-01-30 05:19:55 信息:run-user-117-gvfs.mount: Succeeded. 主机名:mub-PC 进程号:27049 级别:信息 进程:systemd 时间:2021-01-30 05:19:51 信息:Reloading. 主机名:mub-PC 进程号:27049 级别:信息 进程:systemd 时间:2021-01-30 05:19:51 信息:Reloading. 主机名:mub-PC 进程号:27049 级别:信息 进程:systemd 时间:2021-01-30 05:19:50 信息:var-lib-os\x2dprober-mount.mount: Succeeded. 主机名:mub-PC 进程号:27049 级别:信息 进程:systemd 时间:2021-01-30 05:19:50 信息:var-lib-os\x2dprober-mount.mount: Succeeded. 主机名:mub-PC 进程号:27049 级别:信息 进程:systemd 时间:2021-01-30 05:19:50 信息:var-lib-os\x2dprober-mount.mount: Succeeded. 主机名:mub-PC 进程号:27049 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:49 信息:bluetooth.go:776: [DEBUG] Auto connect adapter: /org/bluez/hci0 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:49 信息:app_entry.go:239: attach window id: 62914588, wmClass: "dde-introduction" "dde-introduction", wmState: [], wmWindowType: [386], wmAllowedActions: [520 527], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:27200 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:48 信息:[session uid=1000 pid=27104] Successfully activated service 'com.deepin.Manual.Search' 主机名:mub-PC 进程号:27104 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:48 信息:[session uid=1000 pid=27104] Activating service name='com.deepin.Manual.Search' requested by ':1.58' (uid=1000 pid=27714 comm="/usr/bin/dde-introduction ") 主机名:mub-PC 进程号:27104 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:bluetooth.go:776: [DEBUG] Auto connect adapter: /org/bluez/hci0 主机名:mub-PC 进程号:27200 级别:信息 进程:systemd 时间:2021-01-30 05:19:48 信息:Started Bluetooth OBEX service. 主机名:mub-PC 进程号:27049 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:48 信息:[session uid=1000 pid=27104] Successfully activated service 'org.bluez.obex' 主机名:mub-PC 进程号:27104 级别:信息 进程:obexd 时间:2021-01-30 05:19:48 信息:OBEX daemon 5.50 主机名:mub-PC 进程号:27754 级别:信息 进程:systemd 时间:2021-01-30 05:19:48 信息:Starting Bluetooth OBEX service... 主机名:mub-PC 进程号:27049 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:48 信息:[session uid=1000 pid=27104] Activating via systemd: service name='org.bluez.obex' unit='obex.service' requested by ':1.11' (uid=1000 pid=27200 comm="/usr/lib/deepin-daemon/dde-session-daemon ") 主机名:mub-PC 进程号:27104 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:adapter.go:135: AdapterAdded adapter mub-PC [4C:EB:BD:BA:6E:56] 主机名:mub-PC 进程号:27200 级别:信息 进程:startdde 时间:2021-01-30 05:19:48 信息:startmanager.go:653: send closeapp message, app info /home/mub/.config/autostart/dde-first-run.desktop/深度首次运行//home/mub/.config/autostart/dde-first-run 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:19:48 信息:startmanager.go:653: send closeapp message, app info /etc/xdg/autostart/deepin-ab-recovery.desktop/AbRecovery//etc/xdg/autostart/deepin-ab-recovery 主机名:mub-PC 进程号:27092 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:module.go:89: start audio module cost 629.062367ms 主机名:mub-PC 进程号:27200 级别:信息 进程:startdde 时间:2021-01-30 05:19:48 信息:startmanager.go:653: send closeapp message, app info /etc/xdg/autostart/pulseaudio.desktop/PulseAudio 声音系统//etc/xdg/autostart/pulseaudio 主机名:mub-PC 进程号:27092 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:audio.go:361: first run, Will remove old audio config 主机名:mub-PC 进程号:27200 级别:信息 进程:systemd 时间:2021-01-30 05:19:48 信息:Started Sound Service. 主机名:mub-PC 进程号:27049 级别:信息 进程:startdde 时间:2021-01-30 05:19:48 信息:startmanager.go:653: send closeapp message, app info /etc/xdg/autostart/at-spi-dbus-bus.desktop/AT-SPI D-Bus Bus//etc/xdg/autostart/at-spi-dbus-bus 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:19:48 信息:startmanager.go:653: send closeapp message, app info /etc/xdg/autostart/xdg-user-dirs.desktop/User folders update//etc/xdg/autostart/xdg-user-dirs 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:19:48 信息:startmanager.go:653: send openapp message, app info /home/mub/.config/autostart/dde-first-run.desktop/深度首次运行//home/mub/.config/autostart/dde-first-run 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:19:48 信息:startmanager.go:653: send openapp message, app info /etc/xdg/autostart/at-spi-dbus-bus.desktop/AT-SPI D-Bus Bus//etc/xdg/autostart/at-spi-dbus-bus 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:19:48 信息:startmanager.go:653: send openapp message, app info /etc/xdg/autostart/im-launch.desktop/im-launch//etc/xdg/autostart/im-launch 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:19:48 信息:startmanager.go:653: send openapp message, app info /etc/xdg/autostart/xdg-user-dirs.desktop/User folders update//etc/xdg/autostart/xdg-user-dirs 主机名:mub-PC 进程号:27092 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:manager.go:197: Init mime config file successfully 主机名:mub-PC 进程号:27200 级别:信息 进程:startdde 时间:2021-01-30 05:19:48 信息:startmanager.go:653: send openapp message, app info /etc/xdg/autostart/geoclue-demo-agent.desktop/Geoclue Demo agent//etc/xdg/autostart/geoclue-demo-agent 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:19:48 信息:startmanager.go:653: send openapp message, app info /etc/xdg/autostart/pulseaudio.desktop/PulseAudio 声音系统//etc/xdg/autostart/pulseaudio 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:19:48 信息:startmanager.go:653: send openapp message, app info /etc/xdg/autostart/dde-printer-watch.desktop/打印管理器助手//etc/xdg/autostart/dde-printer-watch 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:19:48 信息:startmanager.go:653: send openapp message, app info /etc/xdg/autostart/com.deepin.deepinid.desktop/com.deepin.deepinid//etc/xdg/autostart/com.deepin.deepinid 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:19:48 信息:startmanager.go:653: send openapp message, app info /etc/xdg/autostart/dde-preload.desktop/dde-preload//etc/xdg/autostart/dde-preload 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:19:48 信息:startmanager.go:653: send openapp message, app info /etc/xdg/autostart/dde-clipboard.desktop/dde-clipboard//etc/xdg/autostart/dde-clipboard 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:19:48 信息:startmanager.go:653: send openapp message, app info /etc/xdg/autostart/deepin-ab-recovery.desktop/AbRecovery//etc/xdg/autostart/deepin-ab-recovery 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:19:48 信息:main.go:314: iowait disabled 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:19:48 信息:session.go:950: send login message to ue module 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:19:48 信息:session_process.go:60: start dde-session-daemon part2 cost: 431.036597ms 主机名:mub-PC 进程号:27092 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:module.go:43: start calendar module cost 123.236883ms 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:157: enable module grub-gfx done, cost 62.080667ms 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:149: enable module grub-gfx 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:157: enable module lastore done, cost 3.801628ms 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:149: enable module lastore 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:157: enable module systeminfo done, cost 53.614145ms 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:info.go:156: d.info.CurrentSpeed : 2300 , d.info.CPUMaxMHz : 2300 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:149: enable module systeminfo 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:157: enable module miracast done, cost 1.650357ms 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:149: enable module miracast 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:157: enable module calendar done, cost 8.196µs 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:149: enable module calendar 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:157: enable module mime done, cost 1.906941ms 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:149: enable module mime 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:157: enable module screenedge done, cost 1.484025ms 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:config.go:63: load bluetooth config file: /home/mub/.config/deepin/bluetooth.json 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:149: enable module screenedge 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:157: enable module bluetooth done, cost 1.300238ms 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:149: enable module bluetooth 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:157: enable module timedate done, cost 1.138103ms 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:149: enable module timedate 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:157: enable module housekeeping done, cost 264.779µs 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:149: enable module housekeeping 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:157: enable module gesture done, cost 8.219518ms 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:149: enable module gesture 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:157: enable module inputdevices done, cost 81.079121ms 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:appearance.go:146: start appearance module cost 251.208773ms 主机名:mub-PC 进程号:27200 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:48 信息:[session uid=1000 pid=27104] Successfully activated service 'com.deepin.api.CursorHelper' 主机名:mub-PC 进程号:27104 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:manager.go:485: eliminate conflict shortcut: 2away keystroke: XF86Away 主机名:mub-PC 进程号:27200 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:48 信息:[session uid=1000 pid=27104] Activating service name='com.deepin.api.CursorHelper' requested by ':1.11' (uid=1000 pid=27200 comm="/usr/lib/deepin-daemon/dde-session-daemon ") 主机名:mub-PC 进程号:27104 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:149: enable module inputdevices 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:manager.go:485: eliminate conflict shortcut: 2audio-stop keystroke: XF86AudioStop 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:157: enable module keybinding done, cost 119.029431ms 主机名:mub-PC 进程号:27200 级别:信息 进程:startdde 时间:2021-01-30 05:19:48 信息:manager_ifc.go:274: success to reset ColorTemperature 主机名:mub-PC 进程号:27092 级别:信息 进程:systemd 时间:2021-01-30 05:19:48 信息:Started DTK widget application launch booster. 主机名:mub-PC 进程号:27049 级别:信息 进程:startdde 时间:2021-01-30 05:19:48 信息:manager_ifc.go:256: success to stop redshift.service 主机名:mub-PC 进程号:27092 级别:信息 进程:systemd 时间:2021-01-30 05:19:48 信息:Starting DTK widget application launch booster... 主机名:mub-PC 进程号:27049 级别:信息 进程:startdde 时间:2021-01-30 05:19:48 信息:manager_ifc.go:256: success to disable redshift.service 主机名:mub-PC 进程号:27092 级别:信息 进程:systemd 时间:2021-01-30 05:19:48 信息:Starting Sound Service... 主机名:mub-PC 进程号:27049 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:module.go:138: start network module cost 143.738147ms 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:submodule.go:58: submodule LidSwitchHandler start 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:screensaver.go:205: SetTimeout to 900 0 false 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:149: enable module keybinding 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:157: enable module clipboard done, cost 3.817198ms 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:submodule.go:58: submodule PowerSavePlan start 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:149: enable module clipboard 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:157: enable module service-trigger done, cost 3.637269ms 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:149: enable module service-trigger 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:157: enable module uadpagent done, cost 2.127416ms 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:149: enable module uadpagent 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:157: enable module power done, cost 52.404126ms 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:manager.go:208: LidIsPresent true 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:149: enable module power 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:157: enable module sessionwatcher done, cost 3.454695ms 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:manager_device.go:143: ignore virtual network interface which driver is unknown /org/freedesktop/NetworkManager/Devices/1 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:149: enable module sessionwatcher 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:157: enable module screensaver done, cost 21.3328ms 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:149: enable module screensaver 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:manager.go:169: initialize network 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:157: enable module appearance done, cost 2.294µs 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:149: enable module appearance 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:157: enable module audio done, cost 12.043µs 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:149: enable module audio 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:157: enable module network done, cost 1.645719ms 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:48 信息:loader.go:149: enable module network 主机名:mub-PC 进程号:27200 级别:信息 进程:systemd 时间:2021-01-30 05:19:48 信息:Reloading. 