jun 01 11:35:27 Adrian-PC kernel: Linux version 6.18.27-amd64-desktop-rolling (root@deepinci-amd7) (gcc (Deepin 12.3.0-17deepin12) 12.3.0, GNU ld (GNU Binutils for Deepin) 2.41) (83922bc10) #25.01.01.24 SMP PREEMPT_DYNAMIC Fri May  8 13:00:43 CST 2026
jun 01 11:35:27 Adrian-PC kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.18.27-amd64-desktop-rolling root=UUID=6b64d00b-dcb9-4fed-9da6-5001ba778547 ostree=auto video=efifb:nobgrt splash quiet loglevel=0 locales=es_ES.UTF-8 rng_core.default_quality=1000 DEEPIN_GFXMODE=3,1366x768,1280x1024,1024x768,1920x1080 efi-pstore.pstore_disable=N luks.crypttab=n
jun 01 11:35:27 Adrian-PC kernel: KERNEL supported cpus:
jun 01 11:35:27 Adrian-PC kernel:   Intel GenuineIntel
jun 01 11:35:27 Adrian-PC kernel:   AMD AuthenticAMD
jun 01 11:35:27 Adrian-PC kernel:   Hygon HygonGenuine
jun 01 11:35:27 Adrian-PC kernel:   Centaur CentaurHauls
jun 01 11:35:27 Adrian-PC kernel:   zhaoxin   Shanghai
jun 01 11:35:27 Adrian-PC kernel: x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
jun 01 11:35:27 Adrian-PC kernel: BIOS-provided physical RAM map:
jun 01 11:35:27 Adrian-PC kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
jun 01 11:35:27 Adrian-PC kernel: BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
jun 01 11:35:27 Adrian-PC kernel: BIOS-e820: [mem 0x0000000000100000-0x000000006d6d8fff] usable
jun 01 11:35:27 Adrian-PC kernel: BIOS-e820: [mem 0x000000006d6d9000-0x0000000072012fff] reserved
jun 01 11:35:27 Adrian-PC kernel: BIOS-e820: [mem 0x0000000072013000-0x00000000720defff] ACPI data
jun 01 11:35:27 Adrian-PC kernel: BIOS-e820: [mem 0x00000000720df000-0x0000000072198fff] ACPI NVS
jun 01 11:35:27 Adrian-PC kernel: BIOS-e820: [mem 0x0000000072199000-0x00000000727fefff] reserved
jun 01 11:35:27 Adrian-PC kernel: BIOS-e820: [mem 0x00000000727ff000-0x00000000727fffff] usable
jun 01 11:35:27 Adrian-PC kernel: BIOS-e820: [mem 0x0000000072800000-0x0000000078ffffff] reserved
jun 01 11:35:27 Adrian-PC kernel: BIOS-e820: [mem 0x0000000079b00000-0x0000000079bfffff] reserved
jun 01 11:35:27 Adrian-PC kernel: BIOS-e820: [mem 0x000000007a400000-0x00000000807fffff] reserved
jun 01 11:35:27 Adrian-PC kernel: BIOS-e820: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
jun 01 11:35:27 Adrian-PC kernel: BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
jun 01 11:35:27 Adrian-PC kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
jun 01 11:35:27 Adrian-PC kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
jun 01 11:35:27 Adrian-PC kernel: BIOS-e820: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
jun 01 11:35:27 Adrian-PC kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
jun 01 11:35:27 Adrian-PC kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
jun 01 11:35:27 Adrian-PC kernel: BIOS-e820: [mem 0x0000000100000000-0x000000027f7fffff] usable
jun 01 11:35:27 Adrian-PC kernel: NX (Execute Disable) protection: active
jun 01 11:35:27 Adrian-PC kernel: APIC: Static calls initialized
jun 01 11:35:27 Adrian-PC kernel: efi: EFI v2.7 by American Megatrends
jun 01 11:35:27 Adrian-PC kernel: efi: ACPI=0x720de000 ACPI 2.0=0x720de014 TPMFinalLog=0x72124000 SMBIOS=0x72609000 SMBIOS 3.0=0x72608000 MEMATTR=0x6ab9c018 ESRT=0x6b14fe98 MOKvar=0x725e5000 INITRD=0x6a67f818 RNG=0x72056018 TPMEventLog=0x7204e018
jun 01 11:35:27 Adrian-PC kernel: random: crng init done
jun 01 11:35:27 Adrian-PC kernel: efi: Remove mem68: MMIO range=[0xc0000000-0xcfffffff] (256MB) from e820 map
jun 01 11:35:27 Adrian-PC kernel: e820: remove [mem 0xc0000000-0xcfffffff] reserved
jun 01 11:35:27 Adrian-PC kernel: efi: Not removing mem69: MMIO range=[0xfe000000-0xfe010fff] (68KB) from e820 map
jun 01 11:35:27 Adrian-PC kernel: efi: Not removing mem70: MMIO range=[0xfec00000-0xfec00fff] (4KB) from e820 map
jun 01 11:35:27 Adrian-PC kernel: efi: Not removing mem71: MMIO range=[0xfed00000-0xfed00fff] (4KB) from e820 map
jun 01 11:35:27 Adrian-PC kernel: efi: Not removing mem73: MMIO range=[0xfee00000-0xfee00fff] (4KB) from e820 map
jun 01 11:35:27 Adrian-PC kernel: efi: Remove mem74: MMIO range=[0xff000000-0xffffffff] (16MB) from e820 map
jun 01 11:35:27 Adrian-PC kernel: e820: remove [mem 0xff000000-0xffffffff] reserved
jun 01 11:35:27 Adrian-PC kernel: secureboot: Secure boot disabled
jun 01 11:35:27 Adrian-PC kernel: SMBIOS 3.3.0 present.
jun 01 11:35:27 Adrian-PC kernel: DMI: ASUSTeK COMPUTER INC. VivoBook_ASUSLaptop X415EA_F415EA/X415EA, BIOS X415EA.308 04/27/2022
jun 01 11:35:27 Adrian-PC kernel: DMI: Memory slots populated: 1/1
jun 01 11:35:27 Adrian-PC kernel: tsc: Detected 2400.000 MHz processor
jun 01 11:35:27 Adrian-PC kernel: tsc: Detected 2419.200 MHz TSC
jun 01 11:35:27 Adrian-PC kernel: [Firmware Bug]: TSC ADJUST: CPU0: -896725541 force to 0
jun 01 11:35:27 Adrian-PC kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
jun 01 11:35:27 Adrian-PC kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
jun 01 11:35:27 Adrian-PC kernel: last_pfn = 0x27f800 max_arch_pfn = 0x400000000
jun 01 11:35:27 Adrian-PC kernel: MTRR map: 5 entries (3 fixed + 2 variable; max 23), built from 10 variable MTRRs
jun 01 11:35:27 Adrian-PC kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
jun 01 11:35:27 Adrian-PC kernel: last_pfn = 0x72800 max_arch_pfn = 0x400000000
jun 01 11:35:27 Adrian-PC kernel: esrt: Reserving ESRT space from 0x000000006b14fe98 to 0x000000006b14ff70.
jun 01 11:35:27 Adrian-PC kernel: e820: update [mem 0x6b14f000-0x6b14ffff] usable ==> reserved
jun 01 11:35:27 Adrian-PC kernel: Using GB pages for direct mapping
jun 01 11:35:27 Adrian-PC kernel: RAMDISK: [mem 0x3ea3c000-0x4a1fbfff]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Early table checksum verification disabled
jun 01 11:35:27 Adrian-PC kernel: ACPI: RSDP 0x00000000720DE014 000024 (v02 _ASUS_)
jun 01 11:35:27 Adrian-PC kernel: ACPI: XSDT 0x00000000720DD728 0000F4 (v01 _ASUS_ Notebook 01072009 AMI  01000013)
jun 01 11:35:27 Adrian-PC kernel: ACPI: FACP 0x00000000720D8000 000114 (v06 _ASUS_ Notebook 01072009 AMI  01000013)
jun 01 11:35:27 Adrian-PC kernel: ACPI: DSDT 0x000000007207B000 05C3EE (v02 _ASUS_ Notebook 01072009 INTL 20191018)
jun 01 11:35:27 Adrian-PC kernel: ACPI: FACS 0x0000000072195000 000040
jun 01 11:35:27 Adrian-PC kernel: ACPI: MCFG 0x00000000720DC000 00003C (v01 _ASUS_ Notebook 01072009 MSFT 00000097)
jun 01 11:35:27 Adrian-PC kernel: ACPI: SSDT 0x00000000720D9000 00255D (v02 CpuRef CpuSsdt  00003000 INTL 20191018)
jun 01 11:35:27 Adrian-PC kernel: ACPI: FIDT 0x000000007207A000 00009C (v01 _ASUS_ Notebook 01072009 AMI  00010013)
jun 01 11:35:27 Adrian-PC kernel: ACPI: ECDT 0x0000000072079000 0000C1 (v01 _ASUS_ Notebook 01072009 AMI. 00000005)
jun 01 11:35:27 Adrian-PC kernel: ACPI: MSDM 0x0000000072078000 000055 (v03 _ASUS_ Notebook 01072009 ASUS 00000001)
jun 01 11:35:27 Adrian-PC kernel: ACPI: SSDT 0x0000000072073000 004D60 (v02 DptfTa DptfTabl 00001000 INTL 20191018)
jun 01 11:35:27 Adrian-PC kernel: ACPI: SSDT 0x0000000072070000 002D64 (v02 SaSsdt SaSsdt   00003000 INTL 20191018)
jun 01 11:35:27 Adrian-PC kernel: ACPI: SSDT 0x000000007206C000 0032B6 (v02 INTEL  IgfxSsdt 00003000 INTL 20191018)
jun 01 11:35:27 Adrian-PC kernel: ACPI: HPET 0x000000007206B000 000038 (v01 _ASUS_ Notebook 01072009 AMI  01000013)
jun 01 11:35:27 Adrian-PC kernel: ACPI: APIC 0x000000007206A000 00012C (v04 _ASUS_ Notebook 01072009 AMI  01000013)
jun 01 11:35:27 Adrian-PC kernel: ACPI: SSDT 0x0000000072063000 00634B (v02 _ASUS_ TglU_Rvp 00001000 INTL 20191018)
jun 01 11:35:27 Adrian-PC kernel: ACPI: NHLT 0x0000000072062000 0002E1 (v00 _ASUS_ Notebook 01072009 AMI  01000013)
jun 01 11:35:27 Adrian-PC kernel: ACPI: LPIT 0x0000000072061000 0000CC (v01 _ASUS_ Notebook 01072009 AMI  01000013)
jun 01 11:35:27 Adrian-PC kernel: ACPI: SSDT 0x000000007205F000 00012A (v02 _ASUS_ TbtTypeC 00000000 INTL 20191018)
jun 01 11:35:27 Adrian-PC kernel: ACPI: DBGP 0x000000007205E000 000034 (v01 _ASUS_ Notebook 01072009 AMI  01000013)
jun 01 11:35:27 Adrian-PC kernel: ACPI: DBG2 0x000000007205D000 000054 (v00 _ASUS_ Notebook 01072009 AMI  01000013)
jun 01 11:35:27 Adrian-PC kernel: ACPI: DMAR 0x000000007205C000 000088 (v02 INTEL  EDK2     00000002      01000013)
jun 01 11:35:27 Adrian-PC kernel: ACPI: SSDT 0x000000007205B000 000144 (v02 Intel  ADebTabl 00001000 INTL 20191018)
jun 01 11:35:27 Adrian-PC kernel: ACPI: BGRT 0x000000007205A000 000038 (v01 _ASUS_ Notebook 01072009 AMI  00010013)
jun 01 11:35:27 Adrian-PC kernel: ACPI: UEFI 0x0000000072105000 00063A (v01 INTEL  RstVmdE  00000000 ??   00000000)
jun 01 11:35:27 Adrian-PC kernel: ACPI: UEFI 0x0000000072104000 00005C (v01 INTEL  RstVmdV  00000000 ??   00000000)
jun 01 11:35:27 Adrian-PC kernel: ACPI: TPM2 0x0000000072059000 00004C (v04 _ASUS_ Notebook 00000001 AMI  00000000)
jun 01 11:35:27 Adrian-PC kernel: ACPI: PTDT 0x0000000072058000 000D44 (v00 _ASUS_ Notebook 00000005 MSFT 0100000D)
jun 01 11:35:27 Adrian-PC kernel: ACPI: WSMT 0x0000000072060000 000028 (v01 _ASUS_ Notebook 01072009 AMI  00010013)
jun 01 11:35:27 Adrian-PC kernel: ACPI: FPDT 0x0000000072057000 000044 (v01 _ASUS_ A M I    01072009 AMI  01000013)
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving FACP table memory at [mem 0x720d8000-0x720d8113]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving DSDT table memory at [mem 0x7207b000-0x720d73ed]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving FACS table memory at [mem 0x72195000-0x7219503f]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving MCFG table memory at [mem 0x720dc000-0x720dc03b]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving SSDT table memory at [mem 0x720d9000-0x720db55c]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving FIDT table memory at [mem 0x7207a000-0x7207a09b]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving ECDT table memory at [mem 0x72079000-0x720790c0]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving MSDM table memory at [mem 0x72078000-0x72078054]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving SSDT table memory at [mem 0x72073000-0x72077d5f]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving SSDT table memory at [mem 0x72070000-0x72072d63]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving SSDT table memory at [mem 0x7206c000-0x7206f2b5]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving HPET table memory at [mem 0x7206b000-0x7206b037]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving APIC table memory at [mem 0x7206a000-0x7206a12b]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving SSDT table memory at [mem 0x72063000-0x7206934a]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving NHLT table memory at [mem 0x72062000-0x720622e0]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving LPIT table memory at [mem 0x72061000-0x720610cb]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving SSDT table memory at [mem 0x7205f000-0x7205f129]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving DBGP table memory at [mem 0x7205e000-0x7205e033]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving DBG2 table memory at [mem 0x7205d000-0x7205d053]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving DMAR table memory at [mem 0x7205c000-0x7205c087]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving SSDT table memory at [mem 0x7205b000-0x7205b143]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving BGRT table memory at [mem 0x7205a000-0x7205a037]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving UEFI table memory at [mem 0x72105000-0x72105639]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving UEFI table memory at [mem 0x72104000-0x7210405b]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving TPM2 table memory at [mem 0x72059000-0x7205904b]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving PTDT table memory at [mem 0x72058000-0x72058d43]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving WSMT table memory at [mem 0x72060000-0x72060027]
jun 01 11:35:27 Adrian-PC kernel: ACPI: Reserving FPDT table memory at [mem 0x72057000-0x72057043]
jun 01 11:35:27 Adrian-PC kernel: No NUMA configuration found
jun 01 11:35:27 Adrian-PC kernel: Faking a node at [mem 0x0000000000000000-0x000000027f7fffff]
jun 01 11:35:27 Adrian-PC kernel: NODE_DATA(0) allocated [mem 0x27f7c0d00-0x27f7ffcff]
jun 01 11:35:27 Adrian-PC kernel: Zone ranges:
jun 01 11:35:27 Adrian-PC kernel:   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
jun 01 11:35:27 Adrian-PC kernel:   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
jun 01 11:35:27 Adrian-PC kernel:   Normal   [mem 0x0000000100000000-0x000000027f7fffff]
jun 01 11:35:27 Adrian-PC kernel:   Device   empty
jun 01 11:35:27 Adrian-PC kernel: Movable zone start for each node
jun 01 11:35:27 Adrian-PC kernel: Early memory node ranges
jun 01 11:35:27 Adrian-PC kernel:   node   0: [mem 0x0000000000001000-0x000000000009efff]
jun 01 11:35:27 Adrian-PC kernel:   node   0: [mem 0x0000000000100000-0x000000006d6d8fff]
jun 01 11:35:27 Adrian-PC kernel:   node   0: [mem 0x00000000727ff000-0x00000000727fffff]
jun 01 11:35:27 Adrian-PC kernel:   node   0: [mem 0x0000000100000000-0x000000027f7fffff]
jun 01 11:35:27 Adrian-PC kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000027f7fffff]
jun 01 11:35:27 Adrian-PC kernel: On node 0, zone DMA: 1 pages in unavailable ranges
jun 01 11:35:27 Adrian-PC kernel: On node 0, zone DMA: 97 pages in unavailable ranges
jun 01 11:35:27 Adrian-PC kernel: On node 0, zone DMA32: 20774 pages in unavailable ranges
jun 01 11:35:27 Adrian-PC kernel: On node 0, zone Normal: 22528 pages in unavailable ranges
jun 01 11:35:27 Adrian-PC kernel: On node 0, zone Normal: 2048 pages in unavailable ranges
jun 01 11:35:27 Adrian-PC kernel: Reserving Intel graphics memory at [mem 0x7c800000-0x807fffff]
jun 01 11:35:27 Adrian-PC kernel: ACPI: PM-Timer IO Port: 0x1808
jun 01 11:35:27 Adrian-PC kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
jun 01 11:35:27 Adrian-PC kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
jun 01 11:35:27 Adrian-PC kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
jun 01 11:35:27 Adrian-PC kernel: ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
jun 01 11:35:27 Adrian-PC kernel: ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
jun 01 11:35:27 Adrian-PC kernel: ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
jun 01 11:35:27 Adrian-PC kernel: ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
jun 01 11:35:27 Adrian-PC kernel: ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
jun 01 11:35:27 Adrian-PC kernel: ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
jun 01 11:35:27 Adrian-PC kernel: ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
jun 01 11:35:27 Adrian-PC kernel: ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
jun 01 11:35:27 Adrian-PC kernel: ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
jun 01 11:35:27 Adrian-PC kernel: ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
jun 01 11:35:27 Adrian-PC kernel: ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
jun 01 11:35:27 Adrian-PC kernel: ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
jun 01 11:35:27 Adrian-PC kernel: ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
jun 01 11:35:27 Adrian-PC kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
jun 01 11:35:27 Adrian-PC kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
jun 01 11:35:27 Adrian-PC kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
jun 01 11:35:27 Adrian-PC kernel: ACPI: Using ACPI (MADT) for SMP configuration information
jun 01 11:35:27 Adrian-PC kernel: ACPI: HPET id: 0x8086a201 base: 0xfed00000
jun 01 11:35:27 Adrian-PC kernel: e820: update [mem 0x6aa8f000-0x6aabdfff] usable ==> reserved
jun 01 11:35:27 Adrian-PC kernel: TSC deadline timer available
jun 01 11:35:27 Adrian-PC kernel: CPU topo: Max. logical packages:   1
jun 01 11:35:27 Adrian-PC kernel: CPU topo: Max. logical dies:       1
jun 01 11:35:27 Adrian-PC kernel: CPU topo: Max. dies per package:   1
jun 01 11:35:27 Adrian-PC kernel: CPU topo: Max. threads per core:   2
jun 01 11:35:27 Adrian-PC kernel: CPU topo: Num. cores per package:     4
jun 01 11:35:27 Adrian-PC kernel: CPU topo: Num. threads per package:   8
jun 01 11:35:27 Adrian-PC kernel: CPU topo: Allowing 8 present CPUs plus 0 hotplug CPUs
jun 01 11:35:27 Adrian-PC kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
jun 01 11:35:27 Adrian-PC kernel: PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
jun 01 11:35:27 Adrian-PC kernel: PM: hibernation: Registered nosave memory: [mem 0x6aa8f000-0x6aabdfff]
jun 01 11:35:27 Adrian-PC kernel: PM: hibernation: Registered nosave memory: [mem 0x6b14f000-0x6b14ffff]
jun 01 11:35:27 Adrian-PC kernel: PM: hibernation: Registered nosave memory: [mem 0x6d6d9000-0x727fefff]
jun 01 11:35:27 Adrian-PC kernel: PM: hibernation: Registered nosave memory: [mem 0x72800000-0xffffffff]
jun 01 11:35:27 Adrian-PC kernel: [mem 0x80800000-0xfdffffff] available for PCI devices
jun 01 11:35:27 Adrian-PC kernel: Booting paravirtualized kernel on bare hardware
jun 01 11:35:27 Adrian-PC kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
jun 01 11:35:27 Adrian-PC kernel: setup_percpu: NR_CPUS:8192 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
jun 01 11:35:27 Adrian-PC kernel: percpu: Embedded 103 pages/cpu s385024 r8192 d28672 u524288
jun 01 11:35:27 Adrian-PC kernel: pcpu-alloc: s385024 r8192 d28672 u524288 alloc=1*2097152
jun 01 11:35:27 Adrian-PC kernel: pcpu-alloc: [0] 0 1 2 3 [0] 4 5 6 7
jun 01 11:35:27 Adrian-PC kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.18.27-amd64-desktop-rolling root=UUID=6b64d00b-dcb9-4fed-9da6-5001ba778547 ostree=auto video=efifb:nobgrt splash quiet loglevel=0 locales=es_ES.UTF-8 rng_core.default_quality=1000 DEEPIN_GFXMODE=3,1366x768,1280x1024,1024x768,1920x1080 efi-pstore.pstore_disable=N luks.crypttab=n
jun 01 11:35:27 Adrian-PC kernel: Unknown kernel command line parameters "splash ostree=auto locales=es_ES.UTF-8 DEEPIN_GFXMODE=3,1366x768,1280x1024,1024x768,1920x1080", will be passed to user space.
jun 01 11:35:27 Adrian-PC kernel: printk: log buffer data + meta data: 262144 + 917504 = 1179648 bytes
jun 01 11:35:27 Adrian-PC kernel: Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
jun 01 11:35:27 Adrian-PC kernel: Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
jun 01 11:35:27 Adrian-PC kernel: software IO TLB: area num 8.
jun 01 11:35:27 Adrian-PC kernel: Fallback order for Node 0: 0
jun 01 11:35:27 Adrian-PC kernel: Built 1 zonelists, mobility grouping on.  Total pages: 2018936
jun 01 11:35:27 Adrian-PC kernel: Policy zone: Normal
jun 01 11:35:27 Adrian-PC kernel: mem auto-init: stack:all(zero), heap alloc:on, heap free:off
jun 01 11:35:27 Adrian-PC kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
jun 01 11:35:27 Adrian-PC kernel: ftrace: allocating 61229 entries in 240 pages
jun 01 11:35:27 Adrian-PC kernel: ftrace: allocated 240 pages with 4 groups
jun 01 11:35:27 Adrian-PC kernel: BORE CPU Scheduler modification 6.6.3 by Masahito Suzuki
jun 01 11:35:27 Adrian-PC kernel: Dynamic Preempt: full
jun 01 11:35:27 Adrian-PC kernel: rcu: Preemptible hierarchical RCU implementation.
jun 01 11:35:27 Adrian-PC kernel: rcu:         RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=8.
jun 01 11:35:27 Adrian-PC kernel: rcu:         RCU priority boosting: priority 1 delay 500 ms.
jun 01 11:35:27 Adrian-PC kernel:         Trampoline variant of Tasks RCU enabled.
jun 01 11:35:27 Adrian-PC kernel:         Rude variant of Tasks RCU enabled.
jun 01 11:35:27 Adrian-PC kernel:         Tracing variant of Tasks RCU enabled.
jun 01 11:35:27 Adrian-PC kernel: rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
jun 01 11:35:27 Adrian-PC kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
jun 01 11:35:27 Adrian-PC kernel: RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
jun 01 11:35:27 Adrian-PC kernel: RCU Tasks Rude: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
jun 01 11:35:27 Adrian-PC kernel: RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
jun 01 11:35:27 Adrian-PC kernel: NR_IRQS: 524544, nr_irqs: 2048, preallocated irqs: 16
jun 01 11:35:27 Adrian-PC kernel: rcu: srcu_init: Setting srcu_struct sizes based on contention.
jun 01 11:35:27 Adrian-PC kernel: Console: colour dummy device 80x25
jun 01 11:35:27 Adrian-PC kernel: printk: legacy console [tty0] enabled
jun 01 11:35:27 Adrian-PC kernel: ACPI: Core revision 20250807
jun 01 11:35:27 Adrian-PC kernel: hpet: HPET dysfunctional in PC10. Force disabled.
jun 01 11:35:27 Adrian-PC kernel: APIC: Switch to symmetric I/O mode setup
jun 01 11:35:27 Adrian-PC kernel: DMAR: Host address width 39
jun 01 11:35:27 Adrian-PC kernel: DMAR: DRHD base: 0x000000fed90000 flags: 0x0
jun 01 11:35:27 Adrian-PC kernel: DMAR: dmar0: reg_base_addr fed90000 ver 4:0 cap 1c0000c40660462 ecap 69e2ff0505e
jun 01 11:35:27 Adrian-PC kernel: DMAR: DRHD base: 0x000000fed91000 flags: 0x1
jun 01 11:35:27 Adrian-PC kernel: DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
jun 01 11:35:27 Adrian-PC kernel: DMAR: RMRR base: 0x0000007c000000 end: 0x000000807fffff
jun 01 11:35:27 Adrian-PC kernel: DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
jun 01 11:35:27 Adrian-PC kernel: DMAR-IR: HPET id 0 under DRHD base 0xfed91000
jun 01 11:35:27 Adrian-PC kernel: DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
jun 01 11:35:27 Adrian-PC kernel: DMAR-IR: Enabled IRQ remapping in x2apic mode
jun 01 11:35:27 Adrian-PC kernel: x2apic enabled
jun 01 11:35:27 Adrian-PC kernel: APIC: Switched APIC routing to: cluster x2apic
jun 01 11:35:27 Adrian-PC kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x22df1149949, max_idle_ns: 440795312789 ns
jun 01 11:35:27 Adrian-PC kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 4838.40 BogoMIPS (lpj=2419200)
jun 01 11:35:27 Adrian-PC kernel: CPU0: Thermal monitoring enabled (TM1)
jun 01 11:35:27 Adrian-PC kernel: x86/cpu: User Mode Instruction Prevention (UMIP) activated
jun 01 11:35:27 Adrian-PC kernel: CET detected: Indirect Branch Tracking enabled
jun 01 11:35:27 Adrian-PC kernel: Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
jun 01 11:35:27 Adrian-PC kernel: Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
jun 01 11:35:27 Adrian-PC kernel: process: using mwait in idle threads
jun 01 11:35:27 Adrian-PC kernel: mitigations: Enabled attack vectors: user_kernel, user_user, guest_host, guest_guest, SMT mitigations: auto
jun 01 11:35:27 Adrian-PC kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
jun 01 11:35:27 Adrian-PC kernel: Spectre V2 : Mitigation: Enhanced / Automatic IBRS
jun 01 11:35:27 Adrian-PC kernel: ITS: Mitigation: Aligned branch/return thunks
jun 01 11:35:27 Adrian-PC kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
jun 01 11:35:27 Adrian-PC kernel: Spectre V2 : Spectre v2 / PBRSB-eIBRS: Retire a single CALL on VMEXIT
jun 01 11:35:27 Adrian-PC kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
jun 01 11:35:27 Adrian-PC kernel: GDS: Mitigation: Microcode
jun 01 11:35:27 Adrian-PC kernel: active return thunk: its_return_thunk
jun 01 11:35:27 Adrian-PC kernel: Spectre V2 : Spectre BHI mitigation: SW BHB clearing on syscall and VM exit
jun 01 11:35:27 Adrian-PC kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
jun 01 11:35:27 Adrian-PC kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
jun 01 11:35:27 Adrian-PC kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
jun 01 11:35:27 Adrian-PC kernel: x86/fpu: Supporting XSAVE feature 0x020: 'AVX-512 opmask'
jun 01 11:35:27 Adrian-PC kernel: x86/fpu: Supporting XSAVE feature 0x040: 'AVX-512 Hi256'
jun 01 11:35:27 Adrian-PC kernel: x86/fpu: Supporting XSAVE feature 0x080: 'AVX-512 ZMM_Hi256'
jun 01 11:35:27 Adrian-PC kernel: x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
jun 01 11:35:27 Adrian-PC kernel: x86/fpu: Supporting XSAVE feature 0x800: 'Control-flow User registers'
jun 01 11:35:27 Adrian-PC kernel: x86/fpu: Supporting XSAVE feature 0x1000: 'Control-flow Kernel registers (KVM only)'
jun 01 11:35:27 Adrian-PC kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
jun 01 11:35:27 Adrian-PC kernel: x86/fpu: xstate_offset[5]:  832, xstate_sizes[5]:   64
jun 01 11:35:27 Adrian-PC kernel: x86/fpu: xstate_offset[6]:  896, xstate_sizes[6]:  512
jun 01 11:35:27 Adrian-PC kernel: x86/fpu: xstate_offset[7]: 1408, xstate_sizes[7]: 1024
jun 01 11:35:27 Adrian-PC kernel: x86/fpu: xstate_offset[9]: 2432, xstate_sizes[9]:    8
jun 01 11:35:27 Adrian-PC kernel: x86/fpu: xstate_offset[11]: 2440, xstate_sizes[11]:   16
jun 01 11:35:27 Adrian-PC kernel: x86/fpu: xstate_offset[12]: 2456, xstate_sizes[12]:   24
jun 01 11:35:27 Adrian-PC kernel: x86/fpu: Enabled xstate features 0x1ae7, context size is 2480 bytes, using 'compacted' format.
jun 01 11:35:27 Adrian-PC kernel: Freeing SMP alternatives memory: 52K
jun 01 11:35:27 Adrian-PC kernel: pid_max: default: 32768 minimum: 301
jun 01 11:35:27 Adrian-PC kernel: LSM: initializing lsm=lockdown,capability,landlock,yama,safesetid,apparmor,tomoyo,bpf,ima,evm
jun 01 11:35:27 Adrian-PC kernel: landlock: Up and running.
jun 01 11:35:27 Adrian-PC kernel: Yama: becoming mindful.
jun 01 11:35:27 Adrian-PC kernel: AppArmor: AppArmor initialized
jun 01 11:35:27 Adrian-PC kernel: TOMOYO Linux initialized
jun 01 11:35:27 Adrian-PC kernel: LSM support for eBPF active
jun 01 11:35:27 Adrian-PC kernel: Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
jun 01 11:35:27 Adrian-PC kernel: Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
jun 01 11:35:27 Adrian-PC kernel: smpboot: CPU0: 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz (family: 0x6, model: 0x8c, stepping: 0x1)
jun 01 11:35:27 Adrian-PC kernel: Performance Events: PEBS fmt4+-baseline,  AnyThread deprecated, Icelake events, 32-deep LBR, full-width counters, Intel PMU driver.
jun 01 11:35:27 Adrian-PC kernel: ... version:                   5
jun 01 11:35:27 Adrian-PC kernel: ... bit width:                 48
jun 01 11:35:27 Adrian-PC kernel: ... generic counters:          8
jun 01 11:35:27 Adrian-PC kernel: ... generic bitmap:            00000000000000ff
jun 01 11:35:27 Adrian-PC kernel: ... fixed-purpose counters:    4
jun 01 11:35:27 Adrian-PC kernel: ... fixed-purpose bitmap:      000000000000000f
jun 01 11:35:27 Adrian-PC kernel: ... value mask:                0000ffffffffffff
jun 01 11:35:27 Adrian-PC kernel: ... max period:                00007fffffffffff
jun 01 11:35:27 Adrian-PC kernel: ... global_ctrl mask:          0001000f000000ff
jun 01 11:35:27 Adrian-PC kernel: signal: max sigframe size: 3632
jun 01 11:35:27 Adrian-PC kernel: Estimated ratio of average max frequency by base frequency (times 1024): 1621
jun 01 11:35:27 Adrian-PC kernel: rcu: Hierarchical SRCU implementation.
jun 01 11:35:27 Adrian-PC kernel: rcu:         Max phase no-delay instances is 400.
jun 01 11:35:27 Adrian-PC kernel: Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
jun 01 11:35:27 Adrian-PC kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
jun 01 11:35:27 Adrian-PC kernel: smp: Bringing up secondary CPUs ...
jun 01 11:35:27 Adrian-PC kernel: smpboot: x86: Booting SMP configuration:
jun 01 11:35:27 Adrian-PC kernel: .... node  #0, CPUs:      #1 #2 #3
jun 01 11:35:27 Adrian-PC kernel: [Firmware Bug]: TSC ADJUST differs within socket(s), fixing all errors
jun 01 11:35:27 Adrian-PC kernel:  #4 #5 #6 #7
jun 01 11:35:27 Adrian-PC kernel: smp: Brought up 1 node, 8 CPUs
jun 01 11:35:27 Adrian-PC kernel: smpboot: Total of 8 processors activated (38707.20 BogoMIPS)
jun 01 11:35:27 Adrian-PC kernel: Memory: 7505832K/8075744K available (20241K kernel code, 9476K rwdata, 17728K rodata, 5420K init, 5384K bss, 545368K reserved, 0K cma-reserved)
jun 01 11:35:27 Adrian-PC kernel: devtmpfs: initialized
jun 01 11:35:27 Adrian-PC kernel: x86/mm: Memory block size: 128MB
jun 01 11:35:27 Adrian-PC kernel: ACPI: PM: Registering ACPI NVS region [mem 0x720df000-0x72198fff] (761856 bytes)
jun 01 11:35:27 Adrian-PC kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
jun 01 11:35:27 Adrian-PC kernel: posixtimers hash table entries: 4096 (order: 4, 65536 bytes, linear)
jun 01 11:35:27 Adrian-PC kernel: futex hash table entries: 2048 (131072 bytes on 1 NUMA nodes, total 128 KiB, linear).
jun 01 11:35:27 Adrian-PC kernel: pinctrl core: initialized pinctrl subsystem
jun 01 11:35:27 Adrian-PC kernel: PM: RTC time: 11:35:23, date: 2026-06-01
jun 01 11:35:27 Adrian-PC kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
jun 01 11:35:27 Adrian-PC kernel: DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
jun 01 11:35:27 Adrian-PC kernel: DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
jun 01 11:35:27 Adrian-PC kernel: DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
jun 01 11:35:27 Adrian-PC kernel: audit: initializing netlink subsys (disabled)
jun 01 11:35:27 Adrian-PC kernel: audit: type=2000 audit(1780313723.014:1): state=initialized audit_enabled=0 res=1
jun 01 11:35:27 Adrian-PC kernel: thermal_sys: Registered thermal governor 'fair_share'
jun 01 11:35:27 Adrian-PC kernel: thermal_sys: Registered thermal governor 'bang_bang'
jun 01 11:35:27 Adrian-PC kernel: thermal_sys: Registered thermal governor 'step_wise'
jun 01 11:35:27 Adrian-PC kernel: thermal_sys: Registered thermal governor 'power_allocator'
jun 01 11:35:27 Adrian-PC kernel: cpuidle: using governor ladder
jun 01 11:35:27 Adrian-PC kernel: cpuidle: using governor menu
jun 01 11:35:27 Adrian-PC kernel: efi: Freeing EFI boot services memory: 85688K
jun 01 11:35:27 Adrian-PC kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
jun 01 11:35:27 Adrian-PC kernel: PCI: ECAM [mem 0xc0000000-0xcfffffff] (base 0xc0000000) for domain 0000 [bus 00-ff]
jun 01 11:35:27 Adrian-PC kernel: PCI: Using configuration type 1 for base access
jun 01 11:35:27 Adrian-PC kernel: kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
jun 01 11:35:27 Adrian-PC kernel: HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
jun 01 11:35:27 Adrian-PC kernel: HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
jun 01 11:35:27 Adrian-PC kernel: HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
jun 01 11:35:27 Adrian-PC kernel: HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
jun 01 11:35:27 Adrian-PC kernel: ACPI: Added _OSI(Module Device)
jun 01 11:35:27 Adrian-PC kernel: ACPI: Added _OSI(Processor Device)
jun 01 11:35:27 Adrian-PC kernel: ACPI: Added _OSI(Processor Aggregator Device)
jun 01 11:35:27 Adrian-PC kernel: ACPI: 8 ACPI AML tables successfully acquired and loaded
jun 01 11:35:27 Adrian-PC kernel: ACPI: EC: EC started
jun 01 11:35:27 Adrian-PC kernel: ACPI: EC: interrupt blocked
jun 01 11:35:27 Adrian-PC kernel: ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
jun 01 11:35:27 Adrian-PC kernel: ACPI: EC: Boot ECDT EC used to handle transactions
jun 01 11:35:27 Adrian-PC kernel: ACPI: Dynamic OEM Table Load:
jun 01 11:35:27 Adrian-PC kernel: ACPI: SSDT 0xFFFF8F0341FDA800 000394 (v02 PmRef  Cpu0Cst  00003001 INTL 20191018)
jun 01 11:35:27 Adrian-PC kernel: ACPI: SSDT 0xFFFF8F0341FE0800 0005C3 (v02 PmRef  Cpu0Ist  00003000 INTL 20191018)
jun 01 11:35:27 Adrian-PC kernel: ACPI: SSDT 0xFFFF8F0342289A00 0001CB (v02 PmRef  Cpu0Psd  00003000 INTL 20191018)
jun 01 11:35:27 Adrian-PC kernel: ACPI: SSDT 0xFFFF8F0341FD8C00 000266 (v02 PmRef  Cpu0Hwp  00003000 INTL 20191018)
jun 01 11:35:27 Adrian-PC kernel: ACPI: SSDT 0xFFFF8F0341FE9000 0008E7 (v02 PmRef  ApIst    00003000 INTL 20191018)
jun 01 11:35:27 Adrian-PC kernel: ACPI: SSDT 0xFFFF8F0341FE4800 00048A (v02 PmRef  ApHwp    00003000 INTL 20191018)
jun 01 11:35:27 Adrian-PC kernel: ACPI: SSDT 0xFFFF8F0341FE7800 0004D4 (v02 PmRef  ApPsd    00003000 INTL 20191018)
jun 01 11:35:27 Adrian-PC kernel: ACPI: SSDT 0xFFFF8F0341FE3000 00048A (v02 PmRef  ApCst    00003000 INTL 20191018)
jun 01 11:35:27 Adrian-PC kernel: ACPI: Interpreter enabled
jun 01 11:35:27 Adrian-PC kernel: ACPI: PM: (supports S0 S3 S4 S5)
jun 01 11:35:27 Adrian-PC kernel: ACPI: Using IOAPIC for interrupt routing
jun 01 11:35:27 Adrian-PC kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
jun 01 11:35:27 Adrian-PC kernel: PCI: Using E820 reservations for host bridge windows
jun 01 11:35:27 Adrian-PC kernel: ACPI: Enabled 8 GPEs in block 00 to 7F
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.PEG0.PXP_: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.RP05.PXP_: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.RP08.PXP_: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.XHCI.RHUB.HS10.BTPR: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.PAUD: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.SAT0.VOL0.V0PR: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.SAT0.VOL1.V1PR: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.SAT0.VOL2.V2PR: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.I2C0.PXTC: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.I2C0.PTPL: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.I2C1.PXTC: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.I2C2.PXTC: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.CNVW.WRST: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.VMD0.RP05.NVPR: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.VMD0.PRT0.NVPR: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.VMD0.PRT1.NVPR: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.VMD0.PRT2.NVPR: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.VMD0.PRT3.NVPR: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.VMD0.PRT4.NVPR: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.VMD0.PRT5.NVPR: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.VMD0.PRT6.NVPR: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.VMD0.PRT7.NVPR: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.VMD0.VOL0.V0PR: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.VMD0.VOL1.V1PR: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.VMD0.VOL2.V2PR: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.VMD0.VOL3.V3PR: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: \PIN_: New power resource
jun 01 11:35:27 Adrian-PC kernel: ACPI: PCI Root Bridge [PC00] (domain 0000 [bus 00-e0])
jun 01 11:35:27 Adrian-PC kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
jun 01 11:35:27 Adrian-PC kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
jun 01 11:35:27 Adrian-PC kernel: PCI host bridge to bus 0000:00
jun 01 11:35:27 Adrian-PC kernel: pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
jun 01 11:35:27 Adrian-PC kernel: pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
jun 01 11:35:27 Adrian-PC kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
jun 01 11:35:27 Adrian-PC kernel: pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000fffff window]
jun 01 11:35:27 Adrian-PC kernel: pci_bus 0000:00: root bus resource [mem 0x80800000-0xbfffffff window]
jun 01 11:35:27 Adrian-PC kernel: pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
jun 01 11:35:27 Adrian-PC kernel: pci_bus 0000:00: root bus resource [bus 00-e0]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:00.0: [8086:9a14] type 00 class 0x060000 conventional PCI endpoint
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:02.0: [8086:9a49] type 00 class 0x030000 PCIe Root Complex Integrated Endpoint
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:02.0: BAR 0 [mem 0x6002000000-0x6002ffffff 64bit]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:02.0: BAR 2 [mem 0x4000000000-0x400fffffff 64bit pref]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:02.0: BAR 4 [io  0x3000-0x303f]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:02.0: DMAR: Skip IOMMU disabling for graphics
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:02.0: VF BAR 0 [mem 0x00000000-0x00ffffff 64bit]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:02.0: VF BAR 0 [mem 0x00000000-0x06ffffff 64bit]: contains BAR 0 for 7 VFs
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:02.0: VF BAR 2 [mem 0x00000000-0x1fffffff 64bit pref]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:02.0: VF BAR 2 [mem 0x00000000-0xdfffffff 64bit pref]: contains BAR 2 for 7 VFs
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:04.0: [8086:9a03] type 00 class 0x118000 conventional PCI endpoint
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:04.0: BAR 0 [mem 0x6003200000-0x600321ffff 64bit]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:08.0: [8086:9a11] type 00 class 0x088000 conventional PCI endpoint
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:08.0: BAR 0 [mem 0x600324b000-0x600324bfff 64bit]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:0a.0: [8086:9a0d] type 00 class 0x118000 PCIe Root Complex Integrated Endpoint
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:0a.0: BAR 0 [mem 0x6003230000-0x6003237fff 64bit]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:0a.0: enabling Extended Tags
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:0e.0: [8086:9a0b] type 00 class 0x010400 PCIe Root Complex Integrated Endpoint
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:0e.0: BAR 0 [mem 0x6000000000-0x6001ffffff 64bit]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:0e.0: BAR 2 [mem 0x82000000-0x83ffffff]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:0e.0: BAR 4 [mem 0x6003100000-0x60031fffff 64bit]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:14.0: [8086:a0ed] type 00 class 0x0c0330 conventional PCI endpoint
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:14.0: BAR 0 [mem 0x6003220000-0x600322ffff 64bit]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:14.2: [8086:a0ef] type 00 class 0x050000 conventional PCI endpoint
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:14.2: BAR 0 [mem 0x6003240000-0x6003243fff 64bit]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:14.2: BAR 2 [mem 0x600324a000-0x600324afff 64bit]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:14.3: [8086:a0f0] type 00 class 0x028000 PCIe Root Complex Integrated Endpoint
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:14.3: BAR 0 [mem 0x600323c000-0x600323ffff 64bit]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:15.0: [8086:a0e8] type 00 class 0x0c8000 conventional PCI endpoint
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:15.0: BAR 0 [mem 0x00000000-0x00000fff 64bit]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:15.1: [8086:a0e9] type 00 class 0x0c8000 conventional PCI endpoint
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:15.1: BAR 0 [mem 0x00000000-0x00000fff 64bit]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:16.0: [8086:a0e0] type 00 class 0x078000 conventional PCI endpoint
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:16.0: BAR 0 [mem 0x6003247000-0x6003247fff 64bit]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:16.0: PME# supported from D3hot
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:17.0: [8086:09ab] type 00 class 0x088000 conventional PCI endpoint
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:1c.0: [8086:a0b8] type 01 class 0x060400 PCIe Root Port
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:1c.0: PCI bridge to [bus 01]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:1e.0: [8086:a0a8] type 00 class 0x078000 conventional PCI endpoint
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:1e.0: BAR 0 [mem 0x00000000-0x00000fff 64bit]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:1e.2: [8086:a0aa] type 00 class 0x0c8000 conventional PCI endpoint
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:1e.2: BAR 0 [mem 0x00000000-0x00000fff 64bit]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:1f.0: [8086:a082] type 00 class 0x060100 conventional PCI endpoint
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:1f.3: [8086:a0c8] type 00 class 0x040380 conventional PCI endpoint
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:1f.3: BAR 0 [mem 0x6003238000-0x600323bfff 64bit]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:1f.3: BAR 4 [mem 0x6003000000-0x60030fffff 64bit]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:1f.3: PME# supported from D3hot D3cold
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:1f.4: [8086:a0a3] type 00 class 0x0c0500 conventional PCI endpoint
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:1f.4: BAR 0 [mem 0x6003244000-0x60032440ff 64bit]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:1f.4: BAR 4 [io  0xefa0-0xefbf]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:1f.5: [8086:a0a4] type 00 class 0x0c8000 conventional PCI endpoint
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:1f.5: BAR 0 [mem 0xfe010000-0xfe010fff]
jun 01 11:35:27 Adrian-PC kernel: ACPI: PCI: Interrupt link LNKA configured for IRQ 0
jun 01 11:35:27 Adrian-PC kernel: ACPI: PCI: Interrupt link LNKB configured for IRQ 1
jun 01 11:35:27 Adrian-PC kernel: ACPI: PCI: Interrupt link LNKC configured for IRQ 0
jun 01 11:35:27 Adrian-PC kernel: ACPI: PCI: Interrupt link LNKD configured for IRQ 0
jun 01 11:35:27 Adrian-PC kernel: ACPI: PCI: Interrupt link LNKE configured for IRQ 0
jun 01 11:35:27 Adrian-PC kernel: ACPI: PCI: Interrupt link LNKF configured for IRQ 0
jun 01 11:35:27 Adrian-PC kernel: ACPI: PCI: Interrupt link LNKG configured for IRQ 0
jun 01 11:35:27 Adrian-PC kernel: ACPI: PCI: Interrupt link LNKH configured for IRQ 0
jun 01 11:35:27 Adrian-PC kernel: Low-power S0 idle used by default for system suspend
jun 01 11:35:27 Adrian-PC kernel: ACPI: EC: interrupt unblocked
jun 01 11:35:27 Adrian-PC kernel: ACPI: EC: event unblocked
jun 01 11:35:27 Adrian-PC kernel: ACPI: EC: GPE=0x6e
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.LPCB.EC0_: Boot ECDT EC initialization complete
jun 01 11:35:27 Adrian-PC kernel: ACPI: \_SB_.PC00.LPCB.EC0_: EC: Used to handle transactions and events
jun 01 11:35:27 Adrian-PC kernel: iommu: Default domain type: Translated
jun 01 11:35:27 Adrian-PC kernel: iommu: DMA domain TLB invalidation policy: lazy mode
jun 01 11:35:27 Adrian-PC kernel: SCSI subsystem initialized
jun 01 11:35:27 Adrian-PC kernel: libata version 3.00 loaded.
jun 01 11:35:27 Adrian-PC kernel: ACPI: bus type USB registered
jun 01 11:35:27 Adrian-PC kernel: usbcore: registered new interface driver usbfs
jun 01 11:35:27 Adrian-PC kernel: usbcore: registered new interface driver hub
jun 01 11:35:27 Adrian-PC kernel: usbcore: registered new device driver usb
jun 01 11:35:27 Adrian-PC kernel: pps_core: LinuxPPS API ver. 1 registered
jun 01 11:35:27 Adrian-PC kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
jun 01 11:35:27 Adrian-PC kernel: PTP clock support registered
jun 01 11:35:27 Adrian-PC kernel: EDAC MC: Ver: 3.0.0
jun 01 11:35:27 Adrian-PC kernel: efivars: Registered efivars operations
jun 01 11:35:27 Adrian-PC kernel: NetLabel: Initializing
jun 01 11:35:27 Adrian-PC kernel: NetLabel:  domain hash size = 128
jun 01 11:35:27 Adrian-PC kernel: NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
jun 01 11:35:27 Adrian-PC kernel: NetLabel:  unlabeled traffic allowed by default
jun 01 11:35:27 Adrian-PC kernel: mctp: management component transport protocol core
jun 01 11:35:27 Adrian-PC kernel: NET: Registered PF_MCTP protocol family
jun 01 11:35:27 Adrian-PC kernel: PCI: Using ACPI for IRQ routing
jun 01 11:35:27 Adrian-PC kernel: PCI: pci_cache_line_size set to 64 bytes
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:1f.5: BAR 0 [mem 0xfe010000-0xfe010fff]: can't claim; no compatible bridge window
jun 01 11:35:27 Adrian-PC kernel: e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
jun 01 11:35:27 Adrian-PC kernel: e820: reserve RAM buffer [mem 0x6aa8f000-0x6bffffff]
jun 01 11:35:27 Adrian-PC kernel: e820: reserve RAM buffer [mem 0x6b14f000-0x6bffffff]
jun 01 11:35:27 Adrian-PC kernel: e820: reserve RAM buffer [mem 0x6d6d9000-0x6fffffff]
jun 01 11:35:27 Adrian-PC kernel: e820: reserve RAM buffer [mem 0x72800000-0x73ffffff]
jun 01 11:35:27 Adrian-PC kernel: e820: reserve RAM buffer [mem 0x27f800000-0x27fffffff]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:02.0: vgaarb: setting as boot VGA device
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:02.0: vgaarb: bridge control possible
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
jun 01 11:35:27 Adrian-PC kernel: vgaarb: loaded
jun 01 11:35:27 Adrian-PC kernel: Monitor-Mwait will be used to enter C-1 state
jun 01 11:35:27 Adrian-PC kernel: Monitor-Mwait will be used to enter C-2 state
jun 01 11:35:27 Adrian-PC kernel: Monitor-Mwait will be used to enter C-3 state
jun 01 11:35:27 Adrian-PC kernel: clocksource: Switched to clocksource tsc-early
jun 01 11:35:27 Adrian-PC kernel: VFS: Disk quotas dquot_6.6.0
jun 01 11:35:27 Adrian-PC kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
jun 01 11:35:27 Adrian-PC kernel: AppArmor: AppArmor Filesystem Enabled
jun 01 11:35:27 Adrian-PC kernel: pnp: PnP ACPI init
jun 01 11:35:27 Adrian-PC kernel: system 00:00: [io  0x0680-0x069f] has been reserved
jun 01 11:35:27 Adrian-PC kernel: system 00:00: [io  0x164e-0x164f] has been reserved
jun 01 11:35:27 Adrian-PC kernel: pnp 00:02: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
jun 01 11:35:27 Adrian-PC kernel: system 00:02: [mem 0xfedc0000-0xfedc7fff] has been reserved
jun 01 11:35:27 Adrian-PC kernel: system 00:02: [mem 0xfeda0000-0xfeda0fff] has been reserved
jun 01 11:35:27 Adrian-PC kernel: system 00:02: [mem 0xfeda1000-0xfeda1fff] has been reserved
jun 01 11:35:27 Adrian-PC kernel: system 00:02: [mem 0xfed20000-0xfed7ffff] could not be reserved
jun 01 11:35:27 Adrian-PC kernel: system 00:02: [mem 0xfed90000-0xfed93fff] could not be reserved
jun 01 11:35:27 Adrian-PC kernel: system 00:02: [mem 0xfed45000-0xfed8ffff] could not be reserved
jun 01 11:35:27 Adrian-PC kernel: system 00:02: [mem 0xfee00000-0xfeefffff] could not be reserved
jun 01 11:35:27 Adrian-PC kernel: system 00:03: [io  0x1800-0x18fe] could not be reserved
jun 01 11:35:27 Adrian-PC kernel: system 00:03: [mem 0xfe000000-0xfe01ffff] could not be reserved
jun 01 11:35:27 Adrian-PC kernel: system 00:03: [mem 0xfe04c000-0xfe04ffff] has been reserved
jun 01 11:35:27 Adrian-PC kernel: system 00:03: [mem 0xfe050000-0xfe0affff] has been reserved
jun 01 11:35:27 Adrian-PC kernel: system 00:03: [mem 0xfe0d0000-0xfe0fffff] has been reserved
jun 01 11:35:27 Adrian-PC kernel: system 00:03: [mem 0xfe200000-0xfe7fffff] has been reserved
jun 01 11:35:27 Adrian-PC kernel: system 00:03: [mem 0xff000000-0xffffffff] has been reserved
jun 01 11:35:27 Adrian-PC kernel: system 00:03: [mem 0xfd000000-0xfd68ffff] has been reserved
jun 01 11:35:27 Adrian-PC kernel: system 00:03: [mem 0xfd6b0000-0xfd6cffff] has been reserved
jun 01 11:35:27 Adrian-PC kernel: system 00:03: [mem 0xfd6f0000-0xfdffffff] has been reserved
jun 01 11:35:27 Adrian-PC kernel: system 00:04: [io  0x2000-0x20fe] has been reserved
jun 01 11:35:27 Adrian-PC kernel: pnp: PnP ACPI: found 6 devices
jun 01 11:35:27 Adrian-PC kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
jun 01 11:35:27 Adrian-PC kernel: NET: Registered PF_INET protocol family
jun 01 11:35:27 Adrian-PC kernel: IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
jun 01 11:35:27 Adrian-PC kernel: tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
jun 01 11:35:27 Adrian-PC kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
jun 01 11:35:27 Adrian-PC kernel: TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
jun 01 11:35:27 Adrian-PC kernel: TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
jun 01 11:35:27 Adrian-PC kernel: TCP: Hash tables configured (established 65536 bind 65536)
jun 01 11:35:27 Adrian-PC kernel: MPTCP token hash table entries: 8192 (order: 6, 196608 bytes, linear)
jun 01 11:35:27 Adrian-PC kernel: UDP hash table entries: 4096 (order: 6, 262144 bytes, linear)
jun 01 11:35:27 Adrian-PC kernel: UDP-Lite hash table entries: 4096 (order: 6, 262144 bytes, linear)
jun 01 11:35:27 Adrian-PC kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
jun 01 11:35:27 Adrian-PC kernel: NET: Registered PF_XDP protocol family
jun 01 11:35:27 Adrian-PC kernel: pci_bus 0000:00: max bus depth: 1 pci_try_num: 2
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:02.0: VF BAR 2 [mem 0x4020000000-0x40ffffffff 64bit pref]: assigned
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:02.0: VF BAR 0 [mem 0x4010000000-0x4016ffffff 64bit]: assigned
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:15.0: BAR 0 [mem 0x4017000000-0x4017000fff 64bit]: assigned
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:15.1: BAR 0 [mem 0x4017001000-0x4017001fff 64bit]: assigned
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:1e.0: BAR 0 [mem 0x4017002000-0x4017002fff 64bit]: assigned
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:1e.2: BAR 0 [mem 0x4017003000-0x4017003fff 64bit]: assigned
jun 01 11:35:27 Adrian-PC kernel: resource: avoiding allocation from e820 entry [mem 0x0009f000-0x000fffff]
jun 01 11:35:27 Adrian-PC kernel: pci 0000:00:1f.5: BAR 0 [mem 0x80800000-0x80800fff]: assigned
jun 01 11:35:27 Adrian-PC kernel: pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
jun 01 11:35:27 Adrian-PC kernel: pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
jun 01 11:35:27 Adrian-PC kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
jun 01 11:35:27 Adrian-PC kernel: pci_bus 0000:00: resource 7 [mem 0x000e0000-0x000fffff window]
jun 01 11:35:27 Adrian-PC kernel: pci_bus 0000:00: resource 8 [mem 0x80800000-0xbfffffff window]
jun 01 11:35:27 Adrian-PC kernel: pci_bus 0000:00: resource 9 [mem 0x4000000000-0x7fffffffff window]
jun 01 11:35:27 Adrian-PC kernel: PCI: CLS 64 bytes, default 64
jun 01 11:35:27 Adrian-PC kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
jun 01 11:35:27 Adrian-PC kernel: software IO TLB: mapped [mem 0x000000006329b000-0x000000006729b000] (64MB)
jun 01 11:35:27 Adrian-PC kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x22df1149949, max_idle_ns: 440795312789 ns
jun 01 11:35:27 Adrian-PC kernel: platform rtc_cmos: registered platform RTC device (no PNP device found)
jun 01 11:35:27 Adrian-PC kernel: Trying to unpack rootfs image as initramfs...
