# CMAKE generated file: DO NOT EDIT!
# Generated by "Unix Makefiles" Generator, CMake Version 3.31
# Default target executed when no arguments are given to make.
default_target: all
.PHONY : default_target
# Allow only one "make -f Makefile2" at a time, but pass parallelism.
.NOTPARALLEL:
# Special targets provided by cmake.
# Disable implicit rules so canonical targets will work.
.SUFFIXES:
# Disable VCS-based implicit rules.
% : %,v
% : RCS/%
% : RCS/%,v
% : SCCS/s.%
% : s.%
.SUFFIXES: .hpux_make_needs_suffix_list
# Command-line flag to silence nested $(MAKE).
$(VERBOSE)MAKESILENT = -s
#Suppress display of executed commands.
$(VERBOSE).SILENT:
# A target that is always out of date.
cmake_force:
.PHONY : cmake_force
# Set environment variables for the build.
# The shell in which to execute make rules.
SHELL = /bin/sh
# The CMake executable.
CMAKE_COMMAND = /usr/bin/cmake
# The command to remove a file.
RM = /usr/bin/cmake -E rm -f
# Escaping for special characters.
EQUALS = =
# The top-level source directory on which CMake was run.
CMAKE_SOURCE_DIR = /home/gisadmin/Desktop/deepin-anything-7.0.38/src/deepin-anything-gui-qt
# The top-level build directory on which CMake was run.
CMAKE_BINARY_DIR = /home/gisadmin/Desktop/deepin-anything-7.0.38/src/deepin-anything-gui-qt/build
# Targets provided globally by CMake.
# Special rule for the target edit_cache
edit_cache:
	@$(CMAKE_COMMAND) -E cmake_echo_color "--switch=$(COLOR)" --cyan "No interactive CMake dialog available..."
	/usr/bin/cmake -E echo No\ interactive\ CMake\ dialog\ available.
.PHONY : edit_cache
edit_cache/fast: edit_cache
.PHONY : edit_cache/fast
# Special rule for the target rebuild_cache
rebuild_cache:
	@$(CMAKE_COMMAND) -E cmake_echo_color "--switch=$(COLOR)" --cyan "Running CMake to regenerate build system..."
	/usr/bin/cmake --regenerate-during-build -S$(CMAKE_SOURCE_DIR) -B$(CMAKE_BINARY_DIR)
.PHONY : rebuild_cache
rebuild_cache/fast: rebuild_cache
.PHONY : rebuild_cache/fast
# The main all target
all: cmake_check_build_system
	$(CMAKE_COMMAND) -E cmake_progress_start /home/gisadmin/Desktop/deepin-anything-7.0.38/src/deepin-anything-gui-qt/build/CMakeFiles /home/gisadmin/Desktop/deepin-anything-7.0.38/src/deepin-anything-gui-qt/build//CMakeFiles/progress.marks
	$(MAKE) $(MAKESILENT) -f CMakeFiles/Makefile2 all
	$(CMAKE_COMMAND) -E cmake_progress_start /home/gisadmin/Desktop/deepin-anything-7.0.38/src/deepin-anything-gui-qt/build/CMakeFiles 0
.PHONY : all
# The main clean target
clean:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/Makefile2 clean
.PHONY : clean
clean/fast: clean
.PHONY : clean/fast
# Prepare targets for installation.
preinstall: all
	$(MAKE) $(MAKESILENT) -f CMakeFiles/Makefile2 preinstall
.PHONY : preinstall
preinstall/fast:
.PHONY : preinstall/fast
# clear depends
depend:
	$(CMAKE_COMMAND) -S$(CMAKE_SOURCE_DIR) -B$(CMAKE_BINARY_DIR) --check-build-system CMakeFiles/Makefile.cmake 1