主机名:mub-PC 进程号:27049 级别:信息 进程:systemd 时间:2021-01-30 05:19:48 信息:Reloading. 主机名:mub-PC 进程号:27049 级别:信息 进程:startdde 时间:2021-01-30 05:19:48 信息:main.go:157: core components cost: 2.054986606s 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:19:48 信息:session_process.go:110: /usr/bin/dde-dock [-r] startup duration: 1.937794875s 主机名:mub-PC 进程号:27092 级别:信息 进程:systemd 时间:2021-01-30 05:19:47 信息:Started Virtual filesystem metadata service. 主机名:mub-PC 进程号:27049 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:47 信息:[session uid=1000 pid=27104] Successfully activated service 'org.gtk.vfs.Metadata' 主机名:mub-PC 进程号:27104 级别:信息 进程:systemd 时间:2021-01-30 05:19:47 信息:Starting Virtual filesystem metadata service... 主机名:mub-PC 进程号:27049 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:47 信息:[session uid=1000 pid=27104] Activating via systemd: service name='org.gtk.vfs.Metadata' unit='gvfs-metadata.service' requested by ':1.20' (uid=1000 pid=27202 comm="/usr/bin/dde-desktop ") 主机名:mub-PC 进程号:27104 级别:信息 进程:systemd 时间:2021-01-30 05:19:46 信息:Started BAMF Application Matcher Framework. 主机名:mub-PC 进程号:27049 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:46 信息:[session uid=1000 pid=27104] Successfully activated service 'org.ayatana.bamf' 主机名:mub-PC 进程号:27104 级别:信息 进程:systemd 时间:2021-01-30 05:19:46 信息:Started Virtual filesystem service - GNOME Online Accounts monitor. 主机名:mub-PC 进程号:27049 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:46 信息:[session uid=1000 pid=27104] Successfully activated service 'org.gtk.vfs.GoaVolumeMonitor' 主机名:mub-PC 进程号:27104 级别:信息 进程:systemd 时间:2021-01-30 05:19:46 信息:Starting Virtual filesystem service - GNOME Online Accounts monitor... 主机名:mub-PC 进程号:27049 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:46 信息:[session uid=1000 pid=27104] Activating via systemd: service name='org.gtk.vfs.GoaVolumeMonitor' unit='gvfs-goa-volume-monitor.service' requested by ':1.22' (uid=1000 pid=27241 comm="/usr/bin/dde-dock -r ") 主机名:mub-PC 进程号:27104 级别:信息 进程:systemd 时间:2021-01-30 05:19:46 信息:Started Virtual filesystem service - Media Transfer Protocol monitor. 主机名:mub-PC 进程号:27049 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:46 信息:[session uid=1000 pid=27104] Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor' 主机名:mub-PC 进程号:27104 级别:信息 进程:systemd 时间:2021-01-30 05:19:46 信息:Starting BAMF Application Matcher Framework... 主机名:mub-PC 进程号:27049 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:46 信息:[session uid=1000 pid=27104] Activating via systemd: service name='org.ayatana.bamf' unit='bamfdaemon.service' requested by ':1.11' (uid=1000 pid=27200 comm="/usr/lib/deepin-daemon/dde-session-daemon ") 主机名:mub-PC 进程号:27104 级别:信息 进程:systemd 时间:2021-01-30 05:19:46 信息:Starting Virtual filesystem service - Media Transfer Protocol monitor... 主机名:mub-PC 进程号:27049 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:46 信息:[session uid=1000 pid=27104] Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service' requested by ':1.22' (uid=1000 pid=27241 comm="/usr/bin/dde-dock -r ") 主机名:mub-PC 进程号:27104 级别:信息 进程:systemd 时间:2021-01-30 05:19:46 信息:Started Virtual filesystem service - digital camera monitor. 主机名:mub-PC 进程号:27049 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:46 信息:[session uid=1000 pid=27104] Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor' 主机名:mub-PC 进程号:27104 级别:信息 进程:systemd 时间:2021-01-30 05:19:46 信息:Starting Virtual filesystem service - digital camera monitor... 主机名:mub-PC 进程号:27049 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:46 信息:[session uid=1000 pid=27104] Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service' requested by ':1.22' (uid=1000 pid=27241 comm="/usr/bin/dde-dock -r ") 主机名:mub-PC 进程号:27104 级别:信息 进程:systemd 时间:2021-01-30 05:19:46 信息:Started Virtual filesystem service - Apple File Conduit monitor. 主机名:mub-PC 进程号:27049 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:46 信息:[session uid=1000 pid=27104] Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor' 主机名:mub-PC 进程号:27104 级别:信息 进程:systemd 时间:2021-01-30 05:19:46 信息:Starting Virtual filesystem service - Apple File Conduit monitor... 主机名:mub-PC 进程号:27049 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:46 信息:[session uid=1000 pid=27104] Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service' requested by ':1.22' (uid=1000 pid=27241 comm="/usr/bin/dde-dock -r ") 主机名:mub-PC 进程号:27104 级别:信息 进程:systemd 时间:2021-01-30 05:19:46 信息:Started Virtual filesystem service - disk device monitor. 主机名:mub-PC 进程号:27049 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:46 信息:[session uid=1000 pid=27104] Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor' 主机名:mub-PC 进程号:27104 级别:信息 进程:systemd 时间:2021-01-30 05:19:46 信息:Starting Virtual filesystem service - disk device monitor... 主机名:mub-PC 进程号:27049 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:46 信息:[session uid=1000 pid=27104] Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service' requested by ':1.22' (uid=1000 pid=27241 comm="/usr/bin/dde-dock -r ") 主机名:mub-PC 进程号:27104 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:46 信息:[session uid=1000 pid=27104] Activated service 'com.deepin.daemon.Timedate' failed: Process com.deepin.daemon.Timedate exited with status 1 主机名:mub-PC 进程号:27104 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:46 信息:[session uid=1000 pid=27104] Activating service name='com.deepin.daemon.Timedate' requested by ':1.21' (uid=1000 pid=27241 comm="/usr/bin/dde-dock -r ") 主机名:mub-PC 进程号:27104 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:46 信息:[session uid=1000 pid=27104] Activated service 'com.deepin.daemon.Timedate' failed: Process com.deepin.daemon.Timedate exited with status 1 主机名:mub-PC 进程号:27104 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:46 信息:[session uid=1000 pid=27104] Activating service name='com.deepin.daemon.Timedate' requested by ':1.21' (uid=1000 pid=27241 comm="/usr/bin/dde-dock -r ") 主机名:mub-PC 进程号:27104 级别:信息 进程:startdde 时间:2021-01-30 05:19:46 信息:main.go:200: after 426.44979ms, call com.deepin.dde.Dock callShow 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:19:46 信息:session_process.go:110: /usr/bin/kwin_no_scale [] startup duration: 320.332712ms 主机名:mub-PC 进程号:27092 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:46 信息:[session uid=1000 pid=27104] Successfully activated service 'org.kde.kglobalaccel' 主机名:mub-PC 进程号:27104 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:46 信息:[session uid=1000 pid=27104] Activating service name='org.kde.kglobalaccel' requested by ':1.14' (uid=1000 pid=27207 comm="kwin_x11 -platform dde-kwin-xcb:appFilePath=/usr/b") 主机名:mub-PC 进程号:27104 级别:信息 进程:startdde 时间:2021-01-30 05:19:46 信息:session_process.go:110: /usr/bin/dde-desktop [] startup duration: 147.810967ms 主机名:mub-PC 进程号:27092 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:46 信息:module.go:83: start launcher module cost 37.064101ms 主机名:mub-PC 进程号:27200 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:46 信息:[session uid=1000 pid=27104] Successfully activated service 'com.deepin.wm' 主机名:mub-PC 进程号:27104 级别:信息 进程:startdde 时间:2021-01-30 05:19:46 信息:session_process.go:91: command /usr/bin/dde-dock [-r] started, pid: 27241 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:19:46 信息:session_process.go:110: /usr/lib/deepin-daemon/dde-session-daemon [] startup duration: 116.386254ms 主机名:mub-PC 进程号:27092 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:46 信息:loader.go:157: enable module x-event-monitor done, cost 4.527976ms 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:46 信息:loader.go:149: enable module x-event-monitor 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:46 信息:loader.go:157: enable module launcher done, cost 1.934µs 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:46 信息:loader.go:149: enable module launcher 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:46 信息:loader.go:157: enable module trayicon done, cost 2.095356ms 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:46 信息:traymanager.go:373: Add tray icon 4194321 name: "[fcitx|fcitx]" 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:46 信息:loader.go:149: enable module trayicon 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:46 信息:loader.go:157: enable module dock done, cost 11.015212ms 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:46 信息:loader.go:149: enable module dock 主机名:mub-PC 进程号:27200 级别:信息 进程:dde-session-dae 时间:2021-01-30 05:19:46 信息:main.go:136: App log level: 5 主机名:mub-PC 进程号:27200 级别:信息 进程:systemd 时间:2021-01-30 05:19:46 信息:Started Accessibility services bus. 主机名:mub-PC 进程号:27049 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:46 信息:[session uid=1000 pid=27104] Successfully activated service 'org.a11y.Bus' 主机名:mub-PC 进程号:27104 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:46 信息:[session uid=1000 pid=27104] Activating service name='com.deepin.wm' requested by ':1.14' (uid=1000 pid=27207 comm="kwin_x11 -platform dde-kwin-xcb:appFilePath=/usr/b") 主机名:mub-PC 进程号:27104 级别:信息 进程:systemd 时间:2021-01-30 05:19:46 信息:Starting Accessibility services bus... 主机名:mub-PC 进程号:27049 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:46 信息:[session uid=1000 pid=27104] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.13' (uid=1000 pid=27200 comm="/usr/lib/deepin-daemon/dde-session-daemon ") 主机名:mub-PC 进程号:27104 级别:信息 进程:startdde 时间:2021-01-30 05:19:45 信息:session_process.go:91: command /usr/bin/dde-desktop [] started, pid: 27202 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:19:45 信息:session_process.go:91: command /usr/lib/deepin-daemon/dde-session-daemon [] started, pid: 27200 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:19:45 信息:session_process.go:91: command /usr/bin/kwin_no_scale [] started, pid: 27198 主机名:mub-PC 进程号:27092 级别:信息 进程:startdde 时间:2021-01-30 05:19:45 信息:handle_event.go:191: redo map touch screen 主机名:mub-PC 进程号:27092 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:45 信息:[session uid=1000 pid=27104] Successfully activated service 'ca.desrt.dconf' 主机名:mub-PC 进程号:27104 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:45 信息:[session uid=1000 pid=27104] Activating service name='ca.desrt.dconf' requested by ':1.6' (uid=1000 pid=27092 comm="/usr/bin/startdde ") 主机名:mub-PC 进程号:27104 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:45 信息:[session uid=1000 pid=27104] Activated service 'org.freedesktop.Notifications' failed: Process org.freedesktop.Notifications exited with status 255 主机名:mub-PC 进程号:27104 级别:信息 进程:systemd 时间:2021-01-30 05:19:45 信息:Started Virtual filesystem service. 主机名:mub-PC 进程号:27049 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:45 信息:[session uid=1000 pid=27104] Successfully activated service 'org.gtk.vfs.Daemon' 主机名:mub-PC 进程号:27104 级别:信息 进程:systemd 时间:2021-01-30 05:19:45 信息:Starting Virtual filesystem service... 主机名:mub-PC 进程号:27049 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:45 信息:[session uid=1000 pid=27104] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.6' (uid=1000 pid=27092 comm="/usr/bin/startdde ") 主机名:mub-PC 进程号:27104 级别:信息 进程:dbus-daemon 时间:2021-01-30 05:19:45 信息:[session uid=1000 pid=27104] Activating service name='org.freedesktop.Notifications' requested by ':1.4' (uid=1000 pid=27157 comm="/usr/bin/fcitx -d ") 主机名:mub-PC 进程号:27104 级别:信息 进程:systemd 时间:2021-01-30 05:19:45 信息:Started D-Bus User Message Bus. 主机名:mub-PC 进程号:27049 级别:信息 进程:systemd 时间:2021-01-30 05:19:45 信息:Startup finished in 69ms. 