jun 01 11:35:27 Adrian-PC kernel: Initialise system trusted keyrings
jun 01 11:35:27 Adrian-PC kernel: Key type blacklist registered
jun 01 11:35:27 Adrian-PC kernel: workingset: timestamp_bits=36 max_order=21 bucket_order=0
jun 01 11:35:27 Adrian-PC kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
jun 01 11:35:27 Adrian-PC kernel: fuse: init (API version 7.45)
jun 01 11:35:27 Adrian-PC kernel: integrity: Platform Keyring initialized
jun 01 11:35:27 Adrian-PC kernel: Key type asymmetric registered
jun 01 11:35:27 Adrian-PC kernel: Asymmetric key parser 'x509' registered
jun 01 11:35:27 Adrian-PC kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
jun 01 11:35:27 Adrian-PC kernel: io scheduler mq-deadline registered
jun 01 11:35:27 Adrian-PC kernel: ledtrig-cpu: registered to indicate activity on CPUs
jun 01 11:35:27 Adrian-PC kernel: pcieport 0000:00:1c.0: PME: Signaling with IRQ 120
jun 01 11:35:27 Adrian-PC kernel: efifb: probing for efifb
jun 01 11:35:27 Adrian-PC kernel: efifb: framebuffer at 0x4000000000, using 8100k, total 8100k
jun 01 11:35:27 Adrian-PC kernel: efifb: mode is 1920x1080x32, linelength=7680, pages=1
jun 01 11:35:27 Adrian-PC kernel: efifb: scrolling: redraw
jun 01 11:35:27 Adrian-PC kernel: efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
jun 01 11:35:27 Adrian-PC kernel: fbcon: Deferring console take-over
jun 01 11:35:27 Adrian-PC kernel: fb0: EFI VGA frame buffer device
jun 01 11:35:27 Adrian-PC kernel: ACPI: AC: AC Adapter [AC0] (on-line)
jun 01 11:35:27 Adrian-PC kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:09/PNP0C09:01/PNP0C0D:00/input/input0
jun 01 11:35:27 Adrian-PC kernel: ACPI: button: Lid Switch [LID]
jun 01 11:35:27 Adrian-PC kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
jun 01 11:35:27 Adrian-PC kernel: ACPI: button: Power Button [PWRB]
jun 01 11:35:27 Adrian-PC kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
jun 01 11:35:27 Adrian-PC kernel: ACPI: button: Power Button [PWRF]
jun 01 11:35:27 Adrian-PC kernel: thermal LNXTHERM:00: registered as thermal_zone0
jun 01 11:35:27 Adrian-PC kernel: ACPI: thermal: Thermal Zone [THRM] (62 C)
jun 01 11:35:27 Adrian-PC kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
jun 01 11:35:27 Adrian-PC kernel: hpet_acpi_add: no address or irqs in _CRS
jun 01 11:35:27 Adrian-PC kernel: Linux agpgart interface v0.103
jun 01 11:35:27 Adrian-PC kernel: ACPI: battery: Slot [BAT0] (battery present)
jun 01 11:35:27 Adrian-PC kernel: loop: module loaded
jun 01 11:35:27 Adrian-PC kernel: mei_me 0000:00:16.0: enabling device (0000 -> 0002)
jun 01 11:35:27 Adrian-PC kernel: Key type psk registered
jun 01 11:35:27 Adrian-PC kernel: tun: Universal TUN/TAP device driver, 1.6
jun 01 11:35:27 Adrian-PC kernel: PPP generic driver version 2.4.2
jun 01 11:35:27 Adrian-PC kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
jun 01 11:35:27 Adrian-PC kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
jun 01 11:35:27 Adrian-PC kernel: xhci_hcd 0000:00:14.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000100200009810
jun 01 11:35:27 Adrian-PC kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
jun 01 11:35:27 Adrian-PC kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
jun 01 11:35:27 Adrian-PC kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.18
jun 01 11:35:27 Adrian-PC kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
jun 01 11:35:27 Adrian-PC kernel: usb usb1: Product: xHCI Host Controller
jun 01 11:35:27 Adrian-PC kernel: usb usb1: Manufacturer: Linux 6.18.27-amd64-desktop-rolling xhci-hcd
jun 01 11:35:27 Adrian-PC kernel: usb usb1: SerialNumber: 0000:00:14.0
jun 01 11:35:27 Adrian-PC kernel: hub 1-0:1.0: USB hub found
jun 01 11:35:27 Adrian-PC kernel: hub 1-0:1.0: 12 ports detected
jun 01 11:35:27 Adrian-PC kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.18
jun 01 11:35:27 Adrian-PC kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
jun 01 11:35:27 Adrian-PC kernel: usb usb2: Product: xHCI Host Controller
jun 01 11:35:27 Adrian-PC kernel: usb usb2: Manufacturer: Linux 6.18.27-amd64-desktop-rolling xhci-hcd
jun 01 11:35:27 Adrian-PC kernel: usb usb2: SerialNumber: 0000:00:14.0
jun 01 11:35:27 Adrian-PC kernel: hub 2-0:1.0: USB hub found
jun 01 11:35:27 Adrian-PC kernel: hub 2-0:1.0: 4 ports detected
jun 01 11:35:27 Adrian-PC kernel: usb: port power management may be unreliable
jun 01 11:35:27 Adrian-PC kernel: usbcore: registered new interface driver usbserial_generic
jun 01 11:35:27 Adrian-PC kernel: usbserial: USB Serial support registered for generic
jun 01 11:35:27 Adrian-PC kernel: i8042: PNP: PS/2 Controller [PNP030b:PS2K] at 0x60,0x64 irq 1
jun 01 11:35:27 Adrian-PC kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
jun 01 11:35:27 Adrian-PC kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
jun 01 11:35:27 Adrian-PC kernel: hv_vmbus: registering driver hyperv_keyboard
jun 01 11:35:27 Adrian-PC kernel: mousedev: PS/2 mouse device common for all mice
jun 01 11:35:27 Adrian-PC kernel: usbcore: registered new interface driver bcm5974
jun 01 11:35:27 Adrian-PC kernel: rtc_cmos rtc_cmos: RTC can wake from S4
jun 01 11:35:27 Adrian-PC kernel: rtc_cmos rtc_cmos: registered as rtc0
jun 01 11:35:27 Adrian-PC kernel: rtc_cmos rtc_cmos: setting system clock to 2026-06-01T11:35:24 UTC (1780313724)
jun 01 11:35:27 Adrian-PC kernel: rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
jun 01 11:35:27 Adrian-PC kernel: i2c_dev: i2c /dev entries driver
jun 01 11:35:27 Adrian-PC kernel: device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
jun 01 11:35:27 Adrian-PC kernel: device-mapper: uevent: version 1.0.3
jun 01 11:35:27 Adrian-PC kernel: device-mapper: ioctl: 4.50.0-ioctl (2025-04-28) initialised: dm-devel@lists.linux.dev
jun 01 11:35:27 Adrian-PC kernel: intel_pstate: Intel P-state driver initializing
jun 01 11:35:27 Adrian-PC kernel: intel_pstate: HWP enabled
jun 01 11:35:27 Adrian-PC kernel: drop_monitor: Initializing network drop monitor service
jun 01 11:35:27 Adrian-PC kernel: NET: Registered PF_INET6 protocol family
jun 01 11:35:27 Adrian-PC kernel: Segment Routing with IPv6
jun 01 11:35:27 Adrian-PC kernel: In-situ OAM (IOAM) with IPv6
jun 01 11:35:27 Adrian-PC kernel: NET: Registered PF_PACKET protocol family
jun 01 11:35:27 Adrian-PC kernel: Key type dns_resolver registered
jun 01 11:35:27 Adrian-PC kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
jun 01 11:35:27 Adrian-PC kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
jun 01 11:35:27 Adrian-PC kernel: microcode: Current revision: 0x000000bc
jun 01 11:35:27 Adrian-PC kernel: microcode: Updated early from: 0x0000009a
jun 01 11:35:27 Adrian-PC kernel: resctrl: L2 allocation detected
jun 01 11:35:27 Adrian-PC kernel: IPI shorthand broadcast: enabled
jun 01 11:35:27 Adrian-PC kernel: sched_clock: Marking stable (464001476, 6670376)->(510397939, -39726087)
jun 01 11:35:27 Adrian-PC kernel: registered taskstats version 1
jun 01 11:35:27 Adrian-PC kernel: Loading compiled-in X.509 certificates
jun 01 11:35:27 Adrian-PC kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 54fb2ed8e027a13bb0c392a25e8697cbc3316be6'
jun 01 11:35:27 Adrian-PC kernel: Demotion targets for Node 0: null
jun 01 11:35:27 Adrian-PC kernel: Key type .fscrypt registered
jun 01 11:35:27 Adrian-PC kernel: Key type fscrypt-provisioning registered
jun 01 11:35:27 Adrian-PC kernel: Key type trusted registered
jun 01 11:35:27 Adrian-PC kernel: usb 1-1: new low-speed USB device number 2 using xhci_hcd
jun 01 11:35:27 Adrian-PC kernel: usb 1-1: New USB device found, idVendor=1c4f, idProduct=0034, bcdDevice= 1.10
jun 01 11:35:27 Adrian-PC kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
jun 01 11:35:27 Adrian-PC kernel: usb 1-1: Product: Usb Mouse
jun 01 11:35:27 Adrian-PC kernel: usb 1-1: Manufacturer: SIGMACHIP
jun 01 11:35:27 Adrian-PC kernel: usb 1-3: new high-speed USB device number 3 using xhci_hcd
jun 01 11:35:27 Adrian-PC kernel: Freeing initrd memory: 188160K
jun 01 11:35:27 Adrian-PC kernel: Key type encrypted registered
jun 01 11:35:27 Adrian-PC kernel: AppArmor: AppArmor sha256 policy hashing enabled
jun 01 11:35:27 Adrian-PC kernel: integrity: Loading X.509 certificate: UEFI:db
jun 01 11:35:27 Adrian-PC kernel: integrity: Loaded X.509 cert 'ASUSTeK Notebook SW Key Certificate: b8e581e4df77a5bb4282d5ccfc00c071'
jun 01 11:35:27 Adrian-PC kernel: integrity: Loaded X.509 cert 'ASUSTeK MotherBoard SW Key Certificate: da83b990422ebc8c441f8d8b039a65a2'
jun 01 11:35:27 Adrian-PC kernel: integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
jun 01 11:35:27 Adrian-PC kernel: integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
jun 01 11:35:27 Adrian-PC kernel: integrity: Loaded X.509 cert 'Canonical Ltd. Master Certificate Authority: ad91990bc22ab1f517048c23b6655a268e345a63'
jun 01 11:35:27 Adrian-PC kernel: Loading compiled-in module X.509 certificates
jun 01 11:35:27 Adrian-PC kernel: ima: Allocated hash algorithm: sha256
jun 01 11:35:27 Adrian-PC kernel: ima: No architecture policies found
jun 01 11:35:27 Adrian-PC kernel: evm: Initialising EVM extended attributes:
jun 01 11:35:27 Adrian-PC kernel: evm: security.selinux
jun 01 11:35:27 Adrian-PC kernel: evm: security.SMACK64
jun 01 11:35:27 Adrian-PC kernel: evm: security.SMACK64EXEC
jun 01 11:35:27 Adrian-PC kernel: evm: security.SMACK64TRANSMUTE
jun 01 11:35:27 Adrian-PC kernel: evm: security.SMACK64MMAP
jun 01 11:35:27 Adrian-PC kernel: evm: security.apparmor
jun 01 11:35:27 Adrian-PC kernel: evm: security.ima
jun 01 11:35:27 Adrian-PC kernel: evm: security.capability
jun 01 11:35:27 Adrian-PC kernel: evm: HMAC attrs: 0x1
jun 01 11:35:27 Adrian-PC kernel: PM:   Magic number: 14:269:579
jun 01 11:35:27 Adrian-PC kernel: mei 0000:00:16.0-8c2f4425-77d6-4755-aca3-891fdbc66a58: hash matches
jun 01 11:35:27 Adrian-PC kernel: pci_bus 0000:00: hash matches
jun 01 11:35:27 Adrian-PC kernel: acpi LNXPOWER:1a: hash matches
jun 01 11:35:27 Adrian-PC kernel: RAS: Correctable Errors collector initialized.
jun 01 11:35:27 Adrian-PC kernel: clk: Disabling unused clocks
jun 01 11:35:27 Adrian-PC kernel: PM: genpd: Disabling unused power domains
jun 01 11:35:27 Adrian-PC kernel: Freeing unused decrypted memory: 2028K
jun 01 11:35:27 Adrian-PC kernel: Freeing unused kernel image (initmem) memory: 5420K
jun 01 11:35:27 Adrian-PC kernel: Write protecting the kernel read-only data: 38912k
jun 01 11:35:27 Adrian-PC kernel: Freeing unused kernel image (text/rodata gap) memory: 236K
jun 01 11:35:27 Adrian-PC kernel: Freeing unused kernel image (rodata/data gap) memory: 704K
jun 01 11:35:27 Adrian-PC kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
jun 01 11:35:27 Adrian-PC kernel: Run /init as init process
jun 01 11:35:27 Adrian-PC kernel:   with arguments:
jun 01 11:35:27 Adrian-PC kernel:     /init
jun 01 11:35:27 Adrian-PC kernel:     splash
jun 01 11:35:27 Adrian-PC kernel:   with environment:
jun 01 11:35:27 Adrian-PC kernel:     HOME=/
jun 01 11:35:27 Adrian-PC kernel:     TERM=linux
jun 01 11:35:27 Adrian-PC kernel:     ostree=auto
jun 01 11:35:27 Adrian-PC kernel:     locales=es_ES.UTF-8
jun 01 11:35:27 Adrian-PC kernel:     DEEPIN_GFXMODE=3,1366x768,1280x1024,1024x768,1920x1080
jun 01 11:35:27 Adrian-PC kernel: usb 1-3: New USB device found, idVendor=13d3, idProduct=5a11, bcdDevice=17.02
jun 01 11:35:27 Adrian-PC kernel: usb 1-3: New USB device strings: Mfr=3, Product=1, SerialNumber=2
jun 01 11:35:27 Adrian-PC kernel: usb 1-3: Product: USB2.0 VGA UVC WebCam
jun 01 11:35:27 Adrian-PC kernel: usb 1-3: Manufacturer: Azurewave
jun 01 11:35:27 Adrian-PC kernel: usb 1-3: SerialNumber:
jun 01 11:35:27 Adrian-PC kernel: usb 1-10: new full-speed USB device number 4 using xhci_hcd
jun 01 11:35:27 Adrian-PC kernel: vmd 0000:00:0e.0: PCI host bridge to bus 10000:e0
jun 01 11:35:27 Adrian-PC kernel: pci_bus 10000:e0: root bus resource [bus e0-ff]
jun 01 11:35:27 Adrian-PC kernel: pci_bus 10000:e0: root bus resource [mem 0x82000000-0x83ffffff]
jun 01 11:35:27 Adrian-PC kernel: pci_bus 10000:e0: root bus resource [mem 0x6003102000-0x60031fffff 64bit]
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:17.0: [8086:a0d3] type 00 class 0x010601 conventional PCI endpoint
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:17.0: BAR 0 [mem 0x00000000-0x00001fff]
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:17.0: BAR 1 [mem 0x00000000-0x000000ff]
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:17.0: BAR 2 [io  0x0000-0x0007]
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:17.0: BAR 3 [io  0x0000-0x0003]
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:17.0: BAR 4 [io  0x0000-0x001f]
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:17.0: BAR 5 [mem 0x82000000-0x820007ff]
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:17.0: PME# supported from D3hot
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:1c.0: [8086:09ab] type 00 class 0x088000 conventional PCI endpoint
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:1c.4: [8086:a0bc] type 01 class 0x060400 PCIe Root Port
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:1c.4: PCI bridge to [bus e1]
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:1c.4:   bridge window [io  0x0000-0x0fff]
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:1c.4:   bridge window [mem 0x82100000-0x821fffff]
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:1c.4: PME# supported from D0 D3hot D3cold
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:1c.4: PTM enabled (root), 4ns granularity
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:1c.4: Primary bus is hard wired to 0
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e1:00.0: [15b7:5009] type 00 class 0x010802 PCIe Endpoint
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e1:00.0: BAR 0 [mem 0x82100000-0x82103fff 64bit]
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e1:00.0: BAR 4 [mem 0x00000000-0x000000ff 64bit]
jun 01 11:35:27 Adrian-PC kernel: ACPI: bus type drm_connector registered
jun 01 11:35:27 Adrian-PC kernel: i801_smbus 0000:00:1f.4: SPD Write Disable is set
jun 01 11:35:27 Adrian-PC kernel: i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
jun 01 11:35:27 Adrian-PC kernel: intel-lpss 0000:00:15.0: enabling device (0004 -> 0006)
jun 01 11:35:27 Adrian-PC kernel: idma64 idma64.0: Found Intel integrated DMA 64-bit
jun 01 11:35:27 Adrian-PC kernel: hid: raw HID events driver (C) Jiri Kosina
jun 01 11:35:27 Adrian-PC kernel: asus_wmi: ASUS WMI generic driver loaded
jun 01 11:35:27 Adrian-PC kernel: intel-lpss 0000:00:15.1: enabling device (0004 -> 0006)
jun 01 11:35:27 Adrian-PC kernel: idma64 idma64.1: Found Intel integrated DMA 64-bit
jun 01 11:35:27 Adrian-PC kernel: intel-lpss 0000:00:1e.0: enabling device (0000 -> 0002)
jun 01 11:35:27 Adrian-PC kernel: idma64 idma64.2: Found Intel integrated DMA 64-bit
jun 01 11:35:27 Adrian-PC kernel: intel-lpss 0000:00:1e.2: enabling device (0004 -> 0006)
jun 01 11:35:27 Adrian-PC kernel: idma64 idma64.3: Found Intel integrated DMA 64-bit
jun 01 11:35:27 Adrian-PC kernel: usb 1-10: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
jun 01 11:35:27 Adrian-PC kernel: usb 1-10: New USB device strings: Mfr=0, Product=0, SerialNumber=0
jun 01 11:35:27 Adrian-PC kernel: usbcore: registered new interface driver usbhid
jun 01 11:35:27 Adrian-PC kernel: usbhid: USB HID core driver
jun 01 11:35:27 Adrian-PC kernel: usbcore: registered new interface driver usbmouse
jun 01 11:35:27 Adrian-PC kernel: input: SIGMACHIP Usb Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:1C4F:0034.0001/input/input4
jun 01 11:35:27 Adrian-PC kernel: hid-generic 0003:1C4F:0034.0001: input,hidraw0: USB HID v1.10 Mouse [SIGMACHIP Usb Mouse] on usb-0000:00:14.0-1/input0
jun 01 11:35:27 Adrian-PC kernel: input: ASUE1301:00 04F3:3128 Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-ASUE1301:00/0018:04F3:3128.0002/input/input5
jun 01 11:35:27 Adrian-PC kernel: input: ASUE1301:00 04F3:3128 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-ASUE1301:00/0018:04F3:3128.0002/input/input6
jun 01 11:35:27 Adrian-PC kernel: hid-generic 0018:04F3:3128.0002: input,hidraw1: I2C HID v1.00 Mouse [ASUE1301:00 04F3:3128] on i2c-ASUE1301:00
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:1c.4: disabling bridge window [mem size 0x00000000 64bit pref disabled] to [bus e1] (unused)
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:1c.4: bridge window [mem 0x82000000-0x820fffff]: assigned
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:17.0: BAR 0 [mem 0x82100000-0x82101fff]: assigned
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:1c.4: bridge window [io  size 0x1000]: can't assign; no space
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:1c.4: bridge window [io  size 0x1000]: failed to assign
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:17.0: BAR 5 [mem 0x82102000-0x821027ff]: assigned
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:17.0: BAR 1 [mem 0x82102800-0x821028ff]: assigned
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:17.0: BAR 4 [io  size 0x0020]: can't assign; no space
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:17.0: BAR 4 [io  size 0x0020]: failed to assign
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:17.0: BAR 2 [io  size 0x0008]: can't assign; no space
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:17.0: BAR 2 [io  size 0x0008]: failed to assign
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:17.0: BAR 3 [io  size 0x0004]: can't assign; no space
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e0:17.0: BAR 3 [io  size 0x0004]: failed to assign
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e1:00.0: BAR 0 [mem 0x82000000-0x82003fff 64bit]: assigned
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e1:00.0: BAR 4 [mem 0x82004000-0x820040ff 64bit]: assigned
jun 01 11:35:27 Adrian-PC kernel: pci 10000:e1:00.0: VMD: Default LTR value set by driver
jun 01 11:35:27 Adrian-PC kernel: ahci 10000:e0:17.0: can't derive routing for PCI INT A
jun 01 11:35:27 Adrian-PC kernel: ahci 10000:e0:17.0: PCI INT A: no GSI
jun 01 11:35:27 Adrian-PC kernel: ahci 10000:e0:17.0: AHCI vers 0001.0301, 32 command slots, 6 Gbps, SATA mode
jun 01 11:35:27 Adrian-PC kernel: ahci 10000:e0:17.0: 1/1 ports implemented (port mask 0x2)
jun 01 11:35:27 Adrian-PC kernel: ahci 10000:e0:17.0: flags: 64bit ncq sntf pm clo only pio slum part deso sadm sds
jun 01 11:35:27 Adrian-PC kernel: scsi host0: ahci
jun 01 11:35:27 Adrian-PC kernel: scsi host1: ahci
jun 01 11:35:27 Adrian-PC kernel: ata1: DUMMY
jun 01 11:35:27 Adrian-PC kernel: ata2: SATA max UDMA/133 abar m2048@0x82102000 port 0x82102180 irq 150 lpm-pol 4
jun 01 11:35:27 Adrian-PC kernel: pcieport 10000:e0:1c.4: can't derive routing for PCI INT A
jun 01 11:35:27 Adrian-PC kernel: pcieport 10000:e0:1c.4: PCI INT A: no GSI
jun 01 11:35:27 Adrian-PC kernel: pcieport 10000:e0:1c.4: PME: Signaling with IRQ 151
jun 01 11:35:27 Adrian-PC kernel: pcieport 10000:e0:1c.4: AER: enabled with IRQ 151
jun 01 11:35:27 Adrian-PC kernel: pcieport 10000:e0:1c.4: DPC: enabled with IRQ 151
jun 01 11:35:27 Adrian-PC kernel: pcieport 10000:e0:1c.4: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
jun 01 11:35:27 Adrian-PC kernel: vmd 0000:00:0e.0: Bound to PCI domain 10000
jun 01 11:35:27 Adrian-PC kernel: nvme nvme0: pci function 10000:e1:00.0
jun 01 11:35:27 Adrian-PC kernel: nvme 10000:e1:00.0: PCI INT A: no GSI
jun 01 11:35:27 Adrian-PC kernel: nvme nvme0: allocated 32 MiB host memory buffer (8 segments).
jun 01 11:35:27 Adrian-PC kernel: nvme nvme0: 8/0/0 default/read/poll queues
jun 01 11:35:27 Adrian-PC kernel:  nvme0n1: p1 p2 p3 p4 p5
jun 01 11:35:27 Adrian-PC kernel: ata2: SATA link down (SStatus 0 SControl 300)
jun 01 11:35:27 Adrian-PC kernel: i915 0000:00:02.0: [drm] Found tigerlake/uy (device ID 9a49) integrated display version 12.00 stepping C0
jun 01 11:35:27 Adrian-PC kernel: i915 0000:00:02.0: vgaarb: deactivate vga console
jun 01 11:35:27 Adrian-PC kernel: i915 0000:00:02.0: [drm] Using Transparent Hugepages
jun 01 11:35:27 Adrian-PC kernel: i915 0000:00:02.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=io+mem:owns=io+mem
jun 01 11:35:27 Adrian-PC kernel: i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/tgl_dmc_ver2_12.bin (v2.12)
jun 01 11:35:27 Adrian-PC kernel: i915 0000:00:02.0: [drm] Protected Xe Path (PXP) protected content support initialized
jun 01 11:35:27 Adrian-PC kernel: i915 0000:00:02.0: [drm] Registered 4 planes with drm panic
jun 01 11:35:27 Adrian-PC kernel: [drm] Initialized i915 1.6.0 for 0000:00:02.0 on minor 0
jun 01 11:35:27 Adrian-PC kernel: ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
jun 01 11:35:27 Adrian-PC kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input7
jun 01 11:35:27 Adrian-PC kernel: fbcon: i915drmfb (fb0) is primary device
jun 01 11:35:27 Adrian-PC kernel: i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
jun 01 11:35:27 Adrian-PC kernel: PM: Image not found (code -22)
jun 01 11:35:27 Adrian-PC kernel: EXT4-fs (nvme0n1p4): mounted filesystem 6b64d00b-dcb9-4fed-9da6-5001ba778547 ro with ordered data mode. Quota mode: none.
jun 01 11:35:27 Adrian-PC kernel: EXT4-fs (nvme0n1p4): re-mounted 6b64d00b-dcb9-4fed-9da6-5001ba778547 r/w.
jun 01 11:35:27 Adrian-PC kernel: EXT4-fs (nvme0n1p5): recovery complete
jun 01 11:35:27 Adrian-PC kernel: EXT4-fs (nvme0n1p5): mounted filesystem fe412338-68ec-49cd-b285-f43fdcf8c926 r/w with ordered data mode. Quota mode: none.
jun 01 11:35:27 Adrian-PC kernel: overlayfs: "xino" feature enabled using 32 upper inode bits.
jun 01 11:35:27 Adrian-PC kernel: Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
jun 01 11:35:27 Adrian-PC systemd[1]: RTC configured in localtime, applying delta of -180 minutes to system time.
jun 01 11:35:27 Adrian-PC systemd[1]: Inserted module 'autofs4'
jun 01 11:35:27 Adrian-PC kernel: pstore: Using crash dump compression: deflate
jun 01 11:35:27 Adrian-PC kernel: lp: driver loaded but no devices found
jun 01 11:35:27 Adrian-PC kernel: EXT4-fs (nvme0n1p4): re-mounted 6b64d00b-dcb9-4fed-9da6-5001ba778547.
jun 01 11:35:27 Adrian-PC kernel: pstore: Registered efi_pstore as persistent store backend
jun 01 11:35:27 Adrian-PC systemd-journald[501]: Collecting audit messages is disabled.
jun 01 11:35:27 Adrian-PC kernel: ppdev: user-space parallel port driver
jun 01 11:35:27 Adrian-PC kernel: loop0: detected capacity change from 0 to 8
jun 01 11:35:27 Adrian-PC kernel: loop1: detected capacity change from 0 to 785112
jun 01 11:35:27 Adrian-PC kernel: loop2: detected capacity change from 0 to 786072
jun 01 11:35:27 Adrian-PC kernel: loop3: detected capacity change from 0 to 113648
jun 01 11:35:27 Adrian-PC kernel: loop4: detected capacity change from 0 to 113640
jun 01 11:35:27 Adrian-PC kernel: loop5: detected capacity change from 0 to 130616
jun 01 11:35:27 Adrian-PC kernel: loop6: detected capacity change from 0 to 130624
jun 01 11:35:27 Adrian-PC kernel: loop7: detected capacity change from 0 to 151456
jun 01 11:35:27 Adrian-PC kernel: loop8: detected capacity change from 0 to 151512
jun 01 11:35:27 Adrian-PC kernel: loop9: detected capacity change from 0 to 1088256
jun 01 11:35:28 Adrian-PC systemd-journald[501]: Received client request to flush runtime journal.
jun 01 11:35:28 Adrian-PC systemd-journald[501]: File /var/log/journal/0e0b9956ac3d4324831a40f9e5b14fe7/system.journal corrupted or uncleanly shut down, renaming and replacing.
jun 01 11:35:28 Adrian-PC kernel: ACPI BIOS Error (bug): Could not resolve symbol [\CTDP], AE_NOT_FOUND (20250807/psargs-332)
jun 01 11:35:28 Adrian-PC kernel: ACPI Error: Aborting method \_SB.IETM.IDSP due to previous error (AE_NOT_FOUND) (20250807/psparse-529)
jun 01 11:35:28 Adrian-PC kernel: ACPI Warning: \_SB.IETM._TRT: Return Package has no elements (empty) (20250807/nsprepkg-94)
jun 01 11:35:28 Adrian-PC kernel: input: ASUE1301:00 04F3:3128 Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-ASUE1301:00/0018:04F3:3128.0002/input/input8
jun 01 11:35:28 Adrian-PC kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._CRT.S1CT], AE_NOT_FOUND (20250807/psargs-332)
jun 01 11:35:28 Adrian-PC kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._CRT due to previous error (AE_NOT_FOUND) (20250807/psparse-529)
jun 01 11:35:28 Adrian-PC kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._HOT.S1HT], AE_NOT_FOUND (20250807/psargs-332)
jun 01 11:35:28 Adrian-PC kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._HOT due to previous error (AE_NOT_FOUND) (20250807/psparse-529)
jun 01 11:35:28 Adrian-PC kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._PSV.S1PT], AE_NOT_FOUND (20250807/psargs-332)
jun 01 11:35:28 Adrian-PC kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._PSV due to previous error (AE_NOT_FOUND) (20250807/psparse-529)
jun 01 11:35:28 Adrian-PC kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._AC0.S1AT], AE_NOT_FOUND (20250807/psargs-332)
jun 01 11:35:28 Adrian-PC kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._AC0 due to previous error (AE_NOT_FOUND) (20250807/psparse-529)
jun 01 11:35:28 Adrian-PC kernel: input: ASUE1301:00 04F3:3128 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-ASUE1301:00/0018:04F3:3128.0002/input/input9
jun 01 11:35:28 Adrian-PC kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN2._CRT.S2CT], AE_NOT_FOUND (20250807/psargs-332)
jun 01 11:35:28 Adrian-PC kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN2._CRT due to previous error (AE_NOT_FOUND) (20250807/psparse-529)
jun 01 11:35:28 Adrian-PC kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN2._HOT.S2HT], AE_NOT_FOUND (20250807/psargs-332)
jun 01 11:35:28 Adrian-PC kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN2._HOT due to previous error (AE_NOT_FOUND) (20250807/psparse-529)
jun 01 11:35:28 Adrian-PC kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN2._PSV.S2PT], AE_NOT_FOUND (20250807/psargs-332)
jun 01 11:35:28 Adrian-PC kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN2._PSV due to previous error (AE_NOT_FOUND) (20250807/psparse-529)
jun 01 11:35:28 Adrian-PC kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN2._AC0.S2AT], AE_NOT_FOUND (20250807/psargs-332)
jun 01 11:35:28 Adrian-PC kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN2._AC0 due to previous error (AE_NOT_FOUND) (20250807/psparse-529)
jun 01 11:35:28 Adrian-PC kernel: intel_pmc_core INT33A1:00:  initialized
jun 01 11:35:28 Adrian-PC kernel: hid-multitouch 0018:04F3:3128.0002: input,hidraw1: I2C HID v1.00 Mouse [ASUE1301:00 04F3:3128] on i2c-ASUE1301:00
jun 01 11:35:28 Adrian-PC kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN3._CRT.S3CT], AE_NOT_FOUND (20250807/psargs-332)
jun 01 11:35:28 Adrian-PC kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN3._CRT due to previous error (AE_NOT_FOUND) (20250807/psparse-529)
jun 01 11:35:28 Adrian-PC kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN3._HOT.S3HT], AE_NOT_FOUND (20250807/psargs-332)
jun 01 11:35:28 Adrian-PC kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN3._HOT due to previous error (AE_NOT_FOUND) (20250807/psparse-529)
jun 01 11:35:28 Adrian-PC kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN3._PSV.S3PT], AE_NOT_FOUND (20250807/psargs-332)
jun 01 11:35:28 Adrian-PC kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN3._PSV due to previous error (AE_NOT_FOUND) (20250807/psparse-529)
jun 01 11:35:28 Adrian-PC kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN4._CRT.S4CT], AE_NOT_FOUND (20250807/psargs-332)
jun 01 11:35:28 Adrian-PC kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN4._CRT due to previous error (AE_NOT_FOUND) (20250807/psparse-529)
jun 01 11:35:28 Adrian-PC kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN4._HOT.S4HT], AE_NOT_FOUND (20250807/psargs-332)
jun 01 11:35:28 Adrian-PC kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN4._HOT due to previous error (AE_NOT_FOUND) (20250807/psparse-529)
jun 01 11:35:28 Adrian-PC kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN4._PSV.S4PT], AE_NOT_FOUND (20250807/psargs-332)
jun 01 11:35:28 Adrian-PC kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN4._PSV due to previous error (AE_NOT_FOUND) (20250807/psparse-529)
jun 01 11:35:28 Adrian-PC kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN4._AC0.S4AT], AE_NOT_FOUND (20250807/psargs-332)
jun 01 11:35:28 Adrian-PC kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN4._AC0 due to previous error (AE_NOT_FOUND) (20250807/psparse-529)
jun 01 11:35:28 Adrian-PC kernel: EDAC igen6: v2.5.1
jun 01 11:35:28 Adrian-PC kernel: Adding 10669052k swap on /dev/nvme0n1p3.  Priority:-2 extents:1 across:10669052k SS
jun 01 11:35:28 Adrian-PC kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
jun 01 11:35:28 Adrian-PC kernel: mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915])
jun 01 11:35:28 Adrian-PC kernel: EXT4-fs (nvme0n1p2): mounted filesystem a63c4c68-2da9-4ea9-b27b-45a3b887483d r/w with ordered data mode. Quota mode: none.
jun 01 11:35:28 Adrian-PC kernel: mc: Linux media interface: v0.10
jun 01 11:35:28 Adrian-PC kernel: asus_wmi: Initialization: 0x1
jun 01 11:35:28 Adrian-PC kernel: asus_wmi: BIOS WMI version: 9.0
jun 01 11:35:28 Adrian-PC kernel: asus_wmi: SFUN value: 0x21
jun 01 11:35:28 Adrian-PC kernel: asus-nb-wmi asus-nb-wmi: Detected ATK, not ASUSWMI, use DSTS
jun 01 11:35:28 Adrian-PC kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
jun 01 11:35:28 Adrian-PC kernel: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
jun 01 11:35:28 Adrian-PC kernel: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
jun 01 11:35:28 Adrian-PC kernel: iTCO_vendor_support: vendor-support=0
jun 01 11:35:28 Adrian-PC kernel: cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
jun 01 11:35:28 Adrian-PC kernel: input: PC Speaker as /devices/platform/pcspkr/input/input10
jun 01 11:35:28 Adrian-PC kernel: resource: resource sanity check: requesting [mem 0x00000000fedc0000-0x00000000fedcdfff], which spans more than pnp 00:02 [mem 0xfedc0000-0xfedc7fff]
jun 01 11:35:28 Adrian-PC kernel: caller uncore_get_box_mmio_addr+0xd1/0x180 [intel_uncore] mapping multiple BARs
jun 01 11:35:28 Adrian-PC kernel: asus-nb-wmi asus-nb-wmi: Using throttle_thermal_policy for platform_profile support
jun 01 11:35:28 Adrian-PC kernel: input: Asus WMI hotkeys as /devices/platform/asus-nb-wmi/input/input11
jun 01 11:35:28 Adrian-PC kernel: iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
jun 01 11:35:28 Adrian-PC kernel: iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
jun 01 11:35:28 Adrian-PC kernel: dw-apb-uart.2: ttyS4 at MMIO 0x4017002000 (irq = 16, base_baud = 6250000) is a 16550A
jun 01 11:35:28 Adrian-PC kernel: asus_wmi: fan_curve_get_factory_default (0x00110024) failed: -19
jun 01 11:35:28 Adrian-PC kernel: asus_wmi: fan_curve_get_factory_default (0x00110025) failed: -19
jun 01 11:35:28 Adrian-PC kernel: asus_wmi: fan_curve_get_factory_default (0x00110032) failed: -19
jun 01 11:35:28 Adrian-PC kernel: asus_wmi: using asus-wmi for asus::kbd_backlight
jun 01 11:35:28 Adrian-PC kernel: spi-nor spi0.0: supply vcc not found, using dummy regulator
jun 01 11:35:28 Adrian-PC kernel: videodev: Linux video capture interface: v2.00
jun 01 11:35:28 Adrian-PC kernel: RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
jun 01 11:35:28 Adrian-PC kernel: RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
jun 01 11:35:28 Adrian-PC kernel: RAPL PMU: hw unit of domain package 2^-14 Joules
jun 01 11:35:28 Adrian-PC kernel: RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
jun 01 11:35:28 Adrian-PC kernel: RAPL PMU: hw unit of domain psys 2^-14 Joules
jun 01 11:35:28 Adrian-PC kernel: iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
jun 01 11:35:28 Adrian-PC kernel: ACPI: battery: new hook: ASUS Battery Extension
jun 01 11:35:28 Adrian-PC kernel: iwlwifi 0000:00:14.3: Detected crf-id 0x2816, cnv-id 0x20000302 wfpm id 0x80000000
jun 01 11:35:28 Adrian-PC kernel: iwlwifi 0000:00:14.3: PCI dev a0f0/0264, rev=0x351, rfid=0x108110
jun 01 11:35:28 Adrian-PC kernel: iwlwifi 0000:00:14.3: Detected Intel(R) Wireless-AC 9461
jun 01 11:35:28 Adrian-PC kernel: iwlwifi 0000:00:14.3: firmware: failed to load iwl-debug-yoyo.bin (-2)
jun 01 11:35:28 Adrian-PC kernel: iwlwifi 0000:00:14.3: loaded firmware version 77.f39cc7f9.0 QuZ-a0-jf-b0-77.ucode op_mode iwlmvm
jun 01 11:35:28 Adrian-PC kernel: Error: Driver 'pcspkr' is already registered, aborting...
jun 01 11:35:28 Adrian-PC kernel: intel_rapl_msr: PL4 support detected.
jun 01 11:35:28 Adrian-PC kernel: intel_rapl_common: Found RAPL domain package
jun 01 11:35:28 Adrian-PC kernel: intel_rapl_common: Found RAPL domain core
jun 01 11:35:28 Adrian-PC kernel: intel_rapl_common: Found RAPL domain uncore
jun 01 11:35:28 Adrian-PC kernel: intel_rapl_common: Found RAPL domain psys
jun 01 11:35:28 Adrian-PC kernel: Bluetooth: Core ver 2.22
jun 01 11:35:28 Adrian-PC kernel: NET: Registered PF_BLUETOOTH protocol family
jun 01 11:35:28 Adrian-PC kernel: Bluetooth: HCI device and connection manager initialized
jun 01 11:35:28 Adrian-PC kernel: Bluetooth: HCI socket layer initialized
jun 01 11:35:28 Adrian-PC kernel: Bluetooth: L2CAP socket layer initialized
jun 01 11:35:28 Adrian-PC kernel: Bluetooth: SCO socket layer initialized
jun 01 11:35:28 Adrian-PC kernel: Creating 1 MTD partitions on "0000:00:1f.5":
jun 01 11:35:28 Adrian-PC kernel: 0x000000000000-0x000001000000 : "BIOS"
jun 01 11:35:28 Adrian-PC kernel: proc_thermal 0000:00:04.0: enabling device (0000 -> 0002)
jun 01 11:35:28 Adrian-PC kernel: uvcvideo 1-3:1.0: Found UVC 1.00 device USB2.0 VGA UVC WebCam (13d3:5a11)
jun 01 11:35:28 Adrian-PC kernel: usbcore: registered new interface driver btusb
jun 01 11:35:28 Adrian-PC kernel: usbcore: registered new interface driver uvcvideo
jun 01 11:35:28 Adrian-PC kernel: Bluetooth: hci0: Bootloader revision 0.0 build 0 week 30 2018
jun 01 11:35:28 Adrian-PC kernel: Bluetooth: hci0: Device revision is 2
jun 01 11:35:28 Adrian-PC kernel: Bluetooth: hci0: Secure boot is enabled
jun 01 11:35:28 Adrian-PC kernel: Bluetooth: hci0: OTP lock is enabled
jun 01 11:35:28 Adrian-PC kernel: Bluetooth: hci0: API lock is enabled
jun 01 11:35:28 Adrian-PC kernel: Bluetooth: hci0: Debug lock is disabled
jun 01 11:35:28 Adrian-PC kernel: Bluetooth: hci0: Minimum firmware build 1 week 10 2014
jun 01 11:35:28 Adrian-PC kernel: Bluetooth: hci0: Found device firmware: intel/ibt-19-0-0.sfi
jun 01 11:35:28 Adrian-PC kernel: Bluetooth: hci0: Boot Address: 0x24800
jun 01 11:35:28 Adrian-PC kernel: Bluetooth: hci0: Firmware Version: 193-33.24
jun 01 11:35:28 Adrian-PC kernel: audit: type=1400 audit(1780324528.519:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="Discord" pid=775 comm="apparmor_parser"
jun 01 11:35:28 Adrian-PC kernel: audit: type=1400 audit(1780324528.520:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="1password" pid=774 comm="apparmor_parser"
jun 01 11:35:28 Adrian-PC kernel: audit: type=1400 audit(1780324528.520:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="buildah" pid=782 comm="apparmor_parser"
jun 01 11:35:28 Adrian-PC kernel: audit: type=1400 audit(1780324528.520:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="QtWebEngineProcess" pid=777 comm="apparmor_parser"
jun 01 11:35:28 Adrian-PC kernel: audit: type=1400 audit(1780324528.520:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="brave" pid=781 comm="apparmor_parser"
jun 01 11:35:28 Adrian-PC kernel: audit: type=1400 audit(1780324528.523:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="balena-etcher" pid=779 comm="apparmor_parser"
jun 01 11:35:28 Adrian-PC kernel: audit: type=1400 audit(1780324528.523:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ch-run" pid=789 comm="apparmor_parser"
jun 01 11:35:28 Adrian-PC kernel: audit: type=1400 audit(1780324528.523:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="cam" pid=787 comm="apparmor_parser"
jun 01 11:35:28 Adrian-PC kernel: audit: type=1400 audit(1780324528.523:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name=4D6F6E676F444220436F6D70617373 pid=776 comm="apparmor_parser"
jun 01 11:35:28 Adrian-PC kernel: RPC: Registered named UNIX socket transport module.
jun 01 11:35:28 Adrian-PC kernel: RPC: Registered udp transport module.
jun 01 11:35:28 Adrian-PC kernel: RPC: Registered tcp transport module.
jun 01 11:35:28 Adrian-PC kernel: RPC: Registered tcp-with-tls transport module.
jun 01 11:35:28 Adrian-PC kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
jun 01 11:35:28 Adrian-PC kernel: intel_tcc_cooling: Programmable TCC Offset detected
jun 01 11:35:28 Adrian-PC kernel: EDAC ieh: No IEHs found
jun 01 11:35:28 Adrian-PC kernel: iwlwifi 0000:00:14.3: base HW address: 14:85:7f:04:e0:11
jun 01 11:35:28 Adrian-PC kernel: iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
jun 01 11:35:28 Adrian-PC kernel: snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
jun 01 11:35:28 Adrian-PC kernel: snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops intel_audio_component_bind_ops [i915])
jun 01 11:35:29 Adrian-PC kernel: snd_hda_codec_alc269 hdaudioC0D0: ALC256: picked fixup  (pin match)
jun 01 11:35:29 Adrian-PC kernel: snd_hda_codec_alc269 hdaudioC0D0: autoconfig for ALC256: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
jun 01 11:35:29 Adrian-PC kernel: snd_hda_codec_alc269 hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
jun 01 11:35:29 Adrian-PC kernel: snd_hda_codec_alc269 hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
jun 01 11:35:29 Adrian-PC kernel: snd_hda_codec_alc269 hdaudioC0D0:    mono: mono_out=0x0
jun 01 11:35:29 Adrian-PC kernel: snd_hda_codec_alc269 hdaudioC0D0:    inputs:
jun 01 11:35:29 Adrian-PC kernel: snd_hda_codec_alc269 hdaudioC0D0:      Internal Mic=0x13
jun 01 11:35:29 Adrian-PC kernel: snd_hda_codec_alc269 hdaudioC0D0:      Headset Mic=0x19
jun 01 11:35:29 Adrian-PC kernel: snd_hda_codec_alc269 hdaudioC0D0:      Internal Mic=0x1b
jun 01 11:35:29 Adrian-PC kernel: kauditd_printk_skb: 115 callbacks suppressed
jun 01 11:35:29 Adrian-PC kernel: audit: type=1400 audit(1780324529.150:126): apparmor="STATUS" operation="profile_load" profile="unconfined" name="transmission-cli" pid=871 comm="apparmor_parser"
jun 01 11:35:29 Adrian-PC kernel: audit: type=1400 audit(1780324529.150:127): apparmor="STATUS" operation="profile_load" profile="unconfined" name="transmission-daemon" pid=871 comm="apparmor_parser"
jun 01 11:35:29 Adrian-PC kernel: audit: type=1400 audit(1780324529.152:128): apparmor="STATUS" operation="profile_load" profile="unconfined" name="transmission-gtk" pid=871 comm="apparmor_parser"
jun 01 11:35:29 Adrian-PC kernel: audit: type=1400 audit(1780324529.153:129): apparmor="STATUS" operation="profile_load" profile="unconfined" name="transmission-qt" pid=871 comm="apparmor_parser"
jun 01 11:35:29 Adrian-PC kernel: input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input12
jun 01 11:35:29 Adrian-PC kernel: input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input13
jun 01 11:35:29 Adrian-PC kernel: input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
jun 01 11:35:29 Adrian-PC kernel: input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
jun 01 11:35:29 Adrian-PC kernel: input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input16
jun 01 11:35:30 Adrian-PC kernel: Bluetooth: hci0: Waiting for firmware download to complete
jun 01 11:35:30 Adrian-PC kernel: Bluetooth: hci0: Firmware loaded in 1943618 usecs
jun 01 11:35:30 Adrian-PC kernel: Bluetooth: hci0: Waiting for device to boot
jun 01 11:35:30 Adrian-PC kernel: Bluetooth: hci0: Device booted in 14587 usecs
jun 01 11:35:30 Adrian-PC kernel: Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-19-0-0.ddc
jun 01 11:35:30 Adrian-PC kernel: Bluetooth: hci0: Applying Intel DDC parameters completed
jun 01 11:35:30 Adrian-PC kernel: Bluetooth: hci0: Firmware revision 0.0 build 193 week 33 2024
jun 01 11:35:30 Adrian-PC kernel: Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
jun 01 11:35:32 Adrian-PC kernel: audit: type=1400 audit(1780324532.866:130): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-soffice" pid=886 comm="apparmor_parser"
jun 01 11:35:32 Adrian-PC kernel: audit: type=1400 audit(1780324532.867:131): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-soffice//gpg" pid=886 comm="apparmor_parser"
jun 01 11:35:33 Adrian-PC kernel: audit: type=1400 audit(1780324533.041:132): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/snap/snapd/26865/usr/lib/snapd/snap-confine" pid=992 comm="apparmor_parser"
jun 01 11:35:33 Adrian-PC kernel: audit: type=1400 audit(1780324533.050:133): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/snap/snapd/26382/usr/lib/snapd/snap-confine" pid=991 comm="apparmor_parser"
jun 01 11:35:33 Adrian-PC kernel: audit: type=1400 audit(1780324533.050:134): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/snap/snapd/26382/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=991 comm="apparmor_parser"
jun 01 11:35:33 Adrian-PC kernel: audit: type=1400 audit(1780324533.144:135): apparmor="STATUS" operation="profile_load" profile="unconfined" name="snap.jdownloader2.hook.configure" pid=995 comm="apparmor_parser"
jun 01 11:35:33 Adrian-PC kernel: /proc/cgroups lists only v1 controllers, use cgroup.controllers of root cgroup for v2 info
jun 01 11:35:33 Adrian-PC kernel: [UFW AUDIT] IN= OUT=lo SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0
jun 01 11:35:33 Adrian-PC kernel: [UFW AUDIT] IN=lo OUT= MAC=00:00:00:00:00:00:00:00:00:00:00:00:86:dd SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0
jun 01 11:35:33 Adrian-PC kernel: [UFW AUDIT] IN= OUT=lo SRC=0.0.0.0 DST=224.0.0.22 LEN=40 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2 MARK=0xfeb0
jun 01 11:35:33 Adrian-PC kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
jun 01 11:35:33 Adrian-PC kernel: Bluetooth: BNEP filters: protocol multicast
jun 01 11:35:33 Adrian-PC kernel: Bluetooth: BNEP socket layer initialized
jun 01 11:35:33 Adrian-PC kernel: Bluetooth: MGMT ver 1.23
jun 01 11:35:33 Adrian-PC kernel: NET: Registered PF_ALG protocol family
jun 01 11:35:33 Adrian-PC kernel: [UFW AUDIT] IN= OUT=lo SRC=127.0.0.1 DST=224.0.0.251 LEN=235 TOS=0x00 PREC=0x00 TTL=255 ID=16287 DF PROTO=UDP SPT=5353 DPT=5353 LEN=215
jun 01 11:35:33 Adrian-PC kernel: [UFW AUDIT] IN=lo OUT= MAC=00:00:00:00:00:00:00:00:00:00:00:00:08:00 SRC=127.0.0.1 DST=224.0.0.251 LEN=235 TOS=0x00 PREC=0x00 TTL=255 ID=16287 DF PROTO=UDP SPT=5353 DPT=5353 LEN=215
jun 01 11:35:33 Adrian-PC kernel: Bluetooth: hci0: No such LE device a4:c7:88:b1:15:1f (0x0)
jun 01 11:35:33 Adrian-PC kernel: set_capacity_and_notify: 7 callbacks suppressed
jun 01 11:35:33 Adrian-PC kernel: loop17: detected capacity change from 0 to 8
jun 01 11:35:33 Adrian-PC kernel: bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
jun 01 11:35:33 Adrian-PC kernel: nvme nvme0: using unchecked data buffer
jun 01 11:35:34 Adrian-PC kernel: block nvme0n1: No UUID available providing old NGUID
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN= OUT=lo SRC=127.0.0.1 DST=224.0.0.251 LEN=235 TOS=0x00 PREC=0x00 TTL=255 ID=16412 DF PROTO=UDP SPT=5353 DPT=5353 LEN=215
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN=lo OUT= MAC=00:00:00:00:00:00:00:00:00:00:00:00:08:00 SRC=127.0.0.1 DST=224.0.0.251 LEN=235 TOS=0x00 PREC=0x00 TTL=255 ID=16412 DF PROTO=UDP SPT=5353 DPT=5353 LEN=215
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN= OUT=lo SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN=lo OUT= MAC=00:00:00:00:00:00:00:00:00:00:00:00:86:dd SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0
jun 01 11:35:34 Adrian-PC kernel: vfs_monitor: loading out-of-tree module taints kernel.