.PHONY : depend
# Target rules for targets named deepin-anything-gui-qt
# Build rule for target.
deepin-anything-gui-qt: cmake_check_build_system
	$(MAKE) $(MAKESILENT) -f CMakeFiles/Makefile2 deepin-anything-gui-qt
.PHONY : deepin-anything-gui-qt
# fast build rule for target.
deepin-anything-gui-qt/fast:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/deepin-anything-gui-qt.dir/build.make CMakeFiles/deepin-anything-gui-qt.dir/build
.PHONY : deepin-anything-gui-qt/fast
# Target rules for targets named deepin-anything-gui-qt_autogen_timestamp_deps
deepin-anything-gui-qt_autogen_timestamp_deps: cmake_check_build_system
	$(MAKE) $(MAKESILENT) -f CMakeFiles/Makefile2 deepin-anything-gui-qt_autogen_timestamp_deps
.PHONY : deepin-anything-gui-qt_autogen_timestamp_deps
deepin-anything-gui-qt_autogen_timestamp_deps/fast:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/deepin-anything-gui-qt_autogen_timestamp_deps.dir/build.make CMakeFiles/deepin-anything-gui-qt_autogen_timestamp_deps.dir/build
.PHONY : deepin-anything-gui-qt_autogen_timestamp_deps/fast
deepin-anything-gui-qt_autogen: cmake_check_build_system
deepin-anything-gui-qt_autogen/fast:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/deepin-anything-gui-qt_autogen.dir/build.make CMakeFiles/deepin-anything-gui-qt_autogen.dir/build
.PHONY : deepin-anything-gui-qt_autogen/fast
deepin-anything-gui-qt_autogen/mocs_compilation.o: deepin-anything-gui-qt_autogen/mocs_compilation.cpp.o
.PHONY : deepin-anything-gui-qt_autogen/mocs_compilation.o
# target to build an object file
deepin-anything-gui-qt_autogen/mocs_compilation.cpp.o:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/deepin-anything-gui-qt.dir/build.make CMakeFiles/deepin-anything-gui-qt.dir/deepin-anything-gui-qt_autogen/mocs_compilation.cpp.o
.PHONY : deepin-anything-gui-qt_autogen/mocs_compilation.cpp.o
deepin-anything-gui-qt_autogen/mocs_compilation.i: deepin-anything-gui-qt_autogen/mocs_compilation.cpp.i
.PHONY : deepin-anything-gui-qt_autogen/mocs_compilation.i
# target to preprocess a source file
deepin-anything-gui-qt_autogen/mocs_compilation.cpp.i:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/deepin-anything-gui-qt.dir/build.make CMakeFiles/deepin-anything-gui-qt.dir/deepin-anything-gui-qt_autogen/mocs_compilation.cpp.i
.PHONY : deepin-anything-gui-qt_autogen/mocs_compilation.cpp.i
deepin-anything-gui-qt_autogen/mocs_compilation.s: deepin-anything-gui-qt_autogen/mocs_compilation.cpp.s
.PHONY : deepin-anything-gui-qt_autogen/mocs_compilation.s
# target to generate assembly for a file
deepin-anything-gui-qt_autogen/mocs_compilation.cpp.s:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/deepin-anything-gui-qt.dir/build.make CMakeFiles/deepin-anything-gui-qt.dir/deepin-anything-gui-qt_autogen/mocs_compilation.cpp.s
.PHONY : deepin-anything-gui-qt_autogen/mocs_compilation.cpp.s
main.o: main.cpp.o
.PHONY : main.o
main.cpp.o:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/deepin-anything-gui-qt.dir/build.make CMakeFiles/deepin-anything-gui-qt.dir/main.cpp.o
.PHONY : main.cpp.o
main.i: main.cpp.i
.PHONY : main.i
main.cpp.i:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/deepin-anything-gui-qt.dir/build.make CMakeFiles/deepin-anything-gui-qt.dir/main.cpp.i
.PHONY : main.cpp.i
main.s: main.cpp.s
.PHONY : main.s
main.cpp.s:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/deepin-anything-gui-qt.dir/build.make CMakeFiles/deepin-anything-gui-qt.dir/main.cpp.s