主机名:mub-PC 进程号:27049 级别:信息 进程:systemd 时间:2021-01-30 05:19:45 信息:Reached target Default. 主机名:mub-PC 进程号:27049 级别:信息 进程:systemd 时间:2021-01-30 05:19:45 信息:Reached target Basic System. 主机名:mub-PC 进程号:27049 级别:信息 进程:systemd 时间:2021-01-30 05:19:45 信息:Reached target Sockets. 主机名:mub-PC 进程号:27049 级别:信息 进程:systemd 时间:2021-01-30 05:19:45 信息:Listening on D-Bus User Message Bus Socket. 主机名:mub-PC 进程号:27049 级别:信息 进程:systemd 时间:2021-01-30 05:19:45 信息:Listening on GnuPG cryptographic agent (ssh-agent emulation). 主机名:mub-PC 进程号:27049 级别:信息 进程:systemd 时间:2021-01-30 05:19:45 信息:Starting D-Bus User Message Bus Socket. 主机名:mub-PC 进程号:27049 级别:信息 进程:systemd 时间:2021-01-30 05:19:45 信息:Reached target Timers. 主机名:mub-PC 进程号:27049 级别:信息 进程:systemd 时间:2021-01-30 05:19:45 信息:Listening on GnuPG network certificate management daemon. 主机名:mub-PC 进程号:27049 级别:信息 进程:systemd 时间:2021-01-30 05:19:45 信息:Listening on Sound System. 主机名:mub-PC 进程号:27049 级别:信息 进程:systemd 时间:2021-01-30 05:19:45 信息:Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers). 主机名:mub-PC 进程号:27049 级别:信息 进程:systemd 时间:2021-01-30 05:19:45 信息:Listening on GnuPG cryptographic agent and passphrase cache (restricted). 主机名:mub-PC 进程号:27049 级别:信息 进程:systemd 时间:2021-01-30 05:19:45 信息:Listening on GnuPG cryptographic agent and passphrase cache. 主机名:mub-PC 进程号:27049 级别:信息 进程:systemd 时间:2021-01-30 05:19:45 信息:Reached target Paths. 主机名:mub-PC 进程号:27049 级别:信息 进程:startdde 时间:2021-01-30 00:26:32 信息:startmanager.go:653: send openapp message, app info /usr/share/applications/deepin-log-viewer.desktop/日志收集工具/deepin-log-viewer 主机名:mub-PC 进程号:3590 级别:信息 进程:dbus-daemon 时间:2021-01-30 00:24:11 信息:[session uid=1000 pid=3602] Successfully activated service 'com.deepin.daemon.LangSelector' 主机名:mub-PC 进程号:3602 级别:信息 进程:dbus-daemon 时间:2021-01-30 00:24:11 信息:[session uid=1000 pid=3602] Activating service name='com.deepin.daemon.LangSelector' requested by ':1.125' (uid=1000 pid=20181 comm="dde-control-center --show ") 主机名:mub-PC 进程号:3602 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:24:08 信息:app_entry.go:239: attach window id: 142606370, wmClass: "dde-control-center" "dde-control-center", wmState: [], wmWindowType: [388], wmAllowedActions: [522 523 497 524 526 527 528 529 498], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:23:35 信息:app_entry.go:239: attach window id: 88082639, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:23:26 信息:app_entry.go:239: attach window id: 88082639, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:23:00 信息:app_entry.go:239: attach window id: 88083050, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:22:46 信息:utils_notify.go:80: notify notification-bluetooth-connected 连接"幕宾的Mi 10"成功 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:22:46 信息:device.go:585: device [7C:2A:DB:55:20:42] 幕宾的Mi 10 connect succeeded 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:22:46 信息:manager_device.go:150: ignore invalid device type 5 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:22:46 信息:manager_connection.go:62: add connection /org/freedesktop/NetworkManager/Settings/8 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:22:45 信息:agent.go:292: emitRequest accept /org/bluez/hci0/dev_7C_2A_DB_55_20_42 with 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:22:45 信息:agent.go:286: receive {/org/bluez/hci0/dev_7C_2A_DB_55_20_42 true} 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:22:45 信息:bluetooth_ifc.go:291: Confirm "/org/bluez/hci0/dev_7C_2A_DB_55_20_42" true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:22:41 信息:agent.go:275: waitResponse 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:22:41 信息:agent.go:326: emitRequest /org/bluez/hci0/dev_7C_2A_DB_55_20_42 RequestConfirmation [470346] 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:22:41 信息:agent.go:173: RequestConfirmation /org/bluez/hci0/dev_7C_2A_DB_55_20_42 470346 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:22:16 信息:utils_notify.go:80: notify notification-bluetooth-error 蓝牙连接失败 请确定"小米手机"已打开而且在通讯范围内 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:22:15 信息:utils_notify.go:215: user no response,close notify when time out 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:22:13 信息:utils_notify.go:80: notify notification-bluetooth-error 蓝牙连接失败 请确定"幕宾的Mi 10"已打开而且在通讯范围内 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:22:13 信息:agent.go:286: receive {/org/bluez/hci0/dev_7C_2A_DB_55_20_42 false} 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:22:13 信息:agent.go:220: Cancel() 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:22:10 信息:agent.go:275: waitResponse 主机名:mub-PC 进程号:3695 级别:信息 进程:dbus-daemon 时间:2021-01-30 00:22:10 信息:[session uid=1000 pid=3602] Successfully activated service 'com.deepin.daemon.SoundEffect' 主机名:mub-PC 进程号:3602 级别:信息 进程:dbus-daemon 时间:2021-01-30 00:22:10 信息:[session uid=1000 pid=3602] Activating service name='com.deepin.daemon.SoundEffect' requested by ':1.37' (uid=1000 pid=3931 comm="/usr/lib/deepin-daemon/dde-osd ") 主机名:mub-PC 进程号:3602 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:22:10 信息:agent.go:326: emitRequest /org/bluez/hci0/dev_7C_2A_DB_55_20_42 RequestConfirmation [284653] 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:22:10 信息:agent.go:173: RequestConfirmation /org/bluez/hci0/dev_7C_2A_DB_55_20_42 284653 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:21:49 信息:agent.go:292: emitRequest accept /org/bluez/hci0/dev_94_87_E0_A1_8D_8F with 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:21:49 信息:agent.go:286: receive {/org/bluez/hci0/dev_94_87_E0_A1_8D_8F true} 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:21:49 信息:bluetooth_ifc.go:291: Confirm "/org/bluez/hci0/dev_94_87_E0_A1_8D_8F" true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:21:45 信息:agent.go:275: waitResponse 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:21:45 信息:agent.go:326: emitRequest /org/bluez/hci0/dev_94_87_E0_A1_8D_8F RequestConfirmation [749318] 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:21:45 信息:agent.go:173: RequestConfirmation /org/bluez/hci0/dev_94_87_E0_A1_8D_8F 749318 主机名:mub-PC 进程号:3695 级别:信息 进程:systemd 时间:2021-01-30 00:21:06 信息:var-lib-os\x2dprober-mount.mount: Succeeded. 主机名:mub-PC 进程号:3548 级别:信息 进程:systemd 时间:2021-01-30 00:21:06 信息:var-lib-os\x2dprober-mount.mount: Succeeded. 主机名:mub-PC 进程号:3548 级别:信息 进程:systemd 时间:2021-01-30 00:21:05 信息:var-lib-os\x2dprober-mount.mount: Succeeded. 主机名:mub-PC 进程号:3548 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:21:04 信息:manager_proxy.go:97: GetProxyMethod none 主机名:mub-PC 进程号:3695 级别:信息 进程:systemd 时间:2021-01-30 00:20:56 信息:var-lib-os\x2dprober-mount.mount: Succeeded. 主机名:mub-PC 进程号:3548 级别:信息 进程:systemd 时间:2021-01-30 00:20:56 信息:var-lib-os\x2dprober-mount.mount: Succeeded. 主机名:mub-PC 进程号:3548 级别:信息 进程:systemd 时间:2021-01-30 00:20:55 信息:var-lib-os\x2dprober-mount.mount: Succeeded. 主机名:mub-PC 进程号:3548 级别:信息 进程:polkit-agent-he 时间:2021-01-30 00:20:53 信息:pam_deepin_authentication(polkit-1:auth): Verification successful 主机名:mub-PC 进程号:25183 级别:信息 进程:polkit-agent-he 时间:2021-01-30 00:20:50 信息:pam_deepin_authentication(polkit-1:auth): Password: 主机名:mub-PC 进程号:25183 级别:信息 进程:polkit-agent-he 时间:2021-01-30 00:20:50 信息:pam_deepin_authentication(polkit-1:auth): Password 主机名:mub-PC 进程号:25183 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:20:44 信息:app_entry.go:239: attach window id: 142606346, wmClass: "dde-control-center" "dde-control-center", wmState: [], wmWindowType: [388], wmAllowedActions: [522 523 497 524 526 527 528 529 498], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:20:44 信息:app_entry.go:239: attach window id: 132120589, wmClass: "dde-file-manager" "dde-file-manager", wmState: [], wmWindowType: [388], wmAllowedActions: [522 523 497 524 526 527 528 529 498], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:startdde 时间:2021-01-30 00:20:44 信息:startmanager.go:653: send openapp message, app info /usr/share/applications/dde-control-center.desktop/控制中心/dde-control-center 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-30 00:20:44 信息:startmanager.go:653: send openapp message, app info /usr/share/applications/dde-file-manager.desktop/深度文件管理器/dde-file-manager 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-30 00:20:42 信息:startmanager.go:653: send closeapp message, app info /usr/share/applications/deepin-log-viewer.desktop/日志收集工具/deepin-log-viewer 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:20:42 信息:dock_manager_entries.go:149: removeAppEntry id: e17T60143034 主机名:mub-PC 进程号:3695 级别:信息 进程:pkexec 时间:2021-01-30 00:20:28 信息:pam_unix(polkit-1:session): session opened for user root by (uid=1000) 主机名:mub-PC 进程号:9639 级别:信息 进程:pkexec 时间:2021-01-30 00:20:24 信息:pam_unix(polkit-1:session): session opened for user root by (uid=1000) 主机名:mub-PC 进程号:31215 级别:信息 进程:polkit-agent-he 时间:2021-01-30 00:20:24 信息:pam_deepin_authentication(polkit-1:auth): Verification successful 主机名:mub-PC 进程号:31354 级别:信息 进程:polkit-agent-he 时间:2021-01-30 00:20:13 信息:pam_deepin_authentication(polkit-1:auth): Password: 主机名:mub-PC 进程号:31354 级别:信息 进程:polkit-agent-he 时间:2021-01-30 00:20:13 信息:pam_deepin_authentication(polkit-1:auth): Password 主机名:mub-PC 进程号:31354 级别:信息 进程:startdde 时间:2021-01-30 00:19:03 信息:startmanager.go:653: send closeapp message, app info /usr/share/applications/deepin-app-store.desktop/深度应用商店/deepin-app-store 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-30 00:19:01 信息:startmanager.go:653: send closeapp message, app info /usr/share/applications/dde-control-center.desktop/控制中心/dde-control-center 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:18:12 信息:app_entry.go:239: attach window id: 88082639, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:18:05 信息:app_entry.go:239: attach window id: 88082639, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:17:58 信息:app_entry.go:239: attach window id: 88082639, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:17:40 信息:app_entry.go:239: attach window id: 88082999, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:17:33 信息:app_entry.go:239: attach window id: 88082639, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:17:27 信息:app_entry.go:239: attach window id: 88082639, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:17:14 信息:app_entry.go:239: attach window id: 88082639, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:16:50 信息:app_entry.go:239: attach window id: 88082993, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:16:14 信息:app_entry.go:239: attach window id: 88082639, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:15:06 信息:app_entry.go:239: attach window id: 88082639, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:14:31 信息:app_entry.go:239: attach window id: 144703498, wmClass: "dde-control-center" "dde-control-center", wmState: [], wmWindowType: [388], wmAllowedActions: [522 523 497 524 526 527 528 529 498], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:startdde 时间:2021-01-30 00:14:30 信息:startmanager.go:653: send openapp message, app info /usr/share/applications/dde-control-center.desktop/控制中心/dde-control-center 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:14:07 信息:app_entry.go:239: attach window id: 88082639, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:13:53 信息:app_entry.go:239: attach window id: 88082951, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 529], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:13:50 信息:app_entry.go:239: attach window id: 88082940, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:13:49 信息:app_entry.go:239: attach window id: 88082943, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 523 497 526 527 528 529 498], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:11:49 信息:app_entry.go:239: attach window id: 88082836, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:11:48 信息:app_entry.go:239: attach window id: 88082880, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:11:43 信息:app_entry.go:239: attach window id: 88082836, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:11:38 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:10:54 信息:app_entry.go:239: attach window id: 88082865, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:10:29 信息:app_entry.go:239: attach window id: 88082517, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:10:28 信息:app_entry.go:239: attach window id: 