jun 01 11:35:34 Adrian-PC kernel: vfs_monitor: module verification failed: signature and/or required key missing - tainting kernel
jun 01 11:35:34 Adrian-PC kernel: vfs_monitor: register_kretprobes 10 ok
jun 01 11:35:34 Adrian-PC kernel: vfs_monitor: init ok, kretprobes, genl, trace_process
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN= OUT=lo SRC=0.0.0.0 DST=224.0.0.22 LEN=40 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2 MARK=0xfeb0
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN= OUT=lo SRC=127.0.0.1 DST=224.0.0.251 LEN=235 TOS=0x00 PREC=0x00 TTL=255 ID=16601 DF PROTO=UDP SPT=5353 DPT=5353 LEN=215
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN=lo OUT= MAC=00:00:00:00:00:00:00:00:00:00:00:00:08:00 SRC=127.0.0.1 DST=224.0.0.251 LEN=235 TOS=0x00 PREC=0x00 TTL=255 ID=16601 DF PROTO=UDP SPT=5353 DPT=5353 LEN=215
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.22 LEN=48 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2 MARK=0xd4
jun 01 11:35:34 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.22 LEN=48 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2 MARK=0xd4
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=19342 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:34 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=19342 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=19342 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=19343 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:34 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=19343 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=19343 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=19344 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:34 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=19344 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=19344 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=19345 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:34 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=19345 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=19345 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=19346 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:34 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=19346 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=19346 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=123 TOS=0x00 PREC=0x00 TTL=255 ID=19508 DF PROTO=UDP SPT=5353 DPT=5353 LEN=103
jun 01 11:35:34 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=123 TOS=0x00 PREC=0x00 TTL=255 ID=19508 DF PROTO=UDP SPT=5353 DPT=5353 LEN=103
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=224.0.0.251 LEN=123 TOS=0x00 PREC=0x00 TTL=255 ID=19508 DF PROTO=UDP SPT=5353 DPT=5353 LEN=103
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN= OUT=lo SRC=127.0.0.1 DST=224.0.0.251 LEN=217 TOS=0x00 PREC=0x00 TTL=255 ID=16759 DF PROTO=UDP SPT=5353 DPT=5353 LEN=197
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN=lo OUT= MAC=00:00:00:00:00:00:00:00:00:00:00:00:08:00 SRC=127.0.0.1 DST=224.0.0.251 LEN=217 TOS=0x00 PREC=0x00 TTL=255 ID=16759 DF PROTO=UDP SPT=5353 DPT=5353 LEN=197
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=123 TOS=0x00 PREC=0x00 TTL=255 ID=19615 DF PROTO=UDP SPT=5353 DPT=5353 LEN=103
jun 01 11:35:34 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=123 TOS=0x00 PREC=0x00 TTL=255 ID=19615 DF PROTO=UDP SPT=5353 DPT=5353 LEN=103
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=224.0.0.251 LEN=123 TOS=0x00 PREC=0x00 TTL=255 ID=19615 DF PROTO=UDP SPT=5353 DPT=5353 LEN=103
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=123 TOS=0x00 PREC=0x00 TTL=255 ID=19721 DF PROTO=UDP SPT=5353 DPT=5353 LEN=103
jun 01 11:35:34 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=123 TOS=0x00 PREC=0x00 TTL=255 ID=19721 DF PROTO=UDP SPT=5353 DPT=5353 LEN=103
jun 01 11:35:34 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=224.0.0.251 LEN=123 TOS=0x00 PREC=0x00 TTL=255 ID=19721 DF PROTO=UDP SPT=5353 DPT=5353 LEN=103
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=lo SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN=lo OUT= MAC=00:00:00:00:00:00:00:00:00:00:00:00:86:dd SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=111 TOS=0x00 PREC=0x00 TTL=255 ID=19908 DF PROTO=UDP SPT=5353 DPT=5353 LEN=91
jun 01 11:35:35 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=111 TOS=0x00 PREC=0x00 TTL=255 ID=19908 DF PROTO=UDP SPT=5353 DPT=5353 LEN=91
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=224.0.0.251 LEN=111 TOS=0x00 PREC=0x00 TTL=255 ID=19908 DF PROTO=UDP SPT=5353 DPT=5353 LEN=91
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=190 TOS=0x00 PREC=0x00 TTL=255 ID=19963 DF PROTO=UDP SPT=5353 DPT=5353 LEN=170
jun 01 11:35:35 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=190 TOS=0x00 PREC=0x00 TTL=255 ID=19963 DF PROTO=UDP SPT=5353 DPT=5353 LEN=170
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=224.0.0.251 LEN=190 TOS=0x00 PREC=0x00 TTL=255 ID=19963 DF PROTO=UDP SPT=5353 DPT=5353 LEN=170
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=lo SRC=127.0.0.1 DST=224.0.0.251 LEN=190 TOS=0x00 PREC=0x00 TTL=255 ID=17559 DF PROTO=UDP SPT=5353 DPT=5353 LEN=170
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN=lo OUT= MAC=00:00:00:00:00:00:00:00:00:00:00:00:08:00 SRC=127.0.0.1 DST=224.0.0.251 LEN=190 TOS=0x00 PREC=0x00 TTL=255 ID=17559 DF PROTO=UDP SPT=5353 DPT=5353 LEN=170
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=248 TOS=0x00 PREC=0x00 TTL=64 ID=20335 DF PROTO=UDP SPT=138 DPT=138 LEN=228
jun 01 11:35:35 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=248 TOS=0x00 PREC=0x00 TTL=64 ID=20335 DF PROTO=UDP SPT=138 DPT=138 LEN=228
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=248 TOS=0x00 PREC=0x00 TTL=64 ID=20335 DF PROTO=UDP SPT=138 DPT=138 LEN=228
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=20336 DF PROTO=UDP SPT=137 DPT=137 LEN=58
jun 01 11:35:35 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=20336 DF PROTO=UDP SPT=137 DPT=137 LEN=58
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=20336 DF PROTO=UDP SPT=137 DPT=137 LEN=58
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=190 TOS=0x00 PREC=0x00 TTL=255 ID=19975 DF PROTO=UDP SPT=5353 DPT=5353 LEN=170
jun 01 11:35:35 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=190 TOS=0x00 PREC=0x00 TTL=255 ID=19975 DF PROTO=UDP SPT=5353 DPT=5353 LEN=170
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=224.0.0.251 LEN=190 TOS=0x00 PREC=0x00 TTL=255 ID=19975 DF PROTO=UDP SPT=5353 DPT=5353 LEN=170
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=lo SRC=127.0.0.1 DST=224.0.0.251 LEN=190 TOS=0x00 PREC=0x00 TTL=255 ID=17629 DF PROTO=UDP SPT=5353 DPT=5353 LEN=170
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN=lo OUT= MAC=00:00:00:00:00:00:00:00:00:00:00:00:08:00 SRC=127.0.0.1 DST=224.0.0.251 LEN=190 TOS=0x00 PREC=0x00 TTL=255 ID=17629 DF PROTO=UDP SPT=5353 DPT=5353 LEN=170
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=lo SRC=127.0.0.1 DST=224.0.0.251 LEN=217 TOS=0x00 PREC=0x00 TTL=255 ID=17640 DF PROTO=UDP SPT=5353 DPT=5353 LEN=197
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN=lo OUT= MAC=00:00:00:00:00:00:00:00:00:00:00:00:08:00 SRC=127.0.0.1 DST=224.0.0.251 LEN=217 TOS=0x00 PREC=0x00 TTL=255 ID=17640 DF PROTO=UDP SPT=5353 DPT=5353 LEN=197
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=190 TOS=0x00 PREC=0x00 TTL=255 ID=20177 DF PROTO=UDP SPT=5353 DPT=5353 LEN=170
jun 01 11:35:35 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=190 TOS=0x00 PREC=0x00 TTL=255 ID=20177 DF PROTO=UDP SPT=5353 DPT=5353 LEN=170
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=224.0.0.251 LEN=190 TOS=0x00 PREC=0x00 TTL=255 ID=20177 DF PROTO=UDP SPT=5353 DPT=5353 LEN=170
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=lo SRC=127.0.0.1 DST=224.0.0.251 LEN=190 TOS=0x00 PREC=0x00 TTL=255 ID=17805 DF PROTO=UDP SPT=5353 DPT=5353 LEN=170
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN=lo OUT= MAC=00:00:00:00:00:00:00:00:00:00:00:00:08:00 SRC=127.0.0.1 DST=224.0.0.251 LEN=190 TOS=0x00 PREC=0x00 TTL=255 ID=17805 DF PROTO=UDP SPT=5353 DPT=5353 LEN=170
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=lo SRC=127.0.0.1 DST=224.0.0.251 LEN=257 TOS=0x00 PREC=0x00 TTL=255 ID=17970 DF PROTO=UDP SPT=5353 DPT=5353 LEN=237
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN=lo OUT= MAC=00:00:00:00:00:00:00:00:00:00:00:00:08:00 SRC=127.0.0.1 DST=224.0.0.251 LEN=257 TOS=0x00 PREC=0x00 TTL=255 ID=17970 DF PROTO=UDP SPT=5353 DPT=5353 LEN=237
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=273 TOS=0x00 PREC=0x00 TTL=255 ID=20342 DF PROTO=UDP SPT=5353 DPT=5353 LEN=253
jun 01 11:35:35 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=273 TOS=0x00 PREC=0x00 TTL=255 ID=20342 DF PROTO=UDP SPT=5353 DPT=5353 LEN=253
jun 01 11:35:35 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=224.0.0.251 LEN=273 TOS=0x00 PREC=0x00 TTL=255 ID=20342 DF PROTO=UDP SPT=5353 DPT=5353 LEN=253
jun 01 11:35:36 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=95 TOS=0x00 PREC=0x00 TTL=255 ID=20401 DF PROTO=UDP SPT=5353 DPT=5353 LEN=75
jun 01 11:35:36 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=95 TOS=0x00 PREC=0x00 TTL=255 ID=20401 DF PROTO=UDP SPT=5353 DPT=5353 LEN=75
jun 01 11:35:36 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=224.0.0.251 LEN=95 TOS=0x00 PREC=0x00 TTL=255 ID=20401 DF PROTO=UDP SPT=5353 DPT=5353 LEN=75
jun 01 11:35:36 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20536 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:36 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20536 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:36 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20536 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:36 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20537 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:36 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20537 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:36 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20537 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:36 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20538 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:36 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20538 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:36 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20538 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:36 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20539 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:36 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20539 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:36 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20539 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:36 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20540 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:36 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20540 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:36 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20540 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN= OUT=lo SRC=127.0.0.1 DST=224.0.0.251 LEN=301 TOS=0x00 PREC=0x00 TTL=255 ID=18244 DF PROTO=UDP SPT=5353 DPT=5353 LEN=281
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN=lo OUT= MAC=00:00:00:00:00:00:00:00:00:00:00:00:08:00 SRC=127.0.0.1 DST=224.0.0.251 LEN=301 TOS=0x00 PREC=0x00 TTL=255 ID=18244 DF PROTO=UDP SPT=5353 DPT=5353 LEN=281
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=273 TOS=0x00 PREC=0x00 TTL=255 ID=20949 DF PROTO=UDP SPT=5353 DPT=5353 LEN=253
jun 01 11:35:37 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=273 TOS=0x00 PREC=0x00 TTL=255 ID=20949 DF PROTO=UDP SPT=5353 DPT=5353 LEN=253
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=224.0.0.251 LEN=273 TOS=0x00 PREC=0x00 TTL=255 ID=20949 DF PROTO=UDP SPT=5353 DPT=5353 LEN=253
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=73 TOS=0x00 PREC=0x00 TTL=255 ID=21046 DF PROTO=UDP SPT=5353 DPT=5353 LEN=53
jun 01 11:35:37 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=73 TOS=0x00 PREC=0x00 TTL=255 ID=21046 DF PROTO=UDP SPT=5353 DPT=5353 LEN=53
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=224.0.0.251 LEN=73 TOS=0x00 PREC=0x00 TTL=255 ID=21046 DF PROTO=UDP SPT=5353 DPT=5353 LEN=53
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN= OUT=lo SRC=127.0.0.1 DST=224.0.0.251 LEN=73 TOS=0x00 PREC=0x00 TTL=255 ID=18363 DF PROTO=UDP SPT=5353 DPT=5353 LEN=53
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN=lo OUT= MAC=00:00:00:00:00:00:00:00:00:00:00:00:08:00 SRC=127.0.0.1 DST=224.0.0.251 LEN=73 TOS=0x00 PREC=0x00 TTL=255 ID=18363 DF PROTO=UDP SPT=5353 DPT=5353 LEN=53
jun 01 11:35:37 Adrian-PC kernel: st: Version 20160209, fixed bufsize 32768, s/g segs 256
jun 01 11:35:37 Adrian-PC kernel: warning: `hwinfo' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
jun 01 11:35:37 Adrian-PC kernel: wlo1: authenticate with d0:6e:de:8d:01:9b (local address=14:85:7f:04:e0:11)
jun 01 11:35:37 Adrian-PC kernel: wlo1: send auth to d0:6e:de:8d:01:9b (try 1/3)
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20946 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:37 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20946 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20946 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20947 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:37 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20947 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20947 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20948 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:37 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20948 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20948 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20949 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:37 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20949 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20949 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20950 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:37 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20950 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=20950 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=20951 DF PROTO=UDP SPT=137 DPT=137 LEN=58
jun 01 11:35:37 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=20951 DF PROTO=UDP SPT=137 DPT=137 LEN=58
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=20951 DF PROTO=UDP SPT=137 DPT=137 LEN=58
jun 01 11:35:37 Adrian-PC kernel: wlo1: authenticated
jun 01 11:35:37 Adrian-PC kernel: wlo1: associate with d0:6e:de:8d:01:9b (try 1/3)
jun 01 11:35:37 Adrian-PC kernel: wlo1: RX AssocResp from d0:6e:de:8d:01:9b (capab=0x1011 status=0 aid=1)
jun 01 11:35:37 Adrian-PC kernel: wlo1: associated
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0 MARK=0x94
jun 01 11:35:37 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0 MARK=0x94
jun 01 11:35:37 Adrian-PC kernel: wlo1: Limiting TX power to 30 (30 - 0) dBm as advertised by d0:6e:de:8d:01:9b
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.22 LEN=40 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2 MARK=0x94
jun 01 11:35:37 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.22 LEN=40 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2 MARK=0x94
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0001:ff04:e011 LEN=72 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=135 CODE=0
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=33:33:00:00:00:01:d0:6e:de:8d:01:99:86:dd SRC=fe80:0000:0000:0000:d26e:deff:fe8d:0199 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=240 TC=0 HOPLIMIT=255 FLOWLBL=1009982 PROTO=ICMPv6 TYPE=134 CODE=0
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=73 TOS=0x00 PREC=0x00 TTL=255 ID=12661 DF PROTO=UDP SPT=5353 DPT=5353 LEN=53
jun 01 11:35:37 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=73 TOS=0x00 PREC=0x00 TTL=255 ID=12661 DF PROTO=UDP SPT=5353 DPT=5353 LEN=53
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=73 TOS=0x00 PREC=0x00 TTL=255 ID=12661 DF PROTO=UDP SPT=5353 DPT=5353 LEN=53
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=167 TOS=0x00 PREC=0x00 TTL=255 ID=12665 DF PROTO=UDP SPT=5353 DPT=5353 LEN=147
jun 01 11:35:37 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=167 TOS=0x00 PREC=0x00 TTL=255 ID=12665 DF PROTO=UDP SPT=5353 DPT=5353 LEN=147
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=167 TOS=0x00 PREC=0x00 TTL=255 ID=12665 DF PROTO=UDP SPT=5353 DPT=5353 LEN=147
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=257 TOS=0x00 PREC=0x00 TTL=255 ID=12666 DF PROTO=UDP SPT=5353 DPT=5353 LEN=237
jun 01 11:35:37 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=257 TOS=0x00 PREC=0x00 TTL=255 ID=12666 DF PROTO=UDP SPT=5353 DPT=5353 LEN=237
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=257 TOS=0x00 PREC=0x00 TTL=255 ID=12666 DF PROTO=UDP SPT=5353 DPT=5353 LEN=237
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN= OUT=lo SRC=127.0.0.1 DST=224.0.0.251 LEN=217 TOS=0x00 PREC=0x00 TTL=255 ID=18751 DF PROTO=UDP SPT=5353 DPT=5353 LEN=197
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN=lo OUT= MAC=00:00:00:00:00:00:00:00:00:00:00:00:08:00 SRC=127.0.0.1 DST=224.0.0.251 LEN=217 TOS=0x00 PREC=0x00 TTL=255 ID=18751 DF PROTO=UDP SPT=5353 DPT=5353 LEN=197
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=257 TOS=0x00 PREC=0x00 TTL=255 ID=12900 DF PROTO=UDP SPT=5353 DPT=5353 LEN=237
jun 01 11:35:37 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=257 TOS=0x00 PREC=0x00 TTL=255 ID=12900 DF PROTO=UDP SPT=5353 DPT=5353 LEN=237
jun 01 11:35:37 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=257 TOS=0x00 PREC=0x00 TTL=255 ID=12900 DF PROTO=UDP SPT=5353 DPT=5353 LEN=237
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=257 TOS=0x00 PREC=0x00 TTL=255 ID=13057 DF PROTO=UDP SPT=5353 DPT=5353 LEN=237
jun 01 11:35:38 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=257 TOS=0x00 PREC=0x00 TTL=255 ID=13057 DF PROTO=UDP SPT=5353 DPT=5353 LEN=237
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=257 TOS=0x00 PREC=0x00 TTL=255 ID=13057 DF PROTO=UDP SPT=5353 DPT=5353 LEN=237
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=111 TOS=0x00 PREC=0x00 TTL=255 ID=21817 DF PROTO=UDP SPT=5353 DPT=5353 LEN=91
jun 01 11:35:38 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=111 TOS=0x00 PREC=0x00 TTL=255 ID=21817 DF PROTO=UDP SPT=5353 DPT=5353 LEN=91
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=224.0.0.251 LEN=111 TOS=0x00 PREC=0x00 TTL=255 ID=21817 DF PROTO=UDP SPT=5353 DPT=5353 LEN=91
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=233 TOS=0x00 PREC=0x00 TTL=255 ID=13109 DF PROTO=UDP SPT=5353 DPT=5353 LEN=213
jun 01 11:35:38 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=233 TOS=0x00 PREC=0x00 TTL=255 ID=13109 DF PROTO=UDP SPT=5353 DPT=5353 LEN=213
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=233 TOS=0x00 PREC=0x00 TTL=255 ID=13109 DF PROTO=UDP SPT=5353 DPT=5353 LEN=213
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0001:ff04:e011 LEN=72 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=135 CODE=0
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=63206 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=21755 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:38 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=21755 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=21755 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=21756 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:38 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=21756 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=21756 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=21757 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:38 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=21757 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=21757 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=21758 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:38 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=21758 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=21758 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=21759 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:38 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=21759 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=21759 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=21760 DF PROTO=UDP SPT=137 DPT=137 LEN=58
jun 01 11:35:38 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=21760 DF PROTO=UDP SPT=137 DPT=137 LEN=58
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=21760 DF PROTO=UDP SPT=137 DPT=137 LEN=58
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fe80:0000:0000:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0 MARK=0x94
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fe80:0000:0000:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:0002 LEN=56 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=133 CODE=0
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=167 TOS=0x00 PREC=0x00 TTL=255 ID=13319 DF PROTO=UDP SPT=5353 DPT=5353 LEN=147
jun 01 11:35:38 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=167 TOS=0x00 PREC=0x00 TTL=255 ID=13319 DF PROTO=UDP SPT=5353 DPT=5353 LEN=147
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=167 TOS=0x00 PREC=0x00 TTL=255 ID=13319 DF PROTO=UDP SPT=5353 DPT=5353 LEN=147
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fe80:0000:0000:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=187 TC=0 HOPLIMIT=255 FLOWLBL=470602 PROTO=UDP SPT=5353 DPT=5353 LEN=147
jun 01 11:35:38 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=fe80:0000:0000:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=187 TC=0 HOPLIMIT=255 FLOWLBL=470602 PROTO=UDP SPT=5353 DPT=5353 LEN=147
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=fe80:0000:0000:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=187 TC=0 HOPLIMIT=255 FLOWLBL=470602 PROTO=UDP SPT=5353 DPT=5353 LEN=147
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fe80:0000:0000:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=336 TC=0 HOPLIMIT=255 FLOWLBL=470602 PROTO=UDP SPT=5353 DPT=5353 LEN=296
jun 01 11:35:38 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=fe80:0000:0000:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=336 TC=0 HOPLIMIT=255 FLOWLBL=470602 PROTO=UDP SPT=5353 DPT=5353 LEN=296
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=fe80:0000:0000:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=336 TC=0 HOPLIMIT=255 FLOWLBL=470602 PROTO=UDP SPT=5353 DPT=5353 LEN=296
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=181 TOS=0x00 PREC=0x00 TTL=255 ID=13324 DF PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:38 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=181 TOS=0x00 PREC=0x00 TTL=255 ID=13324 DF PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=181 TOS=0x00 PREC=0x00 TTL=255 ID=13324 DF PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=201 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:38 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=201 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=201 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=181 TOS=0x00 PREC=0x00 TTL=255 ID=13342 DF PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:38 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=181 TOS=0x00 PREC=0x00 TTL=255 ID=13342 DF PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=181 TOS=0x00 PREC=0x00 TTL=255 ID=13342 DF PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fe80:0000:0000:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=96 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0 MARK=0x94
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=210 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=170
jun 01 11:35:38 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=210 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=170
jun 01 11:35:38 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=210 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=170
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=201 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:39 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=201 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=201 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=181 TOS=0x00 PREC=0x00 TTL=255 ID=13495 DF PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:39 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=181 TOS=0x00 PREC=0x00 TTL=255 ID=13495 DF PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=181 TOS=0x00 PREC=0x00 TTL=255 ID=13495 DF PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=71 TOS=0x00 PREC=0x00 TTL=255 ID=13496 DF PROTO=UDP SPT=5353 DPT=5353 LEN=51
jun 01 11:35:39 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=71 TOS=0x00 PREC=0x00 TTL=255 ID=13496 DF PROTO=UDP SPT=5353 DPT=5353 LEN=51
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=71 TOS=0x00 PREC=0x00 TTL=255 ID=13496 DF PROTO=UDP SPT=5353 DPT=5353 LEN=51
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN= OUT=lo SRC=127.0.0.1 DST=224.0.0.251 LEN=301 TOS=0x00 PREC=0x00 TTL=255 ID=19167 DF PROTO=UDP SPT=5353 DPT=5353 LEN=281
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN=lo OUT= MAC=00:00:00:00:00:00:00:00:00:00:00:00:08:00 SRC=127.0.0.1 DST=224.0.0.251 LEN=301 TOS=0x00 PREC=0x00 TTL=255 ID=19167 DF PROTO=UDP SPT=5353 DPT=5353 LEN=281
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=273 TOS=0x00 PREC=0x00 TTL=255 ID=22101 DF PROTO=UDP SPT=5353 DPT=5353 LEN=253
jun 01 11:35:39 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=224.0.0.251 LEN=273 TOS=0x00 PREC=0x00 TTL=255 ID=22101 DF PROTO=UDP SPT=5353 DPT=5353 LEN=253
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=224.0.0.251 LEN=273 TOS=0x00 PREC=0x00 TTL=255 ID=22101 DF PROTO=UDP SPT=5353 DPT=5353 LEN=253
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=210 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=170
jun 01 11:35:39 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=210 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=170
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=210 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=170
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=181 TOS=0x00 PREC=0x00 TTL=255 ID=13623 DF PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:39 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=181 TOS=0x00 PREC=0x00 TTL=255 ID=13623 DF PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=181 TOS=0x00 PREC=0x00 TTL=255 ID=13623 DF PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=217 TOS=0x00 PREC=0x00 TTL=255 ID=13686 DF PROTO=UDP SPT=5353 DPT=5353 LEN=197
jun 01 11:35:39 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=217 TOS=0x00 PREC=0x00 TTL=255 ID=13686 DF PROTO=UDP SPT=5353 DPT=5353 LEN=197
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=217 TOS=0x00 PREC=0x00 TTL=255 ID=13686 DF PROTO=UDP SPT=5353 DPT=5353 LEN=197
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=63404 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=198 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=158
jun 01 11:35:39 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=198 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=158
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=198 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=158
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fe80:0000:0000:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0 MARK=0x94
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=21800 DF PROTO=UDP SPT=137 DPT=137 LEN=58
jun 01 11:35:39 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=21800 DF PROTO=UDP SPT=137 DPT=137 LEN=58
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=21800 DF PROTO=UDP SPT=137 DPT=137 LEN=58
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=169 TOS=0x00 PREC=0x00 TTL=255 ID=13711 DF PROTO=UDP SPT=5353 DPT=5353 LEN=149
jun 01 11:35:39 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=169 TOS=0x00 PREC=0x00 TTL=255 ID=13711 DF PROTO=UDP SPT=5353 DPT=5353 LEN=149
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=169 TOS=0x00 PREC=0x00 TTL=255 ID=13711 DF PROTO=UDP SPT=5353 DPT=5353 LEN=149
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=189 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=149
jun 01 11:35:39 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=189 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=149
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=189 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=149
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=181 TOS=0x00 PREC=0x00 TTL=255 ID=13712 DF PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:39 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=181 TOS=0x00 PREC=0x00 TTL=255 ID=13712 DF PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=181 TOS=0x00 PREC=0x00 TTL=255 ID=13712 DF PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=187 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=147
jun 01 11:35:39 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=187 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=147
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=187 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=147
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=181 TOS=0x00 PREC=0x00 TTL=255 ID=13957 DF PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:39 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=181 TOS=0x00 PREC=0x00 TTL=255 ID=13957 DF PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=181 TOS=0x00 PREC=0x00 TTL=255 ID=13957 DF PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=71 TOS=0x00 PREC=0x00 TTL=255 ID=13958 DF PROTO=UDP SPT=5353 DPT=5353 LEN=51
jun 01 11:35:39 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=71 TOS=0x00 PREC=0x00 TTL=255 ID=13958 DF PROTO=UDP SPT=5353 DPT=5353 LEN=51
jun 01 11:35:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=71 TOS=0x00 PREC=0x00 TTL=255 ID=13958 DF PROTO=UDP SPT=5353 DPT=5353 LEN=51
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=201 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:40 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=201 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=201 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=181 TOS=0x00 PREC=0x00 TTL=255 ID=14141 DF PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:40 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=181 TOS=0x00 PREC=0x00 TTL=255 ID=14141 DF PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=181 TOS=0x00 PREC=0x00 TTL=255 ID=14141 DF PROTO=UDP SPT=5353 DPT=5353 LEN=161
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=103 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=63
jun 01 11:35:40 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=103 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=63
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=103 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=63
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=83 TOS=0x00 PREC=0x00 TTL=255 ID=14142 DF PROTO=UDP SPT=5353 DPT=5353 LEN=63
jun 01 11:35:40 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=83 TOS=0x00 PREC=0x00 TTL=255 ID=14142 DF PROTO=UDP SPT=5353 DPT=5353 LEN=63
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=83 TOS=0x00 PREC=0x00 TTL=255 ID=14142 DF PROTO=UDP SPT=5353 DPT=5353 LEN=63
jun 01 11:35:40 Adrian-PC kernel: evm: overlay not supported
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=44454 DF PROTO=UDP SPT=34625 DPT=53 LEN=46
jun 01 11:35:40 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=44454 DF PROTO=UDP SPT=34625 DPT=53 LEN=46
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=44455 DF PROTO=UDP SPT=34625 DPT=53 LEN=46
jun 01 11:35:40 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=44455 DF PROTO=UDP SPT=34625 DPT=53 LEN=46
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=241 TOS=0x00 PREC=0x00 TTL=250 ID=968 DF PROTO=UDP SPT=53 DPT=34625 LEN=221
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=186 TOS=0x00 PREC=0x00 TTL=250 ID=969 DF PROTO=UDP SPT=53 DPT=34625 LEN=166
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.248 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=21258 DF PROTO=TCP SPT=58600 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:35:40 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.248 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=21258 DF PROTO=TCP SPT=58600 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.248 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=80 DPT=58600 WINDOW=42340 RES=0x00 ACK SYN URGP=0
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.248 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=21259 DF PROTO=TCP SPT=58600 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.248 LEN=99 TOS=0x00 PREC=0x00 TTL=64 ID=21260 DF PROTO=TCP SPT=58600 DPT=80 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.248 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=34955 DF PROTO=TCP SPT=80 DPT=58600 WINDOW=83 RES=0x00 ACK URGP=0
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.248 DST=192.168.0.66 LEN=680 TOS=0x00 PREC=0x00 TTL=250 ID=34956 DF PROTO=TCP SPT=80 DPT=58600 WINDOW=83 RES=0x00 ACK PSH URGP=0
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.248 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=21261 DF PROTO=TCP SPT=58600 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.248 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=21262 DF PROTO=TCP SPT=58600 DPT=80 WINDOW=63 RES=0x00 ACK FIN URGP=0
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=169 TOS=0x00 PREC=0x00 TTL=255 ID=14214 DF PROTO=UDP SPT=5353 DPT=5353 LEN=149
jun 01 11:35:40 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=169 TOS=0x00 PREC=0x00 TTL=255 ID=14214 DF PROTO=UDP SPT=5353 DPT=5353 LEN=149
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=169 TOS=0x00 PREC=0x00 TTL=255 ID=14214 DF PROTO=UDP SPT=5353 DPT=5353 LEN=149
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=189 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=149
jun 01 11:35:40 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=189 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=149
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=189 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=149
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.248 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=34957 DF PROTO=TCP SPT=80 DPT=58600 WINDOW=83 RES=0x00 ACK FIN URGP=0
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.248 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=21263 DF PROTO=TCP SPT=58600 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=64077 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=198 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=158
jun 01 11:35:40 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=198 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=158
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=198 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=158
jun 01 11:35:40 Adrian-PC kernel: kauditd_printk_skb: 7 callbacks suppressed
jun 01 11:35:40 Adrian-PC kernel: audit: type=1400 audit(1780324540.489:143): apparmor="ALLOWED" operation="open" class="file" profile="Xorg" name="/dev/input/mouse2" pid=1602 comm="Xorg" requested_mask="wr" denied_mask="wr" fsuid=0 ouid=0
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=33:33:00:00:00:01:d0:6e:de:8d:01:99:86:dd SRC=fe80:0000:0000:0000:d26e:deff:fe8d:0199 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=240 TC=0 HOPLIMIT=255 FLOWLBL=1009982 PROTO=ICMPv6 TYPE=134 CODE=0
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=169 TOS=0x00 PREC=0x00 TTL=255 ID=14455 DF PROTO=UDP SPT=5353 DPT=5353 LEN=149
jun 01 11:35:40 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=169 TOS=0x00 PREC=0x00 TTL=255 ID=14455 DF PROTO=UDP SPT=5353 DPT=5353 LEN=149
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=169 TOS=0x00 PREC=0x00 TTL=255 ID=14455 DF PROTO=UDP SPT=5353 DPT=5353 LEN=149
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=301 TOS=0x00 PREC=0x00 TTL=255 ID=14469 DF PROTO=UDP SPT=5353 DPT=5353 LEN=281
jun 01 11:35:40 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=301 TOS=0x00 PREC=0x00 TTL=255 ID=14469 DF PROTO=UDP SPT=5353 DPT=5353 LEN=281
jun 01 11:35:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=301 TOS=0x00 PREC=0x00 TTL=255 ID=14469 DF PROTO=UDP SPT=5353 DPT=5353 LEN=281
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN= OUT=lo SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN=lo OUT= MAC=00:00:00:00:00:00:00:00:00:00:00:00:86:dd SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=58684 DF PROTO=UDP SPT=37429 DPT=53 LEN=46
jun 01 11:35:41 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=58684 DF PROTO=UDP SPT=37429 DPT=53 LEN=46
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=58685 DF PROTO=UDP SPT=37429 DPT=53 LEN=46
jun 01 11:35:41 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=58685 DF PROTO=UDP SPT=37429 DPT=53 LEN=46
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=241 TOS=0x00 PREC=0x00 TTL=250 ID=1115 DF PROTO=UDP SPT=53 DPT=37429 LEN=221
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=186 TOS=0x00 PREC=0x00 TTL=250 ID=1116 DF PROTO=UDP SPT=53 DPT=37429 LEN=166
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.243 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=42195 DF PROTO=TCP SPT=37882 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:35:41 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.243 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=42195 DF PROTO=TCP SPT=37882 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.243 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=80 DPT=37882 WINDOW=42340 RES=0x00 ACK SYN URGP=0
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.243 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=42196 DF PROTO=TCP SPT=37882 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.243 LEN=99 TOS=0x00 PREC=0x00 TTL=64 ID=42197 DF PROTO=TCP SPT=37882 DPT=80 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.243 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=61250 DF PROTO=TCP SPT=80 DPT=37882 WINDOW=83 RES=0x00 ACK URGP=0
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.243 DST=192.168.0.66 LEN=680 TOS=0x00 PREC=0x00 TTL=250 ID=61251 DF PROTO=TCP SPT=80 DPT=37882 WINDOW=83 RES=0x00 ACK PSH URGP=0
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.243 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=42198 DF PROTO=TCP SPT=37882 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.243 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=42199 DF PROTO=TCP SPT=37882 DPT=80 WINDOW=63 RES=0x00 ACK FIN URGP=0
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.243 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=61252 DF PROTO=TCP SPT=80 DPT=37882 WINDOW=83 RES=0x00 ACK FIN URGP=0
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.243 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=42200 DF PROTO=TCP SPT=37882 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:41 Adrian-PC kernel: EXT4-fs (nvme0n1p4): re-mounted 6b64d00b-dcb9-4fed-9da6-5001ba778547.
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=197 TOS=0x00 PREC=0x00 TTL=255 ID=14919 DF PROTO=UDP SPT=5353 DPT=5353 LEN=177
jun 01 11:35:41 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=197 TOS=0x00 PREC=0x00 TTL=255 ID=14919 DF PROTO=UDP SPT=5353 DPT=5353 LEN=177
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=197 TOS=0x00 PREC=0x00 TTL=255 ID=14919 DF PROTO=UDP SPT=5353 DPT=5353 LEN=177
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=217 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=177
jun 01 11:35:41 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=217 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=177
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=217 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=177
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=33:33:00:00:00:01:d0:6e:de:8d:01:99:86:dd SRC=fe80:0000:0000:0000:d26e:deff:fe8d:0199 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=874228 PROTO=ICMPv6 TYPE=130 CODE=0
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=64744 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=30764 DF PROTO=2
jun 01 11:35:41 Adrian-PC kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=30764 DF PROTO=2
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=233 TOS=0x00 PREC=0x00 TTL=255 ID=15059 DF PROTO=UDP SPT=5353 DPT=5353 LEN=213
jun 01 11:35:41 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=233 TOS=0x00 PREC=0x00 TTL=255 ID=15059 DF PROTO=UDP SPT=5353 DPT=5353 LEN=213
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=233 TOS=0x00 PREC=0x00 TTL=255 ID=15059 DF PROTO=UDP SPT=5353 DPT=5353 LEN=213
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=333 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=293
jun 01 11:35:41 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=333 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=293
jun 01 11:35:41 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=333 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=293
jun 01 11:35:42 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=24470 DF PROTO=UDP SPT=53931 DPT=53 LEN=46
jun 01 11:35:42 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=24470 DF PROTO=UDP SPT=53931 DPT=53 LEN=46
jun 01 11:35:42 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=24471 DF PROTO=UDP SPT=53931 DPT=53 LEN=46
jun 01 11:35:42 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=24471 DF PROTO=UDP SPT=53931 DPT=53 LEN=46
jun 01 11:35:42 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=241 TOS=0x00 PREC=0x00 TTL=250 ID=1230 DF PROTO=UDP SPT=53 DPT=53931 LEN=221
jun 01 11:35:42 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=186 TOS=0x00 PREC=0x00 TTL=250 ID=1231 DF PROTO=UDP SPT=53 DPT=53931 LEN=166
jun 01 11:35:42 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=37876 DF PROTO=TCP SPT=46950 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:35:42 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=37876 DF PROTO=TCP SPT=46950 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:35:42 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.245 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=80 DPT=46950 WINDOW=42340 RES=0x00 ACK SYN URGP=0
jun 01 11:35:42 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=37877 DF PROTO=TCP SPT=46950 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:42 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=99 TOS=0x00 PREC=0x00 TTL=64 ID=37878 DF PROTO=TCP SPT=46950 DPT=80 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:35:42 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.245 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=53475 DF PROTO=TCP SPT=80 DPT=46950 WINDOW=83 RES=0x00 ACK URGP=0
jun 01 11:35:42 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.245 DST=192.168.0.66 LEN=680 TOS=0x00 PREC=0x00 TTL=250 ID=53476 DF PROTO=TCP SPT=80 DPT=46950 WINDOW=83 RES=0x00 ACK PSH URGP=0
jun 01 11:35:42 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=37879 DF PROTO=TCP SPT=46950 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:42 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=37880 DF PROTO=TCP SPT=46950 DPT=80 WINDOW=63 RES=0x00 ACK FIN URGP=0
jun 01 11:35:42 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.245 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=53477 DF PROTO=TCP SPT=80 DPT=46950 WINDOW=83 RES=0x00 ACK FIN URGP=0
jun 01 11:35:42 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=37881 DF PROTO=TCP SPT=46950 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:42 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=64958 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:35:42 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=254 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=214
jun 01 11:35:42 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=254 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=214
jun 01 11:35:42 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=254 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=214
jun 01 11:35:42 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=197 TOS=0x00 PREC=0x00 TTL=255 ID=15162 DF PROTO=UDP SPT=5353 DPT=5353 LEN=177
jun 01 11:35:42 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=197 TOS=0x00 PREC=0x00 TTL=255 ID=15162 DF PROTO=UDP SPT=5353 DPT=5353 LEN=177
jun 01 11:35:42 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=197 TOS=0x00 PREC=0x00 TTL=255 ID=15162 DF PROTO=UDP SPT=5353 DPT=5353 LEN=177
jun 01 11:35:42 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=161 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=121
jun 01 11:35:42 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=161 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=121
jun 01 11:35:42 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=161 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=121
jun 01 11:35:43 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=197 TOS=0x00 PREC=0x00 TTL=255 ID=15646 DF PROTO=UDP SPT=5353 DPT=5353 LEN=177
jun 01 11:35:43 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=197 TOS=0x00 PREC=0x00 TTL=255 ID=15646 DF PROTO=UDP SPT=5353 DPT=5353 LEN=177
jun 01 11:35:43 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=197 TOS=0x00 PREC=0x00 TTL=255 ID=15646 DF PROTO=UDP SPT=5353 DPT=5353 LEN=177
jun 01 11:35:43 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=217 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=177
jun 01 11:35:43 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=217 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=177
jun 01 11:35:43 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=fdaa:bbcc:ddee:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=217 TC=0 HOPLIMIT=255 FLOWLBL=519215 PROTO=UDP SPT=5353 DPT=5353 LEN=177
jun 01 11:35:43 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=65482 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:35:44 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=55076 DF PROTO=UDP SPT=49673 DPT=53 LEN=46
jun 01 11:35:44 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=55076 DF PROTO=UDP SPT=49673 DPT=53 LEN=46
jun 01 11:35:44 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=55077 DF PROTO=UDP SPT=49673 DPT=53 LEN=46
jun 01 11:35:44 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=55077 DF PROTO=UDP SPT=49673 DPT=53 LEN=46
jun 01 11:35:44 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=241 TOS=0x00 PREC=0x00 TTL=250 ID=1579 DF PROTO=UDP SPT=53 DPT=49673 LEN=221
jun 01 11:35:44 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=186 TOS=0x00 PREC=0x00 TTL=250 ID=1580 DF PROTO=UDP SPT=53 DPT=49673 LEN=166
jun 01 11:35:44 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.244 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=379 DF PROTO=TCP SPT=60228 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:35:44 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.244 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=379 DF PROTO=TCP SPT=60228 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:35:44 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.244 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=80 DPT=60228 WINDOW=42340 RES=0x00 ACK SYN URGP=0
jun 01 11:35:44 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.244 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=380 DF PROTO=TCP SPT=60228 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:44 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.244 LEN=99 TOS=0x00 PREC=0x00 TTL=64 ID=381 DF PROTO=TCP SPT=60228 DPT=80 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:35:44 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.244 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=63628 DF PROTO=TCP SPT=80 DPT=60228 WINDOW=83 RES=0x00 ACK URGP=0
jun 01 11:35:44 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.244 DST=192.168.0.66 LEN=680 TOS=0x00 PREC=0x00 TTL=250 ID=63629 DF PROTO=TCP SPT=80 DPT=60228 WINDOW=83 RES=0x00 ACK PSH URGP=0
jun 01 11:35:44 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.244 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=382 DF PROTO=TCP SPT=60228 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:44 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.244 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=383 DF PROTO=TCP SPT=60228 DPT=80 WINDOW=63 RES=0x00 ACK FIN URGP=0
jun 01 11:35:44 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.244 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=63630 DF PROTO=TCP SPT=80 DPT=60228 WINDOW=83 RES=0x00 ACK FIN URGP=0
jun 01 11:35:44 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.244 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=384 DF PROTO=TCP SPT=60228 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:44 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=01:00:5e:00:00:fb:f8:1a:67:56:e9:4b:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
jun 01 11:35:44 Adrian-PC kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:fb:f8:1a:67:56:e9:4b:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
jun 01 11:35:45 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=714 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:35:46 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=45975 DF PROTO=UDP SPT=55908 DPT=53 LEN=46
jun 01 11:35:46 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=45975 DF PROTO=UDP SPT=55908 DPT=53 LEN=46
jun 01 11:35:46 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=45976 DF PROTO=UDP SPT=55908 DPT=53 LEN=46
jun 01 11:35:46 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=45976 DF PROTO=UDP SPT=55908 DPT=53 LEN=46
jun 01 11:35:46 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=241 TOS=0x00 PREC=0x00 TTL=250 ID=1952 DF PROTO=UDP SPT=53 DPT=55908 LEN=221
jun 01 11:35:46 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=186 TOS=0x00 PREC=0x00 TTL=250 ID=1953 DF PROTO=UDP SPT=53 DPT=55908 LEN=166
jun 01 11:35:46 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.248 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=8863 DF PROTO=TCP SPT=58614 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:35:46 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.248 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=8863 DF PROTO=TCP SPT=58614 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:35:46 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.248 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=80 DPT=58614 WINDOW=42340 RES=0x00 ACK SYN URGP=0
jun 01 11:35:46 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.248 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=8864 DF PROTO=TCP SPT=58614 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:46 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.248 LEN=99 TOS=0x00 PREC=0x00 TTL=64 ID=8865 DF PROTO=TCP SPT=58614 DPT=80 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:35:46 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.248 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=49489 DF PROTO=TCP SPT=80 DPT=58614 WINDOW=83 RES=0x00 ACK URGP=0
jun 01 11:35:46 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.248 DST=192.168.0.66 LEN=680 TOS=0x00 PREC=0x00 TTL=250 ID=49490 DF PROTO=TCP SPT=80 DPT=58614 WINDOW=83 RES=0x00 ACK PSH URGP=0
jun 01 11:35:46 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.248 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=8866 DF PROTO=TCP SPT=58614 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:46 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.248 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=8867 DF PROTO=TCP SPT=58614 DPT=80 WINDOW=63 RES=0x00 ACK FIN URGP=0
jun 01 11:35:46 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.248 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=49491 DF PROTO=TCP SPT=80 DPT=58614 WINDOW=83 RES=0x00 ACK FIN URGP=0
jun 01 11:35:46 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.248 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=8868 DF PROTO=TCP SPT=58614 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:46 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=807 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:35:46 Adrian-PC kernel: EXT4-fs (nvme0n1p4): re-mounted 6b64d00b-dcb9-4fed-9da6-5001ba778547.
jun 01 11:35:47 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=1410 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:35:48 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=30067 DF PROTO=UDP SPT=49517 DPT=53 LEN=46
jun 01 11:35:48 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=30067 DF PROTO=UDP SPT=49517 DPT=53 LEN=46
jun 01 11:35:48 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=30068 DF PROTO=UDP SPT=49517 DPT=53 LEN=46
jun 01 11:35:48 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=30068 DF PROTO=UDP SPT=49517 DPT=53 LEN=46
jun 01 11:35:48 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=186 TOS=0x00 PREC=0x00 TTL=250 ID=2166 DF PROTO=UDP SPT=53 DPT=49517 LEN=166
jun 01 11:35:48 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fe80:0000:0000:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=96 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0 MARK=0x94
jun 01 11:35:48 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=241 TOS=0x00 PREC=0x00 TTL=250 ID=2223 DF PROTO=UDP SPT=53 DPT=49517 LEN=221
jun 01 11:35:48 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=10551 DF PROTO=TCP SPT=53864 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:35:48 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=10551 DF PROTO=TCP SPT=53864 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:35:48 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=2258 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:35:48 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.245 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=80 DPT=53864 WINDOW=42340 RES=0x00 ACK SYN URGP=0
jun 01 11:35:48 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=10552 DF PROTO=TCP SPT=53864 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:48 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=99 TOS=0x00 PREC=0x00 TTL=64 ID=10553 DF PROTO=TCP SPT=53864 DPT=80 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:35:48 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.245 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=9451 DF PROTO=TCP SPT=80 DPT=53864 WINDOW=83 RES=0x00 ACK URGP=0
jun 01 11:35:48 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.245 DST=192.168.0.66 LEN=680 TOS=0x00 PREC=0x00 TTL=250 ID=9452 DF PROTO=TCP SPT=80 DPT=53864 WINDOW=83 RES=0x00 ACK PSH URGP=0
jun 01 11:35:48 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=10554 DF PROTO=TCP SPT=53864 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:48 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=10555 DF PROTO=TCP SPT=53864 DPT=80 WINDOW=63 RES=0x00 ACK FIN URGP=0
jun 01 11:35:48 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.245 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=9453 DF PROTO=TCP SPT=80 DPT=53864 WINDOW=83 RES=0x00 ACK FIN URGP=0
jun 01 11:35:48 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=10556 DF PROTO=TCP SPT=53864 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:49 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=2908 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:35:50 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=60872 DF PROTO=UDP SPT=49051 DPT=53 LEN=46
jun 01 11:35:50 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=60872 DF PROTO=UDP SPT=49051 DPT=53 LEN=46
jun 01 11:35:50 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=60873 DF PROTO=UDP SPT=49051 DPT=53 LEN=46
jun 01 11:35:50 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=60873 DF PROTO=UDP SPT=49051 DPT=53 LEN=46
jun 01 11:35:50 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=241 TOS=0x00 PREC=0x00 TTL=250 ID=2513 DF PROTO=UDP SPT=53 DPT=49051 LEN=221
jun 01 11:35:50 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=186 TOS=0x00 PREC=0x00 TTL=250 ID=2514 DF PROTO=UDP SPT=53 DPT=49051 LEN=166
jun 01 11:35:50 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=6020 DF PROTO=TCP SPT=53866 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:35:50 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=6020 DF PROTO=TCP SPT=53866 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:35:50 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.245 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=80 DPT=53866 WINDOW=42340 RES=0x00 ACK SYN URGP=0
jun 01 11:35:50 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=6021 DF PROTO=TCP SPT=53866 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:50 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=99 TOS=0x00 PREC=0x00 TTL=64 ID=6022 DF PROTO=TCP SPT=53866 DPT=80 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:35:50 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.245 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=60863 DF PROTO=TCP SPT=80 DPT=53866 WINDOW=83 RES=0x00 ACK URGP=0
jun 01 11:35:50 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.245 DST=192.168.0.66 LEN=680 TOS=0x00 PREC=0x00 TTL=250 ID=60864 DF PROTO=TCP SPT=80 DPT=53866 WINDOW=83 RES=0x00 ACK PSH URGP=0
jun 01 11:35:50 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=6023 DF PROTO=TCP SPT=53866 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:50 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=6024 DF PROTO=TCP SPT=53866 DPT=80 WINDOW=63 RES=0x00 ACK FIN URGP=0
jun 01 11:35:50 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.245 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=60865 DF PROTO=TCP SPT=80 DPT=53866 WINDOW=83 RES=0x00 ACK FIN URGP=0
jun 01 11:35:50 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=6025 DF PROTO=TCP SPT=53866 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:50 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=3413 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:35:50 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=23555 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:35:50 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=23555 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:35:50 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=23555 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:35:51 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=4303 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:35:51 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=24192 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:35:51 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=24192 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:35:51 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=24192 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:35:52 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=31493 DF PROTO=UDP SPT=38312 DPT=53 LEN=46
jun 01 11:35:52 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=31493 DF PROTO=UDP SPT=38312 DPT=53 LEN=46
jun 01 11:35:52 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=31494 DF PROTO=UDP SPT=38312 DPT=53 LEN=46
jun 01 11:35:52 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=31494 DF PROTO=UDP SPT=38312 DPT=53 LEN=46
jun 01 11:35:52 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=241 TOS=0x00 PREC=0x00 TTL=250 ID=2847 DF PROTO=UDP SPT=53 DPT=38312 LEN=221
jun 01 11:35:52 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=186 TOS=0x00 PREC=0x00 TTL=250 ID=2848 DF PROTO=UDP SPT=53 DPT=38312 LEN=166
jun 01 11:35:52 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.244 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=14205 DF PROTO=TCP SPT=36124 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:35:52 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.244 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=14205 DF PROTO=TCP SPT=36124 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:35:52 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.244 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=80 DPT=36124 WINDOW=42340 RES=0x00 ACK SYN URGP=0
jun 01 11:35:52 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.244 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=14206 DF PROTO=TCP SPT=36124 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:52 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.244 LEN=99 TOS=0x00 PREC=0x00 TTL=64 ID=14207 DF PROTO=TCP SPT=36124 DPT=80 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:35:52 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.244 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=13057 DF PROTO=TCP SPT=80 DPT=36124 WINDOW=83 RES=0x00 ACK URGP=0
jun 01 11:35:52 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.244 DST=192.168.0.66 LEN=680 TOS=0x00 PREC=0x00 TTL=250 ID=13058 DF PROTO=TCP SPT=80 DPT=36124 WINDOW=83 RES=0x00 ACK PSH URGP=0
jun 01 11:35:52 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.244 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=14208 DF PROTO=TCP SPT=36124 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:52 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.244 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=14209 DF PROTO=TCP SPT=36124 DPT=80 WINDOW=63 RES=0x00 ACK FIN URGP=0
jun 01 11:35:52 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.244 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=13059 DF PROTO=TCP SPT=80 DPT=36124 WINDOW=83 RES=0x00 ACK FIN URGP=0
jun 01 11:35:52 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.244 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=14210 DF PROTO=TCP SPT=36124 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:52 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=4794 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:35:53 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=4851 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:35:53 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=24676 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:35:53 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=24676 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:35:53 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=24676 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:35:54 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=53755 DF PROTO=UDP SPT=36066 DPT=53 LEN=46
jun 01 11:35:54 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=53755 DF PROTO=UDP SPT=36066 DPT=53 LEN=46
jun 01 11:35:54 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=53756 DF PROTO=UDP SPT=36066 DPT=53 LEN=46
jun 01 11:35:54 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=53756 DF PROTO=UDP SPT=36066 DPT=53 LEN=46
jun 01 11:35:54 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=241 TOS=0x00 PREC=0x00 TTL=250 ID=3283 DF PROTO=UDP SPT=53 DPT=36066 LEN=221
jun 01 11:35:54 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=186 TOS=0x00 PREC=0x00 TTL=250 ID=3284 DF PROTO=UDP SPT=53 DPT=36066 LEN=166
jun 01 11:35:54 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.240 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=35235 DF PROTO=TCP SPT=58318 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:35:54 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.240 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=35235 DF PROTO=TCP SPT=58318 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:35:54 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.240 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=80 DPT=58318 WINDOW=42340 RES=0x00 ACK SYN URGP=0
jun 01 11:35:54 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.240 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=35236 DF PROTO=TCP SPT=58318 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:54 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.240 LEN=99 TOS=0x00 PREC=0x00 TTL=64 ID=35237 DF PROTO=TCP SPT=58318 DPT=80 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:35:54 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.240 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=25227 DF PROTO=TCP SPT=80 DPT=58318 WINDOW=83 RES=0x00 ACK URGP=0
jun 01 11:35:54 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.240 DST=192.168.0.66 LEN=680 TOS=0x00 PREC=0x00 TTL=250 ID=25228 DF PROTO=TCP SPT=80 DPT=58318 WINDOW=83 RES=0x00 ACK PSH URGP=0
jun 01 11:35:54 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.240 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=35238 DF PROTO=TCP SPT=58318 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:54 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.240 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=35239 DF PROTO=TCP SPT=58318 DPT=80 WINDOW=63 RES=0x00 ACK FIN URGP=0
jun 01 11:35:54 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.240 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=25229 DF PROTO=TCP SPT=80 DPT=58318 WINDOW=83 RES=0x00 ACK FIN URGP=0
jun 01 11:35:54 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.240 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=35240 DF PROTO=TCP SPT=58318 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:54 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=4866 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:35:55 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=4881 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:35:55 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=25550 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:35:55 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=25550 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:35:55 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=25550 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:35:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=64879 DF PROTO=UDP SPT=60790 DPT=53 LEN=46
jun 01 11:35:56 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=64879 DF PROTO=UDP SPT=60790 DPT=53 LEN=46
jun 01 11:35:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=64880 DF PROTO=UDP SPT=60790 DPT=53 LEN=46
jun 01 11:35:56 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=64880 DF PROTO=UDP SPT=60790 DPT=53 LEN=46
jun 01 11:35:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=241 TOS=0x00 PREC=0x00 TTL=250 ID=3613 DF PROTO=UDP SPT=53 DPT=60790 LEN=221
jun 01 11:35:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=186 TOS=0x00 PREC=0x00 TTL=250 ID=3614 DF PROTO=UDP SPT=53 DPT=60790 LEN=166
jun 01 11:35:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.248 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=52417 DF PROTO=TCP SPT=46286 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:35:56 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.248 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=52417 DF PROTO=TCP SPT=46286 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:35:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.248 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=80 DPT=46286 WINDOW=42340 RES=0x00 ACK SYN URGP=0
jun 01 11:35:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.248 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=52418 DF PROTO=TCP SPT=46286 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.248 LEN=99 TOS=0x00 PREC=0x00 TTL=64 ID=52419 DF PROTO=TCP SPT=46286 DPT=80 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:35:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.248 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=49991 DF PROTO=TCP SPT=80 DPT=46286 WINDOW=83 RES=0x00 ACK URGP=0
jun 01 11:35:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.248 DST=192.168.0.66 LEN=680 TOS=0x00 PREC=0x00 TTL=250 ID=49992 DF PROTO=TCP SPT=80 DPT=46286 WINDOW=83 RES=0x00 ACK PSH URGP=0
jun 01 11:35:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.248 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=52420 DF PROTO=TCP SPT=46286 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.248 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=52421 DF PROTO=TCP SPT=46286 DPT=80 WINDOW=63 RES=0x00 ACK FIN URGP=0
jun 01 11:35:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.248 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=49993 DF PROTO=TCP SPT=80 DPT=46286 WINDOW=83 RES=0x00 ACK FIN URGP=0
jun 01 11:35:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.248 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=52422 DF PROTO=TCP SPT=46286 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=5672 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:35:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=6345 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:35:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=26975 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:35:57 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=26975 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:35:57 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=26975 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:35:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=26976 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:57 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=26976 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:57 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=26976 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=65459 DF PROTO=UDP SPT=60835 DPT=53 LEN=46
jun 01 11:35:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=65459 DF PROTO=UDP SPT=60835 DPT=53 LEN=46
jun 01 11:35:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=65460 DF PROTO=UDP SPT=60835 DPT=53 LEN=46
jun 01 11:35:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=65460 DF PROTO=UDP SPT=60835 DPT=53 LEN=46
jun 01 11:35:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=241 TOS=0x00 PREC=0x00 TTL=250 ID=3725 DF PROTO=UDP SPT=53 DPT=60835 LEN=221
jun 01 11:35:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=186 TOS=0x00 PREC=0x00 TTL=250 ID=3726 DF PROTO=UDP SPT=53 DPT=60835 LEN=166
jun 01 11:35:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.242 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=41265 DF PROTO=TCP SPT=49858 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:35:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.242 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=41265 DF PROTO=TCP SPT=49858 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:35:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.242 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=80 DPT=49858 WINDOW=42340 RES=0x00 ACK SYN URGP=0
jun 01 11:35:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.242 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=41266 DF PROTO=TCP SPT=49858 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.242 LEN=99 TOS=0x00 PREC=0x00 TTL=64 ID=41267 DF PROTO=TCP SPT=49858 DPT=80 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:35:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.242 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=50934 DF PROTO=TCP SPT=80 DPT=49858 WINDOW=83 RES=0x00 ACK URGP=0
jun 01 11:35:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.242 DST=192.168.0.66 LEN=680 TOS=0x00 PREC=0x00 TTL=250 ID=50935 DF PROTO=TCP SPT=80 DPT=49858 WINDOW=83 RES=0x00 ACK PSH URGP=0
jun 01 11:35:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.242 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=41268 DF PROTO=TCP SPT=49858 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.242 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=41269 DF PROTO=TCP SPT=49858 DPT=80 WINDOW=63 RES=0x00 ACK FIN URGP=0
jun 01 11:35:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.242 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=50936 DF PROTO=TCP SPT=80 DPT=49858 WINDOW=83 RES=0x00 ACK FIN URGP=0
jun 01 11:35:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.242 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=41270 DF PROTO=TCP SPT=49858 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:35:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=7059 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:35:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=13956 DF PROTO=UDP SPT=53932 DPT=53 LEN=40
jun 01 11:35:59 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=13956 DF PROTO=UDP SPT=53932 DPT=53 LEN=40
jun 01 11:35:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=13957 DF PROTO=UDP SPT=53932 DPT=53 LEN=40
jun 01 11:35:59 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=13957 DF PROTO=UDP SPT=53932 DPT=53 LEN=40
jun 01 11:35:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=108 TOS=0x00 PREC=0x00 TTL=250 ID=3825 DF PROTO=UDP SPT=53 DPT=53932 LEN=88
jun 01 11:35:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=114 TOS=0x00 PREC=0x00 TTL=250 ID=3826 DF PROTO=UDP SPT=53 DPT=53932 LEN=94
jun 01 11:35:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=113.141.164.39 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=58736 DF PROTO=UDP SPT=33211 DPT=123 LEN=56
jun 01 11:35:59 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=113.141.164.39 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=58736 DF PROTO=UDP SPT=33211 DPT=123 LEN=56
jun 01 11:35:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=7651 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:35:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=27497 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:59 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=27497 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:59 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=27497 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:35:59 Adrian-PC systemd-journald[501]: File /var/log/journal/0e0b9956ac3d4324831a40f9e5b14fe7/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
jun 01 11:36:00 Adrian-PC kernel: Bluetooth: RFCOMM TTY layer initialized
jun 01 11:36:00 Adrian-PC kernel: Bluetooth: RFCOMM socket layer initialized
jun 01 11:36:00 Adrian-PC kernel: Bluetooth: RFCOMM ver 1.11
jun 01 11:36:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=8443 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=28474 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:36:00 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=28474 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:36:00 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=28474 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:36:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=8474 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=29106 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:36:01 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=29106 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:36:01 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=29106 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:36:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=lo SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0
jun 01 11:36:02 Adrian-PC kernel: [UFW AUDIT] IN=lo OUT= MAC=00:00:00:00:00:00:00:00:00:00:00:00:86:dd SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0
jun 01 11:36:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=56 TOS=0x00 PREC=0x00 TTL=64 ID=50517 DF PROTO=UDP SPT=37654 DPT=53 LEN=36
jun 01 11:36:02 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=56 TOS=0x00 PREC=0x00 TTL=64 ID=50517 DF PROTO=UDP SPT=37654 DPT=53 LEN=36
jun 01 11:36:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=56 TOS=0x00 PREC=0x00 TTL=64 ID=50518 DF PROTO=UDP SPT=37654 DPT=53 LEN=36
jun 01 11:36:02 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=56 TOS=0x00 PREC=0x00 TTL=64 ID=50518 DF PROTO=UDP SPT=37654 DPT=53 LEN=36
jun 01 11:36:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=72 TOS=0x00 PREC=0x00 TTL=250 ID=4162 DF PROTO=UDP SPT=53 DPT=37654 LEN=52
jun 01 11:36:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=114 TOS=0x00 PREC=0x00 TTL=250 ID=4163 DF PROTO=UDP SPT=53 DPT=37654 LEN=94
jun 01 11:36:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=157.249.81.141 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=38271 DF PROTO=TCP SPT=45178 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:36:02 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=157.249.81.141 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=38271 DF PROTO=TCP SPT=45178 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:36:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=9091 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=30026 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:36:02 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=30026 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:36:02 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=30026 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:36:02 Adrian-PC kernel: EXT4-fs (nvme0n1p4): re-mounted 6b64d00b-dcb9-4fed-9da6-5001ba778547.
