[概况] ------------------------------------------------- 设备: Apple Inc. MacBookPro8,1 (System SKU#) Notebook 操作系统: Deepin 20.2 Linux version 5.10.18-amd64-desktop (deepin@deepin-PC) (gcc (Uos 8.3.0.3-3+rebuild) 8.3.0, GNU ld (GNU Binutils for Uos) 2.31.1) #1 SMP Mon Mar 1 17:09:41 CST 2021 处理器: Intel(R) Core(TM) i5-2435M CPU @ 2.40GHz (核 / 逻辑处理器) CPU数量: 4 主板: Mac-94245B3640C91C81 内存: 2GB(0x384A53463235363634485A2D314734443120 DDR3 1333MHz (0.8ns))/2GB(8JSF25664HZ-1G4D1 1333MHz (0.8ns)) 显示适配器: 2nd Generation Core Processor Family Integrated Graphics Controller 音频适配器: 6 Series/C200 Series Chipset Family High Definition Audio Controller 存储设备: ST9500325ASG (500 GB) 电池: 电池 网络适配器: NetXtreme BCM57765 Gigabit Ethernet PCIe/BCM4331 802.11a/b/g/n 鼠标: Apple Inc. Apple Internal Keyboard / Trackpad (Apple Internal Keyboard/Trackpad (ANSI))/2.4G Mouse (SHARKOON [Mediatrack Edge Mini Keyboard]) 键盘: 2.4G Mouse (SHARKOON [Mediatrack Edge Mini Keyboard])/Apple Inc. Apple Internal Keyboard / Trackpad (Apple Internal Keyboard/Trackpad (ANSI)) 显示设备: Apple Color LCD(13.3 英寸 (286x178 mm)) 光驱: DVD-R UJ-8A8 图像设备: FaceTime HD Camera (Apple FaceTime HD Camera) 其他设备: Bluetooth Host Controller/Built-in IR Receiver [处理器] ------------------------------------------------- 名称 制造商 频率 架构 Intel(R) Core(TM) i5-2435M CPU @ 2.40GHz Intel(R) Corporation 0.8-3 GHz x86_64 Intel(R) Core(TM) i5-2435M CPU @ 2.40GHz Intel(R) Corporation 0.8-3 GHz x86_64 Intel(R) Core(TM) i5-2435M CPU @ 2.40GHz Intel(R) Corporation 0.8-3 GHz x86_64 Intel(R) Core(TM) i5-2435M CPU @ 2.40GHz Intel(R) Corporation 0.8-3 GHz x86_64 逻辑处理器 0 名称: Intel(R) Core(TM) i5-2435M CPU @ 2.40GHz 制造商: Intel(R) Corporation 处理器ID: 0 核心ID: 0 线程数: 2 当前频率: 2423 MHz BogoMIPS: 4789.53 架构: x86_64 型号: 42 步进: 7 L1缓存(数据): 32K L1缓存(指令): 32K L2缓存: 256K L3缓存: 3072K 扩展指令集: MMX SSE SSE2 SSE3 SSE4 SSSE3 SSE4_1 SSE4_2 特性: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ht tm pbe syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer aes xsave avx lahf_lm pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid xsaveopt dtherm ida arat pln pts md_clear flush_l1d 虚拟化: VT-x 逻辑处理器 1 名称: Intel(R) Core(TM) i5-2435M CPU @ 2.40GHz 制造商: Intel(R) Corporation 处理器ID: 1 核心ID: 1 线程数: 2 当前频率: 2423 MHz BogoMIPS: 4789.53 架构: x86_64 型号: 42 步进: 7 L1缓存(数据): 32K L1缓存(指令): 32K L2缓存: 256K L3缓存: 3072K 扩展指令集: MMX SSE SSE2 SSE3 SSE4 SSSE3 SSE4_1 SSE4_2 特性: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ht tm pbe syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer aes xsave avx lahf_lm pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid xsaveopt dtherm ida arat pln pts md_clear flush_l1d 虚拟化: VT-x 逻辑处理器 2 名称: Intel(R) Core(TM) i5-2435M CPU @ 2.40GHz 制造商: Intel(R) Corporation 处理器ID: 2 核心ID: 0 线程数: 2 当前频率: 2423 MHz BogoMIPS: 4789.53 架构: x86_64 型号: 42 步进: 7 L1缓存(数据): 32K L1缓存(指令): 32K L2缓存: 256K L3缓存: 3072K 扩展指令集: MMX SSE SSE2 SSE3 SSE4 SSSE3 SSE4_1 SSE4_2 特性: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ht tm pbe syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer aes xsave avx lahf_lm pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid xsaveopt dtherm ida arat pln pts md_clear flush_l1d 虚拟化: VT-x 逻辑处理器 3 名称: Intel(R) Core(TM) i5-2435M CPU @ 2.40GHz 制造商: Intel(R) Corporation 处理器ID: 3 核心ID: 1 线程数: 2 当前频率: 2423 MHz BogoMIPS: 4789.53 架构: x86_64 型号: 42 步进: 7 L1缓存(数据): 32K L1缓存(指令): 32K L2缓存: 256K L3缓存: 3072K 扩展指令集: MMX SSE SSE2 SSE3 SSE4 SSSE3 SSE4_1 SSE4_2 特性: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ht tm pbe syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer aes xsave avx lahf_lm pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid xsaveopt dtherm ida arat pln pts md_clear flush_l1d 虚拟化: VT-x [主板] ------------------------------------------------- BIOS信息 制造商: Apple Inc. 版本: MBP81.88Z.004D.B00.1708080655 BIOS修订版本: 0.1 ROM大小: 8192 kB 发布日期: 08/08/17 特性: PCI is supported / BIOS is upgradeable / BIOS shadowing is allowed / Boot from CD is supported / Selectable boot is supported / ACPI is supported / IEEE 1394 boot is supported / Smart battery is supported / Function key-initiated network boot is supported / 系统信息 制造商: Apple Inc. 版本: 1.0 SKU号: System SKU# UUID: 4a03f31b-8e51-645d-9211-548c2715e51f 产品名称: MacBookPro8,1 唤醒类型: Power Switch 家族: MacBook Pro 序列号: C2WGLUD9DV13 主板信息 制造商: Apple Inc. 版本: MacBookPro8,1 芯片组: Intel Corporation Apple MacBookPro8,2 [Core i7, 15", 2011] SMBIOS版本: 2.4 产品名称: Mac-94245B3640C91C81 包含对象程序: 0 序列号: C02139302CXDTMYAW 机箱内位置: Part Component 机箱程序: 0x001D 特征: Board is a hosting board / Board is replaceable / 类型: Motherboard 资产编号: Base Board Asset Tag# 内存插槽信息 位置: System Board Or Motherboard 卡槽数量: 2 最大容量: 8 GB [内存] ------------------------------------------------- 名称 制造商 类型 速度 大小 0x384A53463235363634485A2D314734443120 Micron Technology DDR3 1333MHz (0.8ns) 2GB 8JSF25664HZ-1G4D1 Micron Technology 1333MHz (0.8ns) 2GB Micron Technology 0x384A53463235363634485A2D314734443120 名称: 0x384A53463235363634485A2D314734443120 制造商: Micron Technology 大小: 2GB 类型: DDR3 速度: 1333MHz (0.8ns) 插槽: DIMM0 序列号: 0x34411826 内存通道: BANK 1 尺寸型号: SODIMM 数组程序: 0x0014 类型详情: Synchronous 部件号码: 0x384A53463235363634485A2D314734443120 错误信息程序: No Error Micron Technology 8JSF25664HZ-1G4D1 名称: 8JSF25664HZ-1G4D1 制造商: Micron Technology 大小: 2GB 速度: 1333MHz (0.8ns) 插槽: DIMM0 序列号: 0x34411826 [存储设备] ------------------------------------------------- 型号: ST9500325ASG 制造商: ST 介质类型: 机械 大小: 500 GB 版本: APM1 功能: partitioned partitioned:dos 转速: 5400 rpm 接口: SATA 序列号: 5VELWA92 描述: ATA Disk 固件版本: 0009APM1 通电时间: 5986 通电次数: 3080 ANSI版本: 5 几何数据(逻辑): CHS 60801/255/63 总线信息: scsi@0:0.0.0 扇区大小: 512 物理ID: 0 硬件类别: disk 设备文件: /dev/sda, /dev/disk/by-id/wwn-0x5000c500442fc14c, /dev/disk/by-path/pci-0000:00:1f.2-ata-1, /dev/disk/by-id/ata-ST9500325ASG_5VELWA92 设备编号: block 8:0-8:15 逻辑分区大小: 512 逻辑地址: /dev/sda [显示适配器] ------------------------------------------------- 名称: 2nd Generation Core Processor Family Integrated Graphics Controller 制造商: Intel Corporation 型号: Intel 2nd Generation Core Processor Family Integrated Graphics Controller 版本: 09 位宽: 64 bits 中断: 33 功能: msi pm vga_controller bus_master cap_list rom DVI: Unable VGA: Unable HDMI: Unable eDP: Unable DP: Unable 时钟频率: 33MHz 描述: VGA compatible controller 驱动: i915 总线信息: pci@0000:00:02.0 I/O端口: 2000(size=64) 内存: a0000000-a03fffff 90000000-9fffffff c0000-dffff 物理ID: 2 子制造商: Apple Inc. 子设备: pci 0x00db 延迟: 0 设备: 2nd Generation Core Processor Family Integrated Graphics Controller 驱动模块: i915 [显示设备] ------------------------------------------------- 名称: Apple Color LCD 制造商: Apple 类型: Apple Color LCD 生产日期: 2010-03 大小: 13.3 英寸 (286x178 mm) 显示比例: 8 : 5 当前分辨率: 1280x800 支持分辨率: 1280x800@60Hz [网络适配器] ------------------------------------------------- 名称 制造商 型号 NetXtreme BCM57765 Gigabit Ethernet PCIeBroadcom Inc. and subsidiaries Ethernet interface (禁用) BCM4331 802.11a/b/g/nBroadcom Inc. and subsidiaries Wireless interface NetXtreme BCM57765 Gigabit Ethernet PCIe 名称: NetXtreme BCM57765 Gigabit Ethernet PCIe 制造商: Broadcom Inc. and subsidiaries 类型: Ethernet interface 版本: 10 总线信息: pci@0000:02:00.0 功能: pm msi msix pciexpress bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation 驱动: tg3 驱动版本: 5.10.18-amd64-desktop 逻辑名称: enp2s0f0 物理地址: 3c:07:54:35:94:cd 中断: 16 内存: a0400000-a040ffff a0410000-a041ffff 位宽: 64 bits 时钟频率: 33MHz 自动协商: on 广播: yes 固件: 57765-v1.37 延迟: 0 连接: no 组播: yes 端口: twisted 容量: 1Gbit/s 物理ID: 0 BCM4331 802.11a/b/g/n 名称: BCM4331 802.11a/b/g/n 制造商: Broadcom Inc. and subsidiaries 类型: Wireless interface 版本: 02 总线信息: pci@0000:03:00.0 功能: pm msi pciexpress bus_master cap_list ethernet physical wireless 驱动: wl0 驱动版本: 6.30.223.271 逻辑名称: wlp3s0 物理地址: b8:8d:12:3a:1d:8c 