88082517, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:10:17 信息:app_entry.go:239: attach window id: 88082850, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:09:52 信息:app_entry.go:239: attach window id: 88082639, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:09:26 信息:app_entry.go:239: attach window id: 88082836, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:08:45 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:08:08 信息:app_entry.go:239: attach window id: 88082639, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:07:44 信息:app_entry.go:239: attach window id: 88082808, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:07:32 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:07:15 信息:app_entry.go:239: attach window id: 88082794, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:06:44 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:05:04 信息:app_entry.go:239: attach window id: 88082745, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:03:25 信息:app_entry.go:239: attach window id: 88082639, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:03:03 信息:app_entry.go:239: attach window id: 88082517, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:02:59 信息:app_entry.go:239: attach window id: 88082698, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 523 497 526 527 528 529 498], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:02:20 信息:app_entry.go:239: attach window id: 88082639, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:01:54 信息:app_entry.go:239: attach window id: 88082645, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:01:46 信息:app_entry.go:239: attach window id: 88082639, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:01:33 信息:app_entry.go:239: attach window id: 88082639, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-30 00:01:17 信息:app_entry.go:239: attach window id: 88082634, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:59:07 信息:app_entry.go:239: attach window id: 88082517, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:59:01 信息:app_entry.go:239: attach window id: 88081018, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 529], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:59:01 信息:app_entry.go:239: attach window id: 88082595, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:58:07 信息:app_entry.go:239: attach window id: 88080532, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:58:07 信息:app_entry.go:239: attach window id: 88082561, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:56:36 信息:app_entry.go:239: attach window id: 142606346, wmClass: "deepin-log-viewer" "deepin-log-viewer", wmState: [], wmWindowType: [388], wmAllowedActions: [522 523 497 524 526 527 528 529 498], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:startdde 时间:2021-01-29 23:56:35 信息:startmanager.go:653: send openapp message, app info /usr/share/applications/deepin-log-viewer.desktop/日志收集工具/deepin-log-viewer 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:56:24 信息:startmanager.go:653: send closeapp message, app info /usr/share/applications/wps-office-prometheus.desktop/WPS 2019/wps-office-prometheus 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:56:14 信息:app_entry.go:239: attach window id: 142606369, wmClass: "Wpsoffice" "wpsoffice", wmState: [367 366], wmWindowType: [389 388], wmAllowedActions: [522 523 497 526 527 528 529 498], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:startdde 时间:2021-01-29 23:56:13 信息:startmanager.go:653: send openapp message, app info /usr/share/applications/wps-office-prometheus.desktop/WPS 2019/wps-office-prometheus 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:56:07 信息:app_entry.go:239: attach window id: 88082517, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:54:36 信息:app_entry.go:239: attach window id: 134217729, wmClass: "Org.deepin.browser" "org.deepin.browser", wmState: [367 366], wmWindowType: [388], wmAllowedActions: [522 523 497 526 527 528 529 498], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:startdde 时间:2021-01-29 23:54:35 信息:startmanager.go:653: send openapp message, app info /usr/share/applications/org.deepin.browser.desktop/浏览器/org.deepin.browser 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:54:33 信息:app_entry.go:239: attach window id: 88080417, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 523 528 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:54:33 信息:app_entry.go:239: attach window id: 88082508, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 529], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:54:09 信息:app_entry.go:239: attach window id: 88082474, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:54:07 信息:app_entry.go:239: attach window id: 88082462, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:54:04 信息:dock_manager_entries.go:149: removeAppEntry id: e16T60142f85 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:53:41 信息:app_entry.go:239: attach window id: 134217744, wmClass: "deepin-manual" "dman", wmState: [], wmWindowType: [388], wmAllowedActions: [522 523 497 524 526 527 528 529 498], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:53:41 信息:[session uid=1000 pid=3602] Successfully activated service 'com.deepin.Manual.Open' 主机名:mub-PC 进程号:3602 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:53:41 信息:[session uid=1000 pid=3602] Activating service name='com.deepin.Manual.Open' requested by ':1.103' (uid=1000 pid=15447 comm="deepin-app-store ") 主机名:mub-PC 进程号:3602 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:53:22 信息:app_entry.go:239: attach window id: 88082462, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:53:18 信息:app_entry.go:239: attach window id: 88082462, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:startdde 时间:2021-01-29 23:53:08 信息:startmanager.go:653: send closeapp message, app info /usr/share/applications/dde-control-center.desktop/控制中心/dde-control-center 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:52:55 信息:app_entry.go:239: attach window id: 88082453, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:52:02 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:51:52 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:51:40 信息:app_entry.go:239: attach window id: 88082377, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:51:24 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:50:58 信息:app_entry.go:239: attach window id: 88082320, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:50:48 信息:app_entry.go:239: attach window id: 140509194, wmClass: "dde-control-center" "dde-control-center", wmState: [], wmWindowType: [388], wmAllowedActions: [522 523 497 524 526 527 528 529 498], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:startdde 时间:2021-01-29 23:50:48 信息:startmanager.go:653: send openapp message, app info /usr/share/applications/dde-control-center.desktop/控制中心/dde-control-center 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:50:14 信息:app_entry.go:239: attach window id: 88081018, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 529], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:50:03 信息:notify.go:46: sendNotify icon: package_install_failed, msg: "\"Sunpinyin\" 安装失败", actions: [{retry 重试 0xc7ec90} {cancel 取消 0xc7edd0}], timeout: -1 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:49:44 信息:notify.go:46: sendNotify icon: package_install_failed, msg: "\"全聚合影视\" 安装失败", actions: [{retry 重试 0xc7ec90} {cancel 取消 0xc7edd0}], timeout: -1 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:49:41 信息:notify.go:46: sendNotify icon: package_install_failed, msg: "\"全聚合影视\" 安装失败", actions: [{retry 重试 0xc7ec90} {cancel 取消 0xc7edd0}], timeout: -1 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:49:39 信息:notify.go:46: sendNotify icon: package_install_failed, msg: "\"全聚合影视\" 安装失败", actions: [{retry 重试 0xc7ec90} {cancel 取消 0xc7edd0}], timeout: -1 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:49:35 信息:notify.go:46: sendNotify icon: package_install_failed, msg: "\"全聚合影视\" 安装失败", actions: [{retry 重试 0xc7ec90} {cancel 取消 0xc7edd0}], timeout: -1 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:48:58 信息:app_entry.go:239: attach window id: 132120592, wmClass: "deepin-app-store" "deepin-app-store", wmState: [], wmWindowType: [388], wmAllowedActions: [522 523 497 524 526 527 528 529 498], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:48:58 信息:[session uid=1000 pid=3602] Successfully activated service 'com.deepin.AppStore.Daemon' 主机名:mub-PC 进程号:3602 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:48:58 信息:[session uid=1000 pid=3602] Activating service name='com.deepin.AppStore.Daemon' requested by ':1.103' (uid=1000 pid=15447 comm="deepin-app-store ") 主机名:mub-PC 进程号:3602 级别:信息 进程:startdde 时间:2021-01-29 23:48:58 信息:startmanager.go:653: send openapp message, app info /usr/share/applications/deepin-app-store.desktop/深度应用商店/deepin-app-store 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:48:44 信息:app_entry.go:239: attach window id: 88082277, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:48:42 信息:app_entry.go:239: attach window id: 88082259, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:48:40 信息:app_entry.go:239: attach window id: 88082258, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:startdde 时间:2021-01-29 23:48:33 信息:startmanager.go:653: send closeapp message, app info /usr/share/applications/org.deepin.browser.desktop/浏览器/org.deepin.browser 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:48:30 信息:startmanager.go:653: send closeapp message, app info /usr/share/applications/org.deepin.browser.desktop/浏览器/org.deepin.browser 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:48:30 信息:startmanager.go:653: send openapp message, app info /usr/share/applications/org.deepin.browser.desktop/浏览器/org.deepin.browser 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:48:29 信息:app_entry.go:239: attach window id: 88082226, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:48:19 信息:app_entry.go:239: attach window id: 88082185, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:48:17 信息:app_entry.go:239: attach window id: 88082181, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:48:13 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:48:08 信息:app_entry.go:239: attach window id: 88080420, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 523 497 526 527 528 529 498], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:48:05 信息:app_entry.go:239: attach window id: 88082136, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:48:01 信息:app_entry.go:239: attach window id: 88082159, wmClass: "Wine" "qq.exe", wmState: [370], wmWindowType: [388], wmAllowedActions: [522 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:startdde 时间:2021-01-29 23:47:55 信息:startmanager.go:653: send closeapp message, app info /usr/share/applications/org.deepin.browser.desktop/浏览器/org.deepin.browser 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:47:54 信息:startmanager.go:653: send openapp message, app info /usr/share/applications/org.deepin.browser.desktop/浏览器/org.deepin.browser 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:47:54 信息:app_entry.go:239: attach window id: 88082150, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:47:49 信息:app_entry.go:239: attach window id: 88082136, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:47:46 信息:app_entry.go:239: attach window id: 88082132, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:47:37 信息:app_entry.go:239: attach window id: 88080532, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:47:14 信息:app_entry.go:239: attach window id: 88080537, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:47:14 信息:app_entry.go:239: attach window id: 88081851, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:47:14 信息:app_entry.go:239: attach window id: 88081851, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:46:55 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:46:51 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:46:10 信息:app_entry.go:239: attach window id: 88082052, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:45:16 信息:app_entry.go:239: attach window id: 88080741, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:45:11 信息:app_entry.go:239: attach window id: 88080741, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:45:03 信息:app_entry.go:239: attach window id: 