jun 01 11:36:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=157.249.81.141 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=45178 WINDOW=65160 RES=0x00 ACK SYN URGP=0
jun 01 11:36:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=157.249.81.141 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=38272 DF PROTO=TCP SPT=45178 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:36:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=157.249.81.141 LEN=569 TOS=0x00 PREC=0x00 TTL=64 ID=38273 DF PROTO=TCP SPT=45178 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:36:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=31825 DF PROTO=UDP SPT=54195 DPT=53 LEN=44
jun 01 11:36:02 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=31825 DF PROTO=UDP SPT=54195 DPT=53 LEN=44
jun 01 11:36:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=31826 DF PROTO=UDP SPT=54195 DPT=53 LEN=44
jun 01 11:36:02 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=31826 DF PROTO=UDP SPT=54195 DPT=53 LEN=44
jun 01 11:36:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=137 TOS=0x00 PREC=0x00 TTL=250 ID=4178 DF PROTO=UDP SPT=53 DPT=54195 LEN=117
jun 01 11:36:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=80 TOS=0x00 PREC=0x00 TTL=250 ID=4211 DF PROTO=UDP SPT=53 DPT=54195 LEN=60
jun 01 11:36:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=25539 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:36:02 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=25539 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:36:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=157.249.81.141 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=337 DF PROTO=TCP SPT=443 DPT=45178 WINDOW=506 RES=0x00 ACK URGP=0
jun 01 11:36:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=157.249.81.141 DST=192.168.0.66 LEN=2948 TOS=0x00 PREC=0x00 TTL=250 ID=338 DF PROTO=TCP SPT=443 DPT=45178 WINDOW=506 RES=0x00 ACK PSH URGP=0
jun 01 11:36:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=157.249.81.141 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=38274 DF PROTO=TCP SPT=45178 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:36:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=157.249.81.141 DST=192.168.0.66 LEN=1252 TOS=0x00 PREC=0x00 TTL=250 ID=340 DF PROTO=TCP SPT=443 DPT=45178 WINDOW=506 RES=0x00 ACK PSH URGP=0
jun 01 11:36:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=157.249.81.141 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=38275 DF PROTO=TCP SPT=45178 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:36:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=157.249.81.141 DST=192.168.0.66 LEN=1478 TOS=0x00 PREC=0x00 TTL=250 ID=341 DF PROTO=TCP SPT=443 DPT=45178 WINDOW=506 RES=0x00 ACK PSH URGP=0
jun 01 11:36:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=157.249.81.141 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=38276 DF PROTO=TCP SPT=45178 DPT=443 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:36:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:36:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25540 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:36:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=322 TOS=0x00 PREC=0x00 TTL=64 ID=25541 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:36:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=9954 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=68 TOS=0x00 PREC=0x00 TTL=64 ID=22142 DF PROTO=UDP SPT=60416 DPT=53 LEN=48
jun 01 11:36:03 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=68 TOS=0x00 PREC=0x00 TTL=64 ID=22142 DF PROTO=UDP SPT=60416 DPT=53 LEN=48
jun 01 11:36:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=68 TOS=0x00 PREC=0x00 TTL=64 ID=22143 DF PROTO=UDP SPT=60416 DPT=53 LEN=48
jun 01 11:36:03 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=68 TOS=0x00 PREC=0x00 TTL=64 ID=22143 DF PROTO=UDP SPT=60416 DPT=53 LEN=48
jun 01 11:36:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=18017 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=131 RES=0x00 ACK URGP=0
jun 01 11:36:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=4148 TOS=0x00 PREC=0x00 TTL=250 ID=18018 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=131 RES=0x00 ACK PSH URGP=0
jun 01 11:36:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25542 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:36:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=2866 TOS=0x00 PREC=0x00 TTL=250 ID=18021 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=131 RES=0x00 ACK PSH URGP=0
jun 01 11:36:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25543 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:36:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=84 TOS=0x00 PREC=0x00 TTL=250 ID=4339 DF PROTO=UDP SPT=53 DPT=60416 LEN=64
jun 01 11:36:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=96 TOS=0x00 PREC=0x00 TTL=250 ID=4340 DF PROTO=UDP SPT=53 DPT=60416 LEN=76
jun 01 11:36:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2400:3200:1300:0000:0000:0000:0000:01a7 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=39081 PROTO=TCP SPT=44340 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:36:03 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2400:3200:1300:0000:0000:0000:0000:01a7 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=39081 PROTO=TCP SPT=44340 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:36:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=132 TOS=0x00 PREC=0x00 TTL=64 ID=25544 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:36:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=334 TOS=0x00 PREC=0x00 TTL=64 ID=25545 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:36:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.139.74.191 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=16278 DF PROTO=TCP SPT=47140 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:36:03 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.139.74.191 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=16278 DF PROTO=TCP SPT=47140 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:36:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2400:3200:1300:0000:0000:0000:0000:01a7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=250 FLOWLBL=0 PROTO=TCP SPT=443 DPT=44340 WINDOW=29200 RES=0x00 ACK SYN URGP=0
jun 01 11:36:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2400:3200:1300:0000:0000:0000:0000:01a7 LEN=60 TC=0 HOPLIMIT=64 FLOWLBL=39081 PROTO=TCP SPT=44340 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2400:3200:1300:0000:0000:0000:0000:01a7 LEN=577 TC=0 HOPLIMIT=64 FLOWLBL=39081 PROTO=TCP SPT=44340 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=131 TOS=0x00 PREC=0x00 TTL=250 ID=18023 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=131 RES=0x00 ACK PSH URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=131 TOS=0x00 PREC=0x00 TTL=250 ID=18024 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=131 RES=0x00 ACK PSH URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25546 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=636 TOS=0x00 PREC=0x00 TTL=250 ID=18025 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=133 RES=0x00 ACK PSH URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=452 TOS=0x00 PREC=0x00 TTL=64 ID=25547 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.139.74.191 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=16278 DF PROTO=TCP SPT=443 DPT=47140 WINDOW=2880 RES=0x00 ACK SYN URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.139.74.191 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=16279 DF PROTO=TCP SPT=47140 DPT=443 WINDOW=64240 RES=0x00 ACK URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.139.74.191 LEN=557 TOS=0x00 PREC=0x00 TTL=64 ID=16280 DF PROTO=TCP SPT=47140 DPT=443 WINDOW=64240 RES=0x00 ACK PSH URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2400:3200:1300:0000:0000:0000:0000:01a7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=60 TC=0 HOPLIMIT=250 FLOWLBL=0 PROTO=TCP SPT=443 DPT=44340 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2400:3200:1300:0000:0000:0000:0000:01a7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1500 TC=0 HOPLIMIT=250 FLOWLBL=0 PROTO=TCP SPT=443 DPT=44340 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2400:3200:1300:0000:0000:0000:0000:01a7 LEN=60 TC=0 HOPLIMIT=64 FLOWLBL=39081 PROTO=TCP SPT=44340 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=10419 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2400:3200:1300:0000:0000:0000:0000:01a7 LEN=60 TC=0 HOPLIMIT=64 FLOWLBL=39081 PROTO=TCP SPT=44340 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2400:3200:1300:0000:0000:0000:0000:01a7 LEN=60 TC=0 HOPLIMIT=64 FLOWLBL=39081 PROTO=TCP SPT=44340 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2400:3200:1300:0000:0000:0000:0000:01a7 LEN=60 TC=0 HOPLIMIT=64 FLOWLBL=39081 PROTO=TCP SPT=44340 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2400:3200:1300:0000:0000:0000:0000:01a7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=746 TC=0 HOPLIMIT=250 FLOWLBL=0 PROTO=TCP SPT=443 DPT=44340 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=30837 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:36:04 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=30837 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=30837 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2400:3200:1300:0000:0000:0000:0000:01a7 LEN=153 TC=0 HOPLIMIT=64 FLOWLBL=39081 PROTO=TCP SPT=44340 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=157.249.81.141 LEN=132 TOS=0x00 PREC=0x00 TTL=64 ID=38277 DF PROTO=TCP SPT=45178 DPT=443 WINDOW=59 RES=0x00 ACK PSH URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=1112 TOS=0x00 PREC=0x00 TTL=250 ID=18026 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=135 RES=0x00 ACK PSH URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25548 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.139.74.191 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=10957 DF PROTO=TCP SPT=443 DPT=47140 WINDOW=41823 RES=0x00 ACK URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.139.74.191 DST=192.168.0.66 LEN=6505 TOS=0x00 PREC=0x00 TTL=250 ID=10958 DF PROTO=TCP SPT=443 DPT=47140 WINDOW=41823 RES=0x00 ACK PSH URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.139.74.191 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=16281 DF PROTO=TCP SPT=47140 DPT=443 WINDOW=57775 RES=0x00 ACK URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.139.74.191 LEN=133 TOS=0x00 PREC=0x00 TTL=64 ID=16282 DF PROTO=TCP SPT=47140 DPT=443 WINDOW=57775 RES=0x00 ACK PSH URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.139.74.191 DST=192.168.0.66 LEN=697 TOS=0x00 PREC=0x00 TTL=250 ID=10963 DF PROTO=TCP SPT=443 DPT=47140 WINDOW=41823 RES=0x00 ACK PSH URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.139.74.191 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=16283 DF PROTO=TCP SPT=47140 DPT=443 WINDOW=57775 RES=0x00 ACK URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=157.249.81.141 DST=192.168.0.66 LEN=131 TOS=0x00 PREC=0x00 TTL=250 ID=342 DF PROTO=TCP SPT=443 DPT=45178 WINDOW=506 RES=0x00 ACK PSH URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=157.249.81.141 LEN=315 TOS=0x00 PREC=0x00 TTL=64 ID=38278 DF PROTO=TCP SPT=45178 DPT=443 WINDOW=59 RES=0x00 ACK PSH URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=157.249.81.141 DST=192.168.0.66 LEN=131 TOS=0x00 PREC=0x00 TTL=250 ID=343 DF PROTO=TCP SPT=443 DPT=45178 WINDOW=506 RES=0x00 ACK PSH URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=157.249.81.141 DST=192.168.0.66 LEN=114 TOS=0x00 PREC=0x00 TTL=250 ID=344 DF PROTO=TCP SPT=443 DPT=45178 WINDOW=506 RES=0x00 ACK PSH URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=157.249.81.141 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=38279 DF PROTO=TCP SPT=45178 DPT=443 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2400:3200:1300:0000:0000:0000:0000:01a7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=302 TC=0 HOPLIMIT=250 FLOWLBL=0 PROTO=TCP SPT=443 DPT=44340 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.139.74.191 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=16284 DF PROTO=TCP SPT=47140 DPT=443 WINDOW=57775 RES=0x00 ACK FIN URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=157.249.81.141 DST=192.168.0.66 LEN=83 TOS=0x00 PREC=0x00 TTL=250 ID=345 DF PROTO=TCP SPT=443 DPT=45178 WINDOW=504 RES=0x00 ACK PSH URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=157.249.81.141 LEN=83 TOS=0x00 PREC=0x00 TTL=64 ID=38280 DF PROTO=TCP SPT=45178 DPT=443 WINDOW=59 RES=0x00 ACK PSH URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=157.249.81.141 DST=192.168.0.66 LEN=2948 TOS=0x00 PREC=0x00 TTL=250 ID=346 DF PROTO=TCP SPT=443 DPT=45178 WINDOW=504 RES=0x00 ACK PSH URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=157.249.81.141 DST=192.168.0.66 LEN=298 TOS=0x00 PREC=0x00 TTL=250 ID=348 DF PROTO=TCP SPT=443 DPT=45178 WINDOW=504 RES=0x00 ACK PSH URGP=0
jun 01 11:36:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=157.249.81.141 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=38281 DF PROTO=TCP SPT=45178 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:36:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.139.74.191 DST=192.168.0.66 LEN=330 TOS=0x00 PREC=0x00 TTL=250 ID=10964 DF PROTO=TCP SPT=443 DPT=47140 WINDOW=41823 RES=0x00 ACK PSH URGP=0
jun 01 11:36:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.139.74.191 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=47140 DPT=443 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:36:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.139.74.191 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=10965 DF PROTO=TCP SPT=443 DPT=47140 WINDOW=41823 RES=0x00 ACK FIN URGP=0
jun 01 11:36:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=157.249.81.141 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=349 DF PROTO=TCP SPT=443 DPT=45178 WINDOW=504 RES=0x00 ACK URGP=0
jun 01 11:36:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=10605 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=31086 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:36:05 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=31086 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:36:05 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=31086 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:36:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2400:3200:1300:0000:0000:0000:0000:01a7 LEN=915 TC=0 HOPLIMIT=64 FLOWLBL=39081 PROTO=TCP SPT=44340 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:36:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2400:3200:1300:0000:0000:0000:0000:01a7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=60 TC=0 HOPLIMIT=250 FLOWLBL=0 PROTO=TCP SPT=443 DPT=44340 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:36:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2400:3200:1300:0000:0000:0000:0000:01a7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=443 TC=0 HOPLIMIT=250 FLOWLBL=0 PROTO=TCP SPT=443 DPT=44340 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:36:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2400:3200:1300:0000:0000:0000:0000:01a7 LEN=60 TC=0 HOPLIMIT=64 FLOWLBL=39081 PROTO=TCP SPT=44340 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:36:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2400:3200:1300:0000:0000:0000:0000:01a7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=94 TC=0 HOPLIMIT=250 FLOWLBL=0 PROTO=TCP SPT=443 DPT=44340 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:36:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2400:3200:1300:0000:0000:0000:0000:01a7 LEN=60 TC=0 HOPLIMIT=64 FLOWLBL=39081 PROTO=TCP SPT=44340 DPT=443 WINDOW=60 RES=0x00 ACK FIN URGP=0
jun 01 11:36:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2400:3200:1300:0000:0000:0000:0000:01a7 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=189563 PROTO=TCP SPT=44354 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:36:05 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2400:3200:1300:0000:0000:0000:0000:01a7 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=189563 PROTO=TCP SPT=44354 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=65 TOS=0x00 PREC=0x00 TTL=64 ID=46878 DF PROTO=UDP SPT=34615 DPT=53 LEN=45
jun 01 11:36:06 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=65 TOS=0x00 PREC=0x00 TTL=64 ID=46878 DF PROTO=UDP SPT=34615 DPT=53 LEN=45
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=65 TOS=0x00 PREC=0x00 TTL=64 ID=46879 DF PROTO=UDP SPT=34615 DPT=53 LEN=45
jun 01 11:36:06 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=65 TOS=0x00 PREC=0x00 TTL=64 ID=46879 DF PROTO=UDP SPT=34615 DPT=53 LEN=45
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.139.74.191 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=54069 DF PROTO=TCP SPT=47144 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.139.74.191 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=54069 DF PROTO=TCP SPT=47144 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2400:3200:1300:0000:0000:0000:0000:01a7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=250 FLOWLBL=0 PROTO=TCP SPT=443 DPT=44354 WINDOW=29200 RES=0x00 ACK SYN URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2400:3200:1300:0000:0000:0000:0000:01a7 LEN=60 TC=0 HOPLIMIT=64 FLOWLBL=189563 PROTO=TCP SPT=44354 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2400:3200:1300:0000:0000:0000:0000:01a7 LEN=577 TC=0 HOPLIMIT=64 FLOWLBL=189563 PROTO=TCP SPT=44354 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2400:3200:1300:0000:0000:0000:0000:01a7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=60 TC=0 HOPLIMIT=250 FLOWLBL=0 PROTO=TCP SPT=443 DPT=44340 WINDOW=63 RES=0x00 ACK FIN URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2400:3200:1300:0000:0000:0000:0000:01a7 LEN=60 TC=0 HOPLIMIT=64 FLOWLBL=39081 PROTO=TCP SPT=44340 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=81 TOS=0x00 PREC=0x00 TTL=250 ID=4633 DF PROTO=UDP SPT=53 DPT=34615 LEN=61
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=138 TOS=0x00 PREC=0x00 TTL=250 ID=4634 DF PROTO=UDP SPT=53 DPT=34615 LEN=118
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=34283 DF PROTO=TCP SPT=34352 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=15126 DF PROTO=TCP SPT=34366 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=34283 DF PROTO=TCP SPT=34352 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=15126 DF PROTO=TCP SPT=34366 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=11113 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=31945 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:36:06 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=31945 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=31945 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2400:3200:1300:0000:0000:0000:0000:01a7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=60 TC=0 HOPLIMIT=250 FLOWLBL=0 PROTO=TCP SPT=443 DPT=44354 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2400:3200:1300:0000:0000:0000:0000:01a7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1500 TC=0 HOPLIMIT=250 FLOWLBL=0 PROTO=TCP SPT=443 DPT=44354 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2400:3200:1300:0000:0000:0000:0000:01a7 LEN=60 TC=0 HOPLIMIT=64 FLOWLBL=189563 PROTO=TCP SPT=44354 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2400:3200:1300:0000:0000:0000:0000:01a7 LEN=60 TC=0 HOPLIMIT=64 FLOWLBL=189563 PROTO=TCP SPT=44354 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.139.74.191 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=54069 DF PROTO=TCP SPT=443 DPT=47144 WINDOW=2880 RES=0x00 ACK SYN URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.139.74.191 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=54070 DF PROTO=TCP SPT=47144 DPT=443 WINDOW=64240 RES=0x00 ACK URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.139.74.191 LEN=557 TOS=0x00 PREC=0x00 TTL=64 ID=54071 DF PROTO=TCP SPT=47144 DPT=443 WINDOW=64240 RES=0x00 ACK PSH URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2400:3200:1300:0000:0000:0000:0000:01a7 LEN=60 TC=0 HOPLIMIT=64 FLOWLBL=189563 PROTO=TCP SPT=44354 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2400:3200:1300:0000:0000:0000:0000:01a7 LEN=60 TC=0 HOPLIMIT=64 FLOWLBL=189563 PROTO=TCP SPT=44354 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2400:3200:1300:0000:0000:0000:0000:01a7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=746 TC=0 HOPLIMIT=250 FLOWLBL=0 PROTO=TCP SPT=443 DPT=44354 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2400:3200:1300:0000:0000:0000:0000:01a7 LEN=153 TC=0 HOPLIMIT=64 FLOWLBL=189563 PROTO=TCP SPT=44354 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=34366 WINDOW=28960 RES=0x00 ACK SYN URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=34352 WINDOW=28960 RES=0x00 ACK SYN URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=15127 DF PROTO=TCP SPT=34366 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=34284 DF PROTO=TCP SPT=34352 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=569 TOS=0x00 PREC=0x00 TTL=64 ID=15128 DF PROTO=TCP SPT=34366 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=569 TOS=0x00 PREC=0x00 TTL=64 ID=34285 DF PROTO=TCP SPT=34352 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.139.74.191 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=59970 DF PROTO=TCP SPT=443 DPT=47144 WINDOW=41823 RES=0x00 ACK URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.139.74.191 DST=192.168.0.66 LEN=2944 TOS=0x00 PREC=0x00 TTL=250 ID=59971 DF PROTO=TCP SPT=443 DPT=47144 WINDOW=41823 RES=0x00 ACK URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.139.74.191 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=54072 DF PROTO=TCP SPT=47144 DPT=443 WINDOW=61336 RES=0x00 ACK URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.139.74.191 DST=192.168.0.66 LEN=697 TOS=0x00 PREC=0x00 TTL=250 ID=59975 DF PROTO=TCP SPT=443 DPT=47144 WINDOW=41823 RES=0x00 ACK PSH URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.139.74.191 DST=192.168.0.66 LEN=2944 TOS=0x00 PREC=0x00 TTL=250 ID=59973 DF PROTO=TCP SPT=443 DPT=47144 WINDOW=41823 RES=0x00 ACK URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.139.74.191 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=54073 DF PROTO=TCP SPT=47144 DPT=443 WINDOW=61336 RES=0x00 ACK URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.139.74.191 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=54074 DF PROTO=TCP SPT=47144 DPT=443 WINDOW=57775 RES=0x00 ACK URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.139.74.191 LEN=133 TOS=0x00 PREC=0x00 TTL=64 ID=54075 DF PROTO=TCP SPT=47144 DPT=443 WINDOW=57775 RES=0x00 ACK PSH URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.139.74.191 DST=192.168.0.66 LEN=697 TOS=0x00 PREC=0x00 TTL=250 ID=59976 DF PROTO=TCP SPT=443 DPT=47144 WINDOW=41823 RES=0x00 ACK PSH URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.139.74.191 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=54076 DF PROTO=TCP SPT=47144 DPT=443 WINDOW=57775 RES=0x00 ACK URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2400:3200:1300:0000:0000:0000:0000:01a7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=302 TC=0 HOPLIMIT=250 FLOWLBL=0 PROTO=TCP SPT=443 DPT=44354 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.139.74.191 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=54077 DF PROTO=TCP SPT=47144 DPT=443 WINDOW=57775 RES=0x00 ACK FIN URGP=0
jun 01 11:36:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2400:3200:1300:0000:0000:0000:0000:01a7 LEN=915 TC=0 HOPLIMIT=64 FLOWLBL=189563 PROTO=TCP SPT=44354 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=61930 DF PROTO=TCP SPT=443 DPT=34352 WINDOW=235 RES=0x00 ACK URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=4148 TOS=0x00 PREC=0x00 TTL=250 ID=61931 DF PROTO=TCP SPT=443 DPT=34352 WINDOW=235 RES=0x00 ACK PSH URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=34286 DF PROTO=TCP SPT=34352 DPT=443 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=2578 TOS=0x00 PREC=0x00 TTL=250 ID=61934 DF PROTO=TCP SPT=443 DPT=34352 WINDOW=235 RES=0x00 ACK PSH URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=34287 DF PROTO=TCP SPT=34352 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=132 TOS=0x00 PREC=0x00 TTL=64 ID=34288 DF PROTO=TCP SPT=34352 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=11156 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.139.74.191 DST=192.168.0.66 LEN=330 TOS=0x00 PREC=0x00 TTL=250 ID=59977 DF PROTO=TCP SPT=443 DPT=47144 WINDOW=41823 RES=0x00 ACK PSH URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.139.74.191 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=47144 DPT=443 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.139.74.191 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=59978 DF PROTO=TCP SPT=443 DPT=47144 WINDOW=41823 RES=0x00 ACK FIN URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2400:3200:1300:0000:0000:0000:0000:01a7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=60 TC=0 HOPLIMIT=250 FLOWLBL=0 PROTO=TCP SPT=443 DPT=44354 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2400:3200:1300:0000:0000:0000:0000:01a7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=443 TC=0 HOPLIMIT=250 FLOWLBL=0 PROTO=TCP SPT=443 DPT=44354 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2400:3200:1300:0000:0000:0000:0000:01a7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=94 TC=0 HOPLIMIT=250 FLOWLBL=0 PROTO=TCP SPT=443 DPT=44354 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2400:3200:1300:0000:0000:0000:0000:01a7 LEN=60 TC=0 HOPLIMIT=64 FLOWLBL=189563 PROTO=TCP SPT=44354 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2400:3200:1300:0000:0000:0000:0000:01a7 LEN=60 TC=0 HOPLIMIT=64 FLOWLBL=189563 PROTO=TCP SPT=44354 DPT=443 WINDOW=60 RES=0x00 ACK FIN URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=208 TOS=0x00 PREC=0x00 TTL=64 ID=32769 DF PROTO=UDP SPT=138 DPT=138 LEN=188
jun 01 11:36:07 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=208 TOS=0x00 PREC=0x00 TTL=64 ID=32769 DF PROTO=UDP SPT=138 DPT=138 LEN=188
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=208 TOS=0x00 PREC=0x00 TTL=64 ID=32769 DF PROTO=UDP SPT=138 DPT=138 LEN=188
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.139.74.191 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=59979 DF PROTO=TCP SPT=443 DPT=47144 WINDOW=41823 RES=0x00 ACK FIN URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=339 TOS=0x00 PREC=0x00 TTL=250 ID=61936 DF PROTO=TCP SPT=443 DPT=34352 WINDOW=235 RES=0x00 ACK PSH URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=244 TOS=0x00 PREC=0x00 TTL=64 ID=34289 DF PROTO=TCP SPT=34352 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=339 TOS=0x00 PREC=0x00 TTL=250 ID=61937 DF PROTO=TCP SPT=443 DPT=34352 WINDOW=235 RES=0x00 ACK PSH URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=114 TOS=0x00 PREC=0x00 TTL=250 ID=61938 DF PROTO=TCP SPT=443 DPT=34352 WINDOW=235 RES=0x00 ACK PSH URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=34290 DF PROTO=TCP SPT=34352 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=569 TOS=0x00 PREC=0x00 TTL=64 ID=15129 DF PROTO=TCP SPT=34366 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2400:3200:1300:0000:0000:0000:0000:01a7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=60 TC=0 HOPLIMIT=250 FLOWLBL=0 PROTO=TCP SPT=443 DPT=44354 WINDOW=63 RES=0x00 ACK FIN URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=83 TOS=0x00 PREC=0x00 TTL=250 ID=61939 DF PROTO=TCP SPT=443 DPT=34352 WINDOW=243 RES=0x00 ACK PSH URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=83 TOS=0x00 PREC=0x00 TTL=64 ID=34291 DF PROTO=TCP SPT=34352 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=356 TOS=0x00 PREC=0x00 TTL=250 ID=61940 DF PROTO=TCP SPT=443 DPT=34352 WINDOW=243 RES=0x00 ACK PSH URGP=0
jun 01 11:36:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=34292 DF PROTO=TCP SPT=34352 DPT=443 WINDOW=57 RES=0x00 ACK FIN URGP=0
jun 01 11:36:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=28466 DF PROTO=TCP SPT=443 DPT=34366 WINDOW=235 RES=0x00 ACK URGP=0
jun 01 11:36:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=1500 TOS=0x00 PREC=0x00 TTL=250 ID=28468 DF PROTO=TCP SPT=443 DPT=34366 WINDOW=235 RES=0x00 ACK URGP=0
jun 01 11:36:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=15130 DF PROTO=TCP SPT=34366 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:36:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=1500 TOS=0x00 PREC=0x00 TTL=250 ID=28467 DF PROTO=TCP SPT=443 DPT=34366 WINDOW=235 RES=0x00 ACK URGP=0
jun 01 11:36:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=15131 DF PROTO=TCP SPT=34366 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:36:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=1252 TOS=0x00 PREC=0x00 TTL=250 ID=28469 DF PROTO=TCP SPT=443 DPT=34366 WINDOW=235 RES=0x00 ACK PSH URGP=0
jun 01 11:36:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=15132 DF PROTO=TCP SPT=34366 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:36:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=2578 TOS=0x00 PREC=0x00 TTL=250 ID=28470 DF PROTO=TCP SPT=443 DPT=34366 WINDOW=235 RES=0x00 ACK PSH URGP=0
jun 01 11:36:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=15133 DF PROTO=TCP SPT=34366 DPT=443 WINDOW=58 RES=0x00 ACK URGP=0
jun 01 11:36:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=132 TOS=0x00 PREC=0x00 TTL=64 ID=15134 DF PROTO=TCP SPT=34366 DPT=443 WINDOW=58 RES=0x00 ACK PSH URGP=0
jun 01 11:36:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=61941 DF PROTO=TCP SPT=443 DPT=34352 WINDOW=243 RES=0x00 ACK FIN URGP=0
jun 01 11:36:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=34293 DF PROTO=TCP SPT=34352 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:36:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=12126 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=339 TOS=0x00 PREC=0x00 TTL=250 ID=28472 DF PROTO=TCP SPT=443 DPT=34366 WINDOW=235 RES=0x00 ACK PSH URGP=0
jun 01 11:36:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=235 TOS=0x00 PREC=0x00 TTL=64 ID=15135 DF PROTO=TCP SPT=34366 DPT=443 WINDOW=58 RES=0x00 ACK PSH URGP=0
jun 01 11:36:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=339 TOS=0x00 PREC=0x00 TTL=250 ID=28473 DF PROTO=TCP SPT=443 DPT=34366 WINDOW=235 RES=0x00 ACK PSH URGP=0
jun 01 11:36:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=114 TOS=0x00 PREC=0x00 TTL=250 ID=28474 DF PROTO=TCP SPT=443 DPT=34366 WINDOW=235 RES=0x00 ACK PSH URGP=0
jun 01 11:36:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=15136 DF PROTO=TCP SPT=34366 DPT=443 WINDOW=58 RES=0x00 ACK URGP=0
jun 01 11:36:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=83 TOS=0x00 PREC=0x00 TTL=250 ID=28475 DF PROTO=TCP SPT=443 DPT=34366 WINDOW=243 RES=0x00 ACK PSH URGP=0
jun 01 11:36:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=83 TOS=0x00 PREC=0x00 TTL=64 ID=15137 DF PROTO=TCP SPT=34366 DPT=443 WINDOW=58 RES=0x00 ACK PSH URGP=0
jun 01 11:36:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=2223 TOS=0x00 PREC=0x00 TTL=250 ID=28476 DF PROTO=TCP SPT=443 DPT=34366 WINDOW=243 RES=0x00 ACK PSH URGP=0
jun 01 11:36:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=15138 DF PROTO=TCP SPT=34366 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:36:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=15139 DF PROTO=TCP SPT=34366 DPT=443 WINDOW=56 RES=0x00 ACK FIN URGP=0
jun 01 11:36:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=fe80:0000:0000:0000:d26e:deff:fe8d:0199 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=135 CODE=0
jun 01 11:36:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=fe80:0000:0000:0000:d26e:deff:fe8d:0199 LEN=64 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=136 CODE=0
jun 01 11:36:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=64 TOS=0x00 PREC=0x00 TTL=250 ID=28478 DF PROTO=TCP SPT=443 DPT=34366 WINDOW=243 RES=0x00 ACK URGP=0
jun 01 11:36:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=83 TOS=0x00 PREC=0x00 TTL=64 ID=15140 DF PROTO=TCP SPT=34366 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:36:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=113.141.164.38 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=49975 DF PROTO=UDP SPT=36847 DPT=123 LEN=56
jun 01 11:36:09 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=113.141.164.38 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=49975 DF PROTO=UDP SPT=36847 DPT=123 LEN=56
jun 01 11:36:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=12987 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=28479 DF PROTO=TCP SPT=443 DPT=34366 WINDOW=243 RES=0x00 ACK URGP=0
jun 01 11:36:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=28480 DF PROTO=TCP SPT=443 DPT=34366 WINDOW=243 RES=0x00 ACK FIN URGP=0
jun 01 11:36:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=34366 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:36:10 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=13317 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:11 Adrian-PC kernel: [UFW AUDIT] IN= OUT=lo SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0
jun 01 11:36:11 Adrian-PC kernel: [UFW AUDIT] IN=lo OUT= MAC=00:00:00:00:00:00:00:00:00:00:00:00:86:dd SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0
jun 01 11:36:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=13652 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=lo SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0
jun 01 11:36:12 Adrian-PC kernel: [UFW AUDIT] IN=lo OUT= MAC=00:00:00:00:00:00:00:00:00:00:00:00:86:dd SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0
jun 01 11:36:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=14073 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=14321 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:14 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25549 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:36:14 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=14620 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:14 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18027 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=137 RES=0x00 ACK PSH URGP=0
jun 01 11:36:14 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25550 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:36:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=14639 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=15618 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=16470 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=248 TOS=0x00 PREC=0x00 TTL=64 ID=40966 DF PROTO=UDP SPT=138 DPT=138 LEN=228
jun 01 11:36:17 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=248 TOS=0x00 PREC=0x00 TTL=64 ID=40966 DF PROTO=UDP SPT=138 DPT=138 LEN=228
jun 01 11:36:17 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=248 TOS=0x00 PREC=0x00 TTL=64 ID=40966 DF PROTO=UDP SPT=138 DPT=138 LEN=228
jun 01 11:36:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=238 TOS=0x00 PREC=0x00 TTL=64 ID=40967 DF PROTO=UDP SPT=138 DPT=138 LEN=218
jun 01 11:36:17 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=238 TOS=0x00 PREC=0x00 TTL=64 ID=40967 DF PROTO=UDP SPT=138 DPT=138 LEN=218
jun 01 11:36:17 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=238 TOS=0x00 PREC=0x00 TTL=64 ID=40967 DF PROTO=UDP SPT=138 DPT=138 LEN=218
jun 01 11:36:18 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=16782 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:19 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=17282 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:19 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=1.82.219.234 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=43931 DF PROTO=UDP SPT=53757 DPT=123 LEN=56
jun 01 11:36:19 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=1.82.219.234 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=43931 DF PROTO=UDP SPT=53757 DPT=123 LEN=56
jun 01 11:36:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=17929 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=18011 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:22 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=18132 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:23 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=18630 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:24 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25551 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:36:24 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=19384 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:24 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18028 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=139 RES=0x00 ACK PSH URGP=0
jun 01 11:36:24 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25552 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:36:25 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=20187 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:26 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=20728 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:27 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=21510 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:28 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=22059 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:29 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=22452 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:30 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=22540 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:31 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=33:33:00:00:00:01:d0:6e:de:8d:01:99:86:dd SRC=fe80:0000:0000:0000:d26e:deff:fe8d:0199 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=240 TC=0 HOPLIMIT=255 FLOWLBL=1009982 PROTO=ICMPv6 TYPE=134 CODE=0
jun 01 11:36:31 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=23116 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:32 Adrian-PC kernel: EXT4-fs (nvme0n1p4): re-mounted 6b64d00b-dcb9-4fed-9da6-5001ba778547.
jun 01 11:36:32 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=23331 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:33 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=24265 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:33 Adrian-PC kernel: EXT4-fs (nvme0n1p4): re-mounted 6b64d00b-dcb9-4fed-9da6-5001ba778547.
jun 01 11:36:34 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25553 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:36:34 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=24669 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:34 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18029 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=141 RES=0x00 ACK PSH URGP=0
jun 01 11:36:34 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25554 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:36:35 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=24986 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:36 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=25223 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:37 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=25694 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:38 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=26050 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=26421 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=26559 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:41 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=27129 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:42 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=27733 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:43 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=28623 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:44 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25555 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:36:44 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=29226 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:44 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18030 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=143 RES=0x00 ACK PSH URGP=0
jun 01 11:36:44 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25556 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:36:45 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=29538 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:46 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=29539 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:47 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=30036 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:48 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=30828 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:49 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=31362 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:50 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=32027 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:51 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=32232 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:52 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=33208 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:53 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=33579 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:54 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25557 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:36:54 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=34476 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:54 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18031 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=145 RES=0x00 ACK PSH URGP=0
jun 01 11:36:54 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25558 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:36:55 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=35476 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=35799 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=36059 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=36343 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:36:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=36771 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=37065 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=37466 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=20093 DF PROTO=UDP SPT=41862 DPT=53 LEN=40
jun 01 11:37:02 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=20093 DF PROTO=UDP SPT=41862 DPT=53 LEN=40
jun 01 11:37:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=20094 DF PROTO=UDP SPT=41862 DPT=53 LEN=40
jun 01 11:37:02 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=20094 DF PROTO=UDP SPT=41862 DPT=53 LEN=40
jun 01 11:37:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=114 TOS=0x00 PREC=0x00 TTL=250 ID=11355 DF PROTO=UDP SPT=53 DPT=41862 LEN=94
jun 01 11:37:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=37706 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=108 TOS=0x00 PREC=0x00 TTL=250 ID=11369 DF PROTO=UDP SPT=53 DPT=41862 LEN=88
jun 01 11:37:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=113.141.164.39 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=50782 DF PROTO=UDP SPT=58164 DPT=123 LEN=56
jun 01 11:37:02 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=113.141.164.39 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=50782 DF PROTO=UDP SPT=58164 DPT=123 LEN=56
jun 01 11:37:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=38311 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25559 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:37:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=38787 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18032 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=147 RES=0x00 ACK PSH URGP=0
jun 01 11:37:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25560 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:37:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=38849 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=33:33:00:00:00:01:d0:6e:de:8d:01:99:86:dd SRC=fe80:0000:0000:0000:d26e:deff:fe8d:0199 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=240 TC=0 HOPLIMIT=255 FLOWLBL=1009982 PROTO=ICMPv6 TYPE=134 CODE=0
jun 01 11:37:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=39110 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=39329 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=39911 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=39974 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:10 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=40690 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=40914 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=41667 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=113.141.164.38 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=5169 DF PROTO=UDP SPT=51670 DPT=123 LEN=56
jun 01 11:37:12 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=113.141.164.38 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=5169 DF PROTO=UDP SPT=51670 DPT=123 LEN=56
jun 01 11:37:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=41820 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:14 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25561 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:37:14 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=42015 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:14 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18033 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=149 RES=0x00 ACK PSH URGP=0
jun 01 11:37:14 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25562 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:37:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=42563 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=43156 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=43915 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:18 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=44053 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:19 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=44897 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=46615 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:22 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=46880 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:22 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=1.82.219.234 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=10176 DF PROTO=UDP SPT=51366 DPT=123 LEN=56
jun 01 11:37:22 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=1.82.219.234 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=10176 DF PROTO=UDP SPT=51366 DPT=123 LEN=56
jun 01 11:37:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=1.82.219.234 DST=192.168.0.66 LEN=76 TOS=0x00 PREC=0x00 TTL=250 ID=44512 DF PROTO=UDP SPT=123 DPT=51366 LEN=56
jun 01 11:37:17 Adrian-PC systemd-journald[501]: Time jumped backwards, rotating.
jun 01 11:37:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=47452 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:18 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25563 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:37:19 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=48033 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:19 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18034 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=152 RES=0x00 ACK PSH URGP=0
jun 01 11:37:19 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25564 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:37:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=48259 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=48331 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:22 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=48632 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:23 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=48735 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:24 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=49405 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:24 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=49699 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:26 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=50464 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:27 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=50728 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:28 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=51650 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:28 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25565 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:37:29 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=51696 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:29 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18035 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=154 RES=0x00 ACK PSH URGP=0
jun 01 11:37:29 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25566 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:37:29 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=51713 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:31 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=52473 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:32 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=53065 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:33 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=54000 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:33 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=54165 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:35 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=54855 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:36 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=55044 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:37 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=55773 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:38 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=56326 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25567 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:37:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=56568 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18036 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=156 RES=0x00 ACK PSH URGP=0
jun 01 11:37:39 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25568 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:37:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=57089 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=33:33:00:00:00:01:d0:6e:de:8d:01:99:86:dd SRC=fe80:0000:0000:0000:d26e:deff:fe8d:0199 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=874228 PROTO=ICMPv6 TYPE=130 CODE=0
jun 01 11:37:41 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=57354 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:42 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=58225 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:43 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=58847 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:44 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=59268 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:45 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=60266 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:46 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=60419 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:46 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=60946 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:48 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=61896 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:48 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25569 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:37:48 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fe80:0000:0000:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=96 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0 MARK=0x94
jun 01 11:37:49 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=62077 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:49 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18037 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=158 RES=0x00 ACK PSH URGP=0
jun 01 11:37:49 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25570 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:37:50 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=63005 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:50 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=1.82.219.234 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=25015 DF PROTO=UDP SPT=37644 DPT=123 LEN=56
jun 01 11:37:50 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=1.82.219.234 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=25015 DF PROTO=UDP SPT=37644 DPT=123 LEN=56
jun 01 11:37:51 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=63262 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:52 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=63813 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:52 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=50026 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:52 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=50026 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:52 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=50026 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:52 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=50027 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:52 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=50027 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:52 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=50027 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:52 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=50028 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:52 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=50028 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:52 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=50028 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:52 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=50029 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:52 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=50029 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:52 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=50029 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:52 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=50030 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:52 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=50030 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:52 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=50030 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:53 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=64315 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:53 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=248 TOS=0x00 PREC=0x00 TTL=64 ID=50635 DF PROTO=UDP SPT=138 DPT=138 LEN=228
jun 01 11:37:53 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=248 TOS=0x00 PREC=0x00 TTL=64 ID=50635 DF PROTO=UDP SPT=138 DPT=138 LEN=228
jun 01 11:37:53 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=248 TOS=0x00 PREC=0x00 TTL=64 ID=50635 DF PROTO=UDP SPT=138 DPT=138 LEN=228
jun 01 11:37:54 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=64537 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:54 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51394 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:54 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51394 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:54 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51394 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:54 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51395 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:54 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51395 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:54 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51395 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:54 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51396 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:54 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51396 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:54 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51396 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:54 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51397 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:54 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51397 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:54 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51397 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:54 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51398 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:54 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51398 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:54 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51398 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:55 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51427 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:55 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51427 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:55 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51427 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:55 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51428 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:55 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51428 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:55 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51428 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:55 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51429 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:55 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51429 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:55 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51429 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:55 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51430 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:55 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51430 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:55 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51430 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:55 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51431 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:55 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51431 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:55 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51431 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:55 Adrian-PC kernel: EXT4-fs (nvme0n1p4): re-mounted 6b64d00b-dcb9-4fed-9da6-5001ba778547.