中断: 17 内存: a0600000-a0603fff 位宽: 64 bits 时钟频率: 33MHz 广播: yes 延迟: 0 组播: yes 物理ID: 0 [音频适配器] ------------------------------------------------- 名称: 6 Series/C200 Series Chipset Family High Definition Audio Controller 制造商: Intel Corporation 型号: Intel Apple MacBookPro8,2 [Core i7, 15", 2011] 版本: 05 总线信息: pci@0000:00:1b.0 中断: 35 (416 events) 内存: 0xa0900000-0xa0903fff (rw,non-prefetchable) 位宽: 64 bits 时钟频率: 33MHz 功能: pm msi pciexpress bus_master cap_list 芯片: CS4206 制造商: Intel Corporation 型号: Intel Apple MacBookPro8,2 [Core i7, 15", 2011] 子制造商: Intel Corporation 子设备: Apple MacBookPro8,2 [Core i7, 15", 2011] 延迟: 0 物理ID: 1b 驱动: snd_hda_intel 驱动激活命令: modprobe snd_hda_intel 驱动状态: snd_hda_intel is active [蓝牙] ------------------------------------------------- 驱动: btusb ACL MTU: 1021:8 SCO MTU: 64:1 总线: USB 数据包类型: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3 特征: 0xff 0xff 0xcf 0xfe 0x9b 0xff 0x79 0x83 蓝牙设备地址: B8:8D:12:3A:1D:8D 连接模式: SLAVE ACCEPT 连接策略: RSWITCH HOLD SNIFF PARK [其他PCI设备] ------------------------------------------------- 未发现其他PCI设备 [电池] ------------------------------------------------- 名称: 电池 容量: 88.4749% 电压: 11.18 V 温度: 201 degrees C Daemon版本: 0.99.10 使用电池: yes 供电: yes 历史记录: yes 可再充电: yes 图标: 'battery-full-symbolic' 安装路径: BAT0 完全充满容量: 55.8998 Wh 容量: 44.8402 Wh 打开笔记本盖子: yes 更新时间: 2021年04月12日 星期一 18时41分12秒 (0 seconds ago) 最低容量: 0 Wh 状态: discharging 用电统计: yes 电压: 11.18 V 电池技术: lithium-ion 电量: 71% 电量极低时执行: HybridSleep 笔记本合盖: no 能量密度: 24.09 W 设计容量: 63.1815 Wh [键盘] ------------------------------------------------- 名称 制造商 型号 2.4G Mouse SHARKOON Technologies GmbHSHARKOON [Mediatrack Edge Mini Keyboard] Apple Inc. Apple Internal Keyboard / Trackpad Apple Inc.Apple Internal Keyboard/Trackpad (ANSI) 2.4G Mouse 名称: 2.4G Mouse 制造商: SHARKOON Technologies GmbH 型号: SHARKOON [Mediatrack Edge Mini Keyboard] 接口: USB 总线信息: usb@2:1.2 版本: 2.00 功能: usb-1.10 驱动: usbhid 最大功率: 100mA 频率: 12Mbit/s 物理ID: 2 硬件类别: keyboard 设备文件: /dev/input/event6, /dev/input/by-id/usb-1ea7_2.4G_Mouse-event-kbd, /dev/input/by-path/pci-0000:00:1d.7-usb-0:1.2:1.0-event-kbd Apple Inc. Apple Internal Keyboard / Trackpad 名称: Apple Inc. Apple Internal Keyboard / Trackpad 制造商: Apple Inc. 型号: Apple Internal Keyboard/Trackpad (ANSI) 接口: USB 总线信息: usb@1:1.2 版本: 1.18 功能: usb-2.00 驱动: usbmouse 最大功率: 40mA 频率: 12Mbit/s 物理ID: 2 硬件类别: keyboard 设备文件: /dev/input/event10, /dev/input/by-id/usb-Apple_Inc._Apple_Internal_Keyboard___Trackpad-event-kbd, /dev/input/by-path/pci-0000:00:1a.7-usb-0:1.2:1.0-event-kbd [鼠标] ------------------------------------------------- 名称 制造商 型号 Apple Inc. Apple Internal Keyboard / Trackpad Apple Inc.Apple Internal Keyboard/Trackpad (ANSI) 2.4G Mouse SHARKOON Technologies GmbHSHARKOON [Mediatrack Edge Mini Keyboard] Apple Inc. Apple Internal Keyboard / Trackpad 名称: Apple Inc. Apple Internal Keyboard / Trackpad 制造商: Apple Inc. 