88082016, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:44:57 信息:app_entry.go:239: attach window id: 88081802, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:44:34 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:43:56 信息:app_entry.go:239: attach window id: 88081973, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:43:49 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:43:45 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:43:06 信息:app_entry.go:239: attach window id: 88081802, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:42:22 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:42:15 信息:app_entry.go:239: attach window id: 88081881, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 529], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:41:42 信息:app_entry.go:239: attach window id: 88080537, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:41:42 信息:app_entry.go:239: attach window id: 88080537, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:41:10 信息:app_entry.go:239: attach window id: 88081809, wmClass: "Wine" "qq.exe", wmState: [363 369], wmWindowType: [388], wmAllowedActions: [522 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:41:10 信息:app_entry.go:239: attach window id: 88081802, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:41:10 信息:app_entry.go:239: attach window id: 88081808, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:41:04 信息:app_entry.go:239: attach window id: 88081802, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:40:57 信息:app_entry.go:239: attach window id: 88081747, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:40:38 信息:app_entry.go:239: attach window id: 88080741, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:40:25 信息:app_entry.go:239: attach window id: 88080741, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:40:22 信息:app_entry.go:239: attach window id: 88081796, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:40:06 信息:app_entry.go:239: attach window id: 88081777, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:40:06 信息:app_entry.go:239: attach window id: 88081775, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:39:49 信息:app_entry.go:239: attach window id: 88080741, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:39:39 信息:app_entry.go:239: attach window id: 88081752, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:39:36 信息:app_entry.go:239: attach window id: 88081747, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:39:32 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:39:23 信息:app_entry.go:239: attach window id: 88081741, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:39:08 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:37:03 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:35:59 信息:app_entry.go:239: attach window id: 88081513, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:35:39 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:35:27 信息:app_entry.go:239: attach window id: 88081513, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:34:42 信息:app_entry.go:239: attach window id: 88080741, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:34:28 信息:app_entry.go:239: attach window id: 88081578, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:34:12 信息:app_entry.go:239: attach window id: 88081554, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:34:04 信息:app_entry.go:239: attach window id: 88081546, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 529], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:34:03 信息:app_entry.go:239: attach window id: 88081513, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:33:59 信息:app_entry.go:239: attach window id: 88081541, wmClass: "Wine" "qq.exe", wmState: [363 369], wmWindowType: [388], wmAllowedActions: [522 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:33:59 信息:app_entry.go:239: attach window id: 88081513, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:33:59 信息:app_entry.go:239: attach window id: 88081540, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:33:25 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:33:16 信息:app_entry.go:239: attach window id: 88080532, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:33:13 信息:app_entry.go:239: attach window id: 88081513, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:33:02 信息:app_entry.go:239: attach window id: 132120577, wmClass: "Org.deepin.browser" "org.deepin.browser", wmState: [367 366], wmWindowType: [388], wmAllowedActions: [522 523 497 526 527 528 529 498], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:startdde 时间:2021-01-29 23:33:01 信息:startmanager.go:653: send openapp message, app info /usr/share/applications/org.deepin.browser.desktop/浏览器/org.deepin.browser 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:32:49 信息:app_entry.go:239: attach window id: 88081499, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:32:49 信息:app_entry.go:239: attach window id: 88081498, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:32:37 信息:app_entry.go:239: attach window id: 88081477, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:32:31 信息:app_entry.go:239: attach window id: 88080537, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:31:30 信息:app_entry.go:239: attach window id: 88081442, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:31:09 信息:app_entry.go:239: attach window id: 88081430, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:31:01 信息:app_entry.go:239: attach window id: 88080741, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:30:31 信息:app_entry.go:239: attach window id: 88081420, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:30:25 信息:app_entry.go:239: attach window id: 88081415, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:30:23 信息:app_entry.go:239: attach window id: 88081056, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:30:21 信息:app_entry.go:239: attach window id: 88081056, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:30:18 信息:app_entry.go:239: attach window id: 88080741, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:29:53 信息:app_entry.go:239: attach window id: 88081399, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:29:06 信息:app_entry.go:239: attach window id: 88081177, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:29:04 信息:app_entry.go:239: attach window id: 88081177, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:29:03 信息:app_entry.go:239: attach window id: 88081177, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:29:03 信息:app_entry.go:239: attach window id: 88081177, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:29:03 信息:app_entry.go:239: attach window id: 88081177, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:29:03 信息:app_entry.go:239: attach window id: 88081177, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:29:03 信息:app_entry.go:239: attach window id: 88081177, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:29:02 信息:app_entry.go:239: attach window id: 88081177, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:29:02 信息:app_entry.go:239: attach window id: 88081177, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:29:02 信息:app_entry.go:239: attach window id: 88081177, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:29:02 信息:app_entry.go:239: attach window id: 88081177, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:29:02 信息:app_entry.go:239: attach window id: 88081177, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:29:02 信息:app_entry.go:239: attach window id: 88081177, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:29:01 信息:app_entry.go:239: attach window id: 88081177, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:28:50 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:28:31 信息:app_entry.go:239: attach window id: 88081118, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:28:21 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:27:43 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:27:40 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:27:31 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:27:19 信息:app_entry.go:239: attach window id: 88081098, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:26:30 信息:app_entry.go:239: attach window id: 88081083, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:26:22 信息:app_entry.go:239: attach window id: 88081056, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:25:55 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:25:41 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:25:32 信息:app_entry.go:239: attach window id: 88081056, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:25:30 信息:app_entry.go:239: attach window id: 88080915, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:25:21 信息:app_entry.go:239: attach window id: 88080915, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:24:58 信息:app_entry.go:239: attach window id: 88081018, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 529], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:24:41 信息:screensaver.go:205: SetTimeout to 900 0 false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:24:39 信息:screensaver.go:205: SetTimeout to 300 0 false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:23:51 信息:app_entry.go:239: attach window id: 88080994, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 529], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:startdde 时间:2021-01-29 23:23:37 信息:checker.go:293: process memory: /usr/share/applications/virtualbox.desktop 2@dde/uiapps/18 6572 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:23:34 信息:checker.go:293: process memory: /usr/share/applications/org.kde.okular.desktop 2@dde/uiapps/17 0 open /sys/fs/cgroup/memory/2@dde/uiapps/17/cgroup.procs: no such file or directory 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:23:33 信息:app_entry.go:239: attach window id: 88080915, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:startdde 时间:2021-01-29 23:23:30 信息:startmanager.go:653: send closeapp message, app info /usr/share/applications/virtualbox.desktop/Oracle VM VirtualBox/virtualbox 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:23:23 信息:app_entry.go:239: attach window id: 132120593, wmClass: "VirtualBox Manager" "VirtualBox Manager", wmState: [], wmWindowType: [388], wmAllowedActions: [522 523 497 524 526 527 528 529 498], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:23:22 信息:app_entry.go:239: attach window id: 132120582, wmClass: "VirtualBox" "VirtualBox", wmState: [367 366], wmWindowType: [389 388], wmAllowedActions: [522 523 497 526 527 528 529 498], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:startdde 时间:2021-01-29 23:23:22 信息:startmanager.go:653: send openapp message, app info /usr/share/applications/virtualbox.desktop/Oracle VM VirtualBox/virtualbox 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:23:20 信息:startmanager.go:653: send closeapp message, app info /usr/share/applications/org.kde.okular.desktop/Okular/org.kde.okular 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:23:19 信息:app_entry.go:239: attach window id: 132120586, wmClass: "okular" "okular", wmState: [367 366], wmWindowType: [388], wmAllowedActions: [522 523 497 524 526 527 528 529 498], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:startdde 时间:2021-01-29 23:23:19 信息:startmanager.go:653: send openapp message, app info /usr/share/applications/org.kde.okular.desktop/Okular/org.kde.okular 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:23:02 信息:app_entry.go:239: attach window id: 88080955, wmClass: "Wine" "qq.exe", wmState: [370], wmWindowType: [388], wmAllowedActions: [522 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:22:26 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:22:03 信息:app_entry.go:239: attach window id: 88080933, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:21:45 信息:app_entry.go:239: attach window id: 88080915, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:21:44 信息:app_entry.go:239: attach window id: 88080915, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:21:26 信息:app_entry.go:239: attach window id: 88080908, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:21:16 信息:[session uid=1000 pid=3602] Successfully activated service 'com.deepin.daemon.SoundEffect' 主机名:mub-PC 进程号:3602 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:21:16 信息:[session