jun 01 11:37:55 Adrian-PC kernel: [UFW AUDIT] IN= OUT=lo SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0
jun 01 11:37:55 Adrian-PC kernel: [UFW AUDIT] IN=lo OUT= MAC=00:00:00:00:00:00:00:00:00:00:00:00:86:dd SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0
jun 01 11:37:55 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=75 TOS=0x00 PREC=0x00 TTL=64 ID=65233 DF PROTO=UDP SPT=45660 DPT=53 LEN=55
jun 01 11:37:55 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=75 TOS=0x00 PREC=0x00 TTL=64 ID=65233 DF PROTO=UDP SPT=45660 DPT=53 LEN=55
jun 01 11:37:55 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=75 TOS=0x00 PREC=0x00 TTL=64 ID=65234 DF PROTO=UDP SPT=45660 DPT=53 LEN=55
jun 01 11:37:55 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=75 TOS=0x00 PREC=0x00 TTL=64 ID=65234 DF PROTO=UDP SPT=45660 DPT=53 LEN=55
jun 01 11:37:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51523 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:56 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51523 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51523 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51524 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:56 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51524 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51524 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51525 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:56 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51525 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51525 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51526 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:56 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51526 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51526 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51527 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:56 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51527 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=51527 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:37:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=103 TOS=0x00 PREC=0x00 TTL=250 ID=19406 DF PROTO=UDP SPT=53 DPT=45660 LEN=83
jun 01 11:37:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=91 TOS=0x00 PREC=0x00 TTL=250 ID=19407 DF PROTO=UDP SPT=53 DPT=45660 LEN=71
jun 01 11:37:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2a01:04f8:0211:0d14:0000:0000:0000:0002 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=183499 PROTO=TCP SPT=53772 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:37:56 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2a01:04f8:0211:0d14:0000:0000:0000:0002 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=183499 PROTO=TCP SPT=53772 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:37:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=148.251.191.185 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=6302 DF PROTO=TCP SPT=37696 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:37:56 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=148.251.191.185 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=6302 DF PROTO=TCP SPT=37696 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:37:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2a01:04f8:0211:0d14:0000:0000:0000:0002 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=250 FLOWLBL=242062 PROTO=TCP SPT=443 DPT=53772 WINDOW=64260 RES=0x00 ACK SYN URGP=0
jun 01 11:37:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2a01:04f8:0211:0d14:0000:0000:0000:0002 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=183499 PROTO=TCP SPT=53772 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:37:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2a01:04f8:0211:0d14:0000:0000:0000:0002 LEN=371 TC=0 HOPLIMIT=64 FLOWLBL=183499 PROTO=TCP SPT=53772 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:37:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=148.251.191.185 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=37696 WINDOW=65160 RES=0x00 ACK SYN URGP=0
jun 01 11:37:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=148.251.191.185 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=37696 DPT=443 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:37:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2a01:04f8:0211:0d14:0000:0000:0000:0002 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=250 FLOWLBL=242062 PROTO=TCP SPT=443 DPT=53772 WINDOW=501 RES=0x00 ACK URGP=0
jun 01 11:37:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2a01:04f8:0211:0d14:0000:0000:0000:0002 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2542 TC=0 HOPLIMIT=250 FLOWLBL=242062 PROTO=TCP SPT=443 DPT=53772 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:37:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2a01:04f8:0211:0d14:0000:0000:0000:0002 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=183499 PROTO=TCP SPT=53772 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:37:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2a01:04f8:0211:0d14:0000:0000:0000:0002 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=183499 PROTO=TCP SPT=53772 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:37:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2a01:04f8:0211:0d14:0000:0000:0000:0002 LEN=158 TC=0 HOPLIMIT=64 FLOWLBL=183499 PROTO=TCP SPT=53772 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:37:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2a01:04f8:0211:0d14:0000:0000:0000:0002 LEN=208 TC=0 HOPLIMIT=64 FLOWLBL=183499 PROTO=TCP SPT=53772 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2a01:04f8:0211:0d14:0000:0000:0000:0002 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=250 FLOWLBL=242062 PROTO=TCP SPT=443 DPT=53772 WINDOW=501 RES=0x00 ACK URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=517 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2a01:04f8:0211:0d14:0000:0000:0000:0002 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=375 TC=0 HOPLIMIT=250 FLOWLBL=242062 PROTO=TCP SPT=443 DPT=53772 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2a01:04f8:0211:0d14:0000:0000:0000:0002 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=183499 PROTO=TCP SPT=53772 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2a01:04f8:0211:0d14:0000:0000:0000:0002 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=143 TC=0 HOPLIMIT=250 FLOWLBL=242062 PROTO=TCP SPT=443 DPT=53772 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2a01:04f8:0211:0d14:0000:0000:0000:0002 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=222 TC=0 HOPLIMIT=250 FLOWLBL=242062 PROTO=TCP SPT=443 DPT=53772 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2a01:04f8:0211:0d14:0000:0000:0000:0002 LEN=103 TC=0 HOPLIMIT=64 FLOWLBL=183499 PROTO=TCP SPT=53772 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2a01:04f8:0211:0d14:0000:0000:0000:0002 LEN=133 TC=0 HOPLIMIT=64 FLOWLBL=183499 PROTO=TCP SPT=53772 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=71 TOS=0x00 PREC=0x00 TTL=64 ID=33094 DF PROTO=UDP SPT=40045 DPT=53 LEN=51
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=87 TOS=0x00 PREC=0x00 TTL=64 ID=36842 DF PROTO=UDP SPT=59743 DPT=53 LEN=67
jun 01 11:37:57 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=71 TOS=0x00 PREC=0x00 TTL=64 ID=33094 DF PROTO=UDP SPT=40045 DPT=53 LEN=51
jun 01 11:37:57 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=87 TOS=0x00 PREC=0x00 TTL=64 ID=36842 DF PROTO=UDP SPT=59743 DPT=53 LEN=67
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=50095 DF PROTO=UDP SPT=48063 DPT=53 LEN=76
jun 01 11:37:57 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=50095 DF PROTO=UDP SPT=48063 DPT=53 LEN=76
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=81 TOS=0x00 PREC=0x00 TTL=64 ID=18619 DF PROTO=UDP SPT=39936 DPT=53 LEN=61
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=90 TOS=0x00 PREC=0x00 TTL=64 ID=7195 DF PROTO=UDP SPT=59228 DPT=53 LEN=70
jun 01 11:37:57 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=81 TOS=0x00 PREC=0x00 TTL=64 ID=18619 DF PROTO=UDP SPT=39936 DPT=53 LEN=61
jun 01 11:37:57 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=90 TOS=0x00 PREC=0x00 TTL=64 ID=7195 DF PROTO=UDP SPT=59228 DPT=53 LEN=70
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=181 TOS=0x00 PREC=0x00 TTL=250 ID=19616 DF PROTO=UDP SPT=53 DPT=48063 LEN=161
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=246 DF PROTO=UDP SPT=33301 DPT=53 LEN=64
jun 01 11:37:57 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=246 DF PROTO=UDP SPT=33301 DPT=53 LEN=64
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=247 DF PROTO=UDP SPT=33301 DPT=53 LEN=64
jun 01 11:37:57 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=247 DF PROTO=UDP SPT=33301 DPT=53 LEN=64
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=131 TOS=0x00 PREC=0x00 TTL=250 ID=19626 DF PROTO=UDP SPT=53 DPT=40045 LEN=111
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=59 TOS=0x00 PREC=0x00 TTL=64 ID=40760 DF PROTO=UDP SPT=34254 DPT=53 LEN=39
jun 01 11:37:57 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=59 TOS=0x00 PREC=0x00 TTL=64 ID=40760 DF PROTO=UDP SPT=34254 DPT=53 LEN=39
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=59 TOS=0x00 PREC=0x00 TTL=64 ID=40761 DF PROTO=UDP SPT=34254 DPT=53 LEN=39
jun 01 11:37:57 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=59 TOS=0x00 PREC=0x00 TTL=64 ID=40761 DF PROTO=UDP SPT=34254 DPT=53 LEN=39
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=211 TOS=0x00 PREC=0x00 TTL=250 ID=19628 DF PROTO=UDP SPT=53 DPT=33301 LEN=191
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=190 TOS=0x00 PREC=0x00 TTL=250 ID=19629 DF PROTO=UDP SPT=53 DPT=33301 LEN=170
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=3.163.139.80 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=16805 DF PROTO=TCP SPT=56974 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=3.163.139.80 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=16805 DF PROTO=TCP SPT=56974 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=75 TOS=0x00 PREC=0x00 TTL=250 ID=19632 DF PROTO=UDP SPT=53 DPT=34254 LEN=55
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=249 ID=0 DF PROTO=TCP SPT=443 DPT=56974 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=87 TOS=0x00 PREC=0x00 TTL=250 ID=19633 DF PROTO=UDP SPT=53 DPT=34254 LEN=67
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=3.163.139.80 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=16806 DF PROTO=TCP SPT=56974 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2800:03f0:4002:080b:0000:0000:0000:200e LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=99354 PROTO=TCP SPT=41786 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2800:03f0:4002:080b:0000:0000:0000:200e LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=99354 PROTO=TCP SPT=41786 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2800:03f0:4002:080b:0000:0000:0000:200e DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=612337 PROTO=TCP SPT=443 DPT=41786 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2800:03f0:4002:080b:0000:0000:0000:200e LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=99354 PROTO=TCP SPT=41786 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=3.163.139.80 LEN=472 TOS=0x00 PREC=0x00 TTL=64 ID=16807 DF PROTO=TCP SPT=56974 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2800:03f0:4002:080b:0000:0000:0000:200e LEN=467 TC=0 HOPLIMIT=64 FLOWLBL=99354 PROTO=TCP SPT=41786 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=249 ID=46089 PROTO=TCP SPT=443 DPT=56974 WINDOW=131 RES=0x00 ACK URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=4336 TOS=0x00 PREC=0x00 TTL=249 ID=46090 PROTO=TCP SPT=443 DPT=56974 WINDOW=131 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=3.163.139.80 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=16808 DF PROTO=TCP SPT=56974 DPT=443 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=618 TOS=0x00 PREC=0x00 TTL=249 ID=46093 PROTO=TCP SPT=443 DPT=56974 WINDOW=131 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=3.163.139.80 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=16809 DF PROTO=TCP SPT=56974 DPT=443 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=3.163.139.80 LEN=58 TOS=0x00 PREC=0x00 TTL=64 ID=16810 DF PROTO=TCP SPT=56974 DPT=443 WINDOW=59 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2800:03f0:4002:080b:0000:0000:0000:200e DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=612337 PROTO=TCP SPT=443 DPT=41786 WINDOW=1053 RES=0x00 ACK URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=249 ID=46094 PROTO=TCP SPT=443 DPT=56974 WINDOW=131 RES=0x00 ACK URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=3.163.139.80 LEN=301 TOS=0x00 PREC=0x00 TTL=64 ID=16811 DF PROTO=TCP SPT=56974 DPT=443 WINDOW=59 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=189 TOS=0x00 PREC=0x00 TTL=250 ID=19650 DF PROTO=UDP SPT=53 DPT=39936 LEN=169
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2800:03f0:4002:080b:0000:0000:0000:200e DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2488 TC=0 HOPLIMIT=249 FLOWLBL=612337 PROTO=TCP SPT=443 DPT=41786 WINDOW=1053 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2800:03f0:4002:080b:0000:0000:0000:200e LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=99354 PROTO=TCP SPT=41786 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2800:03f0:4002:080b:0000:0000:0000:200e DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1513 TC=0 HOPLIMIT=249 FLOWLBL=612337 PROTO=TCP SPT=443 DPT=41786 WINDOW=1053 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2800:03f0:4002:080b:0000:0000:0000:200e LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=99354 PROTO=TCP SPT=41786 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2800:03f0:4002:080b:0000:0000:0000:200e LEN=78 TC=0 HOPLIMIT=64 FLOWLBL=99354 PROTO=TCP SPT=41786 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=69 TOS=0x00 PREC=0x00 TTL=64 ID=56245 DF PROTO=UDP SPT=39153 DPT=53 LEN=49
jun 01 11:37:57 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=69 TOS=0x00 PREC=0x00 TTL=64 ID=56245 DF PROTO=UDP SPT=39153 DPT=53 LEN=49
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=69 TOS=0x00 PREC=0x00 TTL=64 ID=56246 DF PROTO=UDP SPT=39153 DPT=53 LEN=49
jun 01 11:37:57 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=69 TOS=0x00 PREC=0x00 TTL=64 ID=56246 DF PROTO=UDP SPT=39153 DPT=53 LEN=49
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=249 ID=46095 PROTO=TCP SPT=443 DPT=56974 WINDOW=133 RES=0x00 ACK URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=231 TOS=0x00 PREC=0x00 TTL=249 ID=46096 PROTO=TCP SPT=443 DPT=56974 WINDOW=133 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=4336 TOS=0x00 PREC=0x00 TTL=249 ID=46097 PROTO=TCP SPT=443 DPT=56974 WINDOW=133 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=2908 TOS=0x00 PREC=0x00 TTL=249 ID=46100 PROTO=TCP SPT=443 DPT=56974 WINDOW=133 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=1078 TOS=0x00 PREC=0x00 TTL=249 ID=46102 PROTO=TCP SPT=443 DPT=56974 WINDOW=133 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=3.163.139.80 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=16812 DF PROTO=TCP SPT=56974 DPT=443 WINDOW=51 RES=0x00 ACK URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2800:03f0:4002:080b:0000:0000:0000:200e LEN=379 TC=0 HOPLIMIT=64 FLOWLBL=99354 PROTO=TCP SPT=41786 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=133 TOS=0x00 PREC=0x00 TTL=250 ID=19657 DF PROTO=UDP SPT=53 DPT=39153 LEN=113
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2800:03f0:4002:080b:0000:0000:0000:200e DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=612337 PROTO=TCP SPT=443 DPT=41786 WINDOW=1052 RES=0x00 ACK URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=145 TOS=0x00 PREC=0x00 TTL=250 ID=19658 DF PROTO=UDP SPT=53 DPT=39153 LEN=125
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2800:03f0:4003:0c00:0000:0000:0000:0052 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=424205 PROTO=TCP SPT=50164 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2800:03f0:4003:0c00:0000:0000:0000:0052 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=424205 PROTO=TCP SPT=50164 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2800:03f0:4002:080b:0000:0000:0000:200e DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1120 TC=0 HOPLIMIT=249 FLOWLBL=612337 PROTO=TCP SPT=443 DPT=41786 WINDOW=1052 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2800:03f0:4002:080b:0000:0000:0000:200e LEN=262 TC=0 HOPLIMIT=64 FLOWLBL=99354 PROTO=TCP SPT=41786 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2800:03f0:4003:0c00:0000:0000:0000:0052 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=1029675 PROTO=TCP SPT=443 DPT=50164 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2800:03f0:4003:0c00:0000:0000:0000:0052 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=424205 PROTO=TCP SPT=50164 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2800:03f0:4003:0c00:0000:0000:0000:0052 LEN=477 TC=0 HOPLIMIT=64 FLOWLBL=424205 PROTO=TCP SPT=50164 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2800:03f0:4002:080b:0000:0000:0000:200e DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1280 TC=0 HOPLIMIT=249 FLOWLBL=612337 PROTO=TCP SPT=443 DPT=41786 WINDOW=1052 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2800:03f0:4002:080b:0000:0000:0000:200e DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=97 TC=0 HOPLIMIT=249 FLOWLBL=612337 PROTO=TCP SPT=443 DPT=41786 WINDOW=1052 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2800:03f0:4002:080b:0000:0000:0000:200e LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=99354 PROTO=TCP SPT=41786 DPT=443 WINDOW=58 RES=0x00 ACK URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=3.163.139.80 LEN=248 TOS=0x00 PREC=0x00 TTL=64 ID=16813 DF PROTO=TCP SPT=56974 DPT=443 WINDOW=51 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2800:03f0:4003:0c00:0000:0000:0000:0052 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=1029675 PROTO=TCP SPT=443 DPT=50164 WINDOW=1053 RES=0x00 ACK URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2800:03f0:4003:0c00:0000:0000:0000:0052 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2488 TC=0 HOPLIMIT=249 FLOWLBL=1029675 PROTO=TCP SPT=443 DPT=50164 WINDOW=1053 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2800:03f0:4003:0c00:0000:0000:0000:0052 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=424205 PROTO=TCP SPT=50164 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2800:03f0:4003:0c00:0000:0000:0000:0052 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2039 TC=0 HOPLIMIT=249 FLOWLBL=1029675 PROTO=TCP SPT=443 DPT=50164 WINDOW=1053 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2800:03f0:4003:0c00:0000:0000:0000:0052 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=424205 PROTO=TCP SPT=50164 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2800:03f0:4003:0c00:0000:0000:0000:0052 LEN=78 TC=0 HOPLIMIT=64 FLOWLBL=424205 PROTO=TCP SPT=50164 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=4336 TOS=0x00 PREC=0x00 TTL=249 ID=46103 PROTO=TCP SPT=443 DPT=56974 WINDOW=135 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=4336 TOS=0x00 PREC=0x00 TTL=249 ID=46106 PROTO=TCP SPT=443 DPT=56974 WINDOW=135 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=4336 TOS=0x00 PREC=0x00 TTL=249 ID=46109 PROTO=TCP SPT=443 DPT=56974 WINDOW=135 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=4336 TOS=0x00 PREC=0x00 TTL=249 ID=46112 PROTO=TCP SPT=443 DPT=56974 WINDOW=135 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=4336 TOS=0x00 PREC=0x00 TTL=249 ID=46115 PROTO=TCP SPT=443 DPT=56974 WINDOW=135 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=4336 TOS=0x00 PREC=0x00 TTL=249 ID=46118 PROTO=TCP SPT=443 DPT=56974 WINDOW=135 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=4336 TOS=0x00 PREC=0x00 TTL=249 ID=46121 PROTO=TCP SPT=443 DPT=56974 WINDOW=135 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=798 TOS=0x00 PREC=0x00 TTL=249 ID=46124 PROTO=TCP SPT=443 DPT=56974 WINDOW=135 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=3.163.139.80 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=16814 DF PROTO=TCP SPT=56974 DPT=443 WINDOW=21 RES=0x00 ACK URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2800:03f0:4003:0c00:0000:0000:0000:0052 LEN=422 TC=0 HOPLIMIT=64 FLOWLBL=424205 PROTO=TCP SPT=50164 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=3.163.139.80 LEN=580 TOS=0x00 PREC=0x00 TTL=64 ID=16815 DF PROTO=TCP SPT=56974 DPT=443 WINDOW=41 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=4336 TOS=0x00 PREC=0x00 TTL=249 ID=46125 PROTO=TCP SPT=443 DPT=56974 WINDOW=137 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=4336 TOS=0x00 PREC=0x00 TTL=249 ID=46128 PROTO=TCP SPT=443 DPT=56974 WINDOW=137 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=4336 TOS=0x00 PREC=0x00 TTL=249 ID=46131 PROTO=TCP SPT=443 DPT=56974 WINDOW=137 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=3.163.139.80 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=16816 DF PROTO=TCP SPT=56974 DPT=443 WINDOW=40 RES=0x00 ACK URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=4336 TOS=0x00 PREC=0x00 TTL=249 ID=46134 PROTO=TCP SPT=443 DPT=56974 WINDOW=137 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=4336 TOS=0x00 PREC=0x00 TTL=249 ID=46137 PROTO=TCP SPT=443 DPT=56974 WINDOW=137 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=4336 TOS=0x00 PREC=0x00 TTL=249 ID=46140 PROTO=TCP SPT=443 DPT=56974 WINDOW=137 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=3.163.139.80 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=16817 DF PROTO=TCP SPT=56974 DPT=443 WINDOW=32 RES=0x00 ACK URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=4336 TOS=0x00 PREC=0x00 TTL=249 ID=46143 PROTO=TCP SPT=443 DPT=56974 WINDOW=137 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=2429 TOS=0x00 PREC=0x00 TTL=249 ID=46146 PROTO=TCP SPT=443 DPT=56974 WINDOW=137 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=1832 TOS=0x00 PREC=0x00 TTL=249 ID=46148 PROTO=TCP SPT=443 DPT=56974 WINDOW=137 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=3.163.139.80 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=16818 DF PROTO=TCP SPT=56974 DPT=443 WINDOW=20 RES=0x00 ACK URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=3.163.139.80 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=16819 DF PROTO=TCP SPT=56974 DPT=443 WINDOW=41 RES=0x00 ACK URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2800:03f0:4003:0c00:0000:0000:0000:0052 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=1029675 PROTO=TCP SPT=443 DPT=50164 WINDOW=1052 RES=0x00 ACK URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=170 TOS=0x00 PREC=0x00 TTL=250 ID=19685 DF PROTO=UDP SPT=53 DPT=59743 LEN=150
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=75 TOS=0x00 PREC=0x00 TTL=64 ID=25147 DF PROTO=UDP SPT=52603 DPT=53 LEN=55
jun 01 11:37:57 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=75 TOS=0x00 PREC=0x00 TTL=64 ID=25147 DF PROTO=UDP SPT=52603 DPT=53 LEN=55
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=75 TOS=0x00 PREC=0x00 TTL=64 ID=25148 DF PROTO=UDP SPT=52603 DPT=53 LEN=55
jun 01 11:37:57 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=75 TOS=0x00 PREC=0x00 TTL=64 ID=25148 DF PROTO=UDP SPT=52603 DPT=53 LEN=55
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=176 TOS=0x00 PREC=0x00 TTL=250 ID=19686 DF PROTO=UDP SPT=53 DPT=59228 LEN=156
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=41475 DF PROTO=UDP SPT=42340 DPT=53 LEN=58
jun 01 11:37:57 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=41475 DF PROTO=UDP SPT=42340 DPT=53 LEN=58
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=41476 DF PROTO=UDP SPT=42340 DPT=53 LEN=58
jun 01 11:37:57 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=41476 DF PROTO=UDP SPT=42340 DPT=53 LEN=58
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=91 TOS=0x00 PREC=0x00 TTL=250 ID=19689 DF PROTO=UDP SPT=53 DPT=52603 LEN=71
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=103 TOS=0x00 PREC=0x00 TTL=250 ID=19690 DF PROTO=UDP SPT=53 DPT=52603 LEN=83
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2a01:04f8:0211:0d14:0000:0000:0000:0002 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=419185 PROTO=TCP SPT=53776 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2a01:04f8:0211:0d14:0000:0000:0000:0002 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=419185 PROTO=TCP SPT=53776 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2800:03f0:4002:080b:0000:0000:0000:200e LEN=266 TC=0 HOPLIMIT=64 FLOWLBL=99354 PROTO=TCP SPT=41786 DPT=443 WINDOW=58 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=1217 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2800:03f0:4002:080b:0000:0000:0000:200e DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=662 TC=0 HOPLIMIT=249 FLOWLBL=612337 PROTO=TCP SPT=443 DPT=41786 WINDOW=1052 RES=0x00 ACK PSH URGP=0
jun 01 11:37:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2800:03f0:4002:080b:0000:0000:0000:200e LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=99354 PROTO=TCP SPT=41786 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2a01:04f8:0211:0d14:0000:0000:0000:0002 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=250 FLOWLBL=986774 PROTO=TCP SPT=443 DPT=53776 WINDOW=64260 RES=0x00 ACK SYN URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2a01:04f8:0211:0d14:0000:0000:0000:0002 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=419185 PROTO=TCP SPT=53776 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2a01:04f8:0211:0d14:0000:0000:0000:0002 LEN=483 TC=0 HOPLIMIT=64 FLOWLBL=419185 PROTO=TCP SPT=53776 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=175 TOS=0x00 PREC=0x00 TTL=250 ID=19714 DF PROTO=UDP SPT=53 DPT=42340 LEN=155
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=232 TOS=0x00 PREC=0x00 TTL=250 ID=19715 DF PROTO=UDP SPT=53 DPT=42340 LEN=212
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2a01:04f8:0211:0d14:0000:0000:0000:0002 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=250 FLOWLBL=986774 PROTO=TCP SPT=443 DPT=53776 WINDOW=501 RES=0x00 ACK URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2a01:04f8:0211:0d14:0000:0000:0000:0002 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2591 TC=0 HOPLIMIT=250 FLOWLBL=986774 PROTO=TCP SPT=443 DPT=53776 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2a01:04f8:0211:0d14:0000:0000:0000:0002 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=419185 PROTO=TCP SPT=53776 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=112.74.190.222 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=39139 DF PROTO=TCP SPT=41128 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=112.74.190.222 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=39139 DF PROTO=TCP SPT=41128 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2a01:04f8:0211:0d14:0000:0000:0000:0002 LEN=78 TC=0 HOPLIMIT=64 FLOWLBL=419185 PROTO=TCP SPT=53776 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25571 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.77.173.206 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=12345 DF PROTO=TCP SPT=51684 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.77.173.206 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=12345 DF PROTO=TCP SPT=51684 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2800:03f0:4003:0c00:0000:0000:0000:0052 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=918 TC=0 HOPLIMIT=249 FLOWLBL=1029675 PROTO=TCP SPT=443 DPT=50164 WINDOW=1052 RES=0x00 ACK PSH URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2a01:04f8:0211:0d14:0000:0000:0000:0002 LEN=727 TC=0 HOPLIMIT=64 FLOWLBL=419185 PROTO=TCP SPT=53776 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2800:03f0:4003:0c00:0000:0000:0000:0052 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=424205 PROTO=TCP SPT=50164 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=112.74.190.222 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=41128 WINDOW=42720 RES=0x00 ACK SYN URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=112.74.190.222 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=39140 DF PROTO=TCP SPT=41128 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=112.74.190.222 LEN=454 TOS=0x00 PREC=0x00 TTL=64 ID=39141 DF PROTO=TCP SPT=41128 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2a01:04f8:0211:0d14:0000:0000:0000:0002 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=375 TC=0 HOPLIMIT=250 FLOWLBL=986774 PROTO=TCP SPT=443 DPT=53776 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2a01:04f8:0211:0d14:0000:0000:0000:0002 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=275 TC=0 HOPLIMIT=250 FLOWLBL=986774 PROTO=TCP SPT=443 DPT=53776 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=112.74.190.222 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=39142 DF PROTO=TCP SPT=41128 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2a01:04f8:0211:0d14:0000:0000:0000:0002 LEN=655 TC=0 HOPLIMIT=64 FLOWLBL=419185 PROTO=TCP SPT=53776 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.77.173.206 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=51684 WINDOW=42720 RES=0x00 ACK SYN URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.77.173.206 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=51684 DPT=443 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18038 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=160 RES=0x00 ACK PSH URGP=0
jun 01 11:37:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25572 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:37:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=1976 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:37:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=112.74.190.222 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=64149 DF PROTO=TCP SPT=443 DPT=41128 WINDOW=83 RES=0x00 ACK URGP=0
jun 01 11:37:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=112.74.190.222 DST=192.168.0.66 LEN=4136 TOS=0x00 PREC=0x00 TTL=250 ID=64150 DF PROTO=TCP SPT=443 DPT=41128 WINDOW=83 RES=0x00 ACK PSH URGP=0
jun 01 11:37:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=112.74.190.222 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=39143 DF PROTO=TCP SPT=41128 DPT=443 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:37:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=112.74.190.222 DST=192.168.0.66 LEN=2390 TOS=0x00 PREC=0x00 TTL=250 ID=64153 DF PROTO=TCP SPT=443 DPT=41128 WINDOW=83 RES=0x00 ACK PSH URGP=0
jun 01 11:37:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=112.74.190.222 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=39144 DF PROTO=TCP SPT=41128 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:37:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=112.74.190.222 LEN=133 TOS=0x00 PREC=0x00 TTL=64 ID=39145 DF PROTO=TCP SPT=41128 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:37:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.77.173.206 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=51684 WINDOW=42720 RES=0x00 ACK SYN URGP=0
jun 01 11:37:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.77.173.206 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=51684 DPT=443 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:37:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2a01:04f8:0211:0d14:0000:0000:0000:0002 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=275 TC=0 HOPLIMIT=250 FLOWLBL=986774 PROTO=TCP SPT=443 DPT=53776 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:37:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2a01:04f8:0211:0d14:0000:0000:0000:0002 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=419185 PROTO=TCP SPT=53776 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:37:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=157.249.81.141 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=38282 DF PROTO=TCP SPT=45178 DPT=443 WINDOW=56 RES=0x00 ACK FIN URGP=0
jun 01 11:37:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=157.249.81.141 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=350 DF PROTO=TCP SPT=443 DPT=45178 WINDOW=504 RES=0x00 ACK FIN URGP=0
jun 01 11:37:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=157.249.81.141 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=38283 DF PROTO=TCP SPT=45178 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:38:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=112.74.190.222 LEN=133 TOS=0x00 PREC=0x00 TTL=64 ID=39146 DF PROTO=TCP SPT=41128 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:38:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=33:33:00:00:00:01:d0:6e:de:8d:01:99:86:dd SRC=fe80:0000:0000:0000:d26e:deff:fe8d:0199 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=240 TC=0 HOPLIMIT=255 FLOWLBL=1009982 PROTO=ICMPv6 TYPE=134 CODE=0
jun 01 11:38:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=112.74.190.222 DST=192.168.0.66 LEN=282 TOS=0x00 PREC=0x00 TTL=250 ID=64155 DF PROTO=TCP SPT=443 DPT=41128 WINDOW=83 RES=0x00 ACK PSH URGP=0
jun 01 11:38:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=112.74.190.222 LEN=638 TOS=0x00 PREC=0x00 TTL=64 ID=39147 DF PROTO=TCP SPT=41128 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:38:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=112.74.190.222 DST=192.168.0.66 LEN=397 TOS=0x00 PREC=0x00 TTL=250 ID=64156 DF PROTO=TCP SPT=443 DPT=41128 WINDOW=83 RES=0x00 ACK PSH URGP=0
jun 01 11:38:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=3597 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=87 TOS=0x00 PREC=0x00 TTL=64 ID=38721 DF PROTO=UDP SPT=39113 DPT=53 LEN=67
jun 01 11:38:01 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=87 TOS=0x00 PREC=0x00 TTL=64 ID=38721 DF PROTO=UDP SPT=39113 DPT=53 LEN=67
jun 01 11:38:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=112.74.190.222 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=39148 DF PROTO=TCP SPT=41128 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:38:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=fe80:0000:0000:0000:d26e:deff:fe8d:0199 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=135 CODE=0
jun 01 11:38:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=fe80:0000:0000:0000:d26e:deff:fe8d:0199 LEN=64 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=136 CODE=0
jun 01 11:38:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=173 TOS=0x00 PREC=0x00 TTL=250 ID=20131 DF PROTO=UDP SPT=53 DPT=39113 LEN=153
jun 01 11:38:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=75 TOS=0x00 PREC=0x00 TTL=64 ID=12652 DF PROTO=UDP SPT=33380 DPT=53 LEN=55
jun 01 11:38:01 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=75 TOS=0x00 PREC=0x00 TTL=64 ID=12652 DF PROTO=UDP SPT=33380 DPT=53 LEN=55
jun 01 11:38:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=75 TOS=0x00 PREC=0x00 TTL=64 ID=12653 DF PROTO=UDP SPT=33380 DPT=53 LEN=55
jun 01 11:38:01 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=75 TOS=0x00 PREC=0x00 TTL=64 ID=12653 DF PROTO=UDP SPT=33380 DPT=53 LEN=55
jun 01 11:38:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=3821 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=4333 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=5257 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=10605 DF PROTO=UDP SPT=38077 DPT=53 LEN=46
jun 01 11:38:04 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=10605 DF PROTO=UDP SPT=38077 DPT=53 LEN=46
jun 01 11:38:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=10606 DF PROTO=UDP SPT=38077 DPT=53 LEN=46
jun 01 11:38:04 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=10606 DF PROTO=UDP SPT=38077 DPT=53 LEN=46
jun 01 11:38:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=6159 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=186 TOS=0x00 PREC=0x00 TTL=250 ID=20594 DF PROTO=UDP SPT=53 DPT=38077 LEN=166
jun 01 11:38:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=241 TOS=0x00 PREC=0x00 TTL=250 ID=20634 DF PROTO=UDP SPT=53 DPT=38077 LEN=221
jun 01 11:38:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=37624 DF PROTO=TCP SPT=41836 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:38:05 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=37624 DF PROTO=TCP SPT=41836 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:38:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.245 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=80 DPT=41836 WINDOW=42340 RES=0x00 ACK SYN URGP=0
jun 01 11:38:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=37625 DF PROTO=TCP SPT=41836 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:38:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=99 TOS=0x00 PREC=0x00 TTL=64 ID=37626 DF PROTO=TCP SPT=41836 DPT=80 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:38:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.245 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=63432 DF PROTO=TCP SPT=80 DPT=41836 WINDOW=83 RES=0x00 ACK URGP=0
jun 01 11:38:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.245 DST=192.168.0.66 LEN=680 TOS=0x00 PREC=0x00 TTL=250 ID=63433 DF PROTO=TCP SPT=80 DPT=41836 WINDOW=83 RES=0x00 ACK PSH URGP=0
jun 01 11:38:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=37627 DF PROTO=TCP SPT=41836 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:38:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=37628 DF PROTO=TCP SPT=41836 DPT=80 WINDOW=63 RES=0x00 ACK FIN URGP=0
jun 01 11:38:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.245 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=63434 DF PROTO=TCP SPT=80 DPT=41836 WINDOW=83 RES=0x00 ACK FIN URGP=0
jun 01 11:38:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.245 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=37629 DF PROTO=TCP SPT=41836 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:38:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=1.82.219.234 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=28319 DF PROTO=UDP SPT=37644 DPT=123 LEN=56
jun 01 11:38:05 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=1.82.219.234 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=28319 DF PROTO=UDP SPT=37644 DPT=123 LEN=56
jun 01 11:38:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=6211 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.28 LEN=75 TOS=0x00 PREC=0x00 TTL=64 ID=44746 DF PROTO=UDP SPT=35669 DPT=53 LEN=55
jun 01 11:38:06 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.28 LEN=75 TOS=0x00 PREC=0x00 TTL=64 ID=44746 DF PROTO=UDP SPT=35669 DPT=53 LEN=55
jun 01 11:38:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.28 LEN=75 TOS=0x00 PREC=0x00 TTL=64 ID=44747 DF PROTO=UDP SPT=35669 DPT=53 LEN=55
jun 01 11:38:06 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.28 LEN=75 TOS=0x00 PREC=0x00 TTL=64 ID=44747 DF PROTO=UDP SPT=35669 DPT=53 LEN=55
jun 01 11:38:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=7061 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=7807 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25573 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:38:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=8763 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18039 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=162 RES=0x00 ACK PSH URGP=0
jun 01 11:38:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25574 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:38:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=181.45.64.81 LEN=75 TOS=0x00 PREC=0x00 TTL=64 ID=3320 DF PROTO=UDP SPT=39103 DPT=53 LEN=55
jun 01 11:38:09 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=181.45.64.81 LEN=75 TOS=0x00 PREC=0x00 TTL=64 ID=3320 DF PROTO=UDP SPT=39103 DPT=53 LEN=55
jun 01 11:38:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=181.45.64.81 LEN=75 TOS=0x00 PREC=0x00 TTL=64 ID=3321 DF PROTO=UDP SPT=39103 DPT=53 LEN=55
jun 01 11:38:09 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=181.45.64.81 LEN=75 TOS=0x00 PREC=0x00 TTL=64 ID=3321 DF PROTO=UDP SPT=39103 DPT=53 LEN=55
jun 01 11:38:10 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=8994 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:10 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.28 DST=192.168.0.66 LEN=290 TOS=0x00 PREC=0x00 TTL=250 ID=48782 DF PROTO=UDP SPT=53 DPT=35669 LEN=270
jun 01 11:38:10 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.28 DST=192.168.0.66 LEN=327 TOS=0x00 PREC=0x00 TTL=250 ID=48787 DF PROTO=UDP SPT=53 DPT=35669 LEN=307
jun 01 11:38:10 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2a01:04f8:0211:0d14:0000:0000:0000:0002 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=183499 PROTO=TCP SPT=53772 DPT=443 WINDOW=62 RES=0x00 ACK FIN URGP=0
jun 01 11:38:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=9774 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2a01:04f8:0211:0d14:0000:0000:0000:0002 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=250 FLOWLBL=242062 PROTO=TCP SPT=443 DPT=53772 WINDOW=501 RES=0x00 ACK FIN URGP=0
jun 01 11:38:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=290 TOS=0x00 PREC=0x00 TTL=250 ID=21506 DF PROTO=UDP SPT=53 DPT=33380 LEN=270
jun 01 11:38:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=327 TOS=0x00 PREC=0x00 TTL=250 ID=21507 DF PROTO=UDP SPT=53 DPT=33380 LEN=307
jun 01 11:38:11 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2a01:04f8:0211:0d14:0000:0000:0000:0002 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=183499 PROTO=TCP SPT=53772 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:38:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=10274 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=10341 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:14 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=10793 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:14 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=01:00:5e:00:00:fb:f8:1a:67:56:e9:4b:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
jun 01 11:38:14 Adrian-PC kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:fb:f8:1a:67:56:e9:4b:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
jun 01 11:38:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=11571 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=181.45.64.81 DST=192.168.0.66 LEN=290 TOS=0x00 PREC=0x00 TTL=250 ID=17285 DF PROTO=UDP SPT=53 DPT=39103 LEN=270
jun 01 11:38:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=181.45.64.81 DST=192.168.0.66 LEN=327 TOS=0x00 PREC=0x00 TTL=250 ID=17286 DF PROTO=UDP SPT=53 DPT=39103 LEN=307
jun 01 11:38:15 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=156.225.111.19 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=5908 DF PROTO=TCP SPT=60856 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:38:15 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=156.225.111.19 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=5908 DF PROTO=TCP SPT=60856 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:38:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=156.225.111.19 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=60856 WINDOW=42340 RES=0x00 ACK SYN URGP=0
jun 01 11:38:15 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=156.225.111.19 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=5909 DF PROTO=TCP SPT=60856 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:38:15 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=156.225.111.19 LEN=451 TOS=0x00 PREC=0x00 TTL=64 ID=5910 DF PROTO=TCP SPT=60856 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:38:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=156.225.111.19 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=32071 DF PROTO=TCP SPT=443 DPT=60856 WINDOW=165 RES=0x00 ACK URGP=0
jun 01 11:38:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=156.225.111.19 DST=192.168.0.66 LEN=4136 TOS=0x00 PREC=0x00 TTL=250 ID=32072 DF PROTO=TCP SPT=443 DPT=60856 WINDOW=165 RES=0x00 ACK PSH URGP=0
jun 01 11:38:15 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=156.225.111.19 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=5911 DF PROTO=TCP SPT=60856 DPT=443 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:38:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=156.225.111.19 DST=192.168.0.66 LEN=2606 TOS=0x00 PREC=0x00 TTL=250 ID=32075 DF PROTO=TCP SPT=443 DPT=60856 WINDOW=165 RES=0x00 ACK PSH URGP=0
jun 01 11:38:15 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=156.225.111.19 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=5912 DF PROTO=TCP SPT=60856 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:38:15 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=156.225.111.19 LEN=46 TOS=0x00 PREC=0x00 TTL=64 ID=5913 DF PROTO=TCP SPT=60856 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=12015 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=112.74.190.222 DST=192.168.0.66 LEN=71 TOS=0x00 PREC=0x00 TTL=250 ID=64157 DF PROTO=TCP SPT=443 DPT=41128 WINDOW=83 RES=0x00 ACK PSH URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=112.74.190.222 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=39149 DF PROTO=TCP SPT=41128 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=112.74.190.222 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=64158 DF PROTO=TCP SPT=443 DPT=41128 WINDOW=83 RES=0x00 ACK FIN URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=156.225.111.19 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=32077 DF PROTO=TCP SPT=443 DPT=60856 WINDOW=165 RES=0x00 ACK URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=156.225.111.19 LEN=717 TOS=0x00 PREC=0x00 TTL=64 ID=5914 DF PROTO=TCP SPT=60856 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=112.74.190.222 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=39150 DF PROTO=TCP SPT=41128 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=156.225.111.19 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=32078 DF PROTO=TCP SPT=443 DPT=60856 WINDOW=165 RES=0x00 ACK URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=156.225.111.19 DST=192.168.0.66 LEN=343 TOS=0x00 PREC=0x00 TTL=250 ID=32079 DF PROTO=TCP SPT=443 DPT=60856 WINDOW=165 RES=0x00 ACK PSH URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=156.225.111.19 DST=192.168.0.66 LEN=343 TOS=0x00 PREC=0x00 TTL=250 ID=32080 DF PROTO=TCP SPT=443 DPT=60856 WINDOW=165 RES=0x00 ACK PSH URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=156.225.111.19 DST=192.168.0.66 LEN=381 TOS=0x00 PREC=0x00 TTL=250 ID=32081 DF PROTO=TCP SPT=443 DPT=60856 WINDOW=165 RES=0x00 ACK PSH URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=156.225.111.19 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=5915 DF PROTO=TCP SPT=60856 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=156.225.111.19 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=5916 DF PROTO=TCP SPT=60856 DPT=443 WINDOW=57 RES=0x00 ACK FIN URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2800:03f0:4002:080b:0000:0000:0000:200e LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=99354 PROTO=TCP SPT=41786 DPT=443 WINDOW=57 RES=0x00 ACK FIN URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=3.163.139.80 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=16820 DF PROTO=TCP SPT=56974 DPT=443 WINDOW=41 RES=0x00 ACK FIN URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=112.74.190.222 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=39151 DF PROTO=TCP SPT=41128 DPT=443 WINDOW=57 RES=0x00 ACK RST URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2800:03f0:4003:0c00:0000:0000:0000:0052 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=424205 PROTO=TCP SPT=50164 DPT=443 WINDOW=61 RES=0x00 ACK FIN URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2a01:04f8:0211:0d14:0000:0000:0000:0002 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=419185 PROTO=TCP SPT=53776 DPT=443 WINDOW=62 RES=0x00 ACK FIN URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=3.163.139.80 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=249 ID=46150 PROTO=TCP SPT=443 DPT=56974 WINDOW=137 RES=0x00 ACK FIN URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2800:03f0:4002:080b:0000:0000:0000:200e DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=612337 PROTO=TCP SPT=443 DPT=41786 WINDOW=1052 RES=0x00 ACK FIN URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=3.163.139.80 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=16821 DF PROTO=TCP SPT=56974 DPT=443 WINDOW=41 RES=0x00 ACK URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2800:03f0:4002:080b:0000:0000:0000:200e LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=99354 PROTO=TCP SPT=41786 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2800:03f0:4003:0c00:0000:0000:0000:0052 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=1029675 PROTO=TCP SPT=443 DPT=50164 WINDOW=1052 RES=0x00 ACK FIN URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2800:03f0:4003:0c00:0000:0000:0000:0052 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=424205 PROTO=TCP SPT=50164 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=156.225.111.19 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=32082 DF PROTO=TCP SPT=443 DPT=60856 WINDOW=165 RES=0x00 ACK FIN URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=156.225.111.19 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=5917 DF PROTO=TCP SPT=60856 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2a01:04f8:0211:0d14:0000:0000:0000:0002 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=250 FLOWLBL=986774 PROTO=TCP SPT=443 DPT=53776 WINDOW=501 RES=0x00 ACK FIN URGP=0
jun 01 11:38:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2a01:04f8:0211:0d14:0000:0000:0000:0002 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=419185 PROTO=TCP SPT=53776 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:38:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=248 TOS=0x00 PREC=0x00 TTL=64 ID=8330 DF PROTO=UDP SPT=138 DPT=138 LEN=228
jun 01 11:38:17 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=248 TOS=0x00 PREC=0x00 TTL=64 ID=8330 DF PROTO=UDP SPT=138 DPT=138 LEN=228
jun 01 11:38:17 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=248 TOS=0x00 PREC=0x00 TTL=64 ID=8330 DF PROTO=UDP SPT=138 DPT=138 LEN=228
jun 01 11:38:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=238 TOS=0x00 PREC=0x00 TTL=64 ID=8331 DF PROTO=UDP SPT=138 DPT=138 LEN=218
jun 01 11:38:17 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=238 TOS=0x00 PREC=0x00 TTL=64 ID=8331 DF PROTO=UDP SPT=138 DPT=138 LEN=218
jun 01 11:38:17 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=238 TOS=0x00 PREC=0x00 TTL=64 ID=8331 DF PROTO=UDP SPT=138 DPT=138 LEN=218
jun 01 11:38:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=12453 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:18 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=12670 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:18 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25575 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:38:19 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=12671 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:19 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18040 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=164 RES=0x00 ACK PSH URGP=0
jun 01 11:38:19 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25576 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:38:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=13011 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=13466 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:22 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=14159 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:23 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=15051 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:24 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=15649 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:25 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=16290 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:25 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=1.82.219.234 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=41119 DF PROTO=UDP SPT=37644 DPT=123 LEN=56
jun 01 11:38:25 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=1.82.219.234 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=41119 DF PROTO=UDP SPT=37644 DPT=123 LEN=56
jun 01 11:38:25 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=1.82.219.234 DST=192.168.0.66 LEN=76 TOS=0x00 PREC=0x00 TTL=250 ID=22256 DF PROTO=UDP SPT=123 DPT=37644 LEN=56
jun 01 11:38:26 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=16792 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:27 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=16930 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:28 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=17014 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:28 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25577 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:38:29 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18041 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=166 RES=0x00 ACK PSH URGP=0
jun 01 11:38:29 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25578 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:38:29 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=17398 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:30 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=17959 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:31 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=18425 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:32 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=19289 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:33 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=20051 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:34 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=20364 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:35 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=20905 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:36 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=21266 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:37 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=22091 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:38 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=22766 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25579 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:38:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18042 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=168 RES=0x00 ACK PSH URGP=0
jun 01 11:38:39 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25580 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:38:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=23702 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=24510 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:41 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=25207 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:42 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=25227 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:43 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=25928 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:44 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=25934 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:45 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=26029 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:46 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=26283 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:47 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=26447 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:48 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=26733 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:48 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25581 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:38:49 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18043 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=170 RES=0x00 ACK PSH URGP=0
jun 01 11:38:49 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25582 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:38:49 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=27312 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:50 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=27850 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:51 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=28357 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:52 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=29107 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:53 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=29299 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:54 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=29892 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:55 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=30438 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:55 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=33:33:00:00:00:01:d0:6e:de:8d:01:99:86:dd SRC=fe80:0000:0000:0000:d26e:deff:fe8d:0199 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=240 TC=0 HOPLIMIT=255 FLOWLBL=1009982 PROTO=ICMPv6 TYPE=134 CODE=0
jun 01 11:38:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=31252 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=32015 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=1.82.219.234 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=44376 DF PROTO=UDP SPT=50613 DPT=123 LEN=56
jun 01 11:38:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=1.82.219.234 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=44376 DF PROTO=UDP SPT=50613 DPT=123 LEN=56
jun 01 11:38:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=32534 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:38:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25583 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:38:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18044 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=172 RES=0x00 ACK PSH URGP=0
jun 01 11:38:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25584 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:38:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=33401 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=34069 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=34405 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=34892 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=35284 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=36106 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=37284 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=248 TOS=0x00 PREC=0x00 TTL=64 ID=55436 DF PROTO=UDP SPT=138 DPT=138 LEN=228
jun 01 11:39:07 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=248 TOS=0x00 PREC=0x00 TTL=64 ID=55436 DF PROTO=UDP SPT=138 DPT=138 LEN=228
jun 01 11:39:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=248 TOS=0x00 PREC=0x00 TTL=64 ID=55436 DF PROTO=UDP SPT=138 DPT=138 LEN=228
jun 01 11:39:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=38267 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=38899 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25585 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:39:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18045 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=175 RES=0x00 ACK PSH URGP=0
jun 01 11:39:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25586 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:39:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=39254 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:10 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=39879 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=40749 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=40788 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=41066 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=1.82.219.234 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=56284 DF PROTO=UDP SPT=50613 DPT=123 LEN=56
jun 01 11:39:13 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=1.82.219.234 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=56284 DF PROTO=UDP SPT=50613 DPT=123 LEN=56
jun 01 11:39:14 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=42041 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=42595 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=43569 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=44427 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:18 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=44922 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:18 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25587 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:39:19 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18046 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=177 RES=0x00 ACK PSH URGP=0
jun 01 11:39:19 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25588 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:39:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=46784 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=47300 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:22 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=47509 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:23 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=48215 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:24 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=49010 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:25 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=49362 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:26 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=50317 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:27 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=50752 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:28 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=50954 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:28 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25589 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:39:29 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18047 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=179 RES=0x00 ACK PSH URGP=0
jun 01 11:39:29 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25590 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:39:29 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=51936 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:30 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=52101 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:31 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=52313 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:32 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=52363 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:33 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=53279 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:33 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=1.82.219.234 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=59930 DF PROTO=UDP SPT=50613 DPT=123 LEN=56
jun 01 11:39:33 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=1.82.219.234 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=59930 DF PROTO=UDP SPT=50613 DPT=123 LEN=56
jun 01 11:39:34 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=53475 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:35 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=53540 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:36 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=53546 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:37 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=53815 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:38 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=54706 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25591 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:39:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18048 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=181 RES=0x00 ACK PSH URGP=0
jun 01 11:39:39 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25592 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:39:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=54719 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=55578 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:41 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=55635 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:42 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=56566 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:43 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=57200 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:44 Adrian-PC kernel: EXT4-fs (nvme0n1p4): re-mounted 6b64d00b-dcb9-4fed-9da6-5001ba778547.
jun 01 11:39:44 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=58086 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:45 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=58099 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:46 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=33:33:00:00:00:01:d0:6e:de:8d:01:99:86:dd SRC=fe80:0000:0000:0000:d26e:deff:fe8d:0199 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=874228 PROTO=ICMPv6 TYPE=130 CODE=0
jun 01 11:39:46 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=58845 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:47 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=58969 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:48 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=59361 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:48 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25593 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:39:49 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18049 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=183 RES=0x00 ACK PSH URGP=0
jun 01 11:39:49 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25594 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:39:50 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=01:00:5e:00:00:fb:f8:1a:67:56:e9:4b:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
jun 01 11:39:50 Adrian-PC kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:fb:f8:1a:67:56:e9:4b:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
jun 01 11:39:50 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=60968 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:51 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=61481 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:52 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=61816 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:53 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=62325 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:54 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=62925 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:54 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=33:33:00:00:00:01:d0:6e:de:8d:01:99:86:dd SRC=fe80:0000:0000:0000:d26e:deff:fe8d:0199 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=240 TC=0 HOPLIMIT=255 FLOWLBL=1009982 PROTO=ICMPv6 TYPE=134 CODE=0
jun 01 11:39:55 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=63259 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:55 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fe80:0000:0000:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=96 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0 MARK=0x94
jun 01 11:39:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=63983 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=64820 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:39:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25595 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:39:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18050 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=185 RES=0x00 ACK PSH URGP=0
jun 01 11:39:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25596 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:39:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=64887 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=65278 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=245 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=883 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=1491 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=2142 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=3115 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=3319 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=3624 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=4237 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25597 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:40:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18051 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=187 RES=0x00 ACK PSH URGP=0
jun 01 11:40:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25598 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:40:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=4293 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:10 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=5014 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=5934 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=6135 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=7131 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:14 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=8077 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=8479 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:15 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=56842 DF PROTO=UDP SPT=59646 DPT=53 LEN=40
jun 01 11:40:15 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=56842 DF PROTO=UDP SPT=59646 DPT=53 LEN=40
jun 01 11:40:15 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=56843 DF PROTO=UDP SPT=59646 DPT=53 LEN=40
jun 01 11:40:15 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=56843 DF PROTO=UDP SPT=59646 DPT=53 LEN=40
jun 01 11:40:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=108 TOS=0x00 PREC=0x00 TTL=250 ID=37016 DF PROTO=UDP SPT=53 DPT=59646 LEN=88
jun 01 11:40:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=9321 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=114 TOS=0x00 PREC=0x00 TTL=250 ID=37065 DF PROTO=UDP SPT=53 DPT=59646 LEN=94
jun 01 11:40:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=1.82.219.234 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=18197 DF PROTO=UDP SPT=43747 DPT=123 LEN=56
jun 01 11:40:16 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=1.82.219.234 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=18197 DF PROTO=UDP SPT=43747 DPT=123 LEN=56
jun 01 11:40:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=9667 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:18 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=10182 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:18 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25599 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:40:19 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18052 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=189 RES=0x00 ACK PSH URGP=0
jun 01 11:40:19 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25600 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:40:19 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=11155 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=11647 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=11823 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=lo SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0
jun 01 11:40:21 Adrian-PC kernel: [UFW AUDIT] IN=lo OUT= MAC=00:00:00:00:00:00:00:00:00:00:00:00:86:dd SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0
jun 01 11:40:21 Adrian-PC kernel: EXT4-fs (nvme0n1p2): re-mounted a63c4c68-2da9-4ea9-b27b-45a3b887483d.
jun 01 11:40:21 Adrian-PC kernel: EXT4-fs (nvme0n1p4): re-mounted 6b64d00b-dcb9-4fed-9da6-5001ba778547.
jun 01 11:40:21 Adrian-PC kernel: EXT4-fs (nvme0n1p5): re-mounted fe412338-68ec-49cd-b285-f43fdcf8c926.
jun 01 11:40:22 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=12701 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:22 Adrian-PC kernel: [UFW AUDIT] IN= OUT=lo SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0
jun 01 11:40:22 Adrian-PC kernel: [UFW AUDIT] IN=lo OUT= MAC=00:00:00:00:00:00:00:00:00:00:00:00:86:dd SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0
jun 01 11:40:23 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=12770 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:24 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=12972 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:25 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=13775 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:26 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=14031 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:26 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=113.141.164.38 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=6596 DF PROTO=UDP SPT=42040 DPT=123 LEN=56
jun 01 11:40:26 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=113.141.164.38 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=6596 DF PROTO=UDP SPT=42040 DPT=123 LEN=56
jun 01 11:40:27 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=14105 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:28 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=14986 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:28 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25601 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:40:29 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18053 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=191 RES=0x00 ACK PSH URGP=0
jun 01 11:40:29 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25602 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:40:30 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=15939 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:31 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=16526 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:32 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=17469 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:33 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=17472 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:34 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=17711 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:34 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=60690 DF PROTO=UDP SPT=57711 DPT=53 LEN=46
jun 01 11:40:34 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=60690 DF PROTO=UDP SPT=57711 DPT=53 LEN=46
jun 01 11:40:34 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=60691 DF PROTO=UDP SPT=57711 DPT=53 LEN=46
jun 01 11:40:34 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=60691 DF PROTO=UDP SPT=57711 DPT=53 LEN=46
jun 01 11:40:35 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=18468 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:35 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=186 TOS=0x00 PREC=0x00 TTL=250 ID=39966 DF PROTO=UDP SPT=53 DPT=57711 LEN=166
jun 01 11:40:35 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=241 TOS=0x00 PREC=0x00 TTL=250 ID=39967 DF PROTO=UDP SPT=53 DPT=57711 LEN=221
jun 01 11:40:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.241 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=57848 DF PROTO=TCP SPT=56170 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:40:35 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.241 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=57848 DF PROTO=TCP SPT=56170 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:40:35 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.241 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=80 DPT=56170 WINDOW=42340 RES=0x00 ACK SYN URGP=0
jun 01 11:40:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.241 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=57849 DF PROTO=TCP SPT=56170 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:40:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.241 LEN=99 TOS=0x00 PREC=0x00 TTL=64 ID=57850 DF PROTO=TCP SPT=56170 DPT=80 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:40:35 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.241 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=32523 DF PROTO=TCP SPT=80 DPT=56170 WINDOW=83 RES=0x00 ACK URGP=0
jun 01 11:40:35 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.241 DST=192.168.0.66 LEN=680 TOS=0x00 PREC=0x00 TTL=250 ID=32524 DF PROTO=TCP SPT=80 DPT=56170 WINDOW=83 RES=0x00 ACK PSH URGP=0
jun 01 11:40:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.241 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=57851 DF PROTO=TCP SPT=56170 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:40:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.241 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=57852 DF PROTO=TCP SPT=56170 DPT=80 WINDOW=63 RES=0x00 ACK FIN URGP=0
jun 01 11:40:35 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.241 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=32525 DF PROTO=TCP SPT=80 DPT=56170 WINDOW=83 RES=0x00 ACK FIN URGP=0
jun 01 11:40:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.241 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=57853 DF PROTO=TCP SPT=56170 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:40:36 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=18996 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:36 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=113.141.164.39 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=60255 DF PROTO=UDP SPT=53937 DPT=123 LEN=56
jun 01 11:40:36 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=113.141.164.39 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=60255 DF PROTO=UDP SPT=53937 DPT=123 LEN=56
jun 01 11:40:37 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=19372 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:38 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=20157 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25603 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:40:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18054 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=193 RES=0x00 ACK PSH URGP=0
jun 01 11:40:39 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25604 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:40:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=20670 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=21207 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:41 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=21425 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:42 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=22289 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:43 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=23239 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:44 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=23380 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:45 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=24021 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:46 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=24353 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:47 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=24667 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:47 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=22687 DF PROTO=UDP SPT=137 DPT=137 LEN=58
jun 01 11:40:47 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=22687 DF PROTO=UDP SPT=137 DPT=137 LEN=58
jun 01 11:40:47 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=22687 DF PROTO=UDP SPT=137 DPT=137 LEN=58
jun 01 11:40:48 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=25303 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:48 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25605 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:40:49 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18055 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=195 RES=0x00 ACK PSH URGP=0
jun 01 11:40:49 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25606 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:40:49 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=23444 DF PROTO=UDP SPT=137 DPT=137 LEN=58
jun 01 11:40:49 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=23444 DF PROTO=UDP SPT=137 DPT=137 LEN=58
jun 01 11:40:49 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=23444 DF PROTO=UDP SPT=137 DPT=137 LEN=58
jun 01 11:40:49 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=25516 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:50 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=24221 DF PROTO=UDP SPT=137 DPT=137 LEN=58
jun 01 11:40:50 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=24221 DF PROTO=UDP SPT=137 DPT=137 LEN=58
jun 01 11:40:50 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=24221 DF PROTO=UDP SPT=137 DPT=137 LEN=58
jun 01 11:40:51 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=26908 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:51 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=24346 DF PROTO=UDP SPT=137 DPT=137 LEN=58
jun 01 11:40:51 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=24346 DF PROTO=UDP SPT=137 DPT=137 LEN=58
jun 01 11:40:51 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=24346 DF PROTO=UDP SPT=137 DPT=137 LEN=58
jun 01 11:40:52 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=27878 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:53 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=27897 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:54 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=28386 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:54 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=33:33:00:00:00:01:d0:6e:de:8d:01:99:86:dd SRC=fe80:0000:0000:0000:d26e:deff:fe8d:0199 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=240 TC=0 HOPLIMIT=255 FLOWLBL=1009982 PROTO=ICMPv6 TYPE=134 CODE=0
jun 01 11:40:55 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=28792 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=29502 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=30457 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=30584 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:40:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25607 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:40:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18056 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=198 RES=0x00 ACK PSH URGP=0
jun 01 11:40:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25608 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:40:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=30941 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=31198 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=31394 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=32190 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=36171 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:41:03 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=36171 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:41:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=36171 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:41:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=248 TOS=0x00 PREC=0x00 TTL=64 ID=36172 DF PROTO=UDP SPT=138 DPT=138 LEN=228
jun 01 11:41:03 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=248 TOS=0x00 PREC=0x00 TTL=64 ID=36172 DF PROTO=UDP SPT=138 DPT=138 LEN=228
jun 01 11:41:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=248 TOS=0x00 PREC=0x00 TTL=64 ID=36172 DF PROTO=UDP SPT=138 DPT=138 LEN=228
jun 01 11:41:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=32846 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=33240 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=33781 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=37789 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:41:05 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=37789 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:41:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=37789 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:41:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=34557 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=38529 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:41:07 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=38529 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:41:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=38529 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:41:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=34618 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=35500 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=248 TOS=0x00 PREC=0x00 TTL=64 ID=9106 DF PROTO=UDP SPT=138 DPT=138 LEN=228
jun 01 11:41:08 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=248 TOS=0x00 PREC=0x00 TTL=64 ID=9106 DF PROTO=UDP SPT=138 DPT=138 LEN=228
jun 01 11:41:08 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=248 TOS=0x00 PREC=0x00 TTL=64 ID=9106 DF PROTO=UDP SPT=138 DPT=138 LEN=228
jun 01 11:41:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=238 TOS=0x00 PREC=0x00 TTL=64 ID=9107 DF PROTO=UDP SPT=138 DPT=138 LEN=218
jun 01 11:41:08 Adrian-PC kernel: [UFW ALLOW] IN= OUT=virbr0 SRC=192.168.122.1 DST=192.168.122.255 LEN=238 TOS=0x00 PREC=0x00 TTL=64 ID=9107 DF PROTO=UDP SPT=138 DPT=138 LEN=218
jun 01 11:41:08 Adrian-PC kernel: [UFW AUDIT] IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=238 TOS=0x00 PREC=0x00 TTL=64 ID=9107 DF PROTO=UDP SPT=138 DPT=138 LEN=218
jun 01 11:41:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25609 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:41:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18057 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=200 RES=0x00 ACK PSH URGP=0
jun 01 11:41:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25610 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:41:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=39548 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:41:09 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=39548 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:41:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=39548 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:41:10 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=36985 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=37080 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:11 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=39658 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:41:11 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=39658 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:41:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=39658 DF PROTO=UDP SPT=138 DPT=138 LEN=200