.PHONY : main.cpp.s
mainwindow.o: mainwindow.cpp.o
.PHONY : mainwindow.o
mainwindow.cpp.o:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/deepin-anything-gui-qt.dir/build.make CMakeFiles/deepin-anything-gui-qt.dir/mainwindow.cpp.o
.PHONY : mainwindow.cpp.o
mainwindow.i: mainwindow.cpp.i
.PHONY : mainwindow.i
mainwindow.cpp.i:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/deepin-anything-gui-qt.dir/build.make CMakeFiles/deepin-anything-gui-qt.dir/mainwindow.cpp.i
.PHONY : mainwindow.cpp.i
mainwindow.s: mainwindow.cpp.s
.PHONY : mainwindow.s
mainwindow.cpp.s:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/deepin-anything-gui-qt.dir/build.make CMakeFiles/deepin-anything-gui-qt.dir/mainwindow.cpp.s
.PHONY : mainwindow.cpp.s
searcher.o: searcher.cpp.o
.PHONY : searcher.o
searcher.cpp.o:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/deepin-anything-gui-qt.dir/build.make CMakeFiles/deepin-anything-gui-qt.dir/searcher.cpp.o
.PHONY : searcher.cpp.o
searcher.i: searcher.cpp.i
.PHONY : searcher.i
searcher.cpp.i:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/deepin-anything-gui-qt.dir/build.make CMakeFiles/deepin-anything-gui-qt.dir/searcher.cpp.i
.PHONY : searcher.cpp.i
searcher.s: searcher.cpp.s
.PHONY : searcher.s
searcher.cpp.s:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/deepin-anything-gui-qt.dir/build.make CMakeFiles/deepin-anything-gui-qt.dir/searcher.cpp.s
.PHONY : searcher.cpp.s
searchworker.o: searchworker.cpp.o
.PHONY : searchworker.o
searchworker.cpp.o:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/deepin-anything-gui-qt.dir/build.make CMakeFiles/deepin-anything-gui-qt.dir/searchworker.cpp.o
.PHONY : searchworker.cpp.o
searchworker.i: searchworker.cpp.i
.PHONY : searchworker.i
searchworker.cpp.i:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/deepin-anything-gui-qt.dir/build.make CMakeFiles/deepin-anything-gui-qt.dir/searchworker.cpp.i
.PHONY : searchworker.cpp.i
searchworker.s: searchworker.cpp.s
.PHONY : searchworker.s
searchworker.cpp.s:
	$(MAKE) $(MAKESILENT) -f CMakeFiles/deepin-anything-gui-qt.dir/build.make CMakeFiles/deepin-anything-gui-qt.dir/searchworker.cpp.s
.PHONY : searchworker.cpp.s
# Help Target
help:
	@echo "The following are some of the valid targets for this Makefile:"
	@echo "... all (the default if no target is provided)"
	@echo "... clean"
	@echo "... depend"
	@echo "... edit_cache"
	@echo "... rebuild_cache"
	@echo "... deepin-anything-gui-qt_autogen"
	@echo "... deepin-anything-gui-qt_autogen_timestamp_deps"
	@echo "... deepin-anything-gui-qt"
	@echo "... deepin-anything-gui-qt_autogen/mocs_compilation.o"
	@echo "... deepin-anything-gui-qt_autogen/mocs_compilation.i"
	@echo "... deepin-anything-gui-qt_autogen/mocs_compilation.s"
	@echo "... main.o"
	@echo "... main.i"
	@echo "... main.s"
	@echo "... mainwindow.o"
	@echo "... mainwindow.i"
	@echo "... mainwindow.s"
	@echo "... searcher.o"
	@echo "... searcher.i"
	@echo "... searcher.s"
	@echo "... searchworker.o"
	@echo "... searchworker.i"
	@echo "... searchworker.s"
.PHONY : help
# Special targets to cleanup operation of make.
# Special rule to run CMake to check the build system integrity.
# No rule that depends on this can have commands that come from listfiles
# because they might be regenerated.
cmake_check_build_system:
	$(CMAKE_COMMAND) -S$(CMAKE_SOURCE_DIR) -B$(CMAKE_BINARY_DIR) --check-build-system CMakeFiles/Makefile.cmake 0
.PHONY : cmake_check_build_system