uid=1000 pid=3602] Activating service name='com.deepin.daemon.SoundEffect' requested by ':1.37' (uid=1000 pid=3931 comm="/usr/lib/deepin-daemon/dde-osd ") 主机名:mub-PC 进程号:3602 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:21:16 信息:notify.go:46: sendNotify icon: deepin-appstore, msg: "已成功清理软件包缓存", actions: [], timeout: -1 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:20:46 信息:app_entry.go:239: attach window id: 88080837, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:20:08 信息:app_entry.go:239: attach window id: 88080827, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:19:47 信息:app_entry.go:239: attach window id: 88080741, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:19:43 信息:app_entry.go:239: attach window id: 88080794, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:19:34 信息:app_entry.go:239: attach window id: 88080741, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:19:27 信息:app_entry.go:239: attach window id: 88080741, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:19:18 信息:app_entry.go:239: attach window id: 88080782, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:19:10 信息:app_entry.go:239: attach window id: 88080571, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:19:10 信息:app_entry.go:239: attach window id: 88080768, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:18:28 信息:app_entry.go:239: attach window id: 88080751, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:18:26 信息:app_entry.go:239: attach window id: 88080746, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 529], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:18:21 信息:app_entry.go:239: attach window id: 88080741, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:18:13 信息:app_entry.go:239: attach window id: 88080741, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:18:08 信息:app_entry.go:239: attach window id: 88080741, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:17:28 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:17:16 信息:app_entry.go:239: attach window id: 88080703, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 529], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:startdde 时间:2021-01-29 23:16:46 信息:checker.go:293: process memory: /usr/share/applications/com.qq.weixin.deepin.desktop 2@dde/uiapps/16 201532 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:16:44 信息:traymanager.go:373: Add tray icon 115343372 name: "[Wine|explorer.exe]" 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:16:44 信息:app_entry.go:239: attach window id: 121634827, wmClass: "Wine" "wechat.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 523 497 526 527 528 529 498], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:16:33 信息:app_entry.go:239: attach window id: 121634822, wmClass: "Wine" "wechat.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:startdde 时间:2021-01-29 23:16:32 信息:startmanager.go:653: send closeapp message, app info /usr/share/applications/com.qq.weixin.deepin.desktop/微信/com.qq.weixin.deepin 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:16:31 信息:startmanager.go:653: send openapp message, app info /usr/share/applications/com.qq.weixin.deepin.desktop/微信/com.qq.weixin.deepin 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:15:56 信息:app_entry.go:239: attach window id: 88080622, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:15:52 信息:app_entry.go:239: attach window id: 88080571, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:15:27 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:15:18 信息:app_entry.go:239: attach window id: 88080571, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:15:09 信息:app_entry.go:239: attach window id: 88080570, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:15:08 信息:app_entry.go:239: attach window id: 88080570, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:14:34 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:14:18 信息:app_entry.go:239: attach window id: 88080537, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:14:17 信息:app_entry.go:239: attach window id: 88080532, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:13:52 信息:app_entry.go:239: attach window id: 88080486, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:13:36 信息:status-notifier-watcher.go:147: item org.kde.StatusNotifierItem-3655-1 lost 主机名:mub-PC 进程号:3695 级别:信息 进程:startdde 时间:2021-01-29 23:13:01 信息:checker.go:293: process memory: /usr/share/applications/iflyime-setting-wizard.desktop 2@dde/uiapps/15 0 open /sys/fs/cgroup/memory/2@dde/uiapps/15/cgroup.procs: no such file or directory 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:12:59 信息:startmanager.go:653: send closeapp message, app info /usr/share/applications/iflyime-setting-wizard.desktop/讯飞输入法设置向导/iflyime-setting-wizard 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:12:59 信息:dock_manager_entries.go:149: removeAppEntry id: e14T601425ee 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:12:54 信息:dock_manager_entries.go:149: removeAppEntry id: e15T601425f0 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:12:48 信息:app_entry.go:239: attach window id: 102760455, wmClass: "Fcitx-config-gtk3" "fcitx-config-gtk3", wmState: [], wmWindowType: [388], wmAllowedActions: [522 523 497 524 526 527 528 529 498], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:startdde 时间:2021-01-29 23:12:47 信息:checker.go:293: process memory: /usr/share/applications/iflyime-setting-wizard.desktop 2@dde/uiapps/14 0 open /sys/fs/cgroup/memory/2@dde/uiapps/14/cgroup.procs: no such file or directory 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:12:46 信息:app_entry.go:239: attach window id: 100663306, wmClass: "IMSettingWizrd" "iflyime-set-w", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 524 529 498], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:startdde 时间:2021-01-29 23:12:46 信息:startmanager.go:653: send openapp message, app info /usr/share/applications/iflyime-setting-wizard.desktop/讯飞输入法设置向导/iflyime-setting-wizard 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:12:41 信息:startmanager.go:653: send closeapp message, app info /usr/share/applications/iflyime-setting-wizard.desktop/讯飞输入法设置向导/iflyime-setting-wizard 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:12:41 信息:dock_manager_entries.go:149: removeAppEntry id: e13T601425e0 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:12:32 信息:app_entry.go:239: attach window id: 100663306, wmClass: "IMSettingWizrd" "iflyime-set-w", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 524 529 498], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:12:32 信息:[session uid=1000 pid=3602] Successfully activated service 'com.deepin.Manual.Search' 主机名:mub-PC 进程号:3602 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:12:32 信息:[session uid=1000 pid=3602] Activating service name='com.deepin.Manual.Search' requested by ':1.72' (uid=1000 pid=6455 comm="/opt/apps/com.iflytek.iflyime/files/bin/iflyime-se") 主机名:mub-PC 进程号:3602 级别:信息 进程:startdde 时间:2021-01-29 23:12:32 信息:startmanager.go:653: send openapp message, app info /usr/share/applications/iflyime-setting-wizard.desktop/讯飞输入法设置向导/iflyime-setting-wizard 主机名:mub-PC 进程号:3590 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:12:27 信息:[session uid=1000 pid=3602] Successfully activated service 'com.deepin.dde.Launcher' 主机名:mub-PC 进程号:3602 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:12:27 信息:[session uid=1000 pid=3602] Activating service name='com.deepin.dde.Launcher' requested by ':1.20' (uid=1000 pid=3736 comm="/usr/bin/dde-dock -r ") 主机名:mub-PC 进程号:3602 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:12:23 信息:status-notifier-watcher.go:147: item org.kde.StatusNotifierItem-3655-1 lost 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:12:14 信息:app_entry.go:239: attach window id: 88080430, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 497 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:11:54 信息:app_entry.go:239: attach window id: 88080420, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 523 497 526 527 528 529 498], hasXEmbedInfo: false, hasWmTransientFor: false 主机名:mub-PC 进程号:3695 级别:信息 进程:startdde 时间:2021-01-29 23:11:50 信息:checker.go:293: process memory: /usr/share/applications/com.qq.im.deepin.desktop 2@dde/uiapps/13 258036 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:11:48 信息:checker.go:293: process memory: /usr/share/applications/com.qq.im.deepin.desktop 2@dde/uiapps/12 0 open /sys/fs/cgroup/memory/2@dde/uiapps/12/cgroup.procs: no such file or directory 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:11:48 信息:traymanager.go:373: Add tray icon 73400337 name: "[Wine|explorer.exe]" 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:11:45 信息:app_entry.go:239: attach window id: 79691793, wmClass: "Wine" "qq.exe", wmState: [], wmWindowType: [388], wmAllowedActions: [522 529 498], hasXEmbedInfo: false, hasWmTransientFor: true 主机名:mub-PC 进程号:3695 级别:信息 进程:startdde 时间:2021-01-29 23:11:44 信息:checker.go:293: process memory: /usr/share/applications/com.qq.im.deepin.desktop 2@dde/uiapps/11 0 open /sys/fs/cgroup/memory/2@dde/uiapps/11/cgroup.procs: no such file or directory 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:11:40 信息:traymanager.go:373: Add tray icon 73400332 name: "[Wine|explorer.exe]" 主机名:mub-PC 进程号:3695 级别:信息 进程:startdde 时间:2021-01-29 23:11:35 信息:startmanager.go:653: send closeapp message, app info /usr/share/applications/com.qq.im.deepin.desktop/QQ/com.qq.im.deepin 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:11:35 信息:startmanager.go:653: send openapp message, app info /usr/share/applications/com.qq.im.deepin.desktop/QQ/com.qq.im.deepin 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:11:34 信息:startmanager.go:653: send closeapp message, app info /usr/share/applications/com.qq.im.deepin.desktop/QQ/com.qq.im.deepin 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:11:33 信息:startmanager.go:653: send openapp message, app info /usr/share/applications/com.qq.im.deepin.desktop/QQ/com.qq.im.deepin 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:11:30 信息:startmanager.go:653: send closeapp message, app info /usr/share/applications/com.qq.im.deepin.desktop/QQ/com.qq.im.deepin 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:11:29 信息:startmanager.go:653: send openapp message, app info /usr/share/applications/com.qq.im.deepin.desktop/QQ/com.qq.im.deepin 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:55 信息:notify.go:46: sendNotify icon: preferences-system, msg: "检测到有新系统版本", actions: [{update 立即更新 0xc7f040}], timeout: -1 主机名:mub-PC 进程号:3695 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:47 信息:[session uid=1000 pid=3602] Successfully activated service 'com.deepin.daemon.SoundEffect' 主机名:mub-PC 进程号:3602 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:47 信息:[session uid=1000 pid=3602] Activating service name='com.deepin.daemon.SoundEffect' requested by ':1.37' (uid=1000 pid=3931 comm="/usr/lib/deepin-daemon/dde-osd ") 主机名:mub-PC 进程号:3602 级别:信息 进程:startdde 时间:2021-01-29 23:10:43 信息:checker.go:293: process memory: /etc/xdg/autostart/pulseaudio.desktop 2@dde/uiapps/5 0 open /sys/fs/cgroup/memory/2@dde/uiapps/5/cgroup.procs: no such file or directory 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:10:43 信息:checker.go:293: process memory: /etc/xdg/autostart/deepin-ab-recovery.desktop 2@dde/uiapps/3 0 open /sys/fs/cgroup/memory/2@dde/uiapps/3/cgroup.procs: no such file or directory 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:10:43 信息:checker.go:293: process memory: /etc/xdg/autostart/at-spi-dbus-bus.desktop 2@dde/uiapps/4 0 open /sys/fs/cgroup/memory/2@dde/uiapps/4/cgroup.procs: no such file or directory 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:10:43 信息:checker.go:293: process memory: /etc/xdg/autostart/xdg-user-dirs.desktop 2@dde/uiapps/2 0 open /sys/fs/cgroup/memory/2@dde/uiapps/2/cgroup.procs: no such file or directory 主机名:mub-PC 进程号:3590 级别:信息 进程:systemd 时间:2021-01-29 23:10:36 信息:run-user-117.mount: Succeeded. 主机名:mub-PC 进程号:3548 级别:信息 进程:systemd 时间:2021-01-29 23:10:36 信息:run-user-117-gvfs.mount: Succeeded. 主机名:mub-PC 进程号:3548 级别:信息 进程:systemd 时间:2021-01-29 23:10:30 信息:Reloading. 主机名:mub-PC 进程号:3548 级别:信息 进程:systemd 时间:2021-01-29 23:10:30 信息:Reloading. 