jun 01 11:41:11 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=39659 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:41:11 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=39659 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:41:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=39659 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:41:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=37351 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=37910 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=41123 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:41:13 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=41123 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:41:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=41123 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:41:14 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=38023 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:14 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=41460 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:41:14 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=41460 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:41:14 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=41460 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:41:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=38732 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:15 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=42280 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:41:15 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=42280 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:41:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=42280 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:41:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=39281 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=42481 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:41:16 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=42481 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:41:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=42481 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:41:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=40115 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:18 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=40333 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:18 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=43369 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:41:18 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=43369 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:41:18 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=43369 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:41:18 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25611 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:41:19 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18058 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=202 RES=0x00 ACK PSH URGP=0
jun 01 11:41:19 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25612 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:41:19 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=41143 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:19 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=43928 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:41:19 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=43928 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:41:19 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=43928 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:41:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=41349 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=44350 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:41:20 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=44350 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:41:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=44350 DF PROTO=UDP SPT=137 DPT=137 LEN=76
jun 01 11:41:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=41579 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=208 TOS=0x00 PREC=0x00 TTL=64 ID=44777 DF PROTO=UDP SPT=138 DPT=138 LEN=188
jun 01 11:41:21 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=208 TOS=0x00 PREC=0x00 TTL=64 ID=44777 DF PROTO=UDP SPT=138 DPT=138 LEN=188
jun 01 11:41:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=208 TOS=0x00 PREC=0x00 TTL=64 ID=44777 DF PROTO=UDP SPT=138 DPT=138 LEN=188
jun 01 11:41:22 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=41636 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:23 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=41900 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:24 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=42195 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:25 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=43103 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:26 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=43222 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:27 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=43691 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:28 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=33:33:00:00:00:01:d0:6e:de:8d:01:99:86:dd SRC=fe80:0000:0000:0000:d26e:deff:fe8d:0199 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=240 TC=0 HOPLIMIT=255 FLOWLBL=1009982 PROTO=ICMPv6 TYPE=134 CODE=0
jun 01 11:41:28 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=44261 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:28 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25613 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:41:29 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18059 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=204 RES=0x00 ACK PSH URGP=0
jun 01 11:41:29 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25614 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:41:29 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=45126 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:30 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=45379 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:31 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=46101 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:31 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=248 TOS=0x00 PREC=0x00 TTL=64 ID=46108 DF PROTO=UDP SPT=138 DPT=138 LEN=228
jun 01 11:41:31 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=248 TOS=0x00 PREC=0x00 TTL=64 ID=46108 DF PROTO=UDP SPT=138 DPT=138 LEN=228
jun 01 11:41:31 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=248 TOS=0x00 PREC=0x00 TTL=64 ID=46108 DF PROTO=UDP SPT=138 DPT=138 LEN=228
jun 01 11:41:31 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=238 TOS=0x00 PREC=0x00 TTL=64 ID=46109 DF PROTO=UDP SPT=138 DPT=138 LEN=218
jun 01 11:41:31 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=192.168.0.255 LEN=238 TOS=0x00 PREC=0x00 TTL=64 ID=46109 DF PROTO=UDP SPT=138 DPT=138 LEN=218
jun 01 11:41:31 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=192.168.0.255 LEN=238 TOS=0x00 PREC=0x00 TTL=64 ID=46109 DF PROTO=UDP SPT=138 DPT=138 LEN=218
jun 01 11:41:32 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=46152 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:33 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=46937 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:34 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=47139 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:36 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=48171 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:37 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=49150 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:38 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=49724 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25615 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:41:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18060 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=206 RES=0x00 ACK PSH URGP=0
jun 01 11:41:39 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25616 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:41:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=50544 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:41 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=51094 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:42 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=51771 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:43 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=52520 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:44 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=53196 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:45 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=53727 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:46 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=54169 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:47 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=54726 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:48 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=55481 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:48 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25617 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:41:49 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18061 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=208 RES=0x00 ACK PSH URGP=0
jun 01 11:41:49 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25618 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:41:50 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=56857 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:51 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=33:33:00:00:00:01:d0:6e:de:8d:01:99:86:dd SRC=fe80:0000:0000:0000:d26e:deff:fe8d:0199 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=874228 PROTO=ICMPv6 TYPE=130 CODE=0
jun 01 11:41:51 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=13778 DF PROTO=2
jun 01 11:41:51 Adrian-PC kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=13778 DF PROTO=2
jun 01 11:41:51 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=8197 DF PROTO=UDP SPT=53953 DPT=53 LEN=40
jun 01 11:41:51 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=8197 DF PROTO=UDP SPT=53953 DPT=53 LEN=40
jun 01 11:41:51 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=8198 DF PROTO=UDP SPT=53953 DPT=53 LEN=40
jun 01 11:41:51 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=8198 DF PROTO=UDP SPT=53953 DPT=53 LEN=40
jun 01 11:41:51 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=108 TOS=0x00 PREC=0x00 TTL=250 ID=49273 DF PROTO=UDP SPT=53 DPT=53953 LEN=88
jun 01 11:41:51 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=114 TOS=0x00 PREC=0x00 TTL=250 ID=49274 DF PROTO=UDP SPT=53 DPT=53953 LEN=94
jun 01 11:41:51 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=1.82.219.234 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=21772 DF PROTO=UDP SPT=58571 DPT=123 LEN=56
jun 01 11:41:51 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=1.82.219.234 LEN=76 TOS=0x10 PREC=0x00 TTL=64 ID=21772 DF PROTO=UDP SPT=58571 DPT=123 LEN=56
jun 01 11:41:51 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=57357 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:51 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=1.82.219.234 DST=192.168.0.66 LEN=76 TOS=0x00 PREC=0x00 TTL=250 ID=2647 DF PROTO=UDP SPT=123 DPT=58571 LEN=56
jun 01 11:41:52 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=57388 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:52 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=fe80:0000:0000:0000:1685:7fff:fe04:e011 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=96 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0 MARK=0x94
jun 01 11:41:53 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=57668 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:54 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=58378 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:55 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=61 TOS=0x00 PREC=0x00 TTL=64 ID=12223 DF PROTO=UDP SPT=36606 DPT=53 LEN=41
jun 01 11:41:55 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=61 TOS=0x00 PREC=0x00 TTL=64 ID=12223 DF PROTO=UDP SPT=36606 DPT=53 LEN=41
jun 01 11:41:55 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=61 TOS=0x00 PREC=0x00 TTL=64 ID=12224 DF PROTO=UDP SPT=36606 DPT=53 LEN=41
jun 01 11:41:55 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=61 TOS=0x00 PREC=0x00 TTL=64 ID=12224 DF PROTO=UDP SPT=36606 DPT=53 LEN=41
jun 01 11:41:55 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=58668 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:55 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=131 TOS=0x00 PREC=0x00 TTL=250 ID=50109 DF PROTO=UDP SPT=53 DPT=36606 LEN=111
jun 01 11:41:55 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=155 TOS=0x00 PREC=0x00 TTL=250 ID=50110 DF PROTO=UDP SPT=53 DPT=36606 LEN=135
jun 01 11:41:55 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=565934 PROTO=TCP SPT=50176 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:41:55 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=565934 PROTO=TCP SPT=50176 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:41:55 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=417569 PROTO=TCP SPT=443 DPT=50176 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:41:55 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=565934 PROTO=TCP SPT=50176 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:41:55 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=565934 PROTO=TCP SPT=50176 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:41:55 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=417569 PROTO=TCP SPT=443 DPT=50176 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:41:55 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2891 TC=0 HOPLIMIT=249 FLOWLBL=417569 PROTO=TCP SPT=443 DPT=50176 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:41:55 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=565934 PROTO=TCP SPT=50176 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:41:55 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=565934 PROTO=TCP SPT=50176 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:41:55 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=314 TC=0 HOPLIMIT=64 FLOWLBL=565934 PROTO=TCP SPT=50176 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:41:55 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=891238 PROTO=TCP SPT=50180 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:41:55 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=891238 PROTO=TCP SPT=50180 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:41:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=616642 PROTO=TCP SPT=50188 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:41:56 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=616642 PROTO=TCP SPT=50188 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:41:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=318034 PROTO=TCP SPT=443 DPT=50180 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:41:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=891238 PROTO=TCP SPT=50180 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:41:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=891238 PROTO=TCP SPT=50180 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:41:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=562993 PROTO=TCP SPT=443 DPT=50188 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:41:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=616642 PROTO=TCP SPT=50188 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:41:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=616642 PROTO=TCP SPT=50188 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:41:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=318034 PROTO=TCP SPT=443 DPT=50180 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:41:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2891 TC=0 HOPLIMIT=249 FLOWLBL=318034 PROTO=TCP SPT=443 DPT=50180 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:41:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=891238 PROTO=TCP SPT=50180 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:41:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=891238 PROTO=TCP SPT=50180 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:41:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=562993 PROTO=TCP SPT=443 DPT=50188 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:41:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2892 TC=0 HOPLIMIT=249 FLOWLBL=562993 PROTO=TCP SPT=443 DPT=50188 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:41:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=616642 PROTO=TCP SPT=50188 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:41:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=616642 PROTO=TCP SPT=50188 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:41:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=314 TC=0 HOPLIMIT=64 FLOWLBL=891238 PROTO=TCP SPT=50180 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:41:56 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=277 TC=0 HOPLIMIT=64 FLOWLBL=616642 PROTO=TCP SPT=50188 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:41:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=58862 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1469 TC=0 HOPLIMIT=249 FLOWLBL=417569 PROTO=TCP SPT=443 DPT=50176 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:41:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=121 TC=0 HOPLIMIT=249 FLOWLBL=417569 PROTO=TCP SPT=443 DPT=50176 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:41:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=84 TC=0 HOPLIMIT=64 FLOWLBL=565934 PROTO=TCP SPT=50176 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:41:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1469 TC=0 HOPLIMIT=249 FLOWLBL=318034 PROTO=TCP SPT=443 DPT=50180 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:41:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=891238 PROTO=TCP SPT=50180 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:41:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1563 TC=0 HOPLIMIT=249 FLOWLBL=562993 PROTO=TCP SPT=443 DPT=50188 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:41:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=616642 PROTO=TCP SPT=50188 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:41:57 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=279 TC=0 HOPLIMIT=64 FLOWLBL=891238 PROTO=TCP SPT=50180 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:41:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=318034 PROTO=TCP SPT=443 DPT=50180 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:41:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=62 TOS=0x00 PREC=0x00 TTL=64 ID=41880 DF PROTO=UDP SPT=32809 DPT=53 LEN=42
jun 01 11:41:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=62 TOS=0x00 PREC=0x00 TTL=64 ID=41880 DF PROTO=UDP SPT=32809 DPT=53 LEN=42
jun 01 11:41:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=62 TOS=0x00 PREC=0x00 TTL=64 ID=41881 DF PROTO=UDP SPT=32809 DPT=53 LEN=42
jun 01 11:41:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=62 TOS=0x00 PREC=0x00 TTL=64 ID=41881 DF PROTO=UDP SPT=32809 DPT=53 LEN=42
jun 01 11:41:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=78 TOS=0x00 PREC=0x00 TTL=250 ID=50241 DF PROTO=UDP SPT=53 DPT=32809 LEN=58
jun 01 11:41:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=60107 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=334 TC=0 HOPLIMIT=64 FLOWLBL=565934 PROTO=TCP SPT=50176 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:41:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=135 TOS=0x00 PREC=0x00 TTL=250 ID=50242 DF PROTO=UDP SPT=53 DPT=32809 LEN=115
jun 01 11:41:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=417569 PROTO=TCP SPT=443 DPT=50176 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:41:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=18954 DF PROTO=TCP SPT=38674 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:41:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=18954 DF PROTO=TCP SPT=38674 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:41:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25619 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:41:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=38674 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:41:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=18955 DF PROTO=TCP SPT=38674 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:41:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=847 TC=0 HOPLIMIT=249 FLOWLBL=417569 PROTO=TCP SPT=443 DPT=50176 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:41:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=565934 PROTO=TCP SPT=50176 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:41:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=569 TOS=0x00 PREC=0x00 TTL=64 ID=18956 DF PROTO=TCP SPT=38674 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:41:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=279 TC=0 HOPLIMIT=64 FLOWLBL=565934 PROTO=TCP SPT=50176 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18062 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=210 RES=0x00 ACK PSH URGP=0
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=46121 DF PROTO=TCP SPT=443 DPT=38674 WINDOW=131 RES=0x00 ACK URGP=0
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=01:00:5e:00:00:fb:f8:1a:67:56:e9:4b:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25620 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:41:59 Adrian-PC kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:fb:f8:1a:67:56:e9:4b:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=46122 DF PROTO=TCP SPT=443 DPT=38674 WINDOW=131 RES=0x00 ACK URGP=0
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=4148 TOS=0x00 PREC=0x00 TTL=250 ID=46123 DF PROTO=TCP SPT=443 DPT=38674 WINDOW=131 RES=0x00 ACK PSH URGP=0
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=18957 DF PROTO=TCP SPT=38674 DPT=443 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=2875 TOS=0x00 PREC=0x00 TTL=250 ID=46126 DF PROTO=TCP SPT=443 DPT=38674 WINDOW=131 RES=0x00 ACK PSH URGP=0
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=18958 DF PROTO=TCP SPT=38674 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=914 TC=0 HOPLIMIT=249 FLOWLBL=417569 PROTO=TCP SPT=443 DPT=50176 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=132 TOS=0x00 PREC=0x00 TTL=64 ID=18959 DF PROTO=TCP SPT=38674 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=359 TC=0 HOPLIMIT=64 FLOWLBL=565934 PROTO=TCP SPT=50176 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=417569 PROTO=TCP SPT=443 DPT=50176 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=61002 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=131 TOS=0x00 PREC=0x00 TTL=250 ID=46128 DF PROTO=TCP SPT=443 DPT=38674 WINDOW=131 RES=0x00 ACK PSH URGP=0
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=864 TOS=0x00 PREC=0x00 TTL=64 ID=18960 DF PROTO=TCP SPT=38674 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=131 TOS=0x00 PREC=0x00 TTL=250 ID=46129 DF PROTO=TCP SPT=443 DPT=38674 WINDOW=131 RES=0x00 ACK PSH URGP=0
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=114 TOS=0x00 PREC=0x00 TTL=250 ID=46130 DF PROTO=TCP SPT=443 DPT=38674 WINDOW=131 RES=0x00 ACK PSH URGP=0
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=841 TC=0 HOPLIMIT=249 FLOWLBL=417569 PROTO=TCP SPT=443 DPT=50176 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=18961 DF PROTO=TCP SPT=38674 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=83 TOS=0x00 PREC=0x00 TTL=250 ID=46131 DF PROTO=TCP SPT=443 DPT=38674 WINDOW=134 RES=0x00 ACK PSH URGP=0
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=83 TOS=0x00 PREC=0x00 TTL=64 ID=18962 DF PROTO=TCP SPT=38674 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=305 TOS=0x00 PREC=0x00 TTL=250 ID=46132 DF PROTO=TCP SPT=443 DPT=38674 WINDOW=134 RES=0x00 ACK PSH URGP=0
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=83 TOS=0x00 PREC=0x00 TTL=250 ID=46133 DF PROTO=TCP SPT=443 DPT=38674 WINDOW=134 RES=0x00 ACK PSH URGP=0
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=843 TC=0 HOPLIMIT=249 FLOWLBL=417569 PROTO=TCP SPT=443 DPT=50176 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=18963 DF PROTO=TCP SPT=38674 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:41:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=565934 PROTO=TCP SPT=50176 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:42:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=576 TOS=0x00 PREC=0x00 TTL=250 ID=46134 DF PROTO=TCP SPT=443 DPT=38674 WINDOW=134 RES=0x00 ACK PSH URGP=0
jun 01 11:42:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=83 TOS=0x00 PREC=0x00 TTL=250 ID=46135 DF PROTO=TCP SPT=443 DPT=38674 WINDOW=134 RES=0x00 ACK PSH URGP=0
jun 01 11:42:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=18964 DF PROTO=TCP SPT=38674 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:42:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=321 TC=0 HOPLIMIT=64 FLOWLBL=565934 PROTO=TCP SPT=50176 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:42:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=417569 PROTO=TCP SPT=443 DPT=50176 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=145 TC=0 HOPLIMIT=64 FLOWLBL=565934 PROTO=TCP SPT=50176 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:42:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=61071 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=46136 DF PROTO=TCP SPT=443 DPT=38674 WINDOW=134 RES=0x00 ACK URGP=0
jun 01 11:42:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1400 TC=0 HOPLIMIT=249 FLOWLBL=417569 PROTO=TCP SPT=443 DPT=50176 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=565934 PROTO=TCP SPT=50176 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:42:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=fe80:0000:0000:0000:d26e:deff:fe8d:0199 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=135 CODE=0
jun 01 11:42:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=fe80:0000:0000:0000:d26e:deff:fe8d:0199 LEN=64 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=136 CODE=0
jun 01 11:42:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=61994 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=62033 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=919 TC=0 HOPLIMIT=249 FLOWLBL=318034 PROTO=TCP SPT=443 DPT=50180 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=891238 PROTO=TCP SPT=50180 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:42:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=780 TC=0 HOPLIMIT=64 FLOWLBL=891238 PROTO=TCP SPT=50180 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:42:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=318034 PROTO=TCP SPT=443 DPT=50180 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1062 TC=0 HOPLIMIT=249 FLOWLBL=318034 PROTO=TCP SPT=443 DPT=50180 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=891238 PROTO=TCP SPT=50180 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=61 TOS=0x00 PREC=0x00 TTL=64 ID=27382 DF PROTO=UDP SPT=50671 DPT=53 LEN=41
jun 01 11:42:03 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=61 TOS=0x00 PREC=0x00 TTL=64 ID=27382 DF PROTO=UDP SPT=50671 DPT=53 LEN=41
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=61 TOS=0x00 PREC=0x00 TTL=64 ID=27383 DF PROTO=UDP SPT=50671 DPT=53 LEN=41
jun 01 11:42:03 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=61 TOS=0x00 PREC=0x00 TTL=64 ID=27383 DF PROTO=UDP SPT=50671 DPT=53 LEN=41
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=780 TC=0 HOPLIMIT=64 FLOWLBL=891238 PROTO=TCP SPT=50180 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=131 TOS=0x00 PREC=0x00 TTL=250 ID=50962 DF PROTO=UDP SPT=53 DPT=50671 LEN=111
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=155 TOS=0x00 PREC=0x00 TTL=250 ID=50963 DF PROTO=UDP SPT=53 DPT=50671 LEN=135
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=486460 PROTO=TCP SPT=36252 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=675299 PROTO=TCP SPT=36254 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=5312 PROTO=TCP SPT=36250 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=486460 PROTO=TCP SPT=36252 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=675299 PROTO=TCP SPT=36254 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=5312 PROTO=TCP SPT=36250 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=318034 PROTO=TCP SPT=443 DPT=50180 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=188710 PROTO=TCP SPT=443 DPT=36254 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=581433 PROTO=TCP SPT=443 DPT=36250 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=41103 PROTO=TCP SPT=443 DPT=36252 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=675299 PROTO=TCP SPT=36254 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=486460 PROTO=TCP SPT=36252 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=5312 PROTO=TCP SPT=36250 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=486460 PROTO=TCP SPT=36252 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=675299 PROTO=TCP SPT=36254 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=5312 PROTO=TCP SPT=36250 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=41103 PROTO=TCP SPT=443 DPT=36252 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=188710 PROTO=TCP SPT=443 DPT=36254 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=581433 PROTO=TCP SPT=443 DPT=36250 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2890 TC=0 HOPLIMIT=249 FLOWLBL=188710 PROTO=TCP SPT=443 DPT=36254 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=675299 PROTO=TCP SPT=36254 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=675299 PROTO=TCP SPT=36254 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2891 TC=0 HOPLIMIT=249 FLOWLBL=41103 PROTO=TCP SPT=443 DPT=36252 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2890 TC=0 HOPLIMIT=249 FLOWLBL=581433 PROTO=TCP SPT=443 DPT=36250 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=5312 PROTO=TCP SPT=36250 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=486460 PROTO=TCP SPT=36252 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=5312 PROTO=TCP SPT=36250 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=486460 PROTO=TCP SPT=36252 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=188710 PROTO=TCP SPT=443 DPT=36254 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=359 TC=0 HOPLIMIT=64 FLOWLBL=675299 PROTO=TCP SPT=36254 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=581433 PROTO=TCP SPT=443 DPT=36250 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=359 TC=0 HOPLIMIT=64 FLOWLBL=5312 PROTO=TCP SPT=36250 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=41103 PROTO=TCP SPT=443 DPT=36252 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=343 TC=0 HOPLIMIT=64 FLOWLBL=486460 PROTO=TCP SPT=36252 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=63186 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1062 TC=0 HOPLIMIT=249 FLOWLBL=318034 PROTO=TCP SPT=443 DPT=50180 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=891238 PROTO=TCP SPT=50180 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1337 TC=0 HOPLIMIT=249 FLOWLBL=188710 PROTO=TCP SPT=443 DPT=36254 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1341 TC=0 HOPLIMIT=249 FLOWLBL=41103 PROTO=TCP SPT=443 DPT=36252 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1339 TC=0 HOPLIMIT=249 FLOWLBL=581433 PROTO=TCP SPT=443 DPT=36250 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=675299 PROTO=TCP SPT=36254 DPT=443 WINDOW=61 RES=0x00 ACK FIN URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=5312 PROTO=TCP SPT=36250 DPT=443 WINDOW=61 RES=0x00 ACK FIN URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=486460 PROTO=TCP SPT=36252 DPT=443 WINDOW=61 RES=0x00 ACK FIN URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=188710 PROTO=TCP SPT=443 DPT=36254 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=675299 PROTO=TCP SPT=36254 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=41103 PROTO=TCP SPT=443 DPT=36252 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=581433 PROTO=TCP SPT=443 DPT=36250 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=486460 PROTO=TCP SPT=36252 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=5312 PROTO=TCP SPT=36250 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2890 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=306 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1961 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=506 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=99 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=84 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=722 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=31245 DF PROTO=UDP SPT=37886 DPT=53 LEN=44
jun 01 11:42:05 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=31245 DF PROTO=UDP SPT=37886 DPT=53 LEN=44
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=31246 DF PROTO=UDP SPT=37886 DPT=53 LEN=44
jun 01 11:42:05 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=31246 DF PROTO=UDP SPT=37886 DPT=53 LEN=44
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=63760 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=134 TOS=0x00 PREC=0x00 TTL=250 ID=51197 DF PROTO=UDP SPT=53 DPT=37886 LEN=114
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=158 TOS=0x00 PREC=0x00 TTL=250 ID=51203 DF PROTO=UDP SPT=53 DPT=37886 LEN=138
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=497 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2896 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=663 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1650 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1420 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=58 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=115 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2854 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5636 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=7027 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8160 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=3459 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=12 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=36 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4584 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=52 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=68 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=83 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=99 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=108 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=6812 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=124 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=140 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=156 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=171 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=187 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=203 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=235 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=250 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=266 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=282 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=298 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=314 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5520 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=324 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=340 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5994 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=352 RES=0x00 ACK URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=656 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=352 RES=0x00 ACK PSH URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=491 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=58 RES=0x00 ACK URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=64201 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=644 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=99 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=84 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=734 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=352 RES=0x00 ACK PSH URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=1009822 PROTO=TCP SPT=36302 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=1009822 PROTO=TCP SPT=36302 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=896453 PROTO=TCP SPT=36304 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=896453 PROTO=TCP SPT=36304 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=414030 PROTO=TCP SPT=443 DPT=36302 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=108250 PROTO=TCP SPT=443 DPT=36304 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1009822 PROTO=TCP SPT=36302 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=896453 PROTO=TCP SPT=36304 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=1009822 PROTO=TCP SPT=36302 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=896453 PROTO=TCP SPT=36304 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=414030 PROTO=TCP SPT=443 DPT=36302 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=108250 PROTO=TCP SPT=443 DPT=36304 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2891 TC=0 HOPLIMIT=249 FLOWLBL=108250 PROTO=TCP SPT=443 DPT=36304 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2891 TC=0 HOPLIMIT=249 FLOWLBL=414030 PROTO=TCP SPT=443 DPT=36302 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=896453 PROTO=TCP SPT=36304 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1009822 PROTO=TCP SPT=36302 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=1009822 PROTO=TCP SPT=36302 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=896453 PROTO=TCP SPT=36304 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=340 TC=0 HOPLIMIT=64 FLOWLBL=1009822 PROTO=TCP SPT=36302 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=367 TC=0 HOPLIMIT=64 FLOWLBL=896453 PROTO=TCP SPT=36304 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8843 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=369 RES=0x00 ACK URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=755 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=84 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=369 RES=0x00 ACK URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1339 TC=0 HOPLIMIT=249 FLOWLBL=414030 PROTO=TCP SPT=443 DPT=36302 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1009822 PROTO=TCP SPT=36302 DPT=443 WINDOW=61 RES=0x00 ACK FIN URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=414030 PROTO=TCP SPT=443 DPT=36302 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1009822 PROTO=TCP SPT=36302 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1961 TC=0 HOPLIMIT=249 FLOWLBL=108250 PROTO=TCP SPT=443 DPT=36304 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=108250 PROTO=TCP SPT=443 DPT=36304 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2469 TC=0 HOPLIMIT=249 FLOWLBL=108250 PROTO=TCP SPT=443 DPT=36304 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=99 TC=0 HOPLIMIT=249 FLOWLBL=108250 PROTO=TCP SPT=443 DPT=36304 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=896453 PROTO=TCP SPT=36304 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:42:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=478 TC=0 HOPLIMIT=64 FLOWLBL=896453 PROTO=TCP SPT=36304 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=64894 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1306 TC=0 HOPLIMIT=249 FLOWLBL=108250 PROTO=TCP SPT=443 DPT=36304 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=1041 TC=0 HOPLIMIT=64 FLOWLBL=896453 PROTO=TCP SPT=36304 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=108250 PROTO=TCP SPT=443 DPT=36304 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4190 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=377 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=385 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8286 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=401 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=12388 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=425 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=256 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=84 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=425 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=897 TC=0 HOPLIMIT=249 FLOWLBL=108250 PROTO=TCP SPT=443 DPT=36304 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=896453 PROTO=TCP SPT=36304 DPT=443 WINDOW=56 RES=0x00 ACK FIN URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=108250 PROTO=TCP SPT=443 DPT=36304 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=13552 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=451 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=896453 PROTO=TCP SPT=36304 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2998 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=457 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=483 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=6998 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=497 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1167 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=499 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1420 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=502 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=12204 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=526 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=552 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=306 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=579 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=605 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=631 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2768 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=636 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=10856 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=657 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=684 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=710 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=736 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=763 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=359 DF PROTO=UDP SPT=55747 DPT=53 LEN=44
jun 01 11:42:07 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=359 DF PROTO=UDP SPT=55747 DPT=53 LEN=44
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=360 DF PROTO=UDP SPT=55747 DPT=53 LEN=44
jun 01 11:42:07 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=360 DF PROTO=UDP SPT=55747 DPT=53 LEN=44
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=789 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=815 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=842 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=6812 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=868 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=881 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=908 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=540 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4116 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=916 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=942 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=9508 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=960 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=963 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=987 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=83428 PROTO=TCP SPT=36308 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=83428 PROTO=TCP SPT=36308 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1013 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=18944 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1050 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=20292 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1089 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1129 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1132 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=6812 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1145 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1169 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1208 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=10856 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1229 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1248 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1287 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1327 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=14900 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1355 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1379 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=27032 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1432 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1485 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=20292 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1524 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1537 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1590 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1608 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1621 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1661 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1714 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1750 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=83428 PROTO=TCP SPT=36308 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1803 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1832 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=83428 PROTO=TCP SPT=36308 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1856 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1908 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=39164 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1883 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1916 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8160 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1909 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=31076 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1923 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=35120 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1919 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1931 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1912 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1915 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=37816 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1917 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1884 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=7525 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1877 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2891 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=83428 PROTO=TCP SPT=36308 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=83428 PROTO=TCP SPT=36308 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=80 TOS=0x00 PREC=0x00 TTL=250 ID=51769 DF PROTO=UDP SPT=53 DPT=55747 LEN=60
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=137 TOS=0x00 PREC=0x00 TTL=250 ID=51770 DF PROTO=UDP SPT=53 DPT=55747 LEN=117
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=55900 DF PROTO=TCP SPT=57106 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=55900 DF PROTO=TCP SPT=57106 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=306 TC=0 HOPLIMIT=64 FLOWLBL=83428 PROTO=TCP SPT=36308 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=64990 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=490 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=99 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=657 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1931 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=84 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1144 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1933 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8160 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1941 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8390 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=24692 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1920 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1913 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=32884 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=13872 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1901 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1961 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=496 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=99 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=83428 PROTO=TCP SPT=36308 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=657 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1941 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25621 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=55 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=494 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=84 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=55 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1141 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1944 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8286 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1940 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1934 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=16478 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5464 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1916 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=11086 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1939 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1935 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1921 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1914 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1928 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1923 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1925 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=13552 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2998 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1946 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=16248 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=302 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1948 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1420 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=15130 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=13145 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18063 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=212 RES=0x00 ACK PSH URGP=0
jun 01 11:42:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25622 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=54 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=496 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=99 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=657 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1948 RES=0x00 ACK PSH URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=55901 DF PROTO=TCP SPT=57106 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=55901 DF PROTO=TCP SPT=57106 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=65083 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1420 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1947 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=15130 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1936 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=9335 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1941 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=16478 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1927 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=32884 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1899 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=9508 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1891 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=31662 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1922 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=53992 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1903 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=10856 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1940 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=64776 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1885 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=10856 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=23940 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1928 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=62080 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1897 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2768 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1946 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=50210 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1904 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=32424 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=32424 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=52644 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=1948 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=12204 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2093 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=41423 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2174 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=983 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=84 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2174 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=57106 WINDOW=28960 RES=0x00 ACK SYN URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=55902 DF PROTO=TCP SPT=57106 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=569 TOS=0x00 PREC=0x00 TTL=64 ID=55903 DF PROTO=TCP SPT=57106 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4116 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2182 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=12434 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2206 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1140 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2209 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2241 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2273 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=7865 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2288 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=30671 DF PROTO=TCP SPT=443 DPT=57106 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=4148 TOS=0x00 PREC=0x00 TTL=250 ID=30672 DF PROTO=TCP SPT=443 DPT=57106 WINDOW=59 RES=0x00 ACK PSH URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=55904 DF PROTO=TCP SPT=57106 DPT=443 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=2558 TOS=0x00 PREC=0x00 TTL=250 ID=30675 DF PROTO=TCP SPT=443 DPT=57106 WINDOW=59 RES=0x00 ACK PSH URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=55905 DF PROTO=TCP SPT=57106 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:42:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=132 TOS=0x00 PREC=0x00 TTL=64 ID=55906 DF PROTO=TCP SPT=57106 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=65320 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=131 TOS=0x00 PREC=0x00 TTL=250 ID=30677 DF PROTO=TCP SPT=443 DPT=57106 WINDOW=59 RES=0x00 ACK PSH URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=282 TOS=0x00 PREC=0x00 TTL=64 ID=55907 DF PROTO=TCP SPT=57106 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=131 TOS=0x00 PREC=0x00 TTL=250 ID=30678 DF PROTO=TCP SPT=443 DPT=57106 WINDOW=59 RES=0x00 ACK PSH URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=55908 DF PROTO=TCP SPT=57106 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=593015 PROTO=TCP SPT=36310 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=593015 PROTO=TCP SPT=36310 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=920418 PROTO=TCP SPT=36324 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=920418 PROTO=TCP SPT=36324 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=217845 PROTO=TCP SPT=443 DPT=36310 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=593015 PROTO=TCP SPT=36310 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=593015 PROTO=TCP SPT=36310 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=55909 DF PROTO=TCP SPT=57106 DPT=443 WINDOW=57 RES=0x00 ACK FIN URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=603489 PROTO=TCP SPT=443 DPT=36324 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=920418 PROTO=TCP SPT=36324 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=920418 PROTO=TCP SPT=36324 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=217845 PROTO=TCP SPT=443 DPT=36310 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2892 TC=0 HOPLIMIT=249 FLOWLBL=217845 PROTO=TCP SPT=443 DPT=36310 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=593015 PROTO=TCP SPT=36310 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=593015 PROTO=TCP SPT=36310 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=603489 PROTO=TCP SPT=443 DPT=36324 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2892 TC=0 HOPLIMIT=249 FLOWLBL=603489 PROTO=TCP SPT=443 DPT=36324 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=920418 PROTO=TCP SPT=36324 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=920418 PROTO=TCP SPT=36324 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=372 TOS=0x00 PREC=0x00 TTL=250 ID=30679 DF PROTO=TCP SPT=443 DPT=57106 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=57106 DPT=443 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=806 TC=0 HOPLIMIT=64 FLOWLBL=920418 PROTO=TCP SPT=36324 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:10 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=340 TC=0 HOPLIMIT=64 FLOWLBL=593015 PROTO=TCP SPT=36310 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=30680 DF PROTO=TCP SPT=443 DPT=57106 WINDOW=61 RES=0x00 ACK FIN URGP=0
jun 01 11:42:11 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=57106 DPT=443 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:42:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1343 TC=0 HOPLIMIT=249 FLOWLBL=217845 PROTO=TCP SPT=443 DPT=36310 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:11 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=593015 PROTO=TCP SPT=36310 DPT=443 WINDOW=61 RES=0x00 ACK FIN URGP=0
jun 01 11:42:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1961 TC=0 HOPLIMIT=249 FLOWLBL=603489 PROTO=TCP SPT=443 DPT=36324 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=603489 PROTO=TCP SPT=443 DPT=36324 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1986 TC=0 HOPLIMIT=249 FLOWLBL=603489 PROTO=TCP SPT=443 DPT=36324 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=99 TC=0 HOPLIMIT=249 FLOWLBL=603489 PROTO=TCP SPT=443 DPT=36324 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:11 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=920418 PROTO=TCP SPT=36324 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:42:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=217845 PROTO=TCP SPT=443 DPT=36310 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:42:11 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=593015 PROTO=TCP SPT=36310 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:42:11 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=478 TC=0 HOPLIMIT=64 FLOWLBL=920418 PROTO=TCP SPT=36324 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:42:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=603489 PROTO=TCP SPT=443 DPT=36324 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=432 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1417 TC=0 HOPLIMIT=249 FLOWLBL=603489 PROTO=TCP SPT=443 DPT=36324 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:11 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=920418 PROTO=TCP SPT=36324 DPT=443 WINDOW=56 RES=0x00 ACK FIN URGP=0
jun 01 11:42:11 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=306 TC=0 HOPLIMIT=64 FLOWLBL=83428 PROTO=TCP SPT=36308 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:42:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=603489 PROTO=TCP SPT=443 DPT=36324 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:42:11 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=920418 PROTO=TCP SPT=36324 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:42:11 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=306 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=54 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=540 TC=0 HOPLIMIT=64 FLOWLBL=83428 PROTO=TCP SPT=36308 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=540 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=54 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=760567 PROTO=TCP SPT=36620 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=760567 PROTO=TCP SPT=36620 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=773779 PROTO=TCP SPT=36624 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=773779 PROTO=TCP SPT=36624 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=840292 PROTO=TCP SPT=443 DPT=36624 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=993517 PROTO=TCP SPT=443 DPT=36620 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=773779 PROTO=TCP SPT=36624 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=760567 PROTO=TCP SPT=36620 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=760567 PROTO=TCP SPT=36620 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=773779 PROTO=TCP SPT=36624 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=840292 PROTO=TCP SPT=443 DPT=36624 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=993517 PROTO=TCP SPT=443 DPT=36620 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2890 TC=0 HOPLIMIT=249 FLOWLBL=840292 PROTO=TCP SPT=443 DPT=36624 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2891 TC=0 HOPLIMIT=249 FLOWLBL=993517 PROTO=TCP SPT=443 DPT=36620 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=760567 PROTO=TCP SPT=36620 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=773779 PROTO=TCP SPT=36624 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=760567 PROTO=TCP SPT=36620 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=386 TC=0 HOPLIMIT=64 FLOWLBL=773779 PROTO=TCP SPT=36624 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=306 TC=0 HOPLIMIT=64 FLOWLBL=760567 PROTO=TCP SPT=36620 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=1081 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=525 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=53 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=84 TC=0 HOPLIMIT=64 FLOWLBL=83428 PROTO=TCP SPT=36308 DPT=443 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=494 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=99 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=657 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2288 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1961 TC=0 HOPLIMIT=249 FLOWLBL=840292 PROTO=TCP SPT=443 DPT=36624 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=496 TC=0 HOPLIMIT=249 FLOWLBL=840292 PROTO=TCP SPT=443 DPT=36624 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=99 TC=0 HOPLIMIT=249 FLOWLBL=840292 PROTO=TCP SPT=443 DPT=36624 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=773779 PROTO=TCP SPT=36624 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=1242 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2288 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1961 TC=0 HOPLIMIT=249 FLOWLBL=993517 PROTO=TCP SPT=443 DPT=36620 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=498 TC=0 HOPLIMIT=249 FLOWLBL=993517 PROTO=TCP SPT=443 DPT=36620 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=99 TC=0 HOPLIMIT=249 FLOWLBL=993517 PROTO=TCP SPT=443 DPT=36620 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=760567 PROTO=TCP SPT=36620 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2895 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=657 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=83428 PROTO=TCP SPT=36308 DPT=443 WINDOW=58 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=494 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=99 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=52 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=529 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2896 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2897 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=657 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=657 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1162 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2291 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=16478 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2323 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2355 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=6812 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2368 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=9738 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2387 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2419 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2451 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2768 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2456 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=13782 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2483 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2515 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=10856 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2536 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5694 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2547 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2579 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2611 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2643 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2675 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=9508 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2694 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=7042 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2707 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2739 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2771 RES=0x00 ACK URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4616 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2780 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1420 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=2005 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=83428 PROTO=TCP SPT=36308 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=115 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=531 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1961 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2854 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=658 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4245 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=45 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4212 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5636 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=51 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=490 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=99 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=36 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=657 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2780 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=6983 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=537640 PROTO=TCP SPT=52646 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=537640 PROTO=TCP SPT=52646 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2768 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4795 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=657 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=36 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=942361 PROTO=TCP SPT=443 DPT=52646 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=537640 PROTO=TCP SPT=52646 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=537640 PROTO=TCP SPT=52646 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=942361 PROTO=TCP SPT=443 DPT=52646 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2896 TC=0 HOPLIMIT=249 FLOWLBL=942361 PROTO=TCP SPT=443 DPT=52646 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=537640 PROTO=TCP SPT=52646 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=537640 PROTO=TCP SPT=52646 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1660 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2854 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5636 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2810 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=47 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=7027 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4116 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=36 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2939 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8160 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=9508 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8628 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1662 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2854 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4223 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5614 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5636 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=6983 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=36 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=7027 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=9765 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5464 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=54 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=12204 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=73 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=10856 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=16478 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1420 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2812 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=91 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=9362 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=108 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2830 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8286 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2846 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2878 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1420 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2881 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=15130 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2911 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2943 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2975 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=10856 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=2996 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5694 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3007 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3039 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3071 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3103 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3135 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=9508 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3153 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=7042 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3167 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3199 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3231 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=7726 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3246 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=126 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=145 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=86 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1214 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=163 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=182 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=200 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=219 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2768 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=224 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=6812 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=237 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=255 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=274 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=292 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=311 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=6812 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=324 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=128 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=342 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=361 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=379 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=398 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=416 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=434 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=453 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=471 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=490 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=508 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=527 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=545 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5464 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=556 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4116 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=563 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=582 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=600 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=611 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=619 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=637 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=656 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=674 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=14900 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=703 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=732 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=761 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=790 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=819 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=848 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1437 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=850 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=89 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1420 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2975 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=44 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4660 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=53 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4190 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4323 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=70 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=78 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=6812 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=91 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1302 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=7507 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=109 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8160 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=124 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=140 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=156 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=172 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5066 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=203 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=213 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3249 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=7517 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3263 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=16476 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3295 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=96 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3311 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4190 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3319 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3335 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3343 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=12380 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3368 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8288 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3373 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=6812 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3367 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=9736 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3392 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3390 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3394 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3384 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3380 RES=0x00 ACK URGP=0
jun 01 11:42:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=6447 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:14 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=2552 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:14 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1158 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:14 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3397 RES=0x00 ACK URGP=0
jun 01 11:42:14 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8286 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:14 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3390 RES=0x00 ACK URGP=0
jun 01 11:42:14 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=16478 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:14 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3391 RES=0x00 ACK URGP=0
jun 01 11:42:14 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1420 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK URGP=0
jun 01 11:42:14 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3400 RES=0x00 ACK URGP=0
jun 01 11:42:14 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=15130 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:14 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3393 RES=0x00 ACK URGP=0
jun 01 11:42:14 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3379 RES=0x00 ACK URGP=0
jun 01 11:42:14 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3365 RES=0x00 ACK URGP=0
jun 01 11:42:14 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=13917 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:42:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=3481 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=4387 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=4643 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:18 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=4837 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:18 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25623 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:42:19 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18064 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=214 RES=0x00 ACK PSH URGP=0
jun 01 11:42:19 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25624 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:42:19 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=5589 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:19 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=33:33:00:00:00:01:d0:6e:de:8d:01:99:86:dd SRC=fe80:0000:0000:0000:d26e:deff:fe8d:0199 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=240 TC=0 HOPLIMIT=255 FLOWLBL=1009982 PROTO=ICMPv6 TYPE=134 CODE=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=6406 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=205146 PROTO=TCP SPT=36632 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=205146 PROTO=TCP SPT=36632 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=919684 PROTO=TCP SPT=443 DPT=36632 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=205146 PROTO=TCP SPT=36632 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=205146 PROTO=TCP SPT=36632 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=339 TC=0 HOPLIMIT=64 FLOWLBL=83428 PROTO=TCP SPT=36308 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=306 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=51 RES=0x00 ACK PSH URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=394766 PROTO=TCP SPT=36638 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=394766 PROTO=TCP SPT=36638 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=306 TC=0 HOPLIMIT=64 FLOWLBL=760567 PROTO=TCP SPT=36620 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=774198 PROTO=TCP SPT=36648 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=774198 PROTO=TCP SPT=36648 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=919684 PROTO=TCP SPT=443 DPT=36632 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2768 TC=0 HOPLIMIT=249 FLOWLBL=919684 PROTO=TCP SPT=443 DPT=36632 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=205146 PROTO=TCP SPT=36632 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=195 TC=0 HOPLIMIT=249 FLOWLBL=919684 PROTO=TCP SPT=443 DPT=36632 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=205146 PROTO=TCP SPT=36632 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=920155 PROTO=TCP SPT=443 DPT=36648 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=701498 PROTO=TCP SPT=443 DPT=36638 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=774198 PROTO=TCP SPT=36648 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=394766 PROTO=TCP SPT=36638 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=394766 PROTO=TCP SPT=36638 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=774198 PROTO=TCP SPT=36648 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=993517 PROTO=TCP SPT=443 DPT=36620 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=920155 PROTO=TCP SPT=443 DPT=36648 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=701498 PROTO=TCP SPT=443 DPT=36638 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2891 TC=0 HOPLIMIT=249 FLOWLBL=920155 PROTO=TCP SPT=443 DPT=36648 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=774198 PROTO=TCP SPT=36648 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2891 TC=0 HOPLIMIT=249 FLOWLBL=701498 PROTO=TCP SPT=443 DPT=36638 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=394766 PROTO=TCP SPT=36638 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=394766 PROTO=TCP SPT=36638 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=774198 PROTO=TCP SPT=36648 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=384 TC=0 HOPLIMIT=64 FLOWLBL=205146 PROTO=TCP SPT=36632 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=319 TC=0 HOPLIMIT=64 FLOWLBL=774198 PROTO=TCP SPT=36648 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=306 TC=0 HOPLIMIT=64 FLOWLBL=394766 PROTO=TCP SPT=36638 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=993517 PROTO=TCP SPT=443 DPT=36620 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=859 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=493 TC=0 HOPLIMIT=249 FLOWLBL=993517 PROTO=TCP SPT=443 DPT=36620 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=50 RES=0x00 ACK URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=83428 PROTO=TCP SPT=36308 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=99 TC=0 HOPLIMIT=249 FLOWLBL=993517 PROTO=TCP SPT=443 DPT=36620 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=487 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=99 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=760567 PROTO=TCP SPT=36620 DPT=443 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:42:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=84 TC=0 HOPLIMIT=64 FLOWLBL=760567 PROTO=TCP SPT=36620 DPT=443 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1461 TC=0 HOPLIMIT=249 FLOWLBL=919684 PROTO=TCP SPT=443 DPT=36632 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=205146 PROTO=TCP SPT=36632 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=894 TC=0 HOPLIMIT=64 FLOWLBL=205146 PROTO=TCP SPT=36632 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=919684 PROTO=TCP SPT=443 DPT=36632 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1961 TC=0 HOPLIMIT=249 FLOWLBL=920155 PROTO=TCP SPT=443 DPT=36648 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=648 TC=0 HOPLIMIT=249 FLOWLBL=920155 PROTO=TCP SPT=443 DPT=36648 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=774198 PROTO=TCP SPT=36648 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=774198 PROTO=TCP SPT=36648 DPT=443 WINDOW=60 RES=0x00 ACK FIN URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=920155 PROTO=TCP SPT=443 DPT=36648 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1961 TC=0 HOPLIMIT=249 FLOWLBL=701498 PROTO=TCP SPT=443 DPT=36638 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=489 TC=0 HOPLIMIT=249 FLOWLBL=701498 PROTO=TCP SPT=443 DPT=36638 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=99 TC=0 HOPLIMIT=249 FLOWLBL=701498 PROTO=TCP SPT=443 DPT=36638 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=394766 PROTO=TCP SPT=36638 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=306 TC=0 HOPLIMIT=64 FLOWLBL=394766 PROTO=TCP SPT=36638 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=701498 PROTO=TCP SPT=443 DPT=36638 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=672545 PROTO=TCP SPT=443 DPT=52654 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=672545 PROTO=TCP SPT=443 DPT=52654 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2896 TC=0 HOPLIMIT=249 FLOWLBL=672545 PROTO=TCP SPT=443 DPT=52654 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=657 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=7111 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=957 TC=0 HOPLIMIT=249 FLOWLBL=919684 PROTO=TCP SPT=443 DPT=36632 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=701498 PROTO=TCP SPT=443 DPT=36638 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=497 TC=0 HOPLIMIT=249 FLOWLBL=701498 PROTO=TCP SPT=443 DPT=36638 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=84 TC=0 HOPLIMIT=64 FLOWLBL=394766 PROTO=TCP SPT=36638 DPT=443 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=205146 PROTO=TCP SPT=36632 DPT=443 WINDOW=61 RES=0x00 ACK FIN URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=919684 PROTO=TCP SPT=443 DPT=36632 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2895 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=657 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1961 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2854 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=7027 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5636 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8160 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5464 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=36 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2768 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=7063 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4584 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=52 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=68 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=83 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=99 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=108 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=124 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=140 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=155 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=171 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=187 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2768 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=192 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5464 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=203 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=219 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=234 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=250 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=266 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=282 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=298 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5520 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=313 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=324 RES=0x00 ACK URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5923 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:21 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=335 RES=0x00 ACK URGP=0
