[2026-05-24 01:46:30][info] start screen manager... dconfig_resource_path= /org_deepin_installer/org_deepin_installer/0 restartMonitor=method return time=1779558390.355700 sender=:1.23 -> destination=:1.43 serial=187 reply_serial=2 variant boolean false SHELL=/bin/sh DI_INSTALL_MODULE_DIR_ENV=/usr/lib/deepin-installer/modules DI_HOME_DIR_ENV=/usr/share/deepin-installer DI_TARGET_LIVE_DIR_ENV=/media/live/mount/medium DI_SRC_DIR_ENV=/usr/share/deepin-installer/src DI_REPO_BASE_NAME_ENV=beige/develop/25.35/base DI_MODULE_DIR_ENV=/usr/share/deepin-installer/modules XDG_SEAT=seat0 PWD=/ XAUTHORITY=/var/run/lightdm/root/:0 DI_OEM_DIR=/usr/lib/live/mount/medium//oem/ DI_INSTALL_DIR_ENV=/usr/share/deepin-installer HOME=/root DI_OS_VERSION_ENV=V25 XDG_CURRENT_DESKTOP=Deepin DI_LIVE_DIR_ENV=/usr/lib/live/mount/medium/ DI_INSTALL_TOOLS_DIR_ENV=/usr/share/deepin-installer/tools DI_TOOLS_DIR_ENV=/usr/share/deepin-installer/tools DI_HOME_BIN_ENV=/usr/bin/ DISPLAY=:0 SHLVL=1 PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin DI_CONFIG_FILE_ENV=/etc/deepin-installer/deepin-installer.conf DI_CONFIG_DIR_ENV=/usr/share/deepin-installer/configs _=/usr/bin/env [2026-05-24 01:46:30][info] disable screen saver done. kwin_logger: Setting logging rules: ""