主机名:mub-PC 进程号:3548 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:29 信息:bluetooth.go:776: [DEBUG] Auto connect adapter: /org/bluez/hci0 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:29 信息:module.go:89: start audio module cost 50.605977ms 主机名:mub-PC 进程号:3695 级别:信息 进程:systemd 时间:2021-01-29 23:10:29 信息:Started Virtual filesystem metadata service. 主机名:mub-PC 进程号:3548 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:29 信息:[session uid=1000 pid=3602] Successfully activated service 'org.gtk.vfs.Metadata' 主机名:mub-PC 进程号:3602 级别:信息 进程:systemd 时间:2021-01-29 23:10:29 信息:Starting Virtual filesystem metadata service... 主机名:mub-PC 进程号:3548 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:29 信息:[session uid=1000 pid=3602] Activating via systemd: service name='org.gtk.vfs.Metadata' unit='gvfs-metadata.service' requested by ':1.17' (uid=1000 pid=3699 comm="/usr/bin/dde-desktop ") 主机名:mub-PC 进程号:3602 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:module.go:129: Owner: :1.49 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:bluetooth.go:776: [DEBUG] Auto connect adapter: /org/bluez/hci0 主机名:mub-PC 进程号:3695 级别:信息 进程:systemd 时间:2021-01-29 23:10:28 信息:Started Bluetooth OBEX service. 主机名:mub-PC 进程号:3548 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:28 信息:[session uid=1000 pid=3602] Successfully activated service 'org.bluez.obex' 主机名:mub-PC 进程号:3602 级别:信息 进程:obexd 时间:2021-01-29 23:10:28 信息:OBEX daemon 5.50 主机名:mub-PC 进程号:4159 级别:信息 进程:systemd 时间:2021-01-29 23:10:28 信息:Starting Bluetooth OBEX service... 主机名:mub-PC 进程号:3548 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:28 信息:[session uid=1000 pid=3602] Activating via systemd: service name='org.bluez.obex' unit='obex.service' requested by ':1.10' (uid=1000 pid=3695 comm="/usr/lib/deepin-daemon/dde-session-daemon ") 主机名:mub-PC 进程号:3602 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:adapter.go:135: AdapterAdded adapter mub-PC [4C:EB:BD:BA:6E:56] 主机名:mub-PC 进程号:3695 级别:信息 进程:startdde 时间:2021-01-29 23:10:28 信息:startmanager.go:653: send closeapp message, app info /etc/xdg/autostart/deepin-ab-recovery.desktop/AbRecovery//etc/xdg/autostart/deepin-ab-recovery 主机名:mub-PC 进程号:3590 级别:信息 进程:deepin-deepinid 时间:2021-01-29 23:10:28 信息:[INF] push.go:174: Adding consumer for topic: user273113 cf75d5e3d3f1369efcd483736208b7227906687641ae9c75e005eccb06fe9f13 主机名:mub-PC 进程号:4087 级别:信息 进程:startdde 时间:2021-01-29 23:10:28 信息:startmanager.go:653: send closeapp message, app info /etc/xdg/autostart/pulseaudio.desktop/PulseAudio 声音系统//etc/xdg/autostart/pulseaudio 主机名:mub-PC 进程号:3590 级别:信息 进程:systemd 时间:2021-01-29 23:10:28 信息:Started Sound Service. 主机名:mub-PC 进程号:3548 级别:信息 进程:startdde 时间:2021-01-29 23:10:28 信息:startmanager.go:653: send openapp message, app info /etc/xdg/autostart/geoclue-demo-agent.desktop/Geoclue Demo agent//etc/xdg/autostart/geoclue-demo-agent 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:10:28 信息:startmanager.go:653: send closeapp message, app info /etc/xdg/autostart/at-spi-dbus-bus.desktop/AT-SPI D-Bus Bus//etc/xdg/autostart/at-spi-dbus-bus 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:10:28 信息:startmanager.go:653: send openapp message, app info /etc/xdg/autostart/pulseaudio.desktop/PulseAudio 声音系统//etc/xdg/autostart/pulseaudio 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:10:28 信息:startmanager.go:653: send openapp message, app info /etc/xdg/autostart/dde-preload.desktop/dde-preload//etc/xdg/autostart/dde-preload 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:10:28 信息:startmanager.go:653: send openapp message, app info /etc/xdg/autostart/dde-clipboard.desktop/dde-clipboard//etc/xdg/autostart/dde-clipboard 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:10:28 信息:startmanager.go:653: send openapp message, app info /etc/xdg/autostart/com.deepin.deepinid.desktop/com.deepin.deepinid//etc/xdg/autostart/com.deepin.deepinid 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:10:28 信息:startmanager.go:653: send openapp message, app info /etc/xdg/autostart/deepin-ab-recovery.desktop/AbRecovery//etc/xdg/autostart/deepin-ab-recovery 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:10:28 信息:startmanager.go:653: send closeapp message, app info /etc/xdg/autostart/xdg-user-dirs.desktop/User folders update//etc/xdg/autostart/xdg-user-dirs 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:10:28 信息:startmanager.go:653: send openapp message, app info /etc/xdg/autostart/dde-printer-watch.desktop/打印管理器助手//etc/xdg/autostart/dde-printer-watch 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:10:28 信息:startmanager.go:653: send openapp message, app info /etc/xdg/autostart/im-launch.desktop/im-launch//etc/xdg/autostart/im-launch 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:10:28 信息:startmanager.go:653: send openapp message, app info /etc/xdg/autostart/at-spi-dbus-bus.desktop/AT-SPI D-Bus Bus//etc/xdg/autostart/at-spi-dbus-bus 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:10:28 信息:startmanager.go:653: send openapp message, app info /etc/xdg/autostart/xdg-user-dirs.desktop/User folders update//etc/xdg/autostart/xdg-user-dirs 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:10:28 信息:main.go:314: iowait disabled 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:10:28 信息:session.go:950: send login message to ue module 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:10:28 信息:session_process.go:60: start dde-session-daemon part2 cost: 423.486134ms 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:loader.go:157: enable module grub-gfx done, cost 970.104µs 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:state_handler.go:272: device disconnected, type wireless, 50 => 60, reason[0] 设备状态改变 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:loader.go:149: enable module grub-gfx 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:loader.go:157: enable module lastore done, cost 80.655113ms 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:state_handler.go:272: device disconnected, type wireless, 110 => 30, reason[60] 激活连接操作正在等待执行 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:module.go:138: start network module cost 389.990011ms 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:module.go:43: start calendar module cost 11.394224ms 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:loader.go:149: enable module lastore 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:loader.go:157: enable module systeminfo done, cost 4.548626ms 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:info.go:156: d.info.CurrentSpeed : 2300 , d.info.CPUMaxMHz : 2300 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:loader.go:149: enable module systeminfo 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:loader.go:157: enable module miracast done, cost 575.223µs 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:loader.go:149: enable module miracast 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:loader.go:157: enable module calendar done, cost 3.644µs 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:loader.go:149: enable module calendar 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:loader.go:157: enable module mime done, cost 1.287546ms 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:loader.go:149: enable module mime 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:loader.go:157: enable module screenedge done, cost 1.957136ms 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:config.go:63: load bluetooth config file: /home/mub/.config/deepin/bluetooth.json 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:loader.go:149: enable module screenedge 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:loader.go:157: enable module bluetooth done, cost 1.61579ms 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:loader.go:149: enable module bluetooth 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:loader.go:157: enable module timedate done, cost 1.492054ms 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:loader.go:149: enable module timedate 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:loader.go:157: enable module housekeeping done, cost 246.46µs 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:loader.go:149: enable module housekeeping 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:28 信息:loader.go:157: enable module gesture done, cost 6.235327ms 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:loader.go:149: enable module gesture 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:loader.go:157: enable module inputdevices done, cost 86.402696ms 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:loader.go:149: enable module inputdevices 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:loader.go:157: enable module keybinding done, cost 166.200318ms 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:appearance.go:146: start appearance module cost 186.563884ms 主机名:mub-PC 进程号:3695 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:27 信息:[session uid=1000 pid=3602] Successfully activated service 'com.deepin.api.CursorHelper' 主机名:mub-PC 进程号:3602 级别:信息 进程:startdde 时间:2021-01-29 23:10:27 信息:manager_ifc.go:274: success to reset ColorTemperature 主机名:mub-PC 进程号:3590 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:27 信息:[session uid=1000 pid=3602] Activating service name='com.deepin.api.CursorHelper' requested by ':1.10' (uid=1000 pid=3695 comm="/usr/lib/deepin-daemon/dde-session-daemon ") 主机名:mub-PC 进程号:3602 级别:信息 进程:systemd 时间:2021-01-29 23:10:27 信息:Started DTK widget application launch booster. 主机名:mub-PC 进程号:3548 级别:信息 进程:startdde 时间:2021-01-29 23:10:27 信息:manager_ifc.go:256: success to stop redshift.service 主机名:mub-PC 进程号:3590 级别:信息 进程:systemd 时间:2021-01-29 23:10:27 信息:Starting Sound Service... 主机名:mub-PC 进程号:3548 级别:信息 进程:systemd 时间:2021-01-29 23:10:27 信息:Starting DTK widget application launch booster... 主机名:mub-PC 进程号:3548 级别:信息 进程:startdde 时间:2021-01-29 23:10:27 信息:manager_ifc.go:256: success to disable redshift.service 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:loader.go:149: enable module keybinding 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:loader.go:157: enable module clipboard done, cost 33.812354ms 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:manager_device.go:143: ignore virtual network interface which driver is unknown /org/freedesktop/NetworkManager/Devices/1 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:submodule.go:58: submodule LidSwitchHandler start 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:screensaver.go:205: SetTimeout to 900 0 false 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:submodule.go:58: submodule PowerSavePlan start 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:loader.go:149: enable module clipboard 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:loader.go:157: enable module service-trigger done, cost 4.166428ms 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:loader.go:149: enable module service-trigger 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:loader.go:157: enable module uadpagent done, cost 2.240224ms 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:loader.go:149: enable module uadpagent 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:loader.go:157: enable module power done, cost 12.135035ms 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:manager.go:208: LidIsPresent true 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:loader.go:149: enable module power 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:loader.go:157: enable module sessionwatcher done, cost 8.318452ms 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:loader.go:149: enable module sessionwatcher 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:loader.go:157: enable module screensaver done, cost 6.041321ms 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:module.go:129: Owner: :1.49 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:loader.go:149: enable module screensaver 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:loader.go:157: enable module appearance done, cost 5.225µs 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:loader.go:149: enable module appearance 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:loader.go:157: enable module audio done, cost 213.577µs 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:manager.go:169: initialize network 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:loader.go:149: enable module audio 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:loader.go:157: enable module network done, cost 1.815322ms 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:27 信息:loader.go:149: enable module network 主机名:mub-PC 进程号:3695 级别:信息 进程:systemd 时间:2021-01-29 23:10:27 信息:Reloading. 