jun 01 11:42:22 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=7226 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:23 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=8083 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:24 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=8486 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=8979 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1420 TC=0 HOPLIMIT=249 FLOWLBL=672545 PROTO=TCP SPT=443 DPT=52654 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=613 TC=0 HOPLIMIT=249 FLOWLBL=672545 PROTO=TCP SPT=443 DPT=52654 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=672545 PROTO=TCP SPT=443 DPT=52654 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=58 RES=0x00 ACK URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=115 TC=0 HOPLIMIT=249 FLOWLBL=672545 PROTO=TCP SPT=443 DPT=52654 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2854 TC=0 HOPLIMIT=249 FLOWLBL=672545 PROTO=TCP SPT=443 DPT=52654 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4245 TC=0 HOPLIMIT=249 FLOWLBL=672545 PROTO=TCP SPT=443 DPT=52654 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8160 TC=0 HOPLIMIT=249 FLOWLBL=672545 PROTO=TCP SPT=443 DPT=52654 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=50 RES=0x00 ACK URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2015 TC=0 HOPLIMIT=249 FLOWLBL=672545 PROTO=TCP SPT=443 DPT=52654 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=667 TC=0 HOPLIMIT=249 FLOWLBL=672545 PROTO=TCP SPT=443 DPT=52654 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=84 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=36 RES=0x00 ACK URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4584 TC=0 HOPLIMIT=249 FLOWLBL=672545 PROTO=TCP SPT=443 DPT=52654 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=36 RES=0x00 ACK URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=45 RES=0x00 ACK URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=76 RES=0x00 ACK URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=108 RES=0x00 ACK URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=124 RES=0x00 ACK URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5712 TC=0 HOPLIMIT=249 FLOWLBL=672545 PROTO=TCP SPT=443 DPT=52654 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=135 RES=0x00 ACK URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=151 RES=0x00 ACK URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=166 RES=0x00 ACK URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=182 RES=0x00 ACK URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=198 RES=0x00 ACK URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=214 RES=0x00 ACK URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2768 TC=0 HOPLIMIT=249 FLOWLBL=672545 PROTO=TCP SPT=443 DPT=52654 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=219 RES=0x00 ACK URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5464 TC=0 HOPLIMIT=249 FLOWLBL=672545 PROTO=TCP SPT=443 DPT=52654 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=230 RES=0x00 ACK URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=245 RES=0x00 ACK URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=261 RES=0x00 ACK URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=277 RES=0x00 ACK URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=293 RES=0x00 ACK URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=309 RES=0x00 ACK URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5108 TC=0 HOPLIMIT=249 FLOWLBL=672545 PROTO=TCP SPT=443 DPT=52654 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:25 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=318 RES=0x00 ACK URGP=0
jun 01 11:42:26 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=9034 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:27 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=10002 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:28 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=10750 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:28 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=594 TC=0 HOPLIMIT=249 FLOWLBL=942361 PROTO=TCP SPT=443 DPT=52646 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:42:28 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=942361 PROTO=TCP SPT=443 DPT=52646 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:42:28 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=84 TC=0 HOPLIMIT=64 FLOWLBL=537640 PROTO=TCP SPT=52646 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:42:28 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=537640 PROTO=TCP SPT=52646 DPT=443 WINDOW=62 RES=0x00 ACK FIN URGP=0
jun 01 11:42:28 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25625 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:42:28 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=60 TC=0 HOPLIMIT=249 FLOWLBL=980985 PROTO=TCP SPT=443 DPT=52646 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:42:29 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18065 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=216 RES=0x00 ACK PSH URGP=0
jun 01 11:42:29 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25626 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:42:30 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=11525 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:31 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=11553 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:32 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=12302 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:32 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=65 TOS=0x00 PREC=0x00 TTL=64 ID=34480 DF PROTO=UDP SPT=44314 DPT=53 LEN=45
jun 01 11:42:32 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=65 TOS=0x00 PREC=0x00 TTL=64 ID=34480 DF PROTO=UDP SPT=44314 DPT=53 LEN=45
jun 01 11:42:32 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=65 TOS=0x00 PREC=0x00 TTL=64 ID=34481 DF PROTO=UDP SPT=44314 DPT=53 LEN=45
jun 01 11:42:32 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=65 TOS=0x00 PREC=0x00 TTL=64 ID=34481 DF PROTO=UDP SPT=44314 DPT=53 LEN=45
jun 01 11:42:32 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=138 TOS=0x00 PREC=0x00 TTL=250 ID=55115 DF PROTO=UDP SPT=53 DPT=44314 LEN=118
jun 01 11:42:32 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=81 TOS=0x00 PREC=0x00 TTL=250 ID=55116 DF PROTO=UDP SPT=53 DPT=44314 LEN=61
jun 01 11:42:32 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=61906 DF PROTO=TCP SPT=51882 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:42:32 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=61906 DF PROTO=TCP SPT=51882 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:42:33 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=13249 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:33 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=61907 DF PROTO=TCP SPT=51882 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:42:33 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=61907 DF PROTO=TCP SPT=51882 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:42:33 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=51882 WINDOW=28960 RES=0x00 ACK SYN URGP=0
jun 01 11:42:33 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=61908 DF PROTO=TCP SPT=51882 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:42:33 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=569 TOS=0x00 PREC=0x00 TTL=64 ID=61909 DF PROTO=TCP SPT=51882 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:42:34 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=41492 DF PROTO=TCP SPT=443 DPT=51882 WINDOW=235 RES=0x00 ACK URGP=0
jun 01 11:42:34 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=13323 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:34 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=4148 TOS=0x00 PREC=0x00 TTL=250 ID=41493 DF PROTO=TCP SPT=443 DPT=51882 WINDOW=235 RES=0x00 ACK PSH URGP=0
jun 01 11:42:34 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=61910 DF PROTO=TCP SPT=51882 DPT=443 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:42:34 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=2578 TOS=0x00 PREC=0x00 TTL=250 ID=41496 DF PROTO=TCP SPT=443 DPT=51882 WINDOW=235 RES=0x00 ACK PSH URGP=0
jun 01 11:42:34 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=61911 DF PROTO=TCP SPT=51882 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:42:34 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=132 TOS=0x00 PREC=0x00 TTL=64 ID=61912 DF PROTO=TCP SPT=51882 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:42:34 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=339 TOS=0x00 PREC=0x00 TTL=250 ID=41498 DF PROTO=TCP SPT=443 DPT=51882 WINDOW=235 RES=0x00 ACK PSH URGP=0
jun 01 11:42:34 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=380 TOS=0x00 PREC=0x00 TTL=64 ID=61913 DF PROTO=TCP SPT=51882 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:42:34 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=339 TOS=0x00 PREC=0x00 TTL=250 ID=41499 DF PROTO=TCP SPT=443 DPT=51882 WINDOW=235 RES=0x00 ACK PSH URGP=0
jun 01 11:42:34 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=114 TOS=0x00 PREC=0x00 TTL=250 ID=41500 DF PROTO=TCP SPT=443 DPT=51882 WINDOW=235 RES=0x00 ACK PSH URGP=0
jun 01 11:42:34 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=41501 DF PROTO=TCP SPT=443 DPT=51882 WINDOW=235 RES=0x00 ACK URGP=0
jun 01 11:42:34 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=61914 DF PROTO=TCP SPT=51882 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:42:35 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=96 TOS=0x00 PREC=0x00 TTL=250 ID=41502 DF PROTO=TCP SPT=443 DPT=51882 WINDOW=243 RES=0x00 ACK PSH URGP=0
jun 01 11:42:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=83 TOS=0x00 PREC=0x00 TTL=64 ID=61915 DF PROTO=TCP SPT=51882 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:42:35 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=246 TOS=0x00 PREC=0x00 TTL=250 ID=41503 DF PROTO=TCP SPT=443 DPT=51882 WINDOW=243 RES=0x00 ACK PSH URGP=0
jun 01 11:42:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=61916 DF PROTO=TCP SPT=51882 DPT=443 WINDOW=57 RES=0x00 ACK FIN URGP=0
jun 01 11:42:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=71 TOS=0x00 PREC=0x00 TTL=64 ID=22383 DF PROTO=UDP SPT=60450 DPT=53 LEN=51
jun 01 11:42:35 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=71 TOS=0x00 PREC=0x00 TTL=64 ID=22383 DF PROTO=UDP SPT=60450 DPT=53 LEN=51
jun 01 11:42:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=71 TOS=0x00 PREC=0x00 TTL=64 ID=22384 DF PROTO=UDP SPT=60450 DPT=53 LEN=51
jun 01 11:42:35 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=71 TOS=0x00 PREC=0x00 TTL=64 ID=22384 DF PROTO=UDP SPT=60450 DPT=53 LEN=51
jun 01 11:42:35 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=13906 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:35 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=41504 DF PROTO=TCP SPT=443 DPT=51882 WINDOW=243 RES=0x00 ACK URGP=0
jun 01 11:42:35 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=154 TOS=0x00 PREC=0x00 TTL=250 ID=55594 DF PROTO=UDP SPT=53 DPT=60450 LEN=134
jun 01 11:42:35 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=87 TOS=0x00 PREC=0x00 TTL=250 ID=55595 DF PROTO=UDP SPT=53 DPT=60450 LEN=67
jun 01 11:42:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=2476 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:42:35 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=2476 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:42:35 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=65160 RES=0x00 ACK SYN URGP=0
jun 01 11:42:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=2477 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:42:35 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=569 TOS=0x00 PREC=0x00 TTL=64 ID=2478 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:42:36 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=14536 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:36 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=246 TOS=0x00 PREC=0x00 TTL=250 ID=41505 DF PROTO=TCP SPT=443 DPT=51882 WINDOW=243 RES=0x00 ACK PSH URGP=0
jun 01 11:42:36 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=61917 DF PROTO=TCP SPT=51882 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:42:36 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=61918 DF PROTO=TCP SPT=51882 DPT=443 WINDOW=57 RES=0x00 ACK FIN URGP=0
jun 01 11:42:36 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=41506 DF PROTO=TCP SPT=443 DPT=51882 WINDOW=243 RES=0x00 ACK FIN URGP=0
jun 01 11:42:36 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=61919 DF PROTO=TCP SPT=51882 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:42:36 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=569 TOS=0x00 PREC=0x00 TTL=64 ID=2479 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:42:37 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=14540 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:37 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=47441 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=509 RES=0x00 ACK URGP=0
jun 01 11:42:37 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=47442 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=505 RES=0x00 ACK URGP=0
jun 01 11:42:37 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=2948 TOS=0x00 PREC=0x00 TTL=250 ID=47443 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=505 RES=0x00 ACK PSH URGP=0
jun 01 11:42:37 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=2480 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:42:37 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=1612 TOS=0x00 PREC=0x00 TTL=250 ID=47445 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=505 RES=0x00 ACK PSH URGP=0
jun 01 11:42:37 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=2481 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:42:37 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=132 TOS=0x00 PREC=0x00 TTL=64 ID=2482 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:42:38 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=15178 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=132 TOS=0x00 PREC=0x00 TTL=64 ID=2483 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:42:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25627 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:42:38 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=47447 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=505 RES=0x00 ACK URGP=0
jun 01 11:42:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=764 TOS=0x00 PREC=0x00 TTL=64 ID=2484 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:42:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18066 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=219 RES=0x00 ACK PSH URGP=0
jun 01 11:42:39 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25628 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:42:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=15599 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:39 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=764 TOS=0x00 PREC=0x00 TTL=64 ID=2485 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:42:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=16390 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:40 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=764 TOS=0x00 PREC=0x00 TTL=64 ID=2486 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:42:41 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=17205 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:41 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=47448 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=501 RES=0x00 ACK URGP=0
jun 01 11:42:41 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=611 TOS=0x00 PREC=0x00 TTL=250 ID=47449 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:42:41 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=83 TOS=0x00 PREC=0x00 TTL=64 ID=2487 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:42:41 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=47450 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=501 RES=0x00 ACK URGP=0
jun 01 11:42:42 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=525 TOS=0x00 PREC=0x00 TTL=250 ID=47451 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:42:42 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=2488 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:42:42 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=18015 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:42 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=872 TOS=0x00 PREC=0x00 TTL=250 ID=47452 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:42:42 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=2489 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:42:42 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=1137 TOS=0x00 PREC=0x00 TTL=250 ID=47453 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:42:42 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=2490 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:42:42 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=1138 TOS=0x00 PREC=0x00 TTL=250 ID=47454 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:42:42 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=2491 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=58 RES=0x00 ACK URGP=0
jun 01 11:42:42 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=1144 TOS=0x00 PREC=0x00 TTL=250 ID=47455 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:42:42 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=2492 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:42:42 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=1135 TOS=0x00 PREC=0x00 TTL=250 ID=47456 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:42:42 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=2493 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:42:42 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=1135 TOS=0x00 PREC=0x00 TTL=250 ID=47457 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:42:42 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=2494 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=55 RES=0x00 ACK URGP=0
jun 01 11:42:43 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=1143 TOS=0x00 PREC=0x00 TTL=250 ID=47458 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:42:43 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=2495 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=54 RES=0x00 ACK URGP=0
jun 01 11:42:43 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=874 TOS=0x00 PREC=0x00 TTL=250 ID=47459 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:42:43 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=2496 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=54 RES=0x00 ACK URGP=0
jun 01 11:42:43 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=346 TOS=0x00 PREC=0x00 TTL=250 ID=47460 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:42:43 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=2497 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=54 RES=0x00 ACK URGP=0
jun 01 11:42:43 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=18458 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:43 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=1133 TOS=0x00 PREC=0x00 TTL=250 ID=47461 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:42:43 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=2498 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=53 RES=0x00 ACK URGP=0
jun 01 11:42:43 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=1129 TOS=0x00 PREC=0x00 TTL=250 ID=47462 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:42:43 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=2499 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=52 RES=0x00 ACK URGP=0
jun 01 11:42:43 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=1144 TOS=0x00 PREC=0x00 TTL=250 ID=47463 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:42:43 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=2500 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=51 RES=0x00 ACK URGP=0
jun 01 11:42:43 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=1130 TOS=0x00 PREC=0x00 TTL=250 ID=47464 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:42:43 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=2501 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=50 RES=0x00 ACK URGP=0
jun 01 11:42:43 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=1132 TOS=0x00 PREC=0x00 TTL=250 ID=47465 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:42:43 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=2502 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=49 RES=0x00 ACK URGP=0
jun 01 11:42:44 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=1142 TOS=0x00 PREC=0x00 TTL=250 ID=47466 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:42:44 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=2503 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=48 RES=0x00 ACK URGP=0
jun 01 11:42:44 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=1140 TOS=0x00 PREC=0x00 TTL=250 ID=47467 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:42:44 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=2504 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=47 RES=0x00 ACK URGP=0
jun 01 11:42:44 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=1134 TOS=0x00 PREC=0x00 TTL=250 ID=47468 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:42:44 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=2505 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=46 RES=0x00 ACK URGP=0
jun 01 11:42:44 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=998 TOS=0x00 PREC=0x00 TTL=250 ID=47469 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:42:44 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=83 TOS=0x00 PREC=0x00 TTL=250 ID=47470 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:42:44 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=2506 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=46 RES=0x00 ACK URGP=0
jun 01 11:42:44 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=2507 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=46 RES=0x00 ACK FIN URGP=0
jun 01 11:42:44 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=53700 DF PROTO=TCP SPT=54838 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:42:44 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=53700 DF PROTO=TCP SPT=54838 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:42:44 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=54838 WINDOW=28960 RES=0x00 ACK SYN URGP=0
jun 01 11:42:44 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=53701 DF PROTO=TCP SPT=54838 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:42:44 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=569 TOS=0x00 PREC=0x00 TTL=64 ID=53702 DF PROTO=TCP SPT=54838 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:42:45 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=7425 DF PROTO=TCP SPT=443 DPT=54838 WINDOW=235 RES=0x00 ACK URGP=0
jun 01 11:42:45 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=1500 TOS=0x00 PREC=0x00 TTL=250 ID=7426 DF PROTO=TCP SPT=443 DPT=54838 WINDOW=235 RES=0x00 ACK URGP=0
jun 01 11:42:45 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=53703 DF PROTO=TCP SPT=54838 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:42:45 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=1252 TOS=0x00 PREC=0x00 TTL=250 ID=7428 DF PROTO=TCP SPT=443 DPT=54838 WINDOW=235 RES=0x00 ACK PSH URGP=0
jun 01 11:42:45 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=53704 DF PROTO=TCP SPT=54838 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:42:45 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=1500 TOS=0x00 PREC=0x00 TTL=250 ID=7427 DF PROTO=TCP SPT=443 DPT=54838 WINDOW=235 RES=0x00 ACK URGP=0
jun 01 11:42:45 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=2578 TOS=0x00 PREC=0x00 TTL=250 ID=7429 DF PROTO=TCP SPT=443 DPT=54838 WINDOW=235 RES=0x00 ACK PSH URGP=0
jun 01 11:42:45 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=53705 DF PROTO=TCP SPT=54838 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:42:45 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=53706 DF PROTO=TCP SPT=54838 DPT=443 WINDOW=58 RES=0x00 ACK URGP=0
jun 01 11:42:45 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=132 TOS=0x00 PREC=0x00 TTL=64 ID=53707 DF PROTO=TCP SPT=54838 DPT=443 WINDOW=58 RES=0x00 ACK PSH URGP=0
jun 01 11:42:45 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=2508 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=46 RES=0x00 ACK FIN URGP=0
jun 01 11:42:45 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=20037 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:45 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=7431 DF PROTO=TCP SPT=443 DPT=54838 WINDOW=235 RES=0x00 ACK URGP=0
jun 01 11:42:45 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=387 TOS=0x00 PREC=0x00 TTL=64 ID=53708 DF PROTO=TCP SPT=54838 DPT=443 WINDOW=58 RES=0x00 ACK PSH URGP=0
jun 01 11:42:45 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=339 TOS=0x00 PREC=0x00 TTL=250 ID=7432 DF PROTO=TCP SPT=443 DPT=54838 WINDOW=235 RES=0x00 ACK PSH URGP=0
jun 01 11:42:45 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=339 TOS=0x00 PREC=0x00 TTL=250 ID=7433 DF PROTO=TCP SPT=443 DPT=54838 WINDOW=235 RES=0x00 ACK PSH URGP=0
jun 01 11:42:45 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=114 TOS=0x00 PREC=0x00 TTL=250 ID=7434 DF PROTO=TCP SPT=443 DPT=54838 WINDOW=235 RES=0x00 ACK PSH URGP=0
jun 01 11:42:45 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=53709 DF PROTO=TCP SPT=54838 DPT=443 WINDOW=58 RES=0x00 ACK URGP=0
jun 01 11:42:45 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=76 TOS=0x00 PREC=0x00 TTL=250 ID=47471 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=501 RES=0x00 ACK PSH URGP=0
jun 01 11:42:45 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=180.184.47.154 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=58234 DPT=443 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:42:45 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=180.184.47.154 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=47472 DF PROTO=TCP SPT=443 DPT=58234 WINDOW=501 RES=0x00 ACK FIN URGP=0
jun 01 11:42:45 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=96 TOS=0x00 PREC=0x00 TTL=250 ID=7435 DF PROTO=TCP SPT=443 DPT=54838 WINDOW=243 RES=0x00 ACK PSH URGP=0
jun 01 11:42:45 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=83 TOS=0x00 PREC=0x00 TTL=64 ID=53710 DF PROTO=TCP SPT=54838 DPT=443 WINDOW=58 RES=0x00 ACK PSH URGP=0
jun 01 11:42:45 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=228 TOS=0x00 PREC=0x00 TTL=250 ID=7436 DF PROTO=TCP SPT=443 DPT=54838 WINDOW=243 RES=0x00 ACK PSH URGP=0
jun 01 11:42:45 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=53711 DF PROTO=TCP SPT=54838 DPT=443 WINDOW=58 RES=0x00 ACK FIN URGP=0
jun 01 11:42:46 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=120.79.129.34 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=7437 DF PROTO=TCP SPT=443 DPT=54838 WINDOW=243 RES=0x00 ACK FIN URGP=0
jun 01 11:42:46 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=20751 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:46 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=120.79.129.34 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=53712 DF PROTO=TCP SPT=54838 DPT=443 WINDOW=58 RES=0x00 ACK URGP=0
jun 01 11:42:47 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=21510 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:48 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=21540 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:48 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25629 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:42:49 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18067 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=221 RES=0x00 ACK PSH URGP=0
jun 01 11:42:49 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25630 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:42:49 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=21859 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:50 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=22274 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:51 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=22435 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:52 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=22832 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:53 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=23581 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:54 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=24019 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:55 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=24468 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=24815 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=25421 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=25748 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:42:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25631 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:42:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18068 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=223 RES=0x00 ACK PSH URGP=0
jun 01 11:42:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25632 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:42:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=33:33:00:00:00:01:d0:6e:de:8d:01:99:86:dd SRC=fe80:0000:0000:0000:d26e:deff:fe8d:0199 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=240 TC=0 HOPLIMIT=255 FLOWLBL=1009982 PROTO=ICMPv6 TYPE=134 CODE=0
jun 01 11:42:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=26028 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=17179 PROTO=TCP SPT=36956 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:43:00 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=17179 PROTO=TCP SPT=36956 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:43:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=569310 PROTO=TCP SPT=443 DPT=36956 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:43:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=17179 PROTO=TCP SPT=36956 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:43:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=17179 PROTO=TCP SPT=36956 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:43:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=569310 PROTO=TCP SPT=443 DPT=36956 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2892 TC=0 HOPLIMIT=249 FLOWLBL=569310 PROTO=TCP SPT=443 DPT=36956 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=17179 PROTO=TCP SPT=36956 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:43:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=17179 PROTO=TCP SPT=36956 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:43:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=806 TC=0 HOPLIMIT=64 FLOWLBL=17179 PROTO=TCP SPT=36956 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:43:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=26421 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=27389 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1961 TC=0 HOPLIMIT=249 FLOWLBL=569310 PROTO=TCP SPT=443 DPT=36956 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=569310 PROTO=TCP SPT=443 DPT=36956 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=187 TC=0 HOPLIMIT=249 FLOWLBL=569310 PROTO=TCP SPT=443 DPT=36956 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=17179 PROTO=TCP SPT=36956 DPT=443 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:43:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=398 TC=0 HOPLIMIT=64 FLOWLBL=17179 PROTO=TCP SPT=36956 DPT=443 WINDOW=59 RES=0x00 ACK PSH URGP=0
jun 01 11:43:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=569310 PROTO=TCP SPT=443 DPT=36956 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1197 TC=0 HOPLIMIT=249 FLOWLBL=569310 PROTO=TCP SPT=443 DPT=36956 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=17179 PROTO=TCP SPT=36956 DPT=443 WINDOW=58 RES=0x00 ACK FIN URGP=0
jun 01 11:43:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=306 TC=0 HOPLIMIT=64 FLOWLBL=83428 PROTO=TCP SPT=36308 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:43:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=306 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=50 RES=0x00 ACK PSH URGP=0
jun 01 11:43:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=306 TC=0 HOPLIMIT=64 FLOWLBL=760567 PROTO=TCP SPT=36620 DPT=443 WINDOW=59 RES=0x00 ACK PSH URGP=0
jun 01 11:43:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=306 TC=0 HOPLIMIT=64 FLOWLBL=773779 PROTO=TCP SPT=36624 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:43:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=569310 PROTO=TCP SPT=443 DPT=36956 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:43:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=17179 PROTO=TCP SPT=36956 DPT=443 WINDOW=58 RES=0x00 ACK URGP=0
jun 01 11:43:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=540 TC=0 HOPLIMIT=64 FLOWLBL=83428 PROTO=TCP SPT=36308 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:43:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=993517 PROTO=TCP SPT=443 DPT=36620 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=840292 PROTO=TCP SPT=443 DPT=36624 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=27634 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1420 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=83428 PROTO=TCP SPT=36308 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=115 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=49 RES=0x00 ACK URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=490 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=993517 PROTO=TCP SPT=443 DPT=36620 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=840292 PROTO=TCP SPT=443 DPT=36624 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=500 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=493 TC=0 HOPLIMIT=249 FLOWLBL=840292 PROTO=TCP SPT=443 DPT=36624 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=760567 PROTO=TCP SPT=36620 DPT=443 WINDOW=58 RES=0x00 ACK URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=99 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=99 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=99 TC=0 HOPLIMIT=249 FLOWLBL=840292 PROTO=TCP SPT=443 DPT=36624 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=492 TC=0 HOPLIMIT=249 FLOWLBL=993517 PROTO=TCP SPT=443 DPT=36620 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=84 TC=0 HOPLIMIT=64 FLOWLBL=773779 PROTO=TCP SPT=36624 DPT=443 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=84 TC=0 HOPLIMIT=64 FLOWLBL=83428 PROTO=TCP SPT=36308 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=99 TC=0 HOPLIMIT=249 FLOWLBL=993517 PROTO=TCP SPT=443 DPT=36620 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=84 TC=0 HOPLIMIT=64 FLOWLBL=760567 PROTO=TCP SPT=36620 DPT=443 WINDOW=58 RES=0x00 ACK URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=657 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=213 RES=0x00 ACK PSH URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=657 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3400 RES=0x00 ACK PSH URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=657 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=850 RES=0x00 ACK PSH URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=657 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=89 RES=0x00 ACK PSH URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=83428 PROTO=TCP SPT=36308 DPT=443 WINDOW=55 RES=0x00 ACK URGP=0
jun 01 11:43:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=492 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1420 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=7525 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=868 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8286 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=884 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=900 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1948 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=904 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4323 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=97 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=106 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=414 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=108 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=117 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1409 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=119 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=128 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4057 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=135 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=144 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=12204 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=167 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=679 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=170 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=178 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4116 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=186 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=3923 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8876 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=194 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3397 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4190 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=16478 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=202 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3383 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=210 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8160 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3398 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=218 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=226 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8042 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=242 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=250 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8574 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1943 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=271 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8182 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5430 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3393 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3380 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=15566 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3391 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3378 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3364 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1296 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3363 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1420 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=600 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=84 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=904 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=595 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=84 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=271 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2975 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=83428 PROTO=TCP SPT=36308 DPT=443 WINDOW=54 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=222 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=492 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4323 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=230 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=99 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=410 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=241 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1409 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=252 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4057 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=260 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=268 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=276 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=284 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=3849 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=291 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=300 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5191 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=310 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=294 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1147 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=84 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=310 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=10426 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=314 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=657 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3400 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=934379 PROTO=TCP SPT=57518 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=934379 PROTO=TCP SPT=57518 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=287201 PROTO=TCP SPT=443 DPT=57518 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=934379 PROTO=TCP SPT=57518 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=934379 PROTO=TCP SPT=57518 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=306 TC=0 HOPLIMIT=64 FLOWLBL=83428 PROTO=TCP SPT=36308 DPT=443 WINDOW=54 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=306 TC=0 HOPLIMIT=64 FLOWLBL=394766 PROTO=TCP SPT=36638 DPT=443 WINDOW=59 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=306 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=49 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=306 TC=0 HOPLIMIT=64 FLOWLBL=760567 PROTO=TCP SPT=36620 DPT=443 WINDOW=58 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=81507 PROTO=TCP SPT=57530 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=81507 PROTO=TCP SPT=57530 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=287201 PROTO=TCP SPT=443 DPT=57518 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2890 TC=0 HOPLIMIT=249 FLOWLBL=287201 PROTO=TCP SPT=443 DPT=57518 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=934379 PROTO=TCP SPT=57518 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=934379 PROTO=TCP SPT=57518 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=701498 PROTO=TCP SPT=443 DPT=36638 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=215550 PROTO=TCP SPT=443 DPT=57530 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=540 TC=0 HOPLIMIT=64 FLOWLBL=394766 PROTO=TCP SPT=36638 DPT=443 WINDOW=59 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=81507 PROTO=TCP SPT=57530 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=993517 PROTO=TCP SPT=443 DPT=36620 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=589 TC=0 HOPLIMIT=64 FLOWLBL=81507 PROTO=TCP SPT=57530 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=215550 PROTO=TCP SPT=443 DPT=57530 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2892 TC=0 HOPLIMIT=249 FLOWLBL=215550 PROTO=TCP SPT=443 DPT=57530 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=81507 PROTO=TCP SPT=57530 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=152 TC=0 HOPLIMIT=64 FLOWLBL=81507 PROTO=TCP SPT=57530 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=384 TC=0 HOPLIMIT=64 FLOWLBL=934379 PROTO=TCP SPT=57518 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=27853 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=319 TC=0 HOPLIMIT=64 FLOWLBL=81507 PROTO=TCP SPT=57530 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1140 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=312 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=321 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=3588 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=328 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5638 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=338 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8160 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=354 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=198 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=370 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=993517 PROTO=TCP SPT=443 DPT=36620 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=760567 PROTO=TCP SPT=36620 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=495 TC=0 HOPLIMIT=249 FLOWLBL=993517 PROTO=TCP SPT=443 DPT=36620 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=99 TC=0 HOPLIMIT=249 FLOWLBL=993517 PROTO=TCP SPT=443 DPT=36620 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=701498 PROTO=TCP SPT=443 DPT=36638 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=48 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=394766 PROTO=TCP SPT=36638 DPT=443 WINDOW=58 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=386 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=524 TC=0 HOPLIMIT=249 FLOWLBL=701498 PROTO=TCP SPT=443 DPT=36638 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=499 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1646 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=389 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=99 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5926 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=400 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=416 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=432 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=302 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=435 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=437 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=84 TC=0 HOPLIMIT=64 FLOWLBL=394766 PROTO=TCP SPT=36638 DPT=443 WINDOW=58 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=83428 PROTO=TCP SPT=36308 DPT=443 WINDOW=53 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=6812 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=491 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=450 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=466 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=469 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=485 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=500 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=503 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2574 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=508 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=524 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=7098 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=538 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8865 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3400 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8286 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=6812 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=9738 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4190 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=12382 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2768 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5590 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=9608 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3379 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=657 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=335 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=12204 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=359 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4346 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=367 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=391 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=415 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=439 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=462 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=486 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8160 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=502 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4116 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=510 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=533 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=557 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=3746 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=564 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=394766 PROTO=TCP SPT=36638 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=495 TC=0 HOPLIMIT=249 FLOWLBL=701498 PROTO=TCP SPT=443 DPT=36638 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=99 TC=0 HOPLIMIT=249 FLOWLBL=701498 PROTO=TCP SPT=443 DPT=36638 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=84 TC=0 HOPLIMIT=64 FLOWLBL=394766 PROTO=TCP SPT=36638 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:43:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=657 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=564 RES=0x00 ACK PSH URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=13552 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=591 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2998 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=596 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=9344 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=614 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=641 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2768 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=646 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=10856 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=667 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=693 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=720 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=746 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=772 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=799 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=825 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=830 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=851 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=878 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=902 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=913 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=915 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5464 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5464 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=920 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=10856 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2768 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=925 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=951 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=978 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=1004 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=1030 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=1057 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=16248 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=1088 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=1094 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=18944 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=1130 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=17596 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=1165 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1420 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=1204 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8283 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=1220 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1457 TC=0 HOPLIMIT=249 FLOWLBL=287201 PROTO=TCP SPT=443 DPT=57518 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1395 TC=0 HOPLIMIT=249 FLOWLBL=215550 PROTO=TCP SPT=443 DPT=57530 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=934379 PROTO=TCP SPT=57518 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=894 TC=0 HOPLIMIT=64 FLOWLBL=934379 PROTO=TCP SPT=57518 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=81507 PROTO=TCP SPT=57530 DPT=443 WINDOW=61 RES=0x00 ACK FIN URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=287201 PROTO=TCP SPT=443 DPT=57518 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=215550 PROTO=TCP SPT=443 DPT=57530 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=81507 PROTO=TCP SPT=57530 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1420 TC=0 HOPLIMIT=249 FLOWLBL=701498 PROTO=TCP SPT=443 DPT=36638 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=394766 PROTO=TCP SPT=36638 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=28532 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=115 TC=0 HOPLIMIT=249 FLOWLBL=701498 PROTO=TCP SPT=443 DPT=36638 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=491 TC=0 HOPLIMIT=249 FLOWLBL=701498 PROTO=TCP SPT=443 DPT=36638 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=99 TC=0 HOPLIMIT=249 FLOWLBL=701498 PROTO=TCP SPT=443 DPT=36638 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=657 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=1220 RES=0x00 ACK PSH URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=16478 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=1252 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=9346 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=1271 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=1303 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=9508 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=1321 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=15256 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=1351 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=40512 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=1430 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=18944 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=1466 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=21640 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=1509 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=1514 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=12371 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=1538 RES=0x00 ACK URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=961 TC=0 HOPLIMIT=249 FLOWLBL=287201 PROTO=TCP SPT=443 DPT=57518 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=934379 PROTO=TCP SPT=57518 DPT=443 WINDOW=61 RES=0x00 ACK FIN URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=287201 PROTO=TCP SPT=443 DPT=57518 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=45012 DF PROTO=UDP SPT=39867 DPT=53 LEN=46
jun 01 11:43:04 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=45012 DF PROTO=UDP SPT=39867 DPT=53 LEN=46
jun 01 11:43:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=45013 DF PROTO=UDP SPT=39867 DPT=53 LEN=46
jun 01 11:43:04 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=45013 DF PROTO=UDP SPT=39867 DPT=53 LEN=46
jun 01 11:43:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=186 TOS=0x00 PREC=0x00 TTL=250 ID=59512 DF PROTO=UDP SPT=53 DPT=39867 LEN=166
jun 01 11:43:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=241 TOS=0x00 PREC=0x00 TTL=250 ID=59513 DF PROTO=UDP SPT=53 DPT=39867 LEN=221
jun 01 11:43:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.244 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=40652 DF PROTO=TCP SPT=44448 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:05 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.244 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=40652 DF PROTO=TCP SPT=44448 DPT=80 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.244 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=80 DPT=44448 WINDOW=42340 RES=0x00 ACK SYN URGP=0
jun 01 11:43:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.244 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=40653 DF PROTO=TCP SPT=44448 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:43:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.244 LEN=99 TOS=0x00 PREC=0x00 TTL=64 ID=40654 DF PROTO=TCP SPT=44448 DPT=80 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:43:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.244 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=13261 DF PROTO=TCP SPT=80 DPT=44448 WINDOW=83 RES=0x00 ACK URGP=0
jun 01 11:43:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.244 DST=192.168.0.66 LEN=680 TOS=0x00 PREC=0x00 TTL=250 ID=13262 DF PROTO=TCP SPT=80 DPT=44448 WINDOW=83 RES=0x00 ACK PSH URGP=0
jun 01 11:43:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.244 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=40655 DF PROTO=TCP SPT=44448 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:43:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.244 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=40656 DF PROTO=TCP SPT=44448 DPT=80 WINDOW=63 RES=0x00 ACK FIN URGP=0
jun 01 11:43:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=163.181.202.244 DST=192.168.0.66 LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=13263 DF PROTO=TCP SPT=80 DPT=44448 WINDOW=83 RES=0x00 ACK FIN URGP=0
jun 01 11:43:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=163.181.202.244 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=40657 DF PROTO=TCP SPT=44448 DPT=80 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:43:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=fe80:0000:0000:0000:d26e:deff:fe8d:0199 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=135 CODE=0
jun 01 11:43:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=fe80:0000:0000:0000:d26e:deff:fe8d:0199 LEN=64 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=136 CODE=0
jun 01 11:43:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=29634 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=30222 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=30945 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25633 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:43:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18069 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=225 RES=0x00 ACK PSH URGP=0
jun 01 11:43:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25634 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:43:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=31569 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:10 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=32182 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=32317 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=32409 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=32796 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:14 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=33743 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=91 TOS=0x00 PREC=0x00 TTL=250 ID=46137 DF PROTO=TCP SPT=443 DPT=38674 WINDOW=134 RES=0x00 ACK PSH URGP=0
jun 01 11:43:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=76 TOS=0x00 PREC=0x00 TTL=250 ID=46138 DF PROTO=TCP SPT=443 DPT=38674 WINDOW=134 RES=0x00 ACK PSH URGP=0
jun 01 11:43:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=46139 DF PROTO=TCP SPT=443 DPT=38674 WINDOW=134 RES=0x00 ACK FIN URGP=0
jun 01 11:43:15 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=18965 DF PROTO=TCP SPT=38674 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:43:15 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=18966 DF PROTO=TCP SPT=38674 DPT=443 WINDOW=57 RES=0x00 ACK FIN URGP=0
jun 01 11:43:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=34693 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=46140 DF PROTO=TCP SPT=443 DPT=38674 WINDOW=134 RES=0x00 ACK URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=35080 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=83428 PROTO=TCP SPT=36308 DPT=443 WINDOW=53 RES=0x00 ACK FIN URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=48 RES=0x00 ACK FIN URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=760567 PROTO=TCP SPT=36620 DPT=443 WINDOW=57 RES=0x00 ACK FIN URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=773779 PROTO=TCP SPT=36624 DPT=443 WINDOW=59 RES=0x00 ACK FIN URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=538 RES=0x00 ACK FIN URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3400 RES=0x00 ACK FIN URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=904 RES=0x00 ACK FIN URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=314 RES=0x00 ACK FIN URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=394766 PROTO=TCP SPT=36638 DPT=443 WINDOW=56 RES=0x00 ACK FIN URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=1538 RES=0x00 ACK FIN URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=318 RES=0x00 ACK FIN URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=242933 PROTO=TCP SPT=443 DPT=36308 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=882591 PROTO=TCP SPT=443 DPT=52628 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=993517 PROTO=TCP SPT=443 DPT=36620 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=840292 PROTO=TCP SPT=443 DPT=36624 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=268810 PROTO=TCP SPT=443 DPT=36286 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=520863 PROTO=TCP SPT=443 DPT=52612 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=155557 PROTO=TCP SPT=52628 DPT=443 WINDOW=904 RES=0x00 ACK URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=773779 PROTO=TCP SPT=36624 DPT=443 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=760567 PROTO=TCP SPT=36620 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=83428 PROTO=TCP SPT=36308 DPT=443 WINDOW=53 RES=0x00 ACK URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=353357 PROTO=TCP SPT=36286 DPT=443 WINDOW=48 RES=0x00 ACK URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=153619 PROTO=TCP SPT=52612 DPT=443 WINDOW=538 RES=0x00 ACK URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=806754 PROTO=TCP SPT=443 DPT=54834 WINDOW=17 RES=0x00 ACK FIN URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=200261 PROTO=TCP SPT=54834 DPT=443 WINDOW=3400 RES=0x00 ACK URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=829074 PROTO=TCP SPT=443 DPT=35514 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=672545 PROTO=TCP SPT=443 DPT=52654 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=693475 PROTO=TCP SPT=443 DPT=52644 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=506622 PROTO=TCP SPT=35514 DPT=443 WINDOW=1538 RES=0x00 ACK URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=166345 PROTO=TCP SPT=52654 DPT=443 WINDOW=318 RES=0x00 ACK URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=615728 PROTO=TCP SPT=52644 DPT=443 WINDOW=314 RES=0x00 ACK URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=701498 PROTO=TCP SPT=443 DPT=36638 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:43:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=394766 PROTO=TCP SPT=36638 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:43:18 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=35535 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:18 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25635 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:43:19 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18070 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=227 RES=0x00 ACK PSH URGP=0
jun 01 11:43:19 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25636 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:43:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=37251 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=37306 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:22 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=37334 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:23 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=37346 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:24 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=37470 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:25 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=38363 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:26 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=38554 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:27 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=39200 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:28 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=39845 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:28 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25637 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:43:29 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18071 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=229 RES=0x00 ACK PSH URGP=0
jun 01 11:43:29 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25638 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:43:29 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=40239 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:30 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=40332 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:31 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=40483 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:32 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=40840 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:33 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=41105 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:34 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=41594 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:35 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=41759 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:36 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=42296 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:37 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=42515 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:38 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=43319 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:38 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25639 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:43:39 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18072 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=231 RES=0x00 ACK PSH URGP=0
jun 01 11:43:39 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25640 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:43:40 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=44895 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:41 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=45517 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:42 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=45791 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:43 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=46499 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:44 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=33:33:00:00:00:01:d0:6e:de:8d:01:99:86:dd SRC=fe80:0000:0000:0000:d26e:deff:fe8d:0199 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=240 TC=0 HOPLIMIT=255 FLOWLBL=1009982 PROTO=ICMPv6 TYPE=134 CODE=0
jun 01 11:43:44 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=47059 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:45 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=47967 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:46 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=48778 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:47 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=49716 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:48 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=49749 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:48 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25641 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:43:49 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18073 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=233 RES=0x00 ACK PSH URGP=0
jun 01 11:43:49 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25642 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:43:49 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=50274 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:50 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=50394 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:51 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=50766 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:52 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=51372 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:53 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=52213 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:54 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=53169 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:55 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=53356 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=01:00:5e:00:00:fb:f8:1a:67:56:e9:4b:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
jun 01 11:43:56 Adrian-PC kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:fb:f8:1a:67:56:e9:4b:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
jun 01 11:43:56 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=53898 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:57 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=54490 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=54516 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=16479 DF PROTO=UDP SPT=39806 DPT=53 LEN=46
jun 01 11:43:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=16479 DF PROTO=UDP SPT=39806 DPT=53 LEN=46
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=29529 DF PROTO=UDP SPT=26904 DPT=53 LEN=46
jun 01 11:43:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=29529 DF PROTO=UDP SPT=26904 DPT=53 LEN=46
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=4726 DF PROTO=UDP SPT=22236 DPT=53 LEN=46
jun 01 11:43:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=4726 DF PROTO=UDP SPT=22236 DPT=53 LEN=46
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=333 TOS=0x00 PREC=0x00 TTL=250 ID=899 DF PROTO=UDP SPT=53 DPT=26904 LEN=313
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=131 TOS=0x00 PREC=0x00 TTL=250 ID=897 DF PROTO=UDP SPT=53 DPT=39806 LEN=111
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=173 TOS=0x00 PREC=0x00 TTL=250 ID=898 DF PROTO=UDP SPT=53 DPT=22236 LEN=153
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2951:7800:0015:85fe:56c0:93a1 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=527485 PROTO=TCP SPT=54266 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2951:7800:0015:85fe:56c0:93a1 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=527485 PROTO=TCP SPT=54266 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2951:7800:0015:85fe:56c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=342756 PROTO=TCP SPT=443 DPT=54266 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2951:7800:0015:85fe:56c0:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=527485 PROTO=TCP SPT=54266 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2951:7800:0015:85fe:56c0:93a1 LEN=1802 TC=0 HOPLIMIT=64 FLOWLBL=527485 PROTO=TCP SPT=54266 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2951:7800:0015:85fe:56c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=342756 PROTO=TCP SPT=443 DPT=54266 WINDOW=135 RES=0x00 ACK URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2951:7800:0015:85fe:56c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4056 TC=0 HOPLIMIT=249 FLOWLBL=342756 PROTO=TCP SPT=443 DPT=54266 WINDOW=135 RES=0x00 ACK PSH URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2951:7800:0015:85fe:56c0:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=527485 PROTO=TCP SPT=54266 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2951:7800:0015:85fe:56c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1400 TC=0 HOPLIMIT=249 FLOWLBL=342756 PROTO=TCP SPT=443 DPT=54266 WINDOW=135 RES=0x00 ACK URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2951:7800:0015:85fe:56c0:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=527485 PROTO=TCP SPT=54266 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2951:7800:0015:85fe:56c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=671 TC=0 HOPLIMIT=249 FLOWLBL=342756 PROTO=TCP SPT=443 DPT=54266 WINDOW=135 RES=0x00 ACK PSH URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=11835 DF PROTO=UDP SPT=11738 DPT=53 LEN=46
jun 01 11:43:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=11835 DF PROTO=UDP SPT=11738 DPT=53 LEN=46
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=48749 DF PROTO=UDP SPT=27675 DPT=53 LEN=46
jun 01 11:43:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=48749 DF PROTO=UDP SPT=27675 DPT=53 LEN=46
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=15487 DF PROTO=UDP SPT=4137 DPT=53 LEN=46
jun 01 11:43:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=15487 DF PROTO=UDP SPT=4137 DPT=53 LEN=46
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25643 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=213 TOS=0x00 PREC=0x00 TTL=250 ID=905 DF PROTO=UDP SPT=53 DPT=11738 LEN=193
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=213 TOS=0x00 PREC=0x00 TTL=250 ID=904 DF PROTO=UDP SPT=53 DPT=27675 LEN=193
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=257 TOS=0x00 PREC=0x00 TTL=250 ID=906 DF PROTO=UDP SPT=53 DPT=4137 LEN=237
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=41085 DF PROTO=TCP SPT=44722 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=41085 DF PROTO=TCP SPT=44722 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=23223 DF PROTO=TCP SPT=44724 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=23223 DF PROTO=TCP SPT=44724 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2951:7800:0015:85fe:56c0:93a1 LEN=136 TC=0 HOPLIMIT=64 FLOWLBL=527485 PROTO=TCP SPT=54266 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2951:7800:0015:85fe:56c0:93a1 LEN=164 TC=0 HOPLIMIT=64 FLOWLBL=527485 PROTO=TCP SPT=54266 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2951:7800:0015:85fe:56c0:93a1 LEN=406 TC=0 HOPLIMIT=64 FLOWLBL=527485 PROTO=TCP SPT=54266 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2951:7800:0015:85fe:56c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=342756 PROTO=TCP SPT=443 DPT=54266 WINDOW=140 RES=0x00 ACK URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2951:7800:0015:85fe:56c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=251 TC=0 HOPLIMIT=249 FLOWLBL=342756 PROTO=TCP SPT=443 DPT=54266 WINDOW=140 RES=0x00 ACK PSH URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2951:7800:0015:85fe:56c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=143 TC=0 HOPLIMIT=249 FLOWLBL=342756 PROTO=TCP SPT=443 DPT=54266 WINDOW=140 RES=0x00 ACK PSH URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2951:7800:0015:85fe:56c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=552 TC=0 HOPLIMIT=249 FLOWLBL=342756 PROTO=TCP SPT=443 DPT=54266 WINDOW=140 RES=0x00 ACK PSH URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2951:7800:0015:85fe:56c0:93a1 LEN=103 TC=0 HOPLIMIT=64 FLOWLBL=527485 PROTO=TCP SPT=54266 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=60618 DF PROTO=TCP SPT=44734 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=60618 DF PROTO=TCP SPT=44734 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=38287 DF PROTO=TCP SPT=44750 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=38287 DF PROTO=TCP SPT=44750 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=48011 DF PROTO=TCP SPT=44766 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=48011 DF PROTO=TCP SPT=44766 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=62983 DF PROTO=TCP SPT=44774 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=62983 DF PROTO=TCP SPT=44774 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=48797 DF PROTO=TCP SPT=44784 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=48797 DF PROTO=TCP SPT=44784 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=13152 DF PROTO=TCP SPT=44788 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=13152 DF PROTO=TCP SPT=44788 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=34589 DF PROTO=TCP SPT=44796 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=34589 DF PROTO=TCP SPT=44796 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=23353 DF PROTO=TCP SPT=44810 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=23353 DF PROTO=TCP SPT=44810 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=35323 DF PROTO=TCP SPT=44814 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=35323 DF PROTO=TCP SPT=44814 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=48375 DF PROTO=TCP SPT=44824 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=48375 DF PROTO=TCP SPT=44824 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2951:7800:0015:85fe:56c0:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=527485 PROTO=TCP SPT=54266 DPT=443 WINDOW=60 RES=0x00 ACK FIN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=44722 WINDOW=26847 RES=0x00 ACK SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=44724 WINDOW=26847 RES=0x00 ACK SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=44724 DPT=443 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=44722 DPT=443 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2951:7800:0015:85fe:56c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=342756 PROTO=TCP SPT=443 DPT=54266 WINDOW=140 RES=0x00 ACK FIN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=3944 DF PROTO=UDP SPT=42733 DPT=53 LEN=40
jun 01 11:43:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=3944 DF PROTO=UDP SPT=42733 DPT=53 LEN=40
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=27834 DF PROTO=UDP SPT=24723 DPT=53 LEN=40
jun 01 11:43:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=27834 DF PROTO=UDP SPT=24723 DPT=53 LEN=40
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=26877 DF PROTO=UDP SPT=33229 DPT=53 LEN=40
jun 01 11:43:58 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=26877 DF PROTO=UDP SPT=33229 DPT=53 LEN=40
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18074 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=235 RES=0x00 ACK PSH URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=44766 WINDOW=26847 RES=0x00 ACK SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=44766 DPT=443 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25644 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=44734 WINDOW=26847 RES=0x00 ACK SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=44734 DPT=443 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=44750 WINDOW=26847 RES=0x00 ACK SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=44774 WINDOW=26847 RES=0x00 ACK SYN URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=44750 DPT=443 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:43:58 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=44774 DPT=443 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=44796 WINDOW=26847 RES=0x00 ACK SYN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=26847 RES=0x00 ACK SYN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=44788 WINDOW=26847 RES=0x00 ACK SYN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=48798 DF PROTO=TCP SPT=44784 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=13153 DF PROTO=TCP SPT=44788 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=34590 DF PROTO=TCP SPT=44796 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=1846 TOS=0x00 PREC=0x00 TTL=64 ID=48799 DF PROTO=TCP SPT=44784 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=1878 TOS=0x00 PREC=0x00 TTL=64 ID=13154 DF PROTO=TCP SPT=44788 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=1782 TOS=0x00 PREC=0x00 TTL=64 ID=34591 DF PROTO=TCP SPT=44796 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=44810 WINDOW=26847 RES=0x00 ACK SYN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=23354 DF PROTO=TCP SPT=44810 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=44824 WINDOW=26847 RES=0x00 ACK SYN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=44814 WINDOW=26847 RES=0x00 ACK SYN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=35324 DF PROTO=TCP SPT=44814 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=48376 DF PROTO=TCP SPT=44824 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=1814 TOS=0x00 PREC=0x00 TTL=64 ID=23355 DF PROTO=TCP SPT=44810 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=1878 TOS=0x00 PREC=0x00 TTL=64 ID=48377 DF PROTO=TCP SPT=44824 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=1878 TOS=0x00 PREC=0x00 TTL=64 ID=35325 DF PROTO=TCP SPT=44814 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=243 TOS=0x00 PREC=0x00 TTL=250 ID=984 DF PROTO=UDP SPT=53 DPT=42733 LEN=223
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=130 TOS=0x00 PREC=0x00 TTL=250 ID=983 DF PROTO=UDP SPT=53 DPT=33229 LEN=110
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=154 TOS=0x00 PREC=0x00 TTL=250 ID=982 DF PROTO=UDP SPT=53 DPT=24723 LEN=134
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=209188 PROTO=TCP SPT=53008 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=209188 PROTO=TCP SPT=53008 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=533030 PROTO=TCP SPT=443 DPT=53008 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=209188 PROTO=TCP SPT=53008 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=1800 TC=0 HOPLIMIT=64 FLOWLBL=209188 PROTO=TCP SPT=53008 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=533030 PROTO=TCP SPT=443 DPT=53008 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=3455 TC=0 HOPLIMIT=249 FLOWLBL=533030 PROTO=TCP SPT=443 DPT=53008 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=209188 PROTO=TCP SPT=53008 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=136 TC=0 HOPLIMIT=64 FLOWLBL=209188 PROTO=TCP SPT=53008 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=164 TC=0 HOPLIMIT=64 FLOWLBL=209188 PROTO=TCP SPT=53008 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=1306 TC=0 HOPLIMIT=64 FLOWLBL=209188 PROTO=TCP SPT=53008 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=600 TC=0 HOPLIMIT=249 FLOWLBL=533030 PROTO=TCP SPT=443 DPT=53008 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=103 TC=0 HOPLIMIT=64 FLOWLBL=209188 PROTO=TCP SPT=53008 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=103 TC=0 HOPLIMIT=249 FLOWLBL=533030 PROTO=TCP SPT=443 DPT=53008 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=533030 PROTO=TCP SPT=443 DPT=53008 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=378 TC=0 HOPLIMIT=249 FLOWLBL=533030 PROTO=TCP SPT=443 DPT=53008 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2509 TC=0 HOPLIMIT=249 FLOWLBL=533030 PROTO=TCP SPT=443 DPT=53008 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=209188 PROTO=TCP SPT=53008 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=332 TC=0 HOPLIMIT=64 FLOWLBL=209188 PROTO=TCP SPT=53008 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=35691 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=175 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=36598 DF PROTO=TCP SPT=443 DPT=44796 WINDOW=175 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=34399 DF PROTO=TCP SPT=443 DPT=44788 WINDOW=117 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=35692 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=175 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=34400 DF PROTO=TCP SPT=443 DPT=44788 WINDOW=128 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=3218 TOS=0x00 PREC=0x00 TTL=250 ID=36599 DF PROTO=TCP SPT=443 DPT=44796 WINDOW=175 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=3218 TOS=0x00 PREC=0x00 TTL=250 ID=35693 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=175 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=3216 TOS=0x00 PREC=0x00 TTL=250 ID=34401 DF PROTO=TCP SPT=443 DPT=44788 WINDOW=128 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=13156 DF PROTO=TCP SPT=44788 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=34593 DF PROTO=TCP SPT=44796 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=48801 DF PROTO=TCP SPT=44784 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=116 TOS=0x00 PREC=0x00 TTL=64 ID=48802 DF PROTO=TCP SPT=44784 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=116 TOS=0x00 PREC=0x00 TTL=64 ID=34594 DF PROTO=TCP SPT=44796 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=116 TOS=0x00 PREC=0x00 TTL=64 ID=13157 DF PROTO=TCP SPT=44788 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=34595 DF PROTO=TCP SPT=44796 DPT=443 WINDOW=60 RES=0x00 ACK FIN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=13158 DF PROTO=TCP SPT=44788 DPT=443 WINDOW=60 RES=0x00 ACK FIN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=144 TOS=0x00 PREC=0x00 TTL=64 ID=48803 DF PROTO=TCP SPT=44784 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=23357 DF PROTO=TCP SPT=44810 DPT=443 WINDOW=63 RES=0x00 ACK FIN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=35327 DF PROTO=TCP SPT=44814 DPT=443 WINDOW=63 RES=0x00 ACK FIN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=48379 DF PROTO=TCP SPT=44824 DPT=443 WINDOW=63 RES=0x00 ACK FIN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=447 TOS=0x00 PREC=0x00 TTL=64 ID=48804 DF PROTO=TCP SPT=44784 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=494 TOS=0x00 PREC=0x00 TTL=64 ID=48805 DF PROTO=TCP SPT=44784 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=2059 TOS=0x00 PREC=0x00 TTL=64 ID=48806 DF PROTO=TCP SPT=44784 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=2948 TOS=0x00 PREC=0x00 TTL=64 ID=48808 DF PROTO=TCP SPT=44784 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=2948 TOS=0x00 PREC=0x00 TTL=64 ID=48810 DF PROTO=TCP SPT=44784 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=15098 DF PROTO=TCP SPT=443 DPT=44810 WINDOW=119 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=3217 TOS=0x00 PREC=0x00 TTL=250 ID=15099 DF PROTO=TCP SPT=443 DPT=44810 WINDOW=119 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=2295 DF PROTO=TCP SPT=443 DPT=44814 WINDOW=120 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=23842 DF PROTO=TCP SPT=443 DPT=44824 WINDOW=120 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=3217 TOS=0x00 PREC=0x00 TTL=250 ID=23843 DF PROTO=TCP SPT=443 DPT=44824 WINDOW=120 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=3217 TOS=0x00 PREC=0x00 TTL=250 ID=2296 DF PROTO=TCP SPT=443 DPT=44814 WINDOW=120 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=44810 DPT=443 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=44814 DPT=443 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=44824 DPT=443 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=215 TC=0 HOPLIMIT=249 FLOWLBL=533030 PROTO=TCP SPT=443 DPT=53008 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2854 TC=0 HOPLIMIT=249 FLOWLBL=533030 PROTO=TCP SPT=443 DPT=53008 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5636 TC=0 HOPLIMIT=249 FLOWLBL=533030 PROTO=TCP SPT=443 DPT=53008 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8160 TC=0 HOPLIMIT=249 FLOWLBL=533030 PROTO=TCP SPT=443 DPT=53008 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=209188 PROTO=TCP SPT=53008 DPT=443 WINDOW=47 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=209188 PROTO=TCP SPT=53008 DPT=443 WINDOW=40 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=209188 PROTO=TCP SPT=53008 DPT=443 WINDOW=33 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=7096 TC=0 HOPLIMIT=249 FLOWLBL=533030 PROTO=TCP SPT=443 DPT=53008 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=209188 PROTO=TCP SPT=53008 DPT=443 WINDOW=27 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=55286 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2576 TC=0 HOPLIMIT=249 FLOWLBL=533030 PROTO=TCP SPT=443 DPT=53008 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1530 TC=0 HOPLIMIT=249 FLOWLBL=533030 PROTO=TCP SPT=443 DPT=53008 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=71 TOS=0x00 PREC=0x00 TTL=64 ID=34593 DF PROTO=UDP SPT=57720 DPT=53 LEN=51
jun 01 11:43:59 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=71 TOS=0x00 PREC=0x00 TTL=64 ID=34593 DF PROTO=UDP SPT=57720 DPT=53 LEN=51
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=103 TOS=0x00 PREC=0x00 TTL=250 ID=1035 DF PROTO=UDP SPT=53 DPT=57720 LEN=83