型号: Apple Internal Keyboard/Trackpad (ANSI) 接口: USB 总线信息: usb@1:1.2 版本: 1.18 功能: usb-2.00 驱动: usbmouse 最大功率: 40mA 频率: 12Mbit/s 物理ID: 2 硬件类别: mouse 设备文件: /dev/input/mice, /dev/input/mouse1, /dev/input/event12, /dev/input/by-id/usb-Apple_Inc._Apple_Internal_Keyboard___Trackpad-if02-event-mouse, /dev/input/by-path/pci-0000:00:1a.7-usb-0:1.2:1.2-event-mouse, /dev/input/by-id/usb-Apple_Inc._Apple_Internal_Keyboard___Trackpad-if02-mouse, /dev/input/by-path/pci-0000:00:1a.7-usb-0:1.2:1.2-mouse 2.4G Mouse 名称: 2.4G Mouse 制造商: SHARKOON Technologies GmbH 型号: SHARKOON [Mediatrack Edge Mini Keyboard] 接口: USB 总线信息: usb@2:1.2 版本: 2.00 功能: usb-1.10 驱动: usbhid 最大功率: 100mA 频率: 12Mbit/s 物理ID: 2 硬件类别: mouse 设备文件: /dev/input/mice, /dev/input/mouse0, /dev/input/event8, /dev/input/by-path/pci-0000:00:1d.7-usb-0:1.2:1.1-event-mouse, /dev/input/by-id/usb-1ea7_2.4G_Mouse-if01-event-mouse, /dev/input/by-id/usb-1ea7_2.4G_Mouse-if01-mouse, /dev/input/by-path/pci-0000:00:1d.7-usb-0:1.2:1.1-mouse [打印机] ------------------------------------------------- 未发现打印机 [图像设备] ------------------------------------------------- 名称: FaceTime HD Camera 制造商: Apple Inc. 版本: 5.16 型号: Apple FaceTime HD Camera 总线信息: usb@1:2 功能: usb-2.00 驱动: uvcvideo 最大功率: 500mA 速度: 480Mbit/s [光驱] ------------------------------------------------- 名称: DVD-R UJ-8A8 制造商: MATSHITA 型号: MATSHITA DVD-R UJ-8A8 版本: HB14 总线信息: 1:0:0:0 功能: removable audio cd-r cd-rw dvd dvd-r 驱动: ahci, sr ANSI版本: 5 物理ID: 1 状态: open 设备文件: /dev/sr0, /dev/dvd, /dev/cdrom, /dev/disk/by-path/pci-0000:00:1f.2-ata-2, /dev/dvdrw, /dev/disk/by-id/ata-MATSHITADVD-R_UJ-8A8_D0213720FVWDTL7A1, /dev/cdrw 设备编号: block 11:0 (char 21:1) 逻辑地址: /dev/sr0 驱动模块: ahci [其他设备] ------------------------------------------------- 名称 制造商 型号 Bluetooth Host Controller Apple, Inc.Apple Bluetooth Host Controller Built-in IR Receiver Apple, Inc. Apple Built-in IR Receiver Apple Bluetooth Host Controller 名称: Bluetooth Host Controller 制造商: Apple, Inc. 型号: Apple Bluetooth Host Controller 版本: 0.42 总线信息: usb@1:1.1.3 功能: usb-2.00 bluetooth 驱动: btusb 速度: 12Mbit/s Apple Built-in IR Receiver 名称: Built-in IR Receiver 制造商: Apple, Inc. 型号: Apple Built-in IR Receiver 版本: 0.16 总线信息: usb@2:1.1 功能: usb-2.00 驱动: usbhid 最大功率: 100mA 速度: 2Mbit/s