主机名:mub-PC 进程号:3548 级别:信息 进程:systemd 时间:2021-01-29 23:10:27 信息:Reloading. 主机名:mub-PC 进程号:3548 级别:信息 进程:startdde 时间:2021-01-29 23:10:27 信息:main.go:157: core components cost: 811.890444ms 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:10:27 信息:session_process.go:110: /usr/bin/dde-dock [-r] startup duration: 641.848648ms 主机名:mub-PC 进程号:3590 级别:信息 进程:systemd 时间:2021-01-29 23:10:27 信息:Started Virtual filesystem service - GNOME Online Accounts monitor. 主机名:mub-PC 进程号:3548 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:27 信息:[session uid=1000 pid=3602] Successfully activated service 'org.gtk.vfs.GoaVolumeMonitor' 主机名:mub-PC 进程号:3602 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:27 信息:[session uid=1000 pid=3602] Successfully activated service 'ca.desrt.dconf' 主机名:mub-PC 进程号:3602 级别:信息 进程:systemd 时间:2021-01-29 23:10:27 信息:Starting Virtual filesystem service - GNOME Online Accounts monitor... 主机名:mub-PC 进程号:3548 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:27 信息:[session uid=1000 pid=3602] Activating service name='ca.desrt.dconf' requested by ':1.21' (uid=1000 pid=3736 comm="/usr/bin/dde-dock -r ") 主机名:mub-PC 进程号:3602 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:27 信息:[session uid=1000 pid=3602] Activating via systemd: service name='org.gtk.vfs.GoaVolumeMonitor' unit='gvfs-goa-volume-monitor.service' requested by ':1.17' (uid=1000 pid=3699 comm="/usr/bin/dde-desktop ") 主机名:mub-PC 进程号:3602 级别:信息 进程:systemd 时间:2021-01-29 23:10:27 信息:Started Virtual filesystem service - Media Transfer Protocol monitor. 主机名:mub-PC 进程号:3548 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:27 信息:[session uid=1000 pid=3602] Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor' 主机名:mub-PC 进程号:3602 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:27 信息:[session uid=1000 pid=3602] Activated service 'com.deepin.daemon.Timedate' failed: Process com.deepin.daemon.Timedate exited with status 1 主机名:mub-PC 进程号:3602 级别:信息 进程:systemd 时间:2021-01-29 23:10:27 信息:Starting Virtual filesystem service - Media Transfer Protocol monitor... 主机名:mub-PC 进程号:3548 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:27 信息:[session uid=1000 pid=3602] Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service' requested by ':1.17' (uid=1000 pid=3699 comm="/usr/bin/dde-desktop ") 主机名:mub-PC 进程号:3602 级别:信息 进程:systemd 时间:2021-01-29 23:10:27 信息:Started Virtual filesystem service - digital camera monitor. 主机名:mub-PC 进程号:3548 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:27 信息:[session uid=1000 pid=3602] Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor' 主机名:mub-PC 进程号:3602 级别:信息 进程:systemd 时间:2021-01-29 23:10:27 信息:Starting Virtual filesystem service - digital camera monitor... 主机名:mub-PC 进程号:3548 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:27 信息:[session uid=1000 pid=3602] Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service' requested by ':1.17' (uid=1000 pid=3699 comm="/usr/bin/dde-desktop ") 主机名:mub-PC 进程号:3602 级别:信息 进程:systemd 时间:2021-01-29 23:10:27 信息:Started Virtual filesystem service - Apple File Conduit monitor. 主机名:mub-PC 进程号:3548 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:27 信息:[session uid=1000 pid=3602] Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor' 主机名:mub-PC 进程号:3602 级别:信息 进程:systemd 时间:2021-01-29 23:10:27 信息:Starting Virtual filesystem service - Apple File Conduit monitor... 主机名:mub-PC 进程号:3548 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:27 信息:[session uid=1000 pid=3602] Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service' requested by ':1.17' (uid=1000 pid=3699 comm="/usr/bin/dde-desktop ") 主机名:mub-PC 进程号:3602 级别:信息 进程:systemd 时间:2021-01-29 23:10:27 信息:Started Virtual filesystem service - disk device monitor. 主机名:mub-PC 进程号:3548 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:27 信息:[session uid=1000 pid=3602] Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor' 主机名:mub-PC 进程号:3602 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:27 信息:[session uid=1000 pid=3602] Activating service name='com.deepin.daemon.Timedate' requested by ':1.20' (uid=1000 pid=3736 comm="/usr/bin/dde-dock -r ") 主机名:mub-PC 进程号:3602 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:27 信息:[session uid=1000 pid=3602] Activated service 'com.deepin.daemon.Timedate' failed: Process com.deepin.daemon.Timedate exited with status 1 主机名:mub-PC 进程号:3602 级别:信息 进程:systemd 时间:2021-01-29 23:10:27 信息:Starting Virtual filesystem service - disk device monitor... 主机名:mub-PC 进程号:3548 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:27 信息:[session uid=1000 pid=3602] Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service' requested by ':1.17' (uid=1000 pid=3699 comm="/usr/bin/dde-desktop ") 主机名:mub-PC 进程号:3602 级别:信息 进程:systemd 时间:2021-01-29 23:10:27 信息:Started BAMF Application Matcher Framework. 主机名:mub-PC 进程号:3548 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:27 信息:[session uid=1000 pid=3602] Successfully activated service 'org.ayatana.bamf' 主机名:mub-PC 进程号:3602 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:27 信息:[session uid=1000 pid=3602] Activating service name='com.deepin.daemon.Timedate' requested by ':1.20' (uid=1000 pid=3736 comm="/usr/bin/dde-dock -r ") 主机名:mub-PC 进程号:3602 级别:信息 进程:systemd 时间:2021-01-29 23:10:27 信息:Starting BAMF Application Matcher Framework... 主机名:mub-PC 进程号:3548 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:27 信息:[session uid=1000 pid=3602] Activating via systemd: service name='org.ayatana.bamf' unit='bamfdaemon.service' requested by ':1.10' (uid=1000 pid=3695 comm="/usr/lib/deepin-daemon/dde-session-daemon ") 主机名:mub-PC 进程号:3602 级别:信息 进程:startdde 时间:2021-01-29 23:10:27 信息:main.go:200: after 583.019055ms, call com.deepin.dde.Dock callShow 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:10:27 信息:session_process.go:110: /usr/bin/kwin_no_scale [] startup duration: 429.750781ms 主机名:mub-PC 进程号:3590 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:27 信息:[session uid=1000 pid=3602] Successfully activated service 'org.kde.kglobalaccel' 主机名:mub-PC 进程号:3602 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:27 信息:[session uid=1000 pid=3602] Activating service name='org.kde.kglobalaccel' requested by ':1.15' (uid=1000 pid=3702 comm="kwin_x11 -platform dde-kwin-xcb:appFilePath=/usr/b") 主机名:mub-PC 进程号:3602 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:26 信息:[session uid=1000 pid=3602] Successfully activated service 'com.deepin.wm' 主机名:mub-PC 进程号:3602 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:26 信息:module.go:83: start launcher module cost 44.534646ms 主机名:mub-PC 进程号:3695 级别:信息 进程:startdde 时间:2021-01-29 23:10:26 信息:session_process.go:110: /usr/bin/dde-desktop [] startup duration: 187.815514ms 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:10:26 信息:session_process.go:91: command /usr/bin/dde-dock [-r] started, pid: 3736 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:10:26 信息:session_process.go:110: /usr/lib/deepin-daemon/dde-session-daemon [] startup duration: 168.994984ms 主机名:mub-PC 进程号:3590 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:26 信息:loader.go:157: enable module x-event-monitor done, cost 1.393774ms 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:26 信息:loader.go:149: enable module x-event-monitor 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:26 信息:loader.go:157: enable module launcher done, cost 5.085µs 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:26 信息:loader.go:149: enable module launcher 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:26 信息:loader.go:157: enable module trayicon done, cost 2.912075ms 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:26 信息:traymanager.go:373: Add tray icon 4194321 name: "[fcitx|fcitx]" 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:26 信息:loader.go:149: enable module trayicon 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:26 信息:loader.go:157: enable module dock done, cost 18.191091ms 主机名:mub-PC 进程号:3695 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:26 信息:[session uid=1000 pid=3602] Activating service name='com.deepin.wm' requested by ':1.15' (uid=1000 pid=3702 comm="kwin_x11 -platform dde-kwin-xcb:appFilePath=/usr/b") 主机名:mub-PC 进程号:3602 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:26 信息:loader.go:149: enable module dock 主机名:mub-PC 进程号:3695 级别:信息 进程:dde-session-dae 时间:2021-01-29 23:10:26 信息:main.go:136: App log level: 5 主机名:mub-PC 进程号:3695 级别:信息 进程:systemd 时间:2021-01-29 23:10:26 信息:Started Accessibility services bus. 主机名:mub-PC 进程号:3548 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:26 信息:[session uid=1000 pid=3602] Successfully activated service 'org.a11y.Bus' 主机名:mub-PC 进程号:3602 级别:信息 进程:systemd 时间:2021-01-29 23:10:26 信息:Starting Accessibility services bus... 主机名:mub-PC 进程号:3548 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:26 信息:[session uid=1000 pid=3602] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.12' (uid=1000 pid=3695 comm="/usr/lib/deepin-daemon/dde-session-daemon ") 主机名:mub-PC 进程号:3602 级别:信息 进程:startdde 时间:2021-01-29 23:10:26 信息:session_process.go:91: command /usr/bin/dde-desktop [] started, pid: 3699 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:10:26 信息:session_process.go:91: command /usr/lib/deepin-daemon/dde-session-daemon [] started, pid: 3695 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:10:26 信息:session_process.go:91: command /usr/bin/kwin_no_scale [] started, pid: 3694 主机名:mub-PC 进程号:3590 级别:信息 进程:startdde 时间:2021-01-29 23:10:26 信息:handle_event.go:191: redo map touch screen 主机名:mub-PC 进程号:3590 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:26 信息:[session uid=1000 pid=3602] Activated service 'org.freedesktop.Notifications' failed: Process org.freedesktop.Notifications exited with status 255 主机名:mub-PC 进程号:3602 级别:信息 进程:systemd 时间:2021-01-29 23:10:26 信息:Started Virtual filesystem service. 主机名:mub-PC 进程号:3548 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:26 信息:[session uid=1000 pid=3602] Successfully activated service 'org.gtk.vfs.Daemon' 主机名:mub-PC 进程号:3602 级别:信息 进程:systemd 时间:2021-01-29 23:10:26 信息:Starting Virtual filesystem service... 主机名:mub-PC 进程号:3548 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:26 信息:[session uid=1000 pid=3602] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.6' (uid=1000 pid=3590 comm="/usr/bin/startdde ") 主机名:mub-PC 进程号:3602 级别:信息 进程:dbus-daemon 时间:2021-01-29 23:10:26 信息:[session uid=1000 pid=3602] Activating service name='org.freedesktop.Notifications' requested by ':1.4' (uid=1000 pid=3655 comm="/usr/bin/fcitx -d ") 主机名:mub-PC 进程号:3602 级别:信息 进程:systemd 时间:2021-01-29 23:10:26 信息:Started D-Bus User Message Bus. 主机名:mub-PC 进程号:3548 级别:信息 进程:systemd 时间:2021-01-29 23:10:26 信息:Startup finished in 97ms. 主机名:mub-PC 进程号:3548 级别:信息 进程:systemd 时间:2021-01-29 23:10:26 信息:Reached target Default. 主机名:mub-PC 进程号:3548 级别:信息 进程:systemd 时间:2021-01-29 23:10:26 信息:Reached target Basic System. 主机名:mub-PC 进程号:3548 级别:信息 进程:systemd 时间:2021-01-29 23:10:26 信息:Reached target Sockets. 主机名:mub-PC 进程号:3548 级别:信息 进程:systemd 时间:2021-01-29 23:10:26 信息:Listening on D-Bus User Message Bus Socket. 主机名:mub-PC 进程号:3548 级别:信息 进程:systemd 时间:2021-01-29 23:10:26 信息:Listening on GnuPG cryptographic agent and passphrase cache (restricted). 主机名:mub-PC 进程号:3548 级别:信息 进程:systemd 时间:2021-01-29 23:10:26 信息:Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers). 主机名:mub-PC 进程号:3548 级别:信息 进程:systemd 时间:2021-01-29 23:10:26 信息:Listening on GnuPG cryptographic agent (ssh-agent emulation). 主机名:mub-PC 进程号:3548 级别:信息 进程:systemd 时间:2021-01-29 23:10:26 信息:Listening on Sound System. 主机名:mub-PC 进程号:3548 级别:信息 进程:systemd 时间:2021-01-29 23:10:26 信息:Listening on GnuPG network certificate management daemon. 主机名:mub-PC 进程号:3548 级别:信息 进程:systemd 时间:2021-01-29 23:10:26 信息:Starting D-Bus User Message Bus Socket. 主机名:mub-PC 进程号:3548 级别:信息 进程:systemd 时间:2021-01-29 23:10:26 信息:Reached target Paths. 主机名:mub-PC 进程号:3548 级别:信息 进程:systemd 时间:2021-01-29 23:10:26 信息:Reached target Timers. 主机名:mub-PC 进程号:3548 级别:信息 进程:systemd 时间:2021-01-29 23:10:26 信息:Listening on GnuPG cryptographic agent and passphrase cache. 主机名:mub-PC 进程号:3548