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=534 TC=0 HOPLIMIT=64 FLOWLBL=209188 PROTO=TCP SPT=53008 DPT=443 WINDOW=33 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=2590 TC=0 HOPLIMIT=64 FLOWLBL=209188 PROTO=TCP SPT=53008 DPT=443 WINDOW=33 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=23846 DF PROTO=TCP SPT=443 DPT=44824 WINDOW=120 RES=0x00 ACK FIN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=64 TOS=0x00 PREC=0x00 TTL=250 ID=36602 DF PROTO=TCP SPT=443 DPT=44796 WINDOW=175 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=64 TOS=0x00 PREC=0x00 TTL=250 ID=34404 DF PROTO=TCP SPT=443 DPT=44788 WINDOW=128 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=34405 DF PROTO=TCP SPT=443 DPT=44788 WINDOW=128 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=36603 DF PROTO=TCP SPT=443 DPT=44796 WINDOW=175 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=35696 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=175 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=935 TOS=0x00 PREC=0x00 TTL=64 ID=48812 DF PROTO=TCP SPT=44784 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=231 TOS=0x00 PREC=0x00 TTL=250 ID=36604 DF PROTO=TCP SPT=443 DPT=44796 WINDOW=175 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=231 TOS=0x00 PREC=0x00 TTL=250 ID=34406 DF PROTO=TCP SPT=443 DPT=44788 WINDOW=128 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=231 TOS=0x00 PREC=0x00 TTL=250 ID=35697 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=175 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=44788 DPT=443 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=44796 DPT=443 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=114 TOS=0x00 PREC=0x00 TTL=250 ID=35698 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=175 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=35699 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=198 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=83 TOS=0x00 PREC=0x00 TTL=250 ID=35700 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=198 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=76 TOS=0x00 PREC=0x00 TTL=250 ID=36605 DF PROTO=TCP SPT=443 DPT=44796 WINDOW=175 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=35701 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=268 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=76 TOS=0x00 PREC=0x00 TTL=250 ID=34407 DF PROTO=TCP SPT=443 DPT=44788 WINDOW=128 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=35702 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=338 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=327 TOS=0x00 PREC=0x00 TTL=250 ID=35703 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=408 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=36606 DF PROTO=TCP SPT=443 DPT=44796 WINDOW=175 RES=0x00 ACK FIN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=34408 DF PROTO=TCP SPT=443 DPT=44788 WINDOW=128 RES=0x00 ACK FIN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=83 TOS=0x00 PREC=0x00 TTL=250 ID=35704 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=408 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=326 TOS=0x00 PREC=0x00 TTL=250 ID=35705 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=408 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=83 TOS=0x00 PREC=0x00 TTL=250 ID=35706 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=408 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=683 TOS=0x00 PREC=0x00 TTL=250 ID=35707 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=408 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=357 TOS=0x00 PREC=0x00 TTL=250 ID=35708 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=408 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=83 TOS=0x00 PREC=0x00 TTL=250 ID=35709 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=408 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=48813 DF PROTO=TCP SPT=44784 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=48814 DF PROTO=TCP SPT=44784 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=83 TOS=0x00 PREC=0x00 TTL=64 ID=48815 DF PROTO=TCP SPT=44784 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=73 TOS=0x00 PREC=0x00 TTL=64 ID=40012 DF PROTO=UDP SPT=54394 DPT=53 LEN=53
jun 01 11:43:59 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=73 TOS=0x00 PREC=0x00 TTL=64 ID=40012 DF PROTO=UDP SPT=54394 DPT=53 LEN=53
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=73 TOS=0x00 PREC=0x00 TTL=64 ID=62695 DF PROTO=UDP SPT=45546 DPT=53 LEN=53
jun 01 11:43:59 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=73 TOS=0x00 PREC=0x00 TTL=64 ID=62695 DF PROTO=UDP SPT=45546 DPT=53 LEN=53
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=73 TOS=0x00 PREC=0x00 TTL=64 ID=41724 DF PROTO=UDP SPT=60030 DPT=53 LEN=53
jun 01 11:43:59 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=73 TOS=0x00 PREC=0x00 TTL=64 ID=41724 DF PROTO=UDP SPT=60030 DPT=53 LEN=53
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=35710 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=425 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=340 TOS=0x00 PREC=0x00 TTL=250 ID=1062 DF PROTO=UDP SPT=53 DPT=45546 LEN=320
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=180 TOS=0x00 PREC=0x00 TTL=250 ID=1064 DF PROTO=UDP SPT=53 DPT=60030 LEN=160
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=141 TOS=0x00 PREC=0x00 TTL=250 ID=1063 DF PROTO=UDP SPT=53 DPT=54394 LEN=121
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=246 TC=0 HOPLIMIT=249 FLOWLBL=533030 PROTO=TCP SPT=443 DPT=53008 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4323 TC=0 HOPLIMIT=249 FLOWLBL=533030 PROTO=TCP SPT=443 DPT=53008 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=209188 PROTO=TCP SPT=53008 DPT=443 WINDOW=44 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8574 TC=0 HOPLIMIT=249 FLOWLBL=533030 PROTO=TCP SPT=443 DPT=53008 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=3718 TC=0 HOPLIMIT=249 FLOWLBL=533030 PROTO=TCP SPT=443 DPT=53008 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=209188 PROTO=TCP SPT=53008 DPT=443 WINDOW=68 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=1278 TC=0 HOPLIMIT=64 FLOWLBL=588280 PROTO=UDP SPT=46954 DPT=443 LEN=1238
jun 01 11:43:59 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=1278 TC=0 HOPLIMIT=64 FLOWLBL=588280 PROTO=UDP SPT=46954 DPT=443 LEN=1238
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=59492 PROTO=TCP SPT=33122 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=59492 PROTO=TCP SPT=33122 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=71 TOS=0x00 PREC=0x00 TTL=64 ID=46776 DF PROTO=UDP SPT=51573 DPT=53 LEN=51
jun 01 11:43:59 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=71 TOS=0x00 PREC=0x00 TTL=64 ID=46776 DF PROTO=UDP SPT=51573 DPT=53 LEN=51
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=103 TOS=0x00 PREC=0x00 TTL=250 ID=1077 DF PROTO=UDP SPT=53 DPT=51573 LEN=83
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=71 TOS=0x00 PREC=0x00 TTL=64 ID=30617 DF PROTO=UDP SPT=14456 DPT=53 LEN=51
jun 01 11:43:59 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=71 TOS=0x00 PREC=0x00 TTL=64 ID=30617 DF PROTO=UDP SPT=14456 DPT=53 LEN=51
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=71 TOS=0x00 PREC=0x00 TTL=64 ID=19341 DF PROTO=UDP SPT=6163 DPT=53 LEN=51
jun 01 11:43:59 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=71 TOS=0x00 PREC=0x00 TTL=64 ID=19341 DF PROTO=UDP SPT=6163 DPT=53 LEN=51
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=71 TOS=0x00 PREC=0x00 TTL=64 ID=42298 DF PROTO=UDP SPT=5991 DPT=53 LEN=51
jun 01 11:43:59 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=71 TOS=0x00 PREC=0x00 TTL=64 ID=42298 DF PROTO=UDP SPT=5991 DPT=53 LEN=51
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=103 TOS=0x00 PREC=0x00 TTL=250 ID=1084 DF PROTO=UDP SPT=53 DPT=5991 LEN=83
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=127 TOS=0x00 PREC=0x00 TTL=250 ID=1085 DF PROTO=UDP SPT=53 DPT=6163 LEN=107
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=144 TOS=0x00 PREC=0x00 TTL=250 ID=1083 DF PROTO=UDP SPT=53 DPT=14456 LEN=124
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=1807 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=3543 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=136 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=164 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=629 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=600 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=103 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=103 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2211:ce00:001f:086b:f1c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=250 FLOWLBL=612099 PROTO=TCP SPT=443 DPT=33122 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=59492 PROTO=TCP SPT=33122 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=1841 TC=0 HOPLIMIT=64 FLOWLBL=59492 PROTO=TCP SPT=33122 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1429 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2854 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5636 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4245 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8160 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5464 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=39 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2768 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=34 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=6829 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=1272 TOS=0x00 PREC=0x00 TTL=250 ID=35711 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=425 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=9508 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=81 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=100 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=9161 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=113 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=340 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=113 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=35712 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=425 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=685 TOS=0x00 PREC=0x00 TTL=250 ID=35713 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=425 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=83 TOS=0x00 PREC=0x00 TTL=250 ID=35714 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=425 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=682 TOS=0x00 PREC=0x00 TTL=250 ID=35715 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=425 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=83 TOS=0x00 PREC=0x00 TTL=250 ID=35716 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=425 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=48816 DF PROTO=TCP SPT=44784 DPT=443 WINDOW=58 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=398505 PROTO=TCP SPT=33134 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=398505 PROTO=TCP SPT=33134 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=526544 PROTO=TCP SPT=33144 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=526544 PROTO=TCP SPT=33144 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=138 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=189 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2211:ce00:001f:086b:f1c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=250 FLOWLBL=612099 PROTO=TCP SPT=443 DPT=33122 WINDOW=134 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2211:ce00:001f:086b:f1c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=250 FLOWLBL=612099 PROTO=TCP SPT=443 DPT=33122 WINDOW=139 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2211:ce00:001f:086b:f1c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2728 TC=0 HOPLIMIT=250 FLOWLBL=612099 PROTO=TCP SPT=443 DPT=33122 WINDOW=139 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=59492 PROTO=TCP SPT=33122 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=59492 PROTO=TCP SPT=33122 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2211:ce00:001f:086b:f1c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=687 TC=0 HOPLIMIT=250 FLOWLBL=612099 PROTO=TCP SPT=443 DPT=33122 WINDOW=139 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=136 TC=0 HOPLIMIT=64 FLOWLBL=59492 PROTO=TCP SPT=33122 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=164 TC=0 HOPLIMIT=64 FLOWLBL=59492 PROTO=TCP SPT=33122 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=471 TC=0 HOPLIMIT=64 FLOWLBL=59492 PROTO=TCP SPT=33122 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=430 TC=0 HOPLIMIT=64 FLOWLBL=59492 PROTO=TCP SPT=33122 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2211:ce00:001f:086b:f1c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=250 FLOWLBL=967066 PROTO=TCP SPT=443 DPT=33144 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=60 TC=0 HOPLIMIT=64 FLOWLBL=423417 PROTO=TCP SPT=33144 DPT=443 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2211:ce00:001f:086b:f1c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=250 FLOWLBL=794726 PROTO=TCP SPT=443 DPT=33134 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=60 TC=0 HOPLIMIT=64 FLOWLBL=44322 PROTO=TCP SPT=33134 DPT=443 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=519 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=113 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=4574 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=113 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2211:ce00:001f:086b:f1c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=250 FLOWLBL=612099 PROTO=TCP SPT=443 DPT=33122 WINDOW=149 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2211:ce00:001f:086b:f1c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=251 TC=0 HOPLIMIT=250 FLOWLBL=612099 PROTO=TCP SPT=443 DPT=33122 WINDOW=149 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2211:ce00:001f:086b:f1c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=143 TC=0 HOPLIMIT=250 FLOWLBL=612099 PROTO=TCP SPT=443 DPT=33122 WINDOW=149 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2211:ce00:001f:086b:f1c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2390 TC=0 HOPLIMIT=250 FLOWLBL=612099 PROTO=TCP SPT=443 DPT=33122 WINDOW=149 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2211:ce00:001f:086b:f1c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2728 TC=0 HOPLIMIT=250 FLOWLBL=612099 PROTO=TCP SPT=443 DPT=33122 WINDOW=149 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=59492 PROTO=TCP SPT=33122 DPT=443 WINDOW=55 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=103 TC=0 HOPLIMIT=64 FLOWLBL=59492 PROTO=TCP SPT=33122 DPT=443 WINDOW=55 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2211:ce00:001f:086b:f1c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=598 TC=0 HOPLIMIT=250 FLOWLBL=612099 PROTO=TCP SPT=443 DPT=33122 WINDOW=149 RES=0x00 ACK PSH URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=59492 PROTO=TCP SPT=33122 DPT=443 WINDOW=50 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=59492 PROTO=TCP SPT=33122 DPT=443 WINDOW=45 RES=0x00 ACK URGP=0
jun 01 11:43:59 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=59492 PROTO=TCP SPT=33122 DPT=443 WINDOW=40 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2211:ce00:001f:086b:f1c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2728 TC=0 HOPLIMIT=250 FLOWLBL=612099 PROTO=TCP SPT=443 DPT=33122 WINDOW=149 RES=0x00 ACK PSH URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=59492 PROTO=TCP SPT=33122 DPT=443 WINDOW=37 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2211:ce00:001f:086b:f1c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2014 TC=0 HOPLIMIT=250 FLOWLBL=612099 PROTO=TCP SPT=443 DPT=33122 WINDOW=149 RES=0x00 ACK PSH URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=724 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4323 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=124 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8574 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=9508 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8160 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=120 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=114 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1420 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=128 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=8019 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=4116 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=5464 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=138 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=157 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=175 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=193 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=10856 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=214 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=10316 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=236 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=256 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=13552 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=282 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=308 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=335 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=361 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=382 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=408 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=435 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=461 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2768 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=466 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=492 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=16248 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=524 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1857 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK PSH URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=528 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2211:ce00:001f:086b:f1c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=250 FLOWLBL=612099 PROTO=TCP SPT=443 DPT=33122 WINDOW=149 RES=0x00 ACK URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=56091 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=1278 TC=0 HOPLIMIT=64 FLOWLBL=588280 PROTO=UDP SPT=46954 DPT=443 LEN=1238
jun 01 11:44:00 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=1278 TC=0 HOPLIMIT=64 FLOWLBL=588280 PROTO=UDP SPT=46954 DPT=443 LEN=1238
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=71 TOS=0x00 PREC=0x00 TTL=64 ID=20224 DF PROTO=UDP SPT=33014 DPT=53 LEN=51
jun 01 11:44:00 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=71 TOS=0x00 PREC=0x00 TTL=64 ID=20224 DF PROTO=UDP SPT=33014 DPT=53 LEN=51
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=71 TOS=0x00 PREC=0x00 TTL=64 ID=51631 DF PROTO=UDP SPT=9126 DPT=53 LEN=51
jun 01 11:44:00 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=71 TOS=0x00 PREC=0x00 TTL=64 ID=51631 DF PROTO=UDP SPT=9126 DPT=53 LEN=51
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=71 TOS=0x00 PREC=0x00 TTL=64 ID=56152 DF PROTO=UDP SPT=23711 DPT=53 LEN=51
jun 01 11:44:00 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=71 TOS=0x00 PREC=0x00 TTL=64 ID=56152 DF PROTO=UDP SPT=23711 DPT=53 LEN=51
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=338 TOS=0x00 PREC=0x00 TTL=250 ID=1223 DF PROTO=UDP SPT=53 DPT=9126 LEN=318
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=178 TOS=0x00 PREC=0x00 TTL=250 ID=1224 DF PROTO=UDP SPT=53 DPT=23711 LEN=158
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=136 TOS=0x00 PREC=0x00 TTL=250 ID=1225 DF PROTO=UDP SPT=53 DPT=33014 LEN=116
jun 01 11:44:00 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=846483 PROTO=TCP SPT=48480 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:44:00 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=846483 PROTO=TCP SPT=48480 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=743285 PROTO=TCP SPT=48482 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=743285 PROTO=TCP SPT=48482 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=48817 DF PROTO=TCP SPT=44784 DPT=443 WINDOW=58 RES=0x00 ACK FIN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=59492 PROTO=TCP SPT=33122 DPT=443 WINDOW=37 RES=0x00 ACK FIN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=209188 PROTO=TCP SPT=53008 DPT=443 WINDOW=68 RES=0x00 ACK FIN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=528 RES=0x00 ACK FIN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=533030 PROTO=TCP SPT=443 DPT=53008 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=375536 PROTO=TCP SPT=443 DPT=48410 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=209188 PROTO=TCP SPT=53008 DPT=443 WINDOW=68 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=1022027 PROTO=TCP SPT=48410 DPT=443 WINDOW=528 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=29155 DF PROTO=UDP SPT=18460 DPT=53 LEN=46
jun 01 11:44:01 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=29155 DF PROTO=UDP SPT=18460 DPT=53 LEN=46
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=13928 DF PROTO=UDP SPT=15874 DPT=53 LEN=46
jun 01 11:44:01 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=13928 DF PROTO=UDP SPT=15874 DPT=53 LEN=46
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=43742 DF PROTO=UDP SPT=53992 DPT=53 LEN=46
jun 01 11:44:01 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=66 TOS=0x00 PREC=0x00 TTL=64 ID=43742 DF PROTO=UDP SPT=53992 DPT=53 LEN=46
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=213 TOS=0x00 PREC=0x00 TTL=250 ID=1239 DF PROTO=UDP SPT=53 DPT=15874 LEN=193
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=257 TOS=0x00 PREC=0x00 TTL=250 ID=1240 DF PROTO=UDP SPT=53 DPT=53992 LEN=237
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=213 TOS=0x00 PREC=0x00 TTL=250 ID=1241 DF PROTO=UDP SPT=53 DPT=18460 LEN=193
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=54.186.99.250 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=39230 DF PROTO=TCP SPT=59392 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=54.186.99.250 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=39230 DF PROTO=TCP SPT=59392 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=20218 DF PROTO=TCP SPT=44840 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=20218 DF PROTO=TCP SPT=44840 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2502:f600:0016:99eb:5440:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=250 FLOWLBL=743924 PROTO=TCP SPT=443 DPT=48480 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=60 TC=0 HOPLIMIT=64 FLOWLBL=868368 PROTO=TCP SPT=48480 DPT=443 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2211:ce00:001f:086b:f1c0:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=250 FLOWLBL=612099 PROTO=TCP SPT=443 DPT=33122 WINDOW=149 RES=0x00 ACK FIN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2502:f600:0016:99eb:5440:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=250 FLOWLBL=815580 PROTO=TCP SPT=443 DPT=48482 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=60 TC=0 HOPLIMIT=64 FLOWLBL=436472 PROTO=TCP SPT=48482 DPT=443 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=59492 PROTO=TCP SPT=33122 DPT=443 WINDOW=37 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2502:f600:0016:99eb:5440:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=250 FLOWLBL=295285 PROTO=TCP SPT=443 DPT=48496 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=1903 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=76 TOS=0x00 PREC=0x00 TTL=250 ID=35717 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=425 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=44784 DPT=443 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=35718 DF PROTO=TCP SPT=443 DPT=44784 WINDOW=425 RES=0x00 ACK FIN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=56485 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=54.186.99.250 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=59392 WINDOW=26847 RES=0x00 ACK SYN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=54.186.99.250 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=39231 DF PROTO=TCP SPT=59392 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=54.186.99.250 LEN=1782 TOS=0x00 PREC=0x00 TTL=64 ID=39232 DF PROTO=TCP SPT=59392 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=44840 WINDOW=26847 RES=0x00 ACK SYN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=20219 DF PROTO=TCP SPT=44840 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=2031 TOS=0x00 PREC=0x00 TTL=64 ID=20220 DF PROTO=TCP SPT=44840 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2502:f600:0016:99eb:5440:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=250 FLOWLBL=295285 PROTO=TCP SPT=443 DPT=48496 WINDOW=136 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2502:f600:0016:99eb:5440:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1280 TC=0 HOPLIMIT=250 FLOWLBL=295285 PROTO=TCP SPT=443 DPT=48496 WINDOW=136 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2502:f600:0016:99eb:5440:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2488 TC=0 HOPLIMIT=250 FLOWLBL=295285 PROTO=TCP SPT=443 DPT=48496 WINDOW=136 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2502:f600:0016:99eb:5440:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1163 TC=0 HOPLIMIT=250 FLOWLBL=295285 PROTO=TCP SPT=443 DPT=48496 WINDOW=136 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=136 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=59 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=164 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=59 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=295 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=59 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=13009 DF PROTO=TCP SPT=49734 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=13009 DF PROTO=TCP SPT=49734 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2502:f600:0016:99eb:5440:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=250 FLOWLBL=295285 PROTO=TCP SPT=443 DPT=48496 WINDOW=140 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2502:f600:0016:99eb:5440:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=251 TC=0 HOPLIMIT=250 FLOWLBL=295285 PROTO=TCP SPT=443 DPT=48496 WINDOW=140 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2502:f600:0016:99eb:5440:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=143 TC=0 HOPLIMIT=250 FLOWLBL=295285 PROTO=TCP SPT=443 DPT=48496 WINDOW=140 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2502:f600:0016:99eb:5440:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2488 TC=0 HOPLIMIT=250 FLOWLBL=295285 PROTO=TCP SPT=443 DPT=48496 WINDOW=140 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=52 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=103 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=52 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=48 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=44 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=54.186.99.250 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=42097 DF PROTO=TCP SPT=443 DPT=59392 WINDOW=175 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=54.186.99.250 DST=192.168.0.66 LEN=3217 TOS=0x00 PREC=0x00 TTL=250 ID=42098 DF PROTO=TCP SPT=443 DPT=59392 WINDOW=175 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=54.186.99.250 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=39234 DF PROTO=TCP SPT=59392 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=40 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=54.186.99.250 LEN=116 TOS=0x00 PREC=0x00 TTL=64 ID=39235 DF PROTO=TCP SPT=59392 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=54.186.99.250 LEN=144 TOS=0x00 PREC=0x00 TTL=64 ID=39236 DF PROTO=TCP SPT=59392 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=54.186.99.250 LEN=1299 TOS=0x00 PREC=0x00 TTL=64 ID=39237 DF PROTO=TCP SPT=59392 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=36 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=48670 DF PROTO=TCP SPT=443 DPT=44840 WINDOW=175 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=286 TOS=0x00 PREC=0x00 TTL=250 ID=48671 DF PROTO=TCP SPT=443 DPT=44840 WINDOW=175 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=20222 DF PROTO=TCP SPT=44840 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=32 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=116 TOS=0x00 PREC=0x00 TTL=64 ID=20223 DF PROTO=TCP SPT=44840 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=144 TOS=0x00 PREC=0x00 TTL=64 ID=20224 DF PROTO=TCP SPT=44840 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=340 TOS=0x00 PREC=0x00 TTL=64 ID=20225 DF PROTO=TCP SPT=44840 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=1547 TOS=0x00 PREC=0x00 TTL=64 ID=20226 DF PROTO=TCP SPT=44840 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=2787 TOS=0x00 PREC=0x00 TTL=64 ID=20228 DF PROTO=TCP SPT=44840 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=31 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2502:f600:0016:99eb:5440:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1280 TC=0 HOPLIMIT=250 FLOWLBL=295285 PROTO=TCP SPT=443 DPT=48496 WINDOW=140 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=1278 TC=0 HOPLIMIT=64 FLOWLBL=588280 PROTO=UDP SPT=46954 DPT=443 LEN=1238
jun 01 11:44:01 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=1278 TC=0 HOPLIMIT=64 FLOWLBL=588280 PROTO=UDP SPT=46954 DPT=443 LEN=1238
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=49734 WINDOW=26847 RES=0x00 ACK SYN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=49734 DPT=443 WINDOW=0 RES=0x00 RST URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=41 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=46 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=51 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=55 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=65 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=70 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=74 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=79 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2502:f600:0016:99eb:5440:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1432 TC=0 HOPLIMIT=250 FLOWLBL=295285 PROTO=TCP SPT=443 DPT=48496 WINDOW=140 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=82 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2502:f600:0016:99eb:5440:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1464 TC=0 HOPLIMIT=250 FLOWLBL=295285 PROTO=TCP SPT=443 DPT=48496 WINDOW=140 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=85 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=54.186.99.250 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=42101 DF PROTO=TCP SPT=443 DPT=59392 WINDOW=245 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=54.186.99.250 DST=192.168.0.66 LEN=231 TOS=0x00 PREC=0x00 TTL=250 ID=42102 DF PROTO=TCP SPT=443 DPT=59392 WINDOW=245 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=54.186.99.250 DST=192.168.0.66 LEN=123 TOS=0x00 PREC=0x00 TTL=250 ID=42103 DF PROTO=TCP SPT=443 DPT=59392 WINDOW=245 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=54.186.99.250 DST=192.168.0.66 LEN=175 TOS=0x00 PREC=0x00 TTL=250 ID=42104 DF PROTO=TCP SPT=443 DPT=59392 WINDOW=245 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=54.186.99.250 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=39238 DF PROTO=TCP SPT=59392 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=54.186.99.250 LEN=83 TOS=0x00 PREC=0x00 TTL=64 ID=39239 DF PROTO=TCP SPT=59392 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=72 TOS=0x00 PREC=0x00 TTL=64 ID=30185 DF PROTO=UDP SPT=14151 DPT=53 LEN=52
jun 01 11:44:01 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=72 TOS=0x00 PREC=0x00 TTL=64 ID=30185 DF PROTO=UDP SPT=14151 DPT=53 LEN=52
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=72 TOS=0x00 PREC=0x00 TTL=64 ID=40366 DF PROTO=UDP SPT=19640 DPT=53 LEN=52
jun 01 11:44:01 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=72 TOS=0x00 PREC=0x00 TTL=64 ID=40366 DF PROTO=UDP SPT=19640 DPT=53 LEN=52
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=72 TOS=0x00 PREC=0x00 TTL=64 ID=63248 DF PROTO=UDP SPT=25590 DPT=53 LEN=52
jun 01 11:44:01 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=72 TOS=0x00 PREC=0x00 TTL=64 ID=63248 DF PROTO=UDP SPT=25590 DPT=53 LEN=52
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=48672 DF PROTO=TCP SPT=443 DPT=44840 WINDOW=175 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=231 TOS=0x00 PREC=0x00 TTL=250 ID=48673 DF PROTO=TCP SPT=443 DPT=44840 WINDOW=175 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=114 TOS=0x00 PREC=0x00 TTL=250 ID=48674 DF PROTO=TCP SPT=443 DPT=44840 WINDOW=175 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=20230 DF PROTO=TCP SPT=44840 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=83 TOS=0x00 PREC=0x00 TTL=64 ID=20231 DF PROTO=TCP SPT=44840 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=230 TOS=0x00 PREC=0x00 TTL=250 ID=1355 DF PROTO=UDP SPT=53 DPT=14151 LEN=210
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=48675 DF PROTO=TCP SPT=443 DPT=44840 WINDOW=198 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=48676 DF PROTO=TCP SPT=443 DPT=44840 WINDOW=220 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=83 TOS=0x00 PREC=0x00 TTL=250 ID=48677 DF PROTO=TCP SPT=443 DPT=44840 WINDOW=220 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=127 TOS=0x00 PREC=0x00 TTL=250 ID=48678 DF PROTO=TCP SPT=443 DPT=44840 WINDOW=220 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=126 TOS=0x00 PREC=0x00 TTL=250 ID=48679 DF PROTO=TCP SPT=443 DPT=44840 WINDOW=220 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=20232 DF PROTO=TCP SPT=44840 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=210 TOS=0x00 PREC=0x00 TTL=250 ID=1357 DF PROTO=UDP SPT=53 DPT=25590 LEN=190
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=258 TOS=0x00 PREC=0x00 TTL=250 ID=1356 DF PROTO=UDP SPT=53 DPT=19640 LEN=238
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:1f13:011b:9904:e1dc:7809:ab8e:aee7 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=885423 PROTO=TCP SPT=58116 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:1f13:011b:9904:e1dc:7809:ab8e:aee7 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=885423 PROTO=TCP SPT=58116 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=89 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=126 TOS=0x00 PREC=0x00 TTL=250 ID=48680 DF PROTO=TCP SPT=443 DPT=44840 WINDOW=220 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=94 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=99 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2502:f600:0016:99eb:5440:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2152 TC=0 HOPLIMIT=250 FLOWLBL=295285 PROTO=TCP SPT=443 DPT=48496 WINDOW=140 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=103 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=108 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=112 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=117 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=122 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=126 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=131 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=136 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=141 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=145 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=20233 DF PROTO=TCP SPT=44840 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=150 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=155 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=159 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=164 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=172 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=176 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=181 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=186 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=191 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=195 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=200 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=205 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=209 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=214 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=219 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=224 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=228 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=236 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=241 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=245 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=250 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=255 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=259 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=264 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=269 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=274 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=278 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2502:f600:0016:99eb:5440:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2440 TC=0 HOPLIMIT=250 FLOWLBL=295285 PROTO=TCP SPT=443 DPT=48496 WINDOW=140 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=283 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=288 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=292 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2502:f600:0016:99eb:5440:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1328 TC=0 HOPLIMIT=250 FLOWLBL=295285 PROTO=TCP SPT=443 DPT=48496 WINDOW=140 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=295 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=300 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:9000:2502:f600:0016:99eb:5440:93a1 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1209 TC=0 HOPLIMIT=250 FLOWLBL=295285 PROTO=TCP SPT=443 DPT=48496 WINDOW=140 RES=0x00 ACK PSH URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=54.186.99.250 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=42105 DF PROTO=TCP SPT=443 DPT=59392 WINDOW=245 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2502:f600:0016:99eb:5440:93a1 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=943005 PROTO=TCP SPT=48496 DPT=443 WINDOW=303 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=48681 DF PROTO=TCP SPT=443 DPT=44840 WINDOW=220 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:1f13:011b:9904:e1dc:7809:ab8e:aee7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=250 FLOWLBL=51019 PROTO=TCP SPT=443 DPT=58116 WINDOW=26787 RES=0x00 ACK SYN URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:1f13:011b:9904:e1dc:7809:ab8e:aee7 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=885423 PROTO=TCP SPT=58116 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:44:01 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:1f13:011b:9904:e1dc:7809:ab8e:aee7 LEN=1904 TC=0 HOPLIMIT=64 FLOWLBL=885423 PROTO=TCP SPT=58116 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:1f13:011b:9904:e1dc:7809:ab8e:aee7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=250 FLOWLBL=51019 PROTO=TCP SPT=443 DPT=58116 WINDOW=175 RES=0x00 ACK URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:1f13:011b:9904:e1dc:7809:ab8e:aee7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=250 FLOWLBL=51019 PROTO=TCP SPT=443 DPT=58116 WINDOW=186 RES=0x00 ACK URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:1f13:011b:9904:e1dc:7809:ab8e:aee7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=3686 TC=0 HOPLIMIT=250 FLOWLBL=51019 PROTO=TCP SPT=443 DPT=58116 WINDOW=186 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:1f13:011b:9904:e1dc:7809:ab8e:aee7 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=885423 PROTO=TCP SPT=58116 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:1f13:011b:9904:e1dc:7809:ab8e:aee7 LEN=136 TC=0 HOPLIMIT=64 FLOWLBL=885423 PROTO=TCP SPT=58116 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:1f13:011b:9904:e1dc:7809:ab8e:aee7 LEN=164 TC=0 HOPLIMIT=64 FLOWLBL=885423 PROTO=TCP SPT=58116 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:1f13:011b:9904:e1dc:7809:ab8e:aee7 LEN=1330 TC=0 HOPLIMIT=64 FLOWLBL=885423 PROTO=TCP SPT=58116 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=57483 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:1f13:011b:9904:e1dc:7809:ab8e:aee7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=251 TC=0 HOPLIMIT=250 FLOWLBL=51019 PROTO=TCP SPT=443 DPT=58116 WINDOW=186 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:1f13:011b:9904:e1dc:7809:ab8e:aee7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=134 TC=0 HOPLIMIT=250 FLOWLBL=51019 PROTO=TCP SPT=443 DPT=58116 WINDOW=186 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:1f13:011b:9904:e1dc:7809:ab8e:aee7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=250 FLOWLBL=51019 PROTO=TCP SPT=443 DPT=58116 WINDOW=256 RES=0x00 ACK URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:1f13:011b:9904:e1dc:7809:ab8e:aee7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=103 TC=0 HOPLIMIT=250 FLOWLBL=51019 PROTO=TCP SPT=443 DPT=58116 WINDOW=256 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:1f13:011b:9904:e1dc:7809:ab8e:aee7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=682 TC=0 HOPLIMIT=250 FLOWLBL=51019 PROTO=TCP SPT=443 DPT=58116 WINDOW=256 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:1f13:011b:9904:e1dc:7809:ab8e:aee7 LEN=103 TC=0 HOPLIMIT=64 FLOWLBL=885423 PROTO=TCP SPT=58116 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=54.186.99.250 LEN=140 TOS=0x00 PREC=0x00 TTL=64 ID=39240 DF PROTO=TCP SPT=59392 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=54.186.99.250 LEN=889 TOS=0x00 PREC=0x00 TTL=64 ID=39241 DF PROTO=TCP SPT=59392 DPT=443 WINDOW=60 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=542875 PROTO=TCP SPT=37030 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=542875 PROTO=TCP SPT=37030 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=54.186.99.250 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=42106 DF PROTO=TCP SPT=443 DPT=59392 WINDOW=245 RES=0x00 ACK URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=54.186.99.250 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=42107 DF PROTO=TCP SPT=443 DPT=59392 WINDOW=315 RES=0x00 ACK URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=54.186.99.250 DST=192.168.0.66 LEN=174 TOS=0x00 PREC=0x00 TTL=250 ID=42108 DF PROTO=TCP SPT=443 DPT=59392 WINDOW=315 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:1f13:011b:9904:e1dc:7809:ab8e:aee7 LEN=167 TC=0 HOPLIMIT=64 FLOWLBL=885423 PROTO=TCP SPT=58116 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:1f13:011b:9904:e1dc:7809:ab8e:aee7 LEN=909 TC=0 HOPLIMIT=64 FLOWLBL=885423 PROTO=TCP SPT=58116 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=291730 PROTO=TCP SPT=443 DPT=37030 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=542875 PROTO=TCP SPT=37030 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=2078 TC=0 HOPLIMIT=64 FLOWLBL=542875 PROTO=TCP SPT=37030 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=291730 PROTO=TCP SPT=443 DPT=37030 WINDOW=17 RES=0x00 ACK URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1447 TC=0 HOPLIMIT=249 FLOWLBL=291730 PROTO=TCP SPT=443 DPT=37030 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=542875 PROTO=TCP SPT=37030 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=136 TC=0 HOPLIMIT=64 FLOWLBL=542875 PROTO=TCP SPT=37030 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=164 TC=0 HOPLIMIT=64 FLOWLBL=542875 PROTO=TCP SPT=37030 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=674 TC=0 HOPLIMIT=64 FLOWLBL=542875 PROTO=TCP SPT=37030 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=54.186.99.250 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=39242 DF PROTO=TCP SPT=59392 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=609 TC=0 HOPLIMIT=249 FLOWLBL=291730 PROTO=TCP SPT=443 DPT=37030 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=291730 PROTO=TCP SPT=443 DPT=37030 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=418 TC=0 HOPLIMIT=249 FLOWLBL=291730 PROTO=TCP SPT=443 DPT=37030 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=103 TC=0 HOPLIMIT=249 FLOWLBL=291730 PROTO=TCP SPT=443 DPT=37030 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=542875 PROTO=TCP SPT=37030 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=103 TC=0 HOPLIMIT=64 FLOWLBL=542875 PROTO=TCP SPT=37030 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=252 TC=0 HOPLIMIT=64 FLOWLBL=542875 PROTO=TCP SPT=37030 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=139 TC=0 HOPLIMIT=249 FLOWLBL=291730 PROTO=TCP SPT=443 DPT=37030 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:44:02 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=538 TC=0 HOPLIMIT=249 FLOWLBL=291730 PROTO=TCP SPT=443 DPT=37030 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:1f13:011b:9904:e1dc:7809:ab8e:aee7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=250 FLOWLBL=51019 PROTO=TCP SPT=443 DPT=58116 WINDOW=326 RES=0x00 ACK URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:1f13:011b:9904:e1dc:7809:ab8e:aee7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=680 TC=0 HOPLIMIT=250 FLOWLBL=51019 PROTO=TCP SPT=443 DPT=58116 WINDOW=326 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2600:1f13:011b:9904:e1dc:7809:ab8e:aee7 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=103 TC=0 HOPLIMIT=250 FLOWLBL=51019 PROTO=TCP SPT=443 DPT=58116 WINDOW=326 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:1f13:011b:9904:e1dc:7809:ab8e:aee7 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=885423 PROTO=TCP SPT=58116 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=157 TOS=0x00 PREC=0x00 TTL=1 ID=55748 DF PROTO=UDP SPT=5353 DPT=5353 LEN=137
jun 01 11:44:03 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=157 TOS=0x00 PREC=0x00 TTL=1 ID=55748 DF PROTO=UDP SPT=5353 DPT=5353 LEN=137
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=157 TOS=0x00 PREC=0x00 TTL=1 ID=55748 DF PROTO=UDP SPT=5353 DPT=5353 LEN=137
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=65 TOS=0x00 PREC=0x00 TTL=64 ID=30576 DF PROTO=UDP SPT=13371 DPT=53 LEN=45
jun 01 11:44:03 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=65 TOS=0x00 PREC=0x00 TTL=64 ID=30576 DF PROTO=UDP SPT=13371 DPT=53 LEN=45
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=65 TOS=0x00 PREC=0x00 TTL=64 ID=57787 DF PROTO=UDP SPT=39669 DPT=53 LEN=45
jun 01 11:44:03 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=65 TOS=0x00 PREC=0x00 TTL=64 ID=57787 DF PROTO=UDP SPT=39669 DPT=53 LEN=45
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=57861 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=81 TOS=0x00 PREC=0x00 TTL=250 ID=1610 DF PROTO=UDP SPT=53 DPT=13371 LEN=61
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=93 TOS=0x00 PREC=0x00 TTL=250 ID=1611 DF PROTO=UDP SPT=53 DPT=39669 LEN=73
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=162.159.207.0 LEN=48 TOS=0x00 PREC=0x00 TTL=64 ID=56831 DF PROTO=UDP SPT=34466 DPT=3478 LEN=28
jun 01 11:44:03 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=162.159.207.0 LEN=48 TOS=0x00 PREC=0x00 TTL=64 ID=56831 DF PROTO=UDP SPT=34466 DPT=3478 LEN=28
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=162.159.207.0 LEN=48 TOS=0x00 PREC=0x00 TTL=64 ID=56832 DF PROTO=UDP SPT=40824 DPT=3478 LEN=28
jun 01 11:44:03 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=162.159.207.0 LEN=48 TOS=0x00 PREC=0x00 TTL=64 ID=56832 DF PROTO=UDP SPT=40824 DPT=3478 LEN=28
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=162.159.207.0 LEN=48 TOS=0x00 PREC=0x00 TTL=64 ID=56833 DF PROTO=UDP SPT=46031 DPT=3478 LEN=28
jun 01 11:44:03 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=162.159.207.0 LEN=48 TOS=0x00 PREC=0x00 TTL=64 ID=56833 DF PROTO=UDP SPT=46031 DPT=3478 LEN=28
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0049:0000:0000:0000:0000:0000 LEN=68 TC=0 HOPLIMIT=64 FLOWLBL=230308 PROTO=UDP SPT=36726 DPT=3478 LEN=28
jun 01 11:44:03 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0049:0000:0000:0000:0000:0000 LEN=68 TC=0 HOPLIMIT=64 FLOWLBL=230308 PROTO=UDP SPT=36726 DPT=3478 LEN=28
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0049:0000:0000:0000:0000:0000 LEN=68 TC=0 HOPLIMIT=64 FLOWLBL=188043 PROTO=UDP SPT=40516 DPT=3478 LEN=28
jun 01 11:44:03 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0049:0000:0000:0000:0000:0000 LEN=68 TC=0 HOPLIMIT=64 FLOWLBL=188043 PROTO=UDP SPT=40516 DPT=3478 LEN=28
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0049:0000:0000:0000:0000:0000 LEN=68 TC=0 HOPLIMIT=64 FLOWLBL=21436 PROTO=UDP SPT=51578 DPT=3478 LEN=28
jun 01 11:44:03 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0049:0000:0000:0000:0000:0000 LEN=68 TC=0 HOPLIMIT=64 FLOWLBL=21436 PROTO=UDP SPT=51578 DPT=3478 LEN=28
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=162.159.207.0 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=249 ID=60773 DF PROTO=UDP SPT=3478 DPT=40824 LEN=40
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=162.159.207.0 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=249 ID=41188 DF PROTO=UDP SPT=3478 DPT=46031 LEN=40
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=162.159.207.0 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=249 ID=61518 DF PROTO=UDP SPT=3478 DPT=34466 LEN=40
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=162.159.207.0 LEN=88 TOS=0x00 PREC=0xC0 TTL=64 ID=36387 PROTO=ICMP TYPE=3 CODE=3 [SRC=162.159.207.0 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=249 ID=60773 DF PROTO=UDP SPT=3478 DPT=40824 LEN=40 ]
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=162.159.207.0 LEN=88 TOS=0x00 PREC=0xC0 TTL=64 ID=36388 PROTO=ICMP TYPE=3 CODE=3 [SRC=162.159.207.0 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=249 ID=61518 DF PROTO=UDP SPT=3478 DPT=34466 LEN=40 ]
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=162.159.207.0 LEN=88 TOS=0x00 PREC=0xC0 TTL=64 ID=36389 PROTO=ICMP TYPE=3 CODE=3 [SRC=162.159.207.0 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=249 ID=41188 DF PROTO=UDP SPT=3478 DPT=46031 LEN=40 ]
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=1278 TC=0 HOPLIMIT=64 FLOWLBL=588280 PROTO=UDP SPT=46954 DPT=443 LEN=1238
jun 01 11:44:03 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2600:9000:2211:ce00:001f:086b:f1c0:93a1 LEN=1278 TC=0 HOPLIMIT=64 FLOWLBL=588280 PROTO=UDP SPT=46954 DPT=443 LEN=1238
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=498 TC=0 HOPLIMIT=64 FLOWLBL=542875 PROTO=TCP SPT=37030 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=6812 TC=0 HOPLIMIT=64 FLOWLBL=542875 PROTO=TCP SPT=37030 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=5464 TC=0 HOPLIMIT=64 FLOWLBL=542875 PROTO=TCP SPT=37030 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=291730 PROTO=TCP SPT=443 DPT=37030 WINDOW=17 RES=0x00 ACK URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=107 TC=0 HOPLIMIT=249 FLOWLBL=291730 PROTO=TCP SPT=443 DPT=37030 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=13552 TC=0 HOPLIMIT=64 FLOWLBL=542875 PROTO=TCP SPT=37030 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=2768 TC=0 HOPLIMIT=64 FLOWLBL=542875 PROTO=TCP SPT=37030 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=8160 TC=0 HOPLIMIT=64 FLOWLBL=542875 PROTO=TCP SPT=37030 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=10856 TC=0 HOPLIMIT=64 FLOWLBL=542875 PROTO=TCP SPT=37030 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=3887 TC=0 HOPLIMIT=64 FLOWLBL=542875 PROTO=TCP SPT=37030 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=291730 PROTO=TCP SPT=443 DPT=37030 WINDOW=18 RES=0x00 ACK URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=291730 PROTO=TCP SPT=443 DPT=37030 WINDOW=19 RES=0x00 ACK URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=107 TC=0 HOPLIMIT=249 FLOWLBL=291730 PROTO=TCP SPT=443 DPT=37030 WINDOW=20 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=291730 PROTO=TCP SPT=443 DPT=37030 WINDOW=21 RES=0x00 ACK URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=107 TC=0 HOPLIMIT=249 FLOWLBL=291730 PROTO=TCP SPT=443 DPT=37030 WINDOW=21 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=291730 PROTO=TCP SPT=443 DPT=37030 WINDOW=22 RES=0x00 ACK URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=107 TC=0 HOPLIMIT=249 FLOWLBL=291730 PROTO=TCP SPT=443 DPT=37030 WINDOW=22 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=542875 PROTO=TCP SPT=37030 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=291730 PROTO=TCP SPT=443 DPT=37030 WINDOW=22 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1743 TC=0 HOPLIMIT=249 FLOWLBL=291730 PROTO=TCP SPT=443 DPT=37030 WINDOW=22 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2768 TC=0 HOPLIMIT=249 FLOWLBL=291730 PROTO=TCP SPT=443 DPT=37030 WINDOW=22 RES=0x00 ACK URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=542875 PROTO=TCP SPT=37030 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=158 TC=0 HOPLIMIT=249 FLOWLBL=291730 PROTO=TCP SPT=443 DPT=37030 WINDOW=22 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:0000:0000:0000:0000:6812:5f29 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2823 TC=0 HOPLIMIT=249 FLOWLBL=291730 PROTO=TCP SPT=443 DPT=37030 WINDOW=22 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:0000:0000:0000:0000:6812:5f29 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=542875 PROTO=TCP SPT=37030 DPT=443 WINDOW=54 RES=0x00 ACK URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=2024 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=17 RES=0x00 ACK URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1372 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=136 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=164 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=1577 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=6812 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=1311 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=600 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=103 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=18 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=18 RES=0x00 ACK URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=103 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=fe80:0000:0000:0000:d26e:deff:fe8d:0199 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=135 CODE=0
jun 01 11:44:03 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=fe80:0000:0000:0000:d26e:deff:fe8d:0199 LEN=64 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=136 CODE=0
jun 01 11:44:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=18 RES=0x00 ACK PSH URGP=0
jun 01 11:44:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1551 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=18 RES=0x00 ACK PSH URGP=0
jun 01 11:44:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1836 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=18 RES=0x00 ACK PSH URGP=0
jun 01 11:44:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=103 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=18 RES=0x00 ACK PSH URGP=0
jun 01 11:44:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:44:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=816 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=59 RES=0x00 ACK PSH URGP=0
jun 01 11:44:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=2687 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=59 RES=0x00 ACK PSH URGP=0
jun 01 11:44:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=18 RES=0x00 ACK URGP=0
jun 01 11:44:04 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=157 TOS=0x00 PREC=0x00 TTL=1 ID=55942 DF PROTO=UDP SPT=5353 DPT=5353 LEN=137
jun 01 11:44:04 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=157 TOS=0x00 PREC=0x00 TTL=1 ID=55942 DF PROTO=UDP SPT=5353 DPT=5353 LEN=137
jun 01 11:44:04 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=157 TOS=0x00 PREC=0x00 TTL=1 ID=55942 DF PROTO=UDP SPT=5353 DPT=5353 LEN=137
jun 01 11:44:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=172 TOS=0x00 PREC=0x00 TTL=1 ID=56459 DF PROTO=UDP SPT=5353 DPT=5353 LEN=152
jun 01 11:44:05 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=172 TOS=0x00 PREC=0x00 TTL=1 ID=56459 DF PROTO=UDP SPT=5353 DPT=5353 LEN=152
jun 01 11:44:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=172 TOS=0x00 PREC=0x00 TTL=1 ID=56459 DF PROTO=UDP SPT=5353 DPT=5353 LEN=152
jun 01 11:44:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=585 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1326 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:44:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=84 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:44:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=841 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=846 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=73 TOS=0x00 PREC=0x00 TTL=64 ID=5926 DF PROTO=UDP SPT=47536 DPT=53 LEN=53
jun 01 11:44:05 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=73 TOS=0x00 PREC=0x00 TTL=64 ID=5926 DF PROTO=UDP SPT=47536 DPT=53 LEN=53
jun 01 11:44:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=791 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=55 RES=0x00 ACK URGP=0
jun 01 11:44:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=875 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=84 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=55 RES=0x00 ACK URGP=0
jun 01 11:44:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=54 RES=0x00 ACK URGP=0
jun 01 11:44:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=53 RES=0x00 ACK URGP=0
jun 01 11:44:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1117 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=52 RES=0x00 ACK URGP=0
jun 01 11:44:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=1825 DF PROTO=UDP SPT=41272 DPT=53 LEN=44
jun 01 11:44:05 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=1825 DF PROTO=UDP SPT=41272 DPT=53 LEN=44
jun 01 11:44:05 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=80 TOS=0x00 PREC=0x00 TTL=250 ID=1928 DF PROTO=UDP SPT=53 DPT=41272 LEN=60
jun 01 11:44:05 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=67 TOS=0x00 PREC=0x00 TTL=64 ID=12534 DF PROTO=UDP SPT=49939 DPT=53 LEN=47
jun 01 11:44:05 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=67 TOS=0x00 PREC=0x00 TTL=64 ID=12534 DF PROTO=UDP SPT=49939 DPT=53 LEN=47
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=172 TOS=0x00 PREC=0x00 TTL=1 ID=57430 DF PROTO=UDP SPT=5353 DPT=5353 LEN=152
jun 01 11:44:06 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=172 TOS=0x00 PREC=0x00 TTL=1 ID=57430 DF PROTO=UDP SPT=5353 DPT=5353 LEN=152
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=172 TOS=0x00 PREC=0x00 TTL=1 ID=57430 DF PROTO=UDP SPT=5353 DPT=5353 LEN=152
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1463 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=51 RES=0x00 ACK URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=263 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=62 TOS=0x00 PREC=0x00 TTL=64 ID=29206 DF PROTO=UDP SPT=49037 DPT=53 LEN=42
jun 01 11:44:06 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=62 TOS=0x00 PREC=0x00 TTL=64 ID=29206 DF PROTO=UDP SPT=49037 DPT=53 LEN=42
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=258 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=323 TOS=0x00 PREC=0x00 TTL=250 ID=1975 DF PROTO=UDP SPT=53 DPT=47536 LEN=303
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=50 RES=0x00 ACK URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=49 RES=0x00 ACK URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2506 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=47 RES=0x00 ACK URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=241 TOS=0x00 PREC=0x00 TTL=250 ID=1996 DF PROTO=UDP SPT=53 DPT=49037 LEN=221
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=765 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=48 RES=0x00 ACK URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1248 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=712 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=54 RES=0x00 ACK URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1353 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=124 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=126 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=795 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=103 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=15873 DF PROTO=UDP SPT=27497 DPT=53 LEN=40
jun 01 11:44:06 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=15873 DF PROTO=UDP SPT=27497 DPT=53 LEN=40
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=56129 DF PROTO=UDP SPT=2416 DPT=53 LEN=40
jun 01 11:44:06 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=56129 DF PROTO=UDP SPT=2416 DPT=53 LEN=40
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=18551 DF PROTO=UDP SPT=54081 DPT=53 LEN=40
jun 01 11:44:06 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=18551 DF PROTO=UDP SPT=54081 DPT=53 LEN=40
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=186 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=59 RES=0x00 ACK PSH URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=154 TOS=0x00 PREC=0x00 TTL=250 ID=2063 DF PROTO=UDP SPT=53 DPT=2416 LEN=134
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=130 TOS=0x00 PREC=0x00 TTL=250 ID=2064 DF PROTO=UDP SPT=53 DPT=54081 LEN=110
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=116167 PROTO=TCP SPT=33470 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=116167 PROTO=TCP SPT=33470 DPT=443 WINDOW=64800 RES=0x00 SYN URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=80 TC=0 HOPLIMIT=249 FLOWLBL=325566 PROTO=TCP SPT=443 DPT=33470 WINDOW=65535 RES=0x00 ACK SYN URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=116167 PROTO=TCP SPT=33470 DPT=443 WINDOW=64 RES=0x00 ACK URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=1796 TC=0 HOPLIMIT=64 FLOWLBL=116167 PROTO=TCP SPT=33470 DPT=443 WINDOW=64 RES=0x00 ACK PSH URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=325566 PROTO=TCP SPT=443 DPT=33470 WINDOW=17 RES=0x00 ACK URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=3567 TC=0 HOPLIMIT=249 FLOWLBL=325566 PROTO=TCP SPT=443 DPT=33470 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=116167 PROTO=TCP SPT=33470 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=136 TC=0 HOPLIMIT=64 FLOWLBL=116167 PROTO=TCP SPT=33470 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=164 TC=0 HOPLIMIT=64 FLOWLBL=116167 PROTO=TCP SPT=33470 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=570 TC=0 HOPLIMIT=64 FLOWLBL=116167 PROTO=TCP SPT=33470 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=600 TC=0 HOPLIMIT=249 FLOWLBL=325566 PROTO=TCP SPT=443 DPT=33470 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=150 TOS=0x00 PREC=0x00 TTL=250 ID=2086 DF PROTO=UDP SPT=53 DPT=49939 LEN=130
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=103 TC=0 HOPLIMIT=64 FLOWLBL=116167 PROTO=TCP SPT=33470 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:44:06 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=103 TC=0 HOPLIMIT=249 FLOWLBL=325566 PROTO=TCP SPT=443 DPT=33470 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=116167 PROTO=TCP SPT=33470 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=325566 PROTO=TCP SPT=443 DPT=33470 WINDOW=17 RES=0x00 ACK URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=157 TOS=0x00 PREC=0x00 TTL=1 ID=58009 DF PROTO=UDP SPT=5353 DPT=5353 LEN=137
jun 01 11:44:07 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=157 TOS=0x00 PREC=0x00 TTL=1 ID=58009 DF PROTO=UDP SPT=5353 DPT=5353 LEN=137
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=157 TOS=0x00 PREC=0x00 TTL=1 ID=58009 DF PROTO=UDP SPT=5353 DPT=5353 LEN=137
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=393 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=198 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=103 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=59681 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=173 TC=0 HOPLIMIT=64 FLOWLBL=116167 PROTO=TCP SPT=33470 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=153 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=239 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=212 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=213 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=62 RES=0x00 ACK PSH URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=107 TC=0 HOPLIMIT=64 FLOWLBL=116167 PROTO=TCP SPT=33470 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=653 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=243 TOS=0x00 PREC=0x00 TTL=250 ID=2155 DF PROTO=UDP SPT=53 DPT=27497 LEN=223
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=104 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=271 TOS=0x00 PREC=0xC0 TTL=64 ID=64173 PROTO=ICMP TYPE=3 CODE=3 [SRC=200.115.192.90 DST=192.168.0.66 LEN=243 TOS=0x00 PREC=0x00 TTL=250 ID=2155 DF PROTO=UDP SPT=53 DPT=27497 LEN=223 ]
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=422 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=105 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1003 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=345 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=445 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=385 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=341 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=342 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=413 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=337 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:07 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:44:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=602 TC=0 HOPLIMIT=249 FLOWLBL=325566 PROTO=TCP SPT=443 DPT=33470 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:44:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=116167 PROTO=TCP SPT=33470 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:44:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=107 TC=0 HOPLIMIT=64 FLOWLBL=116167 PROTO=TCP SPT=33470 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:44:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3034:0000:0000:0000:ac43:8051 LEN=175 TC=0 HOPLIMIT=64 FLOWLBL=116167 PROTO=TCP SPT=33470 DPT=443 WINDOW=61 RES=0x00 ACK PSH URGP=0
jun 01 11:44:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=325566 PROTO=TCP SPT=443 DPT=33470 WINDOW=17 RES=0x00 ACK URGP=0
jun 01 11:44:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=679 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=104 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=103 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:44:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=157 TOS=0x00 PREC=0x00 TTL=1 ID=58408 DF PROTO=UDP SPT=5353 DPT=5353 LEN=137
jun 01 11:44:08 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=157 TOS=0x00 PREC=0x00 TTL=1 ID=58408 DF PROTO=UDP SPT=5353 DPT=5353 LEN=137
jun 01 11:44:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=157 TOS=0x00 PREC=0x00 TTL=1 ID=58408 DF PROTO=UDP SPT=5353 DPT=5353 LEN=137
jun 01 11:44:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=59698 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:08 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25645 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:44:08 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3034:0000:0000:0000:ac43:8051 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=350 TC=0 HOPLIMIT=249 FLOWLBL=325566 PROTO=TCP SPT=443 DPT=33470 WINDOW=17 RES=0x00 ACK PSH URGP=0
jun 01 11:44:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18075 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=237 RES=0x00 ACK PSH URGP=0
jun 01 11:44:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25646 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:44:09 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=226 TOS=0x00 PREC=0x00 TTL=1 ID=58581 DF PROTO=UDP SPT=5353 DPT=5353 LEN=206
jun 01 11:44:09 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=224.0.0.251 LEN=226 TOS=0x00 PREC=0x00 TTL=1 ID=58581 DF PROTO=UDP SPT=5353 DPT=5353 LEN=206
jun 01 11:44:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC= SRC=192.168.0.66 DST=224.0.0.251 LEN=226 TOS=0x00 PREC=0x00 TTL=1 ID=58581 DF PROTO=UDP SPT=5353 DPT=5353 LEN=206
jun 01 11:44:09 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=60379 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:10 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=61122 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=62040 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=91 TOS=0x00 PREC=0x00 TTL=250 ID=48682 DF PROTO=TCP SPT=443 DPT=44840 WINDOW=220 RES=0x00 ACK PSH URGP=0
jun 01 11:44:11 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=20234 DF PROTO=TCP SPT=44840 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:44:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=76 TOS=0x00 PREC=0x00 TTL=250 ID=48683 DF PROTO=TCP SPT=443 DPT=44840 WINDOW=220 RES=0x00 ACK PSH URGP=0
jun 01 11:44:11 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=20235 DF PROTO=TCP SPT=44840 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:44:11 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=48684 DF PROTO=TCP SPT=443 DPT=44840 WINDOW=220 RES=0x00 ACK FIN URGP=0
jun 01 11:44:11 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=44.254.116.179 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=20236 DF PROTO=TCP SPT=44840 DPT=443 WINDOW=63 RES=0x00 ACK FIN URGP=0
jun 01 11:44:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=44.254.116.179 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=48685 DF PROTO=TCP SPT=443 DPT=44840 WINDOW=220 RES=0x00 ACK URGP=0
jun 01 11:44:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=62433 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=54.186.99.250 DST=192.168.0.66 LEN=91 TOS=0x00 PREC=0x00 TTL=250 ID=42109 DF PROTO=TCP SPT=443 DPT=59392 WINDOW=315 RES=0x00 ACK PSH URGP=0
jun 01 11:44:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=54.186.99.250 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=39243 DF PROTO=TCP SPT=59392 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:44:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=54.186.99.250 DST=192.168.0.66 LEN=76 TOS=0x00 PREC=0x00 TTL=250 ID=42110 DF PROTO=TCP SPT=443 DPT=59392 WINDOW=315 RES=0x00 ACK PSH URGP=0
jun 01 11:44:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=54.186.99.250 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=39244 DF PROTO=TCP SPT=59392 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:44:12 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=54.186.99.250 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=42111 DF PROTO=TCP SPT=443 DPT=59392 WINDOW=315 RES=0x00 ACK FIN URGP=0
jun 01 11:44:12 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=54.186.99.250 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=39245 DF PROTO=TCP SPT=59392 DPT=443 WINDOW=60 RES=0x00 ACK FIN URGP=0
jun 01 11:44:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=54.186.99.250 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=42112 DF PROTO=TCP SPT=443 DPT=59392 WINDOW=315 RES=0x00 ACK URGP=0
jun 01 11:44:13 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=63387 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:14 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=63541 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=64147 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:15 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=230 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:15 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=363 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:15 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=243 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK URGP=0
jun 01 11:44:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=484 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1093 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=103 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:15 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=360 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:15 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=84 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=62 RES=0x00 ACK URGP=0
jun 01 11:44:15 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=107 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK URGP=0
jun 01 11:44:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=400 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=2321 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:44:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=353 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=416 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=64276 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=484 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1848 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=103 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=350 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=212 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=213 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=353 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=6321 DF PROTO=UDP SPT=38837 DPT=53 LEN=44
jun 01 11:44:16 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=6321 DF PROTO=UDP SPT=38837 DPT=53 LEN=44
jun 01 11:44:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=43702 DF PROTO=UDP SPT=47048 DPT=53 LEN=44
jun 01 11:44:16 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=43702 DF PROTO=UDP SPT=47048 DPT=53 LEN=44
jun 01 11:44:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=30477 DF PROTO=UDP SPT=44727 DPT=53 LEN=44
jun 01 11:44:16 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=30477 DF PROTO=UDP SPT=44727 DPT=53 LEN=44
jun 01 11:44:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=80 TOS=0x00 PREC=0x00 TTL=250 ID=3056 DF PROTO=UDP SPT=53 DPT=44727 LEN=60
jun 01 11:44:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=137 TOS=0x00 PREC=0x00 TTL=250 ID=3057 DF PROTO=UDP SPT=53 DPT=47048 LEN=117
jun 01 11:44:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=20654 DF PROTO=TCP SPT=38120 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:44:16 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=20654 DF PROTO=TCP SPT=38120 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:44:16 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=200.115.192.90 DST=192.168.0.66 LEN=137 TOS=0x00 PREC=0x00 TTL=250 ID=3071 DF PROTO=UDP SPT=53 DPT=38837 LEN=117
jun 01 11:44:16 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=200.115.192.90 LEN=165 TOS=0x00 PREC=0xC0 TTL=64 ID=6476 PROTO=ICMP TYPE=3 CODE=3 [SRC=200.115.192.90 DST=192.168.0.66 LEN=137 TOS=0x00 PREC=0x00 TTL=250 ID=3071 DF PROTO=UDP SPT=53 DPT=38837 LEN=117 ]
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=6547 DF PROTO=TCP SPT=38122 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=6547 DF PROTO=TCP SPT=38122 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=376 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=107 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=999 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=342 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=64686 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=38122 WINDOW=28960 RES=0x00 ACK SYN URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=6548 DF PROTO=TCP SPT=38122 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=1812 TOS=0x00 PREC=0x00 TTL=64 ID=6549 DF PROTO=TCP SPT=38122 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=354 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=1098 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=105 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=103 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=410 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=355 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=340 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=343 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=142 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=348 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=464 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=339 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=14053 DF PROTO=TCP SPT=443 DPT=38122 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=14054 DF PROTO=TCP SPT=443 DPT=38122 WINDOW=68 RES=0x00 ACK URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=4148 TOS=0x00 PREC=0x00 TTL=250 ID=14055 DF PROTO=TCP SPT=443 DPT=38122 WINDOW=68 RES=0x00 ACK PSH URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=6551 DF PROTO=TCP SPT=38122 DPT=443 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=2567 TOS=0x00 PREC=0x00 TTL=250 ID=14058 DF PROTO=TCP SPT=443 DPT=38122 WINDOW=68 RES=0x00 ACK PSH URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=6552 DF PROTO=TCP SPT=38122 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=132 TOS=0x00 PREC=0x00 TTL=64 ID=6553 DF PROTO=TCP SPT=38122 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=144 TOS=0x00 PREC=0x00 TTL=64 ID=6554 DF PROTO=TCP SPT=38122 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=529 TOS=0x00 PREC=0x00 TTL=64 ID=6555 DF PROTO=TCP SPT=38122 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=20655 DF PROTO=TCP SPT=38120 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:44:17 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=20655 DF PROTO=TCP SPT=38120 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:44:18 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=64689 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:18 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=131 TOS=0x00 PREC=0x00 TTL=250 ID=14060 DF PROTO=TCP SPT=443 DPT=38122 WINDOW=68 RES=0x00 ACK PSH URGP=0
jun 01 11:44:18 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=131 TOS=0x00 PREC=0x00 TTL=250 ID=14061 DF PROTO=TCP SPT=443 DPT=38122 WINDOW=68 RES=0x00 ACK PSH URGP=0
jun 01 11:44:18 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=114 TOS=0x00 PREC=0x00 TTL=250 ID=14062 DF PROTO=TCP SPT=443 DPT=38122 WINDOW=68 RES=0x00 ACK PSH URGP=0
jun 01 11:44:18 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=14063 DF PROTO=TCP SPT=443 DPT=38122 WINDOW=74 RES=0x00 ACK URGP=0
jun 01 11:44:18 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=83 TOS=0x00 PREC=0x00 TTL=250 ID=14064 DF PROTO=TCP SPT=443 DPT=38122 WINDOW=74 RES=0x00 ACK PSH URGP=0
jun 01 11:44:18 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=158 TOS=0x00 PREC=0x00 TTL=250 ID=14065 DF PROTO=TCP SPT=443 DPT=38122 WINDOW=74 RES=0x00 ACK PSH URGP=0
jun 01 11:44:18 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=6556 DF PROTO=TCP SPT=38122 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:44:18 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=83 TOS=0x00 PREC=0x00 TTL=64 ID=6557 DF PROTO=TCP SPT=38122 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:44:18 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25647 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:44:18 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=14066 DF PROTO=TCP SPT=443 DPT=38122 WINDOW=74 RES=0x00 ACK URGP=0
jun 01 11:44:18 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=20656 DF PROTO=TCP SPT=38120 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:44:18 Adrian-PC kernel: [UFW ALLOW] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=20656 DF PROTO=TCP SPT=38120 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
jun 01 11:44:18 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18076 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=239 RES=0x00 ACK PSH URGP=0
jun 01 11:44:19 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25648 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:44:19 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=65454 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:19 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=60 TOS=0x00 PREC=0x00 TTL=250 ID=0 DF PROTO=TCP SPT=443 DPT=38120 WINDOW=28960 RES=0x00 ACK SYN URGP=0
jun 01 11:44:19 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=20657 DF PROTO=TCP SPT=38120 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:44:19 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=1500 TOS=0x00 PREC=0x00 TTL=64 ID=20658 DF PROTO=TCP SPT=38120 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:44:19 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=891238 PROTO=TCP SPT=50180 DPT=443 WINDOW=61 RES=0x00 ACK FIN URGP=0
jun 01 11:44:19 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=565934 PROTO=TCP SPT=50176 DPT=443 WINDOW=60 RES=0x00 ACK FIN URGP=0
jun 01 11:44:19 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=616642 PROTO=TCP SPT=50188 DPT=443 WINDOW=61 RES=0x00 ACK FIN URGP=0
jun 01 11:44:19 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=417569 PROTO=TCP SPT=443 DPT=50176 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:44:19 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=562993 PROTO=TCP SPT=443 DPT=50188 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:44:19 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=318034 PROTO=TCP SPT=443 DPT=50180 WINDOW=16 RES=0x00 ACK FIN URGP=0
jun 01 11:44:19 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=891238 PROTO=TCP SPT=50180 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:44:19 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=565934 PROTO=TCP SPT=50176 DPT=443 WINDOW=60 RES=0x00 ACK URGP=0
jun 01 11:44:19 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=616642 PROTO=TCP SPT=50188 DPT=443 WINDOW=61 RES=0x00 ACK URGP=0
jun 01 11:44:19 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=6216 DF PROTO=TCP SPT=443 DPT=38120 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:44:19 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=491 TOS=0x00 PREC=0x00 TTL=64 ID=20659 DF PROTO=TCP SPT=38120 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=52 TOS=0x00 PREC=0x00 TTL=250 ID=6217 DF PROTO=TCP SPT=443 DPT=38120 WINDOW=68 RES=0x00 ACK URGP=0
jun 01 11:44:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=4148 TOS=0x00 PREC=0x00 TTL=250 ID=6218 DF PROTO=TCP SPT=443 DPT=38120 WINDOW=68 RES=0x00 ACK PSH URGP=0
jun 01 11:44:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=20660 DF PROTO=TCP SPT=38120 DPT=443 WINDOW=59 RES=0x00 ACK URGP=0
jun 01 11:44:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=2567 TOS=0x00 PREC=0x00 TTL=250 ID=6221 DF PROTO=TCP SPT=443 DPT=38120 WINDOW=68 RES=0x00 ACK PSH URGP=0
jun 01 11:44:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=20661 DF PROTO=TCP SPT=38120 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:44:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=132 TOS=0x00 PREC=0x00 TTL=64 ID=20662 DF PROTO=TCP SPT=38120 DPT=443 WINDOW=57 RES=0x00 ACK PSH URGP=0
jun 01 11:44:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=65504 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=131 TOS=0x00 PREC=0x00 TTL=250 ID=6223 DF PROTO=TCP SPT=443 DPT=38120 WINDOW=68 RES=0x00 ACK PSH URGP=0
jun 01 11:44:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=131 TOS=0x00 PREC=0x00 TTL=250 ID=6224 DF PROTO=TCP SPT=443 DPT=38120 WINDOW=68 RES=0x00 ACK PSH URGP=0
jun 01 11:44:20 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=8.136.204.218 DST=192.168.0.66 LEN=114 TOS=0x00 PREC=0x00 TTL=250 ID=6225 DF PROTO=TCP SPT=443 DPT=38120 WINDOW=68 RES=0x00 ACK PSH URGP=0
jun 01 11:44:20 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=8.136.204.218 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=20663 DF PROTO=TCP SPT=38120 DPT=443 WINDOW=57 RES=0x00 ACK URGP=0
jun 01 11:44:21 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=783 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:22 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=1615 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:23 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=2028 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:24 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=2334 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:24 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=33:33:00:00:00:01:d0:6e:de:8d:01:99:86:dd SRC=fe80:0000:0000:0000:d26e:deff:fe8d:0199 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=240 TC=0 HOPLIMIT=255 FLOWLBL=1009982 PROTO=ICMPv6 TYPE=134 CODE=0
jun 01 11:44:25 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=3280 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:26 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=164 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:26 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=4073 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:26 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK URGP=0
jun 01 11:44:27 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=4183 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:28 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=4214 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
jun 01 11:44:28 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=471 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:28 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=661 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:28 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=174 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:28 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:44:28 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=107 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=63 RES=0x00 ACK PSH URGP=0
jun 01 11:44:28 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=72 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK URGP=0
jun 01 11:44:28 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=120 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:28 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=115 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:28 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=116 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:28 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=107 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:28 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=111 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:28 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=119 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:28 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=123 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:28 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=367 TOS=0x00 PREC=0x00 TTL=64 ID=25649 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK PSH URGP=0
jun 01 11:44:28 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:08:00 SRC=47.239.232.129 DST=192.168.0.66 LEN=655 TOS=0x00 PREC=0x00 TTL=250 ID=18077 DF PROTO=TCP SPT=443 DPT=57458 WINDOW=242 RES=0x00 ACK PSH URGP=0
jun 01 11:44:28 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=192.168.0.66 DST=47.239.232.129 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=25650 DF PROTO=TCP SPT=57458 DPT=443 WINDOW=56 RES=0x00 ACK URGP=0
jun 01 11:44:29 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=107 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:29 Adrian-PC kernel: [UFW AUDIT] IN= OUT=wlo1 SRC=2800:0810:044b:05d3:1685:7fff:fe04:e011 DST=2606:4700:3035:0000:0000:0000:6815:00d9 LEN=72 TC=0 HOPLIMIT=64 FLOWLBL=914471 PROTO=TCP SPT=40778 DPT=443 WINDOW=63 RES=0x00 ACK URGP=0
jun 01 11:44:29 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=111 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:29 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=119 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:29 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=115 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:29 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=114 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:29 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=180 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:29 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=116 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:29 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=108 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:29 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=14:85:7f:04:e0:11:d0:6e:de:8d:01:99:86:dd SRC=2606:4700:3035:0000:0000:0000:6815:00d9 DST=2800:0810:044b:05d3:1685:7fff:fe04:e011 LEN=128 TC=0 HOPLIMIT=249 FLOWLBL=937696 PROTO=TCP SPT=443 DPT=40778 WINDOW=19 RES=0x00 ACK PSH URGP=0
jun 01 11:44:29 Adrian-PC kernel: [UFW AUDIT] IN=wlo1 OUT= MAC=ff:ff:ff:ff:ff:ff:d0:6e:de:8d:01:99:08:00 SRC=192.168.0.1 DST=192.168.0.255 LEN=101 TOS=0x18 PREC=0xA0 TTL=64 ID=4920 DF PROTO=UDP SPT=9431 DPT=9